View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 94 si front lip and power window questions
- Mix Honda MTF and motor oil?
- CTR EK9
- Possible TPS problem
- Mobile 1 Oil filter Unusual Leak? QUICK HELP??
- Having idle problems with my build d16z6... NEED HELP
- wiring tach on ex
- Over heating
- SI VTEC RPM engagement ques. 1.6 L
- Skunk2 Intake Mani & TB issues(Searched)
- rear camber arm adjustment question
- firing order
- Water pump
- Help!! My reverse light stays on
- MISSING IA 08-- PLEASE READ AND ADVISE!!!!!!!!!!!!!!!!!!!!!
- pcv valve help
- muffler Question
- BIG PROBLEM SOMEBODY HELP ME OUT PLEASE !!!!!!!!
- code 67
- 08 S2000 steering wheel in a 96 Civic
- 1992 si with Blown D16z6..
- oem fan on mitsumoto rad and walbro fuel pump Question
- cel still on after fix
- SI eg door pockets on dx door panels?
- Shifter Bushing replacement.
- which a/c compressor to use?
- oil light problem
- ARP Stud Install questions
- HELP...power window conversion
- A/C Compressor not kicking on
- Removing Crank Pulley [Quick Tutorial]
- need help!! screeching screaming noise!!!! HELP HELP HELP
- Electronic cluster vs NON electronic
- wiring question
- Whos civic was this?
- Direct link to a 2000 ex back o2 sensor simulator from reputable source?
- Kill sitch questions
- Need help trying to take the hub off so i can take the axles out.
- my 96 civic ex swapping in a b18c and much more
- Alternator problem?
- Y7 with Y8 intake
- Civic Not Starting .. Trust Me I Searched
- Really need help on idle problem plzzz
- 5 lug conversion on em1
- Cranks but NO spark, tdc question too!
- SRS LIGHT! GOING ON AND OFF !
- what tires yall recommend???
- Just picked up my new 96civic.
- Wiring Issues - Need Help Bad!
- single cam vtec intake manifold on single cam non vtec??
- intake mani choice
- starter problems
- 97 civic ex no start
- Timing belt and waterpump
- EG hatch buying guideance...
- will a 97 dizzy work on a 91?
- anyone knows a site??
- anyone know where to get red/white eg taillights that arent upside down?
- Valve Cover Gasket
- honda help
- 96 civic dx coupe/jdm b16a swap - obd2 port won't read
- Salvage title 94 civic, questionable engine, should I get this or walk away?
- what ecu is this from
- will a 96+ 4 door carpet fit a 97 EJ6 (EK-hatch)
- Looking at a 99 hatch, what to look for?
- Traction bar fitment for h22 with HCP mount.
- It's times for seats 95 civic coupe
- timing problem on rebuilt b18c6 engine
- Transmission leak!!
- Battery Keeps on Draining
- b16a2 into a 96 coupe
- Need some clips and bolts
- 2000 civic si motor in a 96 coupe?
- 96 98 gunmetal oem headlights?
- rear brakes
- 95 SI SPOILER WASHER NOZZLE
- push button starter?
- pls help asap obd2 motor
- civic lca??
- Small question to people that do 8000 RPM
- altenator question
- B18B throwing code 8 and 14
- Has anyone ever had their oil light flash b/c they used a non-honda brand filter?
- c.e.l. help!
- 93 del sol si
- Mechanic says:rebuild or swap the engine - your opinion?
- d16y8 block z6 head?
- Head and valve kits
- Build for boost
- my car will only start when I jump it, 2 days after buying a new battery
- 99 Civic Lx failed emissions, cracked exhaust manifold
- Will EP3 seats fit in a EK?
- NooB! questions about engine block rebuilding
- How do you wire the fan on all the time? (overheating)
- Fog light blow out?
- having an issue with my swap
- What MPG do you get ????
- Please Help?
- rsx seats into EK
- Pulsation Damper assembly????
- help-------wiring jdm b18c obd2 to 98 hatch dx.
- ???? about D series cam gears
- Is there such thing as a BAR Smog Ref hookup??
- Starter dying?
- Anyone bought these seats?
- clutch problem
- Question about OEM 92-95 Civic Lip on a CX hatchback
- DIY Stiffen motor mounts and random rubber fixes on cars!!! ;)
- Just replaced Intake Manifold having idling problem?
- Going to be doing a gsr swap in 2 days, think i'm missing anything?
- During sound system install, AC system punctured through firewall, freon GONE...help!
- system too rich code p0712 comes on in my 98 civic dx after i did a jdm b16a swap..
- Reputable swap shops near Port St. Lucie, FL or the 34953 area
- E-brake Doesn't Work
- Ctr city lights
- key stuck in ignition
- AC ?
- b18 v d15 axle size
- 92 ciic dx wit d15b 5th gear
- Intermittent rattle at idle
- AC condensor fan motor
- B18 in EK. What Else?
- ********STUPID PIC REQUEST*************
- 98 civic keyless entry any way to get around not useing head unit
- any info on bar'd gsr into 98 civic ek?
- D15B [UNRATED]
- ls vtec?
- Any good gsr into eg threads?
- Running Lean
- CONSTANT backfiring
- catback
- Place to order inner tail light for 99 coupe?
- battery light comes on N off!
- HOW TO : DIY EK Hood Dampers using eg rear window dampers
- h22 ref'd in 94 si
- How many cases of Red Bull will fit in an EK?
- headlights
- Real Quick... power steering rack
- Simple question. Opinion needed.
- help car still smoking
- EG Sedan JDM Armrest fit all EG's..??
- Rings And Valve seals $$$$
- 99 EX with problems!! HELP!! :.-((
- Which o2 sensor for the VX?
- Clutch help *searched*
- CAN ANY1 HELP?? AXLE/ TRANSMISSION PROBLEM??
- Running without a knock sensor
- 3 stage and MMT
- cv halfshaft torque specs
- brake master
- Del Sol Swap from D16 to B17 ?
- hood propin'
- how to tell
- Diamond in the Rough
- 98 civic whats up with keyless entry is there another way besides the stock radio
- 1994 civic cx 3r window problem?
- i got a shell
- do the Ebay ecu chips work?
- how do i read this code
- car bogging
- exhaust valves rockers are 2 tight?
- Torque mount question - 94 civic auto
- sluggish in third gear
- throttle cable bracket
- Brand new 2000 Integra type r tranny from acura? LSD?
- i think my ps pump exploded!
- block girdle/ block guard
- rear wiper delete..
- b20vtec question
- spoon lip or spoon bumper?
- powersteering after swap B18c1 EG
- D15 to D16z6 in my EG
- Timing belt & water pump change question
- help.. Installing nrg fuel pressure regulator
- boosted Fg2 looking to buy an EG or EK...
- Oil turn black almost immediately!
- Need help again with my dying car ...
- Brake light help!!!!
- H22 EGH2 Axle question ( Yes I've Searched )
- did some work on the interior, molding in glovebox, etc
- Question re: 96 stock exhaust on a 99
- So, i just got jacked...
- keyless entry messed up
- where can i buy the meal/rubber peice at the bottom of my window?
- Quick Question??
- wierd high pitch noise coming from brake booster area when car is off
- Code P1337 Crankshaft Position Sensor
- ive searched and iall i get is sell sell sell ......will type r seats fit in an eg?
- 98-00 steering coloumns the same?
- My new Project - Ek B18C4 Full-Race T3/T67H.O. Turbo
- Code 3 MAP 2 ecus 3 map sensors
- idle surging Please help!!!
- Comptech header and Moroso 20911 Oil Pan???
- need help or write ups on changing b20 head gasket
- Tach is off, can it be run off ecu/S200?
- 1998 civic ex hesitation problem...
- Yep, another tranny question.
- EG radiator fit and EK?
- Shaking, what the hell?
- 2000 civic si, sputtering issue
- b16a swap issues
- Is my 98 ex supose to be Vtec?
- Acura used EL engine by texas junkyards
- standard transmission
- T.P.S. please advise
- d16y8 intake manifold to d16y7? si intake manifold to gsr??
- helppp with throttle cable
- Ebay YCP Vitara Pistons Kits For D16 motors
- help 97 acura EL swap
- lug nut size??
- will a automatic d16y8 harness work for a 5spd?NEED HELP ASAP!!!
- Del sol Rear Brakes
- Starting problem
- How much is my del sol worth?
- wondering what my car is worth
- HELP: Emissions test = Major fail
- fuel injector question
- Boosting OBD1 ZC questions in 95 civic
- em1?????
- VIN check?
- Quakerstate syncromesh
- HELP.........
- EG steering wheel
- h22a price info!!!
- B18c1 swap ?'s
- harness question
- my motor mounts are broken,.... what type of mounts should i put....
- VSS HELp!!!
- Recommended Tire Pressure for 1997 Civic EX Coupe?
- Torque Specs for 94 Civic DX
- Any DIY 5 bolt on an EG?
- 96-98 fog lights
- Need help connecting all water, heater, fuel, and radiator hoses
- Will An EK EX Wiring Harness Fit In An EG EX?
- when changing you oil pan gasket what do you use to clean the mating surfaces
- problem installed ac equipement into 92 eg dx
- b18 swap?
- Main relay buzzing, CEL Flickering....WTF?
- White smoke screen =P sooo gay!
- Stripped Fill plug hole on man. tranny,,,,suggestions?
- been a member since 04 and my first time posting pics of my car...take a look
- 92 civic with jdm d15b7..vtec not hitting?????
- gsr itr ?s
- Need engine bay wiring diagram for 93' si hatch! Searched!
- b16 in 92 hatch, weird idle
- 92-95 h swap, transmission questions
- mudgaurds!!!!!!!!!!!!!
- wut do i have????? ej1 ej2
- burned car...is my motor rebuildable?
