View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Jdm D15B Usdm D16Z6
- Fixing Rust
- rear disk conversion...
- incorrect offset affect anything?
- tranny removal because of gear slipping,
- I improved my 1/4 time! 2000 Civic EX/B18b
- Crank Pully
- what causes engine idle to surge up and down?
- I rarely do this... cool pic...
- Tom, and others: Whats the best you've ran on all-motor street tires
- The 1.8 HB is dead (56k warning)
- Quick question: What is the stamp name for the 99 b16a tranny?
- V-AFC trouble, need help please
- If i bring my car to honda......
- obdII injector harness/clip for my RC injectors
- Question on Jdm B16?
- heavy clunking noise??
- Where to get guages fixed?
- HELP!!! JDM Sir II cluster!!
- Some 1/4 mile passes...is this a norm?
- need help - jdm d15b
- ~ES MM Inserts~ Question
- Rack and pinion or Tie Rod?
- camber kit install
- EX-to-DX Cluster (mph/rpm)
- yo
- help help i just pulled of my weel an two studs broke@!
- wiring jdm itr harness on my 94 hatch
- Its been covered a hundered times anybody got an answer yet
- Stock wheels
- post your suspension setup, sway bars included..
- Tire Sizes for 15" wheels on a EK?
- idle prob
- New guy looking to get in
- good deal on hatch?
- Is there a picture thread for this forum?
- OT: looking for a MUGEN replica front bumper for my Lude
- PCV Valve
- pic request of knock sensor
- do i need to hook up my knock sensor
- ngk wires
- Odometer rollback
- haha...what luck i have
- integra muffler onto a eg?
- AC question
- Can someone explain this to me about wheel wells?
- my hatch *sorry im new*
- Which is the best Bang for your Buck (Carbon Fiber Duckbill)
- Integra mirrors on Civic
- question about my steering.
- Honda R&D History on tonite
- will 96-00 ultima shocks fit a 92-95??
- 1st mod
- Civic 1999 DX Engine HELP!!!
- Bizzare problem with uneven rear suspension 99 Si
- How to pull the VTEC harnesses from an Eg? Going to the junkyard!
- VAFC/CEL question
- Hey guys hit the 1/8 tonight
- looking for a sideskirt....
- I Love HB Stickers
- Whats wrong with lighter in car not working?
- will this throttle body fit?
- Turbo exhaust, DX motor... need which cat back?
- pic request: eg hatch + hr race springs...
- rolling the fenders?..anyone?
- Speed Sensor, Need your help guys!!
- Tune up from a Honda dealer
- Nj
- smog hookup?
- ***can some one help what header is better for my 2000 si ***
- Ever heard of a d16ZC???
- Apexi Exhaust for 95 EX VTEC coupe
- Quick Clutch Question ! ! ! !
- Project D16Z6 N/A
- Do '97 Civic EX doors automatically lock after starting engine or reaching a certain speed?
- My headlights don't work.. Where should I start?
- cam lettering on shaft
- Header torque specs . . .
- Is this unsafe/bad?
- hot to remove n1 silencer?
- eagle rods and srp pistons for d series problem
- what do u think of these?
- To keep the OEM cupholders, or get a JDM center console...
- Tapping from crank area????
- black housing headlight for EG?
- Smog and Visual Inspection?
- Which chassis are you driving?
- Skunk D16 intake manifold
- Question about CTR and SI lips... HELP!
- 5 door ek?
- v-tec solenoid
- ETA on the D16 intake manifold from Skunk2?
- is 50$ a fair price?
- Water pump and timing belt change
- Changing my spark plugs
- Integra and Civic Rad cap the same??
- HELP!!!! Car wount go into gear!!!!!!!!
- B16A/B18B LS/Vtec leftovers..
- EK question
- Hybrid input please!
- how to correctly read Chassis Codes
- guess what happnd today? =[
- Engine can't stay revving
- Lug Nuts or Your Nuts?
- whats the lightest.. dx, cx, or vx?
- Comptech Race header....................
- shocks/struts (Searched)
- Intake install and sylvania silverstars
- eBay intake installed, pics of what the quality is like!
- race header ??
- Got a Question, need help....
- quick exhaust question...
- ITR exhaust on a 94 civic coupe
- 16" inch rims too small with bodykit/lowered?
- VTEC enguagement and high idle questions
- Picked up my head!
- Looking for apperance and function, any suggestions?
- 92-95 Civic CX hatch
- Is there such a thing as a car fax for engines
- HI new 2 board - camber question
- Can someone post pics of 18's on a del sol?
- car is overheating again please help if ur der!!!!!
- 96-98 civic din block off plate
- finally got swapped! (pics)
- picture request of 99-00 si front LCA's
- 4pt racing harnes???? (sparco clubman)
- power fc for na?
- Im gonna get the final answer, the truth.
- KYB - GR-2
- engine/ suspension combo q's?
- 2000 usdm b16 ecu is it the same as the jdm b16a2 94 ecu?
- Sad day for the civic
- Anyone in chicago wanna help a brother out?
- 5 lug /suspension conversion for the EG
- Knock sensor pin #
- EK rear disc conversion (have searched already)
- would u buy this?
- NEED good sites for built blocks.. im aborting building mine
- What the heck? Has this happened to you.
- old question
- my new engine is in!
- 98 Civic DX Y8 manifold and GSR/TypeR TB!!
- Check Engine Light !!!
- OEM HID with the shield
- Tanabe Racing Medallion tip size?
- Engine rebuilt kit..
- My car goes....aaaaaahhhh...bup...aaahhhhh...bup???
- del sol offset?
- what to clean wheels with
- So I have a spare 500 bucks...
- My car (most of you don't know)
- ssr neos...........
- itr 96 spec 4 lug, will it fit a 96-+civic hatch
- DragRacing vs. RoadRacing/AutoX
- locating PVC valve and fuel filter.
- 2000 Civic EX Exhaust and springs?
- 2000 Civic exhaust and springs
- Tanabe GF210's
- aem cam gear 7-14 horsepower gain?
- rear disc brakes off an EG sedan??
- Best Internals?
- what to buy... getting a car this weekend
- WTB - carbon fiber duck bill spoiler for eg hatch
- Where to get Spoon Gauges w/ Needles?????
- EG lx with B18 brake question
- 97 dx throwing codes
- Go Go Gadget Honda Reliability
- got my b18c1 installed in my Cx
- has anyone done 99 oem fogs on eg?
- Is this a good price for LS/VTEC buildup.
- password jdm? also question about dc2r recaros
- Will a integra type r intake fit a 92-95 civic dx.
- EK HID kit
- exedy clutches on ebay...
- what aem cam gear for the jdm d15b vtec?
- Aftermarket Mounts for D series...
- 1995 JDM H22a LSD
- DC shifter for CIVIC .. will it fit TEG?
- snap timing belt tonight please help
- painting rims
- Turbo the D16 or swap for b18c? Which has more potential?
- Ek sides on my hatch. Got pics
- painting over headlights that have already been painted???
- DC2 integra dash conversion into EG, can it be done?
- Replacing Rods/Pistons?
- any body have the same foglithg like mine here?
- oem jdm soiler?
- pics of my 94 del sol vtec turbo
- Replacing Fuel Injectors
- how to adjust headlights?
- would this pedal set be sufficient in an auto to manual swap?
- 2000 Si catback on EG?
- H-series mounts in 92-95 civic....
- Pic request... bottom of an EK
- Has anyone done this???
- ctr pistons...
- Tranny Question..........i searched
- EK exhaust question
- Tirerack and them mounting your tires??
- Fabbed heat sheild for intake today.....tech questions
- Lookin For Cheapest Way To Turbo 92 Civic
- **HELP** D15 and D16Y8 stock cam gears interchangeable???
- Grind in Tranny...
- cable tranny
- Del Sol with Integra JDM front?
- putting manual tranny EL's on a auto cluster?
- a quick coilover question
- thermal
- D15B8
- Getting ECU chipped?
- Are these IM connections done right
- Timing Belt question.
- Civic EK Seat Covers
- exhaust gaskets
- am I paying to much?
- Theives in NOVA found
- EG Carpet....
- What OEM Rotors will fit my cx?
- Need help deciding on what i should do next
- help...
- vtec switch question (. . search is disabled)
- sprint springs?
- "Search"???
- Brake Pad options?
- need o2 wiring help.bad
- Engine swaps and/or auto to 5spd conversions in ATL?
- 18/19in rim size recommendation plz!
- New Paint Color for 96-98 EK Hatch!!!
- coupe sunroofers
- if anyone has n1 on there hatches and has pictures can you post em up?
- auto to manual swap
- ideas
- ebc green stuff..how do u like them?
- B series, 2.5 inch collector, CA smog legal, 4-1 header?
- check engine light
- High flow cat?
- act sucks balls, and i have a vortech help please..
- Chrome intake manifold ???????
- 99-00 Climate controls in a 96-98
- radiator position
- Chikara headers by Hedman?
- need help on zex kit install
- Does a 5th gen pedal set fit in a 6th gen?
- Need a pic of the stock rear wiper on a 92-95 Civic hatch.
- 98 EX Ecu.........HELP
- 5th gen si/ex swaybar?
- civic type R, how much?
- insurance
- Stupid but serious question
- Phantom Gray Civic
