View Full Version : Honda Civic / Del Sol (1992 - 2000)
- failed smog gross polluter HELP!
- B18B1 JUMPED TIMING? Possible issues? Results? Solution?
- Transmission Issues?
- new strut mounts needed?
- new wheels quick question
- *NO CRANK* on a 96-98 D16y8 sitting in a 2000 Civic EX
- 99 Civic turns over but won't start
- Ecu question for my mini me
- Acceleration Without Pressing Gas Pedal
- 1999 Acura El won't turn over
- White smoke and radiator problems
- '94 Civic - Possible head gasket?
- B16a oil pump question
- 98 DX Manual Rack & Pinion fit on a 00 EX?
- b16 first gen
- 1998 Honda Civic DX Hatchback L4 1.6L SOHC MFI 8 codes came up.
- 97 civic ex, y7 engine, y8 intake p06 ecu
- Dimmer switch questions
- 2000 Civic EX AC Compressor completely Siezed
- Just bought 95 civic auto - what are some minor upgrades I can do?
- 00 civic vtec - auto trans wont shift into second!
- front left bottoms out
- ARC INTAKE FILTER INTERCHANGE
- 94 civic EX wont start....NEED HELP (solved)
- where is my o2 sensor wiring?
- rota torque polished silver.
- Master Cylinder Question
- Is there a write up on replacing head gasket for d16y7 engine?
- Rough idle and stalling - codes 8, 9, 15
- Civic A/C Conversion?
- 99-00 Civic Dash Harness Swap Problems
- Which hi-flow cat do i need for my Toda header?
- throttle/idle problem
- Civic EG AC hose blown apart?
- ecu swap require a flash?
- 2K Civic DX: Help ID'ing this connector behind D/S kick panel
- Bypass heater core... Issues?
- Thermo or No Thermo?
- d15z6 build piston/ set up help
- quick help! odometer prob
- Sound like a restricted A/C expansion valve to anyone else?
- The VERY slow Sol transformation
- Black ★BudgetBuilder★ EG6 Hatch (Europe)
- clutch fork/slave cylinder problem
- Clutch issues once again..
- IACV B18b Swap
- Countershaft nut tips or tricks?
- 95 Civic EX - CEL takes 5 second to 10 minutes to go out
- Stumped fan wont work
- 93 Del Sol manual L side door latch - What years/models are interchangeable
- What's missing/wrong with this engine?
- EG6 brake conversion civic si 08
- D Series Rod Bearings - Which did you use for your build?
- replaced wheel bearing 99 em1 now more noises
- 94 civic ac diagnostic
- 1997 Civic Hatch with GSR Swap Code 43
- Do 99 Civic's Have a Cabin Air Filter?
- Brake issue, would love some help
- help! battery died - no radio :(
- will a chipped p28 work like a p07
- P1259 CEL, 98 Civic Ex
- Exhaust question
- rpm gauge fluttering honda civic ex
- Exhaust questions 1998 ek ej6 hatchback help!!
- Yet another A/C wiring problem
- Crazy CEL Issue
- Auto tranny dipstick is loose and fluid spills out
- Engine rpm surge at steady acceleration
- radiator fan is not going on
- Multitude of ABS codes.
- first time swap: D to B series
- RPM Jumping randomly
- buying a 1992 Honda Civic VX, please help.
- Problem with one of the drum brakes
- Security Engine immobilizer
- Parts swap question??
- CIVIC EK3 won't engage the GEAR
- another no start HELP!
- d16y7 white smoke?
- Want more power..but not sure how to.
- 98 D16Y4 sedan Central locking driver side not working in hot weather
- 95 DX d15b7 shutting off, hard start, loss of power.
- '97 Civic not reaching normal temperature
- del sol b16 into eg
- Identifying an OEM hood
- 93 del sol speedo dosent work help!!!!
- LED dash lights
- Is 37820p28a00 same as 37820p28a01?
- 2 wire CKF plug? one of a kind?
- Soft brake pedal. 99 dx
- Confused About Brake Booster Part #?
- worn control arm bushing cause sloppy steering
- a/c on, exhaust sound question?
- 92 civic fuel pump doesnt prime
- Parking Lights won't turn off
- civic crankshaft broken at keyway, pulley wobbling
- Alignment After B18b Swap
- EJ1 Seat Replacement - suggestions
- 2000 honda civic si head unit upgrade issues
- Need info on what parts to buy for D15B
- b18 aftermarket ebay solid mount help. got pics
- B16a, can a spoon ecu cause problems?
- Ecu problem 00 ej8
- brake lights not working
- problem with h-brace on 96 civic ex
- Buying new clutch.
- anzo headlights
- 2000 hatch opinions
- HID + Side Marker Install + Fog Light Questions in EG HELP!!
- problem with passenger window
- 92-95 master cylinder 15/16" upgrade info
- dome light stays on after replacing door.
- Problem with brand new main relay not turning on fuel pump.
- Whining noise on de-celeration?
- Gauge cluster issue in '96 DX
- transmission.... FAIL!
- Loose shifter
- Tune up.
- tachometer is off supposedly...?
- change front seats
- 95 Civic 4DR EX Mini Me Swap - D15B7/Y8 Head
- ebrake light on dash stays on.
- 93 Del Sol s resurrection
- SI cluster RPM gauge question.
- HELP hose connection behind intake manifold
- p1337(ckf) or ignition fault?
- zc worth it?
- just replaced my timing belt now my enging sounds like its knocking
- Weapon-R "fake cat" test pipe fitment in EJ6
- hood release cable
- Specific speedometer issue
- another civic with no spark and fuel pump not primming
- Lowering IAT's Experiment
- Does the 92-95 civic sedan come with beige/tan interior?
- obd0 to obd2a?
- 1998 Honda Civic radiator fan not spinning
- Slipping new clutch.
- Koni Srt.T + Ground Control Instalation
- new TPS options
- Eg/ej cluster help !
- Remote Trunk Release - Honda Civic Fifth Generation
- 1999 civic ex idle surge - TLDR beware
- b16a Swap ek9 Shell
- 95 civic turns over but won't start how do i know if the fuel pump is bad?
- brakes please help
- What oil do you use on your very high mileage Civic?
- help - camshaft/gears removed not being at tdc
- Wanting to Install 2000 OEM keyless into a 1996 DX
- Help! Trans & Engine trouble 98 Civic
- HELP ME IDENTIFY the fuse for the A/C button
- Adding AC to my civic
- Cylinder 1 missfire/CEL/blinking CEL
- B16A2 swap..
- grinding noise and driver side water leak help
- AC Electrical Problem - Fuse box bad twice?
- Transmission Fluid
- Soft Brakes with A/C on
- D16y8 99 civic ex will not start (no crank problem)
- Brake & Fuel Lines rotting - 00 Civic - Do they need to be replaced?
- d16y8 transmission help
- Help – Civic EX overheating 1999
- Squeeky Exhuast Rear End..
- How to make it faster....
- D to B Swap Axle Question
- Del sol ek front build with pics
- Help! Civic dx 00 black fouled plugs
- 98 clicked and wouldn't start. New battery, and now no power to dash
- Aem v2 for integra fit 1995 civic dx d15?
- D15B Ecu?
- Intermittent failure. Chasing for months.
- Heater control panel works intermittently with engine on [video included]
- Error code P0117 and check engine light
- Z6 Block Y7 Head, ECU, Timing Belt & Water Pump Question
- Coupe 94 Water leakage on passenger side. HELP!!!
- 1.6 dual carb in civic eg
- clutch question
- VTEC Solenoid wont stop leaking, please help
- Exedy Clutch, rough take off from stop - 92 vx
- Hatch window won't latch into the hatch
- d series with high compression
- Del Sol Core Support
- D15b7 hard cold start/and now bogging/died upon take off
- EJ6 Streetlegal Racecar - suspension and engine swap questions
- Scraping sounds coming from all wheels? 96 Civic
- Rack and pinion gone wrong. HELP!!!
- 1999 honda civic 1.6 wont go up hill lacking power
- daily driven/show car (need advice)
- Auto tranny woes
- EG Rear disc conversion difference from drums?
- Honda Civic 98 Wheel Lug Nuts Q:
- Should i replace head bolts?
- '94 Civic Si Trans Question
- Head bolts wont torque down.
- Volkswagen recaro seats into civic
- Rear Disk Swap
- Aftermarket Window Regulator for 2000 Civic?
- Front End Clunk
- HELP Test Pipe doesn't fit
- Hard steering.
- tire clearance issues
- A/c put together from random parts?
- 92 95 civic hatch d15b heeelpppppppp!!!
- 94 EX RPM Fluctuate at release of throttle
- Speedometer issues
- 2000 Honda Civic P0131 O2 Sensor Issue
- Fuel Lines
- 93 delsol s automatic
- Clutch/Flywheel Setup Question
- d13 to d15 or d16 carbed ???
- D16Z6 to D16Y8 swap - Need advice
- VX: Trade one problem for another
- Will a 99 CRV A/C parts work in a 97 Civic LX?
- Newbie Timing Belt Questions about 94 Civic DX
- civic seat covers on integra cushion
- feel heat in the cabin when heater is off and fan off ?
- D15b8 to vtech?
- Can't find male plugs. OBD2A D15B7-Y7 head swap
- 1996 d16y7 mini me y8 swap
- Idle dips under load
- 99 Civic 5 speed overheating
- Weird Clutch Issue in First Gear Only
- VX - Rough idle on startup, now won't start
- Del Sol wont start
- How to fix these holes in front bumper cover
- difference between 2000 civic EX and SI engine wire harness
- antifreeze smell???
- hey guys! quick question
- Del Sol Rear Compensator Arms
- 98 civic batery voltage wile running?
- cleaning carbon off of pistons?
- Ebay Fog Lights Install Problem!
- help! rpm revs up and won't shift gear
- low comp. causes?
- fitv question
- Step on the gas, let off the clutch, and 97 Civic just dies
- 99-00 conversions to 96 dx hatch clarifications.
- Del Sol h-23 sittin low and crooked
- climate control dash lights not working
- auto trans wont go backwards initially
- D16Y7 -> Y8 manifold swap: throttle cable.
- Hard to shift
- HELP HELP REPLACING WINDOW HARNESS!!
- exhaust/cat questions.
- Block stamp question
- Cooling Fan Relay Bypass Picture?
- 2000 civic ex with z6
- Interior fan only blows on speeds 3 and 4
- wont start sometimes issue help
- 93 civic ac compressor problem
