View Full Version : Honda Civic / Del Sol (1992 - 2000)
- horn will not work!!!!
- b18c5 swap, need obd1/obd2 jumper
- Curb Weight: 92-93 CX vs 94-95 CX
- HKS mufflers
- need help bad losen hope on my swap
- 01 Civic check engine light
- Wheel Stud/ Hub Replace Help Please
- JDM Fenders
- Ls and 05 ex rims on eg hatchs!
- onsoku coilovers
- 92 civic dx sensors
- new and wtb engine and trans....
- civic wagon
- Smoked amber corners
- Skunk 2 or Jun Cam Gears??
- any advice? 00 si 1/4 mile slip
- wtf? are these
- Please read this post.......
- 1/4 mile
- Strange noise
- Question about this site?
- Considering selling my EG with b16swap in South Florida
- difference betweeen Z6 bottom and Y8?
- s200
- Best pistons... to run on otherwise stock ls/vtec B18b/B16a head.
- 100 shot
- need help in beaverton
- b18c into a 94 civic, wiring problems
- sputtering b16 in a 92 si!help!
- vtec light
- Action packed with hesitation and acceleration issues - 1993 Automatic DX coupe
- Ignition problems for d16y8
- quick question bout engine
- Which throttle cable for GSR swap in EK
- window -prob-
- NOW WHAT????? (detailed pics inside)
- OEM JDM or AFTERMARKET winddeflectors???????????
- I need to know if anyone in maryland or surrounding states knows where i can get a OEM dirvers side
- Tobayfest anyone? April 10th
- Horn Install w/ Diagram.. what am I doing wrong???
- Mini Air Filter Breather ??
- D16 Crank In D15
- d16y7 engine swap now smoking problem plz help
- Help!!!!!! Help!!!! I just put new pistons and rods in but when I spin the crank it is free then it
- HELP PLEASE I just put new pistons and rods in but when I spin the crank it is free then it becomes
- Interchangeable trannies for civics??
- Overheated at a weird time with my new turbo kit..
- need help! start up on 05 civic .
- B16A valve adjusment....question
- Ek hatch with K20 Refable?
- EK HB: Rear Tie/Sway + Tanabe Sustec Pro SS.....
- front end swap
- oem gsr exhaust on eg hatch?
- Difference between Wheel Hubs? EK DC
- another break light ........... help
- neewbie here, but trying to sell 95 civic lx sedan
- HELP!!I just put new pistons and rod in but when I spin the crank and it is on a power stroke it get
- Will EX rotors and calipers fit on HX knuckles?
- am i better off with...
- change catalytic converter now?
- Power steering line removal
- Installation: (2) EK Skunk2 Tie Bar and OmniPower LCA (w/pics)
- EK steering wheel HELP!!!
- ITR Type R Muffler on a EG EJ EK Coupe HB Hatchback
- IACV problems
- new friend!!
- d16z6 rods and jdm d15b rods: Fitment answers from Eagle, Crower and Endyn
- K20 Swap
- shifter bushings in my eg?????????
- Axleback problems
- i want to buy a eg hatch or coupe for 1200 or less
- LS Redline?
- 1995 EX brakes on 1992 CX NO FIT???????
- BIG PROBLEM!!! Need help.
- 2000 EX auto to manual tunnel question
- BC Cam gears
- B16 or GSR tranny?
- Scammed!! Please read
- civic 03 cruse control
- JRSC b16a people...Please Post Your Full Setup & Numbers.
- how to install AME CAI
- b18 idleing problems and running issues
- best exhaust for a 2000 civic si
- Help wiring Battery/Alt/Starter
- =) new toy.
- need advice about getting rim, NEW TO RIMS' world
- dx to ex cluster swap
- got a couple of questions
- huge question on jdm mirror conversion
- VAFC II INSTALL PROBLEMS
- anybody here have...
- sedan lip
- ..SOME SUSPENSION QUESTIONZ....
- 5 Speed or Automatic ECU?
- help cel code problem
- finally got em'
- Brakage....
- Will a LS Rear Sway Bar need support?
- Clutch is officially gone...
- headrest problem...NEED FIXING.
- help on H/D headlight harness
- ball joint bolt (plz clarify)
- Del Sol axles
- GSR vs JDM B16
- budget on tha motor...
- Question about 18" wheels for 2002 Civic
- Integra cat back exhaust bolts onto eg with B16a swap????
- NO sway bars WTF was honda thinking where do i get some
- 02 Civic halo projector headlights
- Civics from toronto and Canada post ur pics
- HIT & RUN [O.C 714] I NEED YOUR HELP.
- need some parts
- b16 swap in my 98 civic...wiring..issues...easiest route..
- keep blowing fuses, checked everything, PLEASE help!!
- what setings do you use on your KYBs'
- purchasing a del sol tomorrow
- how to tell if im getting an ex/si transmission?
- Slight sputter at idle D16Z6 no CEL
- Sparkplugs Cables
- removing srs in california legal?
- puddle of water on drivers side wtf!
- OBD2 B16A2 Swap Question.....
- help motor question
- 92 civic hatch
- Rolled Civic into ditch :( Need your estimates/advice (6 pics inside)
- shipping engine across border to canada (did search)
- sea foam
- help installed vafc 2 and now got code 22
- I've decided to remove the SRS.
- Anyone know a good place online for pads and rotors
- picking up this eg for 500
- rear susp. cut the strut?
- Electrical Problem with B18C-R Swap!
- how much did you get your EG hatchies for?
- Smoking deal on some eibach sportlines...but they're for a teg!
- Performance ECU (98 EX)...
- is this a good deal? (95 eg coupe)
- anti-teft strategy possibility?
- Timing belt too tight?
- car was towed with e-brake up...
- My power windows are terrible...
- mini-me swap question
- mugen valve cover swap, aem cold air
- FiberGlass HooD?
- 96 civic EX exhaust Fit a 99 civic si? like to know asap!!!!
- FAQ: o2 Sensor Simulator wiring
- CLutch Questions...
- Energy suspension bushings for a type-r?
- Shock went through hood...still good to use?
- Great jdm D15B vtec info!
- 99 civic gear box lights and stock radio lights out!
- looking for a cheap rear-section exhaust
- Brake bleeding 94 Ex w/ABS
- ANYBODY KNOW HOW MUCH I CAN GET FOR B16A2 BLOCK & B20 HEAD??
- when removing bolts, not snap?
- are v-tec and non-vtec dizzys different?
- Autometer Gauge Works Pod for 99 civic
- How to get rocker arms off?
- d16 tranny question
- HELP NOISE!!!
- Del Sol body rigidity
- spark plug question em1
- ACL rod bearings d16y8...need model #...
- tach gauge cluster swap help
- A/C mount question...
- NOT ANOTHER ONE!!!!! ***THEFT*** AZ
- what is the cheapest way to ship a motor and tranny?
- E-Ram Supercharger
- Dimmer switch dosnt work
- engine swap from 95(1.5) to 2.3 v-tec
- any one got any info on hack for a turbo using apexi afc
- d series transmission are they interchangable looking to put ex trans on 96dx hatch motor
- b18c5 in delsol
- Hydro to Cable??
- EK Window Issue... Yes, I Searched.
- oil leaking from rear, by driver side axle (alot)?? info inside 92 hatch b16 swap.
- Rear wiper question
- 3 quick D15b swap questions
- h22 into a EG Hatchback question.....
- wilwood brake question.
- d15b7 misfire?
- 92 civic cx with gsr....
- Help!!! What Sensor is this???
- the most wonderful day evar...my car died so help me please
- CX Fuel Filter
- d16z6 Q's (tuning?)
- [FAQ] Finally!!!! ITR Cluster into EG Write up!
- Help some locals out - Washington
- Rewiring D16z6 distributor to OBD2?
- 2 lb metal in glovebox!
- D-series motor Half Shaft?
- Anybody kno where i can buy civic 99-00 CF spoon lip?
- launch rpm?
- boost or vtec?
- 95 civic oem stainless exhaust
- VTEC Light on my d16zc.
- EG JDM Sidemarker template???
- b18c dizzy
- headers?
- Thinking about getting a sunroof for 2000 Civic
- Does anybody have this muffler?
- y8 headgasket
- Anyone with an RSR GTII slammed?
- VTEC on my Mini-Me isnt working...
- Clutch fork bent? Makes noise, vibrates, and idle drops when clutch pedal pressed.
- grinding sound... dont do it for me do it for my hatch
- Installed new dizzy....is my timing off?
- question about axles in a b18c5 swap for my 92 hatch
- Anyone w/ info on installing actuators??
- should i get an si/ex fuel pressure regulator for crx manifold or aem adjustable one
- Wiring ITR in EG
- Need help with cluster ...
- Need Some Help and some input on this noise from my motor
- Help: Headlight Flashing
- Honda Genuine Wheel Lock Locking Lug Size and Weight -- too big and heavy?
- Question : Will Da rear disc fit 00 civic dx?
- Safe without front and rear bumper supports?
- burning smell when rpm's get high
- header ???
- ??'s about putting a 96 ls into a 96 civic??
- ??Proportional Valve question??
- B16 tranny leaking fluid...possible to fix?
- Does size really matter hahah
- idle flux on 94 civic cx 1.5L
- ECU and o2 sensor compatilbility issue
- Connector for cluster with tachometer
- B16 Stroker
- What now???Geesh....
- Redline question
- Help figure out my engine problem and i will Paypal you $20
- help
- b16 into a 91 hatch axle question
- Could an exhaust leak cause my car to run rich?
- Over heating!!!
- just installed my omni's....quick ques on adjustment
- hey harness question for mini me
- Idle Dips real low
- Any Advice on Aftermarket Brake Pads/Rotors/Calipers for 97 Del Sol VTEC?
- 93 DX hatch with b18c swap are my stock brakes good enuff?
- Door hanging washer trick of power and amazement, behold?
- head question
- comptech exhaust diameter? searched
- Please help with window tint peeling on left side window of 99-00 civic
- how to clean my nasty stripped trunk?
- Help -- H22 Into an EG with P/S and A/C
- you guys have it good in cali
- Brakes
- EK9 Bodykits
- Will my LS Comptech Intake System work on a LS B18B swapped hatch?
- Loose Ignition
