View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 03 civic hybrid wheel question.
- Flickering oil psi light.
- ex/esid series trannies
- question on manifold interchange...
- Removing Cruise Control
- Driver side fan (a/c?) needed?
- Fixing the SOL - "New" Parts today -- 56k wait. .. ...
- Tranny Rebuild Kits
- jdm map lights
- How do you like KYB's AGX shocks?
- how many del sol
- Water Temp gauge
- AWD civic
- vetec working?
- HAS THIS EVER HAPPENED TO ANYONE??
- motor swap, now no temp
- Nut, Washer, and rubber piece came off rear strut? What to do? Help!
- Need Crank Pulley Bolt
- skunk2 exhaust on 98 civic ex sohc vtec?
- Weight reduction gone too far??? My new project
- Q ABOUT A TURBO manifold
- Vehicle speed sensor problem!
- YO PLEASE HELP IDLE PROBLEM
- Survey for which products are most over-priced
- '95 EX exhaust and header upgrade
- 1996 Honda Civc Mods?
- hit and run
- Integra Trailing Arms/Brake Swap
- EG 4 door corner OEM or JDM lens?
- Anti-Theft Devices
- 89-91 CRX Si wheels on a 94 EX
- Wtb: Spoon Ek Wing Real
- its time
- Fairly odd swap question.
- EX? DX?
- V-AFC settings
- car turn on...then turns right off....why??
- INTEGRATED CONTROL UNIT! help please.
- 5 wire to 4 wire o2 sensor help
- ls-vtec 1/4 times
- The newest addition to the K20eg Family (56k ok)
- help with koni yellows
- B18C5 into a EG Hatch.
- Mods for 2004 Civic
- so which camber kit is really the best?
- Tein S-Techs Bump stop question
- What side skirts does this guy have on??
- Hayame coilovers... NEW feedback!!!!
- 2000 si front end on my 98' ex coupe
- DO EK Sideskirts(96-00) fit on 92-95 coupes
- itr axle back on ek coupe
- how to properly chip an obd2a ecu
- STRUT BARS (questions)
- rewiring iacv....
- Passport 8500 x-50
- Anyone know where i can get insulated coaxial wire?
- Should I buy a S4C transmission from Ken/KRS? Who has personal experience?
- Compression Question??? Did search
- d16y7 d16y8 minime vtec knock sensor code 23 problems!!
- tranny bearing bad? or axel? rattling.... help
- civic cd player
- 94 DX with a B20
- Tranny issues!
- ground cord...
- Transmission bearings - noise when pushing in clutch
- 99-00 Foglight bulbs
- Custom del sol sub box for the trunk
- do EKs have a EGR valve?
- i want to hear your personal opinion on my suspension setup
- dumb question
- ITB's for those of you who don't venture into other forums!!!
- Whats the best trans for the race track
- Mugen M-7 Rims
- d16z6 into crx question
- will a b16a2 tranny bolt up to a gsr block?
- gsr dash and door panels into a 95 hatch
- d16a6 oil pan d16z6
- d16z6
- Does anybody know if there are new Tokico's coming out?
- What to replace.... cap & rotor or only ignitor?
- 04 civic
- Can anyone here get me my radio code?
- skunk 2?
- Grinding Reverse when cold ????
- Heat shrink wrap on engine electrical wires?
- Civic HX cat options
- climate control lights keep going out, then coming back on...
- honda part # for d16y8 HG?
- jdm headlights peeling
- good machine shop in SD...
- JDM motors getting it BAR....
- Help needed in Maryland...
- b20 ac bracket fits civic ac compressor?
- b-series swap guys who has b-series fuel pump...
- motor swap
- very very quick question
- Ingalls Camber Kit Question
- b18 swap in a eg hatch, trying to get a/c to work
- any info or parts out on a k20a swap?
- honda coilovers?
- will front and rear 94+ gsr seats fit in my 98' civic coupe?
- where to get HKS head gaskets
- Zenki Extended Lugs
- d16z6 crank/block girddle question?
- head gasket
- will these fit?
- Problem with rotors
- how olds too old??
- 94 civic alternator
- D16a6 into a del sol s, what mounts do i use???????????
- h22 swap running like poo poo
- air/fuel fact or fiction?
- overheating...
- struts
- Turbo Downpipe
- Need HELP with Ricer to OEM conversion-- Please!
- Oxygen Sensor Extension for Comptech SOHC Header
- are honda keys 1 sided or 2 sided?
- FS or Trade, THEFT RECOVERY 1997 CIVIC EX 5 SPD IN Northern VIRGINIA
- Questions about Skunk2 intake manifold in 2000 Civic Si
- Azenis Tires
- 93 del sol probs
- Del sol conversion
- are ex and si tranny the same in 92-95
- how much can i get for my civic??????????
- help me out. installing ex tranny
- Newbie stupidy
- Honda Guru's need your help
- Good place to buy koni yellows?
- FLIK apex2 wheels?
- new valves with port and polish.
- Width of Civic Hx wheels?
- Ok... tranny noise....yes i search....im confused
- trying to install an OBX intake manifold on a '00 DX
- l/s throttle body size
- GSR rear seats in 99 coupe
- genuine parts
- oil catch can
- EG trani removal
- CTR intake cam and CTR n1 pulley
- Crank Pulley for JDM D15B Vtec?
- strange sound from engine bay, not sure what it might be...
- Raspy exhaust noise
- Specific Hondata and VAFC question!? FREE?
- Custom B-Pipe for Spoon N1 question...
- what parts am i going to need
- fitment question, need help asap
- Cam Gears and VAFC
- Ls/vtec??? GOOD OR BAD idea??
- What kind of brake pads do i have?
- exhaust for a 98 civic ex
- Bilstein shocks!!! or NOT?!
- heating and a/c in a swap 92 hatch?
- Oil Pan
- EXHAUST CHECK IT OUT W
- no more p/s n a/c
- 99 civic SI w/ 200whp, how fast?
- CEL 08. TDC sensor??? What to replace???
- New springs?
- ECU code: 54 CKF Crankshaft Fluctuation Sensor HELP
- ECU wiring and o2 sim gurus help!!
- Del Sol Speaker Sizes?
- May Anyone Please CARFAX this
- Del Sol Oil Light?
- y5 vs z6
- EK side markers
- Buying engine parts on Ebay
- can u compression test a motor that is out of the car?
- clean injectors
- megan racing lca's????? INPUT?
- harness, no cage
- vtec+white smoke??
- B18C5-EH2
- Does you know who makes front LCA's?
- where to get a EG9 ferio spoiler?
- Stock exhaust????????? Coupe Vs. Hatchback?????
- rich FT
- s2000 wiring (cluster)
- Can anyone give the meaning of Short block and long block
- installing rear passenger side fender on EG 4dr
- HID question
- Air/Fuel Gauge Help
- thanks to everyone/ anybody looking for black slipstreams?
- peakboostHONDA-B series turbo kit
- Concernin a hot swap.......
- ALL OF YOUR HELP NEEDED!!!
- Stripped tuner style lug nut, please help!
- D15B vtec timing issues
- WW mini me commando
- WHAT KIND OF EXHAUST 3" or 2.5"????
- Option Racing???
- I Am Updating Everyone On My Progress On My Swap.......
- Need suspension help for '99 civic
- Greddy Evo 2 or SP 2
- ecu plugs??? which one is D14?
- Stillen Headers?
- *reputable or not* japanstarmotors
- Sun Damage to Dash
- Plugging a/c line leak.
- Auto to Manual B18B or Auto B16A2??
- Is the crank pulley bolt on D16s reverse threaded?
- whens the spoon style abs lip comming????
- Road Kill (stupid ass cats)
- GSR Rear swaybar on 99 civic???
- b16sir2 ecu question
- d16y8
- guage cluster prob.
- EG auto tranny same as a EK auto tranny?
- mystery trans/motor?
- Equal length drive shafts in a d series tranny??
- Tranny problems, need some advice.
- code 14 after intake mani swap?????
- Brief trial user question/problem
- DelSol turbo question
- CARFAX needed please! :D (IF POSSIBLE)
- Oil Pan Dents...
- I need some help.....
- old benen eg hatch
- Civic Wings M3 style?
- Footrest for EG hatch?
- B18B obd1 question...help me out guys need some quick answers...
- 91 civic DX engine swap
- HELP.. b16a2 distributor wiring(colors dont match)
- 2.5" exhaust tubes?
- Del sol Fender
- Clutch help???
- Need big brake kit info
- What suspension for my 93 si bubbleback ?
- People with a complete 00 Civic Si front suspension on their 96-00 Dx
- 93 DX Hatch prewired for rear speakers?
- CEL came on today
- HID pics and help
- comfortable suspension for 96 hatch, that slightly tucks 15's????
- Quick Help needed!!!
- need some opinions on tokiko shocks and springs
- Dx help plzzzzzz
- 00si shifter problems
- Tach wiring help for a 93 civic HB????
- 1992 cx d16z6 swAP...(ecu ?)
- lookin for a shop that does k20 in a ek
- Just drained Oil and it didnt fully drain?
- what kind of engine do i got?
- plug wires...already searched
- Parts for 97 del sol si
- IS a 9000 RPM revlimiter for a B16a too much??
- Oil Filter, am I missing a gasket?
- DC dash into EK? --> possible?
- Still got JDM Del Sol parts for sale and Quick release
- what parts are needed for a full swap???
