View Full Version : Honda Civic / Del Sol (1992 - 2000)
- b16a2
- obx cat ne good?
- PLEASE HELP!!!! B16A SIRII Swap into 92DX Questions
- d16z6 built to boost
- over heating help .....
- Dash lighting thread.
- My eyes! My eyes are burning!! aggghhhh
- help...swap engine
- lock conversion HELP!!!
- starter
- Help me solve this d15b7's stutering problem (video inside)
- my turbo manifold (header) is leeking, how much hp can i lose from this?
- question about a launch button?
- MPH gauge
- A little Help please
- speedo might be off?
- steering wheel
- pcv quick question
- Help, low car,cold air intake, and high water.
- preloading the clutch ??
- Need Help Funny noise!!!!
- 1999 civic si comparisons
- shifter problem in 99 civic si
- wiper problems?
- camber "washer trick" affect ability to adjust toe?
- Smoke?
- runnin no knock sensor
- B16a2 Into 97 Civic Q??
- Headers
- Sitting motor? What to do to prevent rust..etc
- d16y8 1996 honda civic ex 4dr
- Cheap and easy swap
- Installing Cat Back
- Been working on my rebuild since July 06
- front driver caliper
- new honda
- boost question
- gsr rear sway bar on 92-95 civic hatch??
- 97 Civic w/ B16a2 swap
- b16a cable tranny question
- whats the difference??
- v-tec problem
- just my luck!!!
- Exaust opinion?
- Clutch engagement problems on 92 civic. Need some help!!
- I Need Help with this connector
- non vtech to vtech help please
- i blew the mototr in my 93 del sol si
- 94 civic - clutch(exedy) problem
- Hood Latch Cable snapped!!!Please help!!
- NEED RADIO CODE!!!!!!!
- Amount of torque
- no power
- cluster & instrument panel lights went out,but fuses ok? help
- Built motor wont start
- reinstalling AC help
- horribly bad idle, recent ls/vtec install
- need help with aem cam gears
- TPS problem again ------ 99-00 si with 98+ jdm type r
- TPS problem again :( 99-00 si with 95+ jdm type r
- Pulled plugs, Gangsta lean!
- Lightweight wheels - money in the garbage ?
- FS: Buddy Club Spec Exhaust system
- Fuel Delivery problem
- my new Exedy clutch and flywheel install
- b18b swap
- b16 vs 06 325
- EG hood for K24A2 swap
- Crx Resistor box into a 97 ex honda civic turboed
- Bisimoto H2B Kit
- where is the IAT sensor?
- H22... is it true that they have transmission problems?
- Backfire
- Clutch replacement DIY
- how to remove ac properly
- tail light colors??
- PLZ HELP electrical issue?
- Will the Turn signal arm fit form a DC?
- VX crank into d16z6 (EMERGENCY)
- engine2
- starting problem...
- D16... B16 is there really a noticeble difference??
- Largest Front Mount Intercooler on stock bumper????
- golden eagle
- gsr swap into ek hatch
- Ground control seized. WTF.....
- b16 swap
- Need help contacting someone!!
- Tranny Questions
- Intake arm length?
- Trunk release lever for a 93 del sol, Will a 1992 civic couple setup work?
- need info on motor
- b18 swap
- teggy dashboard on 93 civic hatch
- b16 owners
- scratching noise
- Invidia N1 Exhaust System will it fit?
- 92 hatch needs a new front
- tach issue, need help quick
- i put gsr front knunkles on 95 coupe right wheel sticks out more then left wheel?
- Feel's Vs. Vision Exhaust witch one is the best and were to buy it
- integra exhaust on civic coupe?
- engine from d13b to b16b
- Throttle body spacer any good?
- Idle prob and its not the IACV
- swap motor or rebuild engine
- AEM V2 Intake Question
- NEED HELP WITH CLUSTER URGENT!
- bypassing a dimmer switch?
- blown engine
- 96-00 Cat back - Hatch/Coupe interchangeable?
- Need some Info.
- Introduce myself...
- safc2 install questions
- Testing waters, hatch worth??
- Car not getting up to full engine temp
- Drivers side front suspension creak
- need help TIMING BELT with b16a3 on del sol
- I HAVE 92 VX 15DZ1 LIKE FLASH ECU
- Ls/vtec headgasket...
- What Clutch/Flywheel Should I Go With?
- Hmm... whats this for?
- 97 civic swap questions
- electrical problem, need help please! (searched)
- Valve question
- Poor Man's R - H2B build
- Koni Yellow shocks, spring seating problem
- Integra dash into civic - my experience and questions
- REAL ctr front grill not ctr STYLE
- DC exhaust
- SRS Light
- Honda question
- 1998 honda civic ex, What to do with $4000
- Mugen or Competech CAI
- Question about power steering with LS/Vtec
- Vtec Head
- Burned A Piston? What do you think?
- Clock Problem
- Copues (eK) in japan?
- OEM ftw... or aftermarket headgasket?
- gas leak
- obd2 question...
- code 45??
- EK4 NAVIGATION FINALLY INSTALLED!
- brake install, need help
- Vac leak @ idle = Horribly lean?
- ><><> AiR CONDiTiON QUESTION!
- Is there anyway to tell if your timing belt has been replaced?
- quick question about vtec solenoid pins
- 95 Ex 4d want to know about a swap
- oil in the dizzy?
- post pics of ur sportmax 501's
- LS/VTEC TURBO HELP!!
- Civic HX performance stats?
- How to tell all the different engine options for the Civic HX (96-00)?
- CTR spoiler hinges..
- Brake Gurus: Break-in question
- tranny question
- Need help with a motor mount question. Video inside.
- Upper castle nuts won't come off
- 94 honda civic ex won't start
- is there a way to identify the heads of b series engines??
- obd2a to obd2b distributor conversion... possible ?
- car starts then shuts off
- I need help. I got a 1.6l i want to swap but i dont know what for?
- pretty please read: swap problem :( have spark and fuel but doesnt run?
- Small Triangular Tab on the Window?????
- car puttering/backfireing help pls.
- Steering rack, window, sunroof compatibility question
- canadian type r seats for sale!!!!!!!!!!
- I have a very very stupid question
- I blow my motor
- JDM 5 Zigen Pro Racer on my 99-00 CIVIC SI, with 98+ JDM TYPE R???
- Whats the most weight a car can have without blowing these coilovers?
- b16 idle problem...idles @2500-3000 rpm
- adding power windows..
- Honda "Superman" logo
- Engine mounts
- Clutch slip when hot?
- B18c OIl pan
- AEM Big Brake Kit for Integra Civic Del Sol
- quick question...
- Motor Help.
- pinging
- rust repair
- what is the factory tire size of my 00 dx hatch?
- Cooling fan help.
- Best place to get front endlinks?
- 92 civic dash lighting dimming problems
- Tried searching but couldn't find simple answer 98 trans on d15b7 motor
- Del sol electrical problem everything blown?!
- ABS brake booster - master cylinder comparison / bench bleed how-to
- 96 ek dx tranny problem......
- INTAKE! ! Suggestion
- Best windshield wipers?
- best place to by oem replacement parts?
- oval muffler
- D16Y8 Intake Mani into EG.
- functional ram air pics
- Just curious i fthese remotely fit an EH?
- EG enjin masuk EK, EJ tamper tukar meter dan deshbord
- HELP!! Did I fry my ECU
- SOME QUESTIONS..
- Engine Problem??
- honda civic
- jdm h22 on eg6/b16a2 in eg
- popping out of gear?
- want to build a race hatch need help!
- b16a3 on a gsr
- valve clearance
- need civic info
- problems after problems
- My mostly stock 95 EH2.
- question on injectors
- resistor pack 450cc injectors
- gsr brake master cylinder
- Crank I.D
- Y7 to Y8 swap question
- getting readt to do my swap this weekend
- Best Strut/Sway Bars
- Tranny Swap D16Y8 2dr coupe EX
- lean @ wot?
- quick question.
- Pic request: ITR intake arm with EG box
- Bugatti Veyron start button effect in Honda Civic
- d16y8 block d16z6 head... what is the deal?!?
- Timming
- need a vitara piston
- ICB Sidemarkers ?
- Newbie in a 99 Civic Si......
- Car Overheated!!!!!b20 vtec Need HElP!!!
- honda civic crx 92 D16A9
- pcv system
- bouncing idle in 93 hatch
- i'm going to du my first swap
- Main Relay Location
- Injector Harness Question
- failed BAR due to high emissions how to fix? smog gurus help?
- Ls swap??
- 92-95 civic hb stock piping size diff (searched already)
- Hub Caps
- IF I AM NOT RUNNING ANY O2 SENSOR, WHERE CAN I HOOK UP THE AIR/FUEL GAUGE JUST FOR LIGHT SHOW?
- gauge question
- Need help identifying a hose and a plug in an EK engine
- exhaust interchangeable
- turboing my ls
- emergency brake line removal
- How is this possible? Seen it before?
- Kind of lost? any tips or help?
- Newbiee...My first project
