00 Ex : brake pedal too low
So im in the middle of upgrading to ITR calipers with 11.1" prelude rotors , ep3 rear calipers and rotos along with a 1" MC and booster , now i think i was sold a 00 prelude booster and MC for a 98+itr one.
Problem is the brake pedal is waaay too low and the car bearly breaks. i've bench bleed the mc and bleed the brakes a few times to make sure all the air is out of the system and nothing. i had to extend the booster vacuum line in order to reach the booster and manifold. if i put the line backwards ( with the arrow that says engine to the booster side )the car brakes but the pedal is low like i said , if i put the line the way its supposed to be the pedal goes all the way to the floor when the engine is on , with the car off i have pressure in the pedal , is this a bad booster o mc?
Re: 00 Ex : brake pedal too low
i got the old master and booster back in the car and i still have no pressure , i opened the bleeder screw on one of the calipers and fluid doesnt come out when i pump the pedal , i think the problem is the check valve , could this be?
Bled the system again , if the vacuum hose is connected the way its supposed to be with the arrow going to the engine the brakes have pressure while the car is off , once its on it has no pressure and when i let go of the pedal the idle goes up a few hundred rpms
if the vacuum hose is backwards the car stops but the pedal is really low and does not grip hard enough.
This is really driving me crazy.
STN_Pat
03-20-2009 10:55 AM
jaideep_asokan
05-04-2008 05:00 AM
