View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Bilstein shocks
- dumb question but want answers!!!
- Valve clearance check question (B16)
- Lexus Style(Eurostyle) light issues
- coilovers with stock struts?
- upgrading clutch...
- anybody dealt with
- spoon brakes...2 pistons won't compress?
- Word of Advice to people who buy clutches
- Can the trailer arm bushing be changed?
- redline and suggestive shifting points for 98 civic dx
- Gear oil question
- 96-00 ek civic suspension/steering ratio question
- 97 Civic LX dome light not working.
- [review] robear racing tow hooks
- Brights dont work???
- Power window question
- For the People that talk alot of sh*t
- dashboard question
- Which would you pick?
- Hood bent on edge - common?
- What is a good 1G B16A head worth?
- looking for a couple del sol parts, can anybody point me into the right direction?
- ASR EG subframe reinforcement
- Putting a 4-2-1 Header + K&N Drop-in Filter on a D16Y8 Automatic?
- [Honda Civic 97 Dx] RPM
- One does not simply walk into tuning...
- engine codes
- NEED HELP ASAP!! how do i install lights for a 96-98 ek???????
- Would this work?
- Are stock Civic radiator fans pusher or puller fans?
- Question about mini-me swap..
- i got a free AEM intake from my Honda dealer!
- Coolant resevoir overflowing, not what you think..
- Which color wheels???
- EG oR EK???
- intake wrap?
- What is the correct timing for a Mini-me?
- Gauge lights go out when high beams are hit, searched no answers
- What kinda of Del Sol Catback Exhaust yall recommend?(Greddy SP2,EVO2,Invidia,Skunk2)
- turbo for a vertical intake manifold?
- o2 sensor slows me down?
- OBD0 jdmb16 into 93 civic ex
- My hatch is a mystery....
- CRX cat-back on 92 hatch???
- turbo charging a d16y7
- Help me B16
- Fixing interior door panels?
- head gasket help!
- 4wd CIVIC EK???
- Does D16Y8 intake mani. fit on D16Y7 head
- rear speakers
- 95 Hatch DX woes
- custom exhaust?
- d16y7 motor working lean
- Knock sensor cause car to not start?
- HURRY! I NEED HELP FAST
- B18c1 into a 5th gen civic dx
- Tranny gurus what is this bearing called??
- Opening Bolts
- Please help on ECU of Civic'98EX and '99SI
- Engine pricing question
- wiring d15b into 93 ex
- glue in driver doorlock. please help
- Need help with clutch allignment...
- B&M FPR Problem
- battery light
- IS my CLutch gone??
- engine setup?
- p28 chip
- Cluster problem..
- Hub
- Running 0w-40 Synthetic Oil in a D16Y8 ?
- ok new i am going to be putting in swap paint help
- Removing spark plug gaskets? Stuck!?! D series
- Unknown usage for ground under/behind cluster
- Anyone running ebay header/downpipe/muffler combo?
- how hard is a block swap on a d16?
- what to do LS vtec or b20 vtec
- I Have No O2 Bung
- "luxuries" in my EG hatch
- HELP!! already searched......What mc, prop valve, and bb, for EK with GSR brakes.
- blinking srs light...
- temp gauage reading hot!
- best way to remove the glue on the inside of doors.
- How-to Check OBD Codes in a US-spec '97 Civic EX?
- O2 sensor by-pass?
- Replacing 99-00 SI axle seals
- Another tire size question for 15-16" tires...
- I have an ECU code 15 - Ignition output signal - What does that mean?
- i got a code 78....what is it?
- transmission gears trouble
- Solid CEL broken hondata
- Something unnormal in my vehicle
- Reading codes: Steady CEL, flashing SRS??
- vacuum solenoid??
- Help With Del Sol clutch
- d16z6 ???
- B16 timing !!SEARCHED CANT FIND!!
- jdm p72 (short) chippers beware!
- secret weapon intake
- rear wiper motor wiring ?
- Is this a pretty good run??
- Loud Valve Train
- exedy clutch kit
- calling GSR into Ek owners
- URGENT!! how to fit engine + g/b into eg
- cel code 54-CFK sensor-Crankshaft speed fluctuation.??????
- Radiator Fan Dead... Need Help!
- SUSPENSION HELP!!!! stupid question but need an answer
- dumb ? bout engine swap
- INTEGRA SEAT BELTS AND SEATS INTO A 95 CIVIC.
- h22 writeups???
- Why is the 91-95 civic vti faster then 95-01 civic vti when it weighs more?
- b20, h22, or b18?
- to swap or not to swap?
- 96-98 Civic turn signal bulbs
- wiring experts...
- GSR exhaust manifold troubles: o2 sensor compatibility
- Tow Proofing??
- play in steering after tierod replacement?
- Civic Winter Storage Prep?
- What's causing the overheating?? D16Z6 engine...
- Gauge face on an si cluster, Do i need to remove the needle?
- Manual transmission stuck in 2nd gear
- Identifying D16 Crower Valve Springs?
- how to tell which single cam tranny
- will a 92 4 door stock muffler fit on a 96 2 door coupe without modding it?
- going to see the state ref
- Anyone know about civic interior?
- My Show car
- popping window fuses...
- DC2 front and rear sway bars on EG?
- tire size larger than 205/40/17?
- driver mount stripped
- How to wire fan to stay on with ign ACC?
- Instrument panel problem.
- cluster lights...
- What to check for !!!??. please reply
- Are these nessesary
- ECU Codes...... continuous....
- Engine code for 98-99 EK
- del sol tail light wiring info
- GSR swapped Hatch, Cutting out when accelerating
- Tried searching...no luck. Can you use Integra exhaust pipes (B pipe, etc....) on a 2000 Civic Si?
- Anyone here use Cusco Zero-2 coilvers?
- whats it worth?
- SIde DOor MIrrors HELp
- Fastest way to clean engine and enginebay?
- where is my oil?
- hood positions
- Smogging a SOHC VTEC Mini Me 96-00??????
- p/w wiring prob
- B16A Crank fluctuation sensor ( Need help Badly)
- B20 in EK can I keep A/C
- HOW DO YOU WIRE THE COOLING FAN TO STAY ON CONSTANT
- obdIIa or obdIIb
- Fuel injectors interchangable between usdm z6 and jdm b16
- engine knocking when cold
- 96-00 civic conversion (acura el front)
- wheres the relay?
- EG 4x100 rear disc conversion PT 2
- *bodywork problem* bondy has airbubbles/holes after curred..
- question about dseries
- Already searched NEED HELP!!!!
- Replacing radiator support Q's
- b16a swap question
- b18b vs d16y8 in EK
- buying used motor....what to look for
- Searched: How to separate D16Y8 Headgasket
- Re:Body kits
- Condenser?
- Folding mirror reley and info?
- 00 EX Chipped Ecu? p28
- Which size Allen key do I need for my Ground Control?
- I'm not a trial User!!!
- I need to change my rear pads on my 99-00SI . Does anyone have a DIY on this?
- Can you.....
- EK w/ITR swap smoke question and oil question
- Avatars Disabled?
- it just quit
- Please post pics of B16A2 TB gasket.
- camber kit question
- Removing wax?
- RADIO MEMORY
- Porting Head ..does this trick work ??
- Is Anyone Running 215 or Wider Tires on Their EG?
- What is the Oxygen Sensor Thread Pitch?
- Mild priced or CHeap header for B16a3 motor with A/C
- need help with taking out ek dash...
- 94 Civic Si not starting??
- Fuel Consumption Change...
- n00b question: Will Si center caps fit gs-r blades?
- How do I tighten my A/C belt? (Pictures included)
- Superchargers ...how much and how easy to install ???
- motor swap day
- Will obd1 DOHC ZC swap will it bolt up to a Auto-tragic tranny?
- Passenger window goes down slow
- JDM headlights?
- buddy club 2 body kit on 92-95 4dr civic
- integra springs in del sol?
- intake question
- anyone ever drop a f22 or f23 into a civic?
- OBD2 P28 question
- (After Much Searching) Settle the EK compatible Proportioning Valve Question...
- missing bolt on exhaust manifold
- (help) Changing master cylinder on eg
- headers collecter size!!
- Will a GSR Fuel pump work for a DX?
- new omnipower adjustable coilovers
- will my shift linkage work with this swap
- Steering Rack Falling off...
- gsr block or ls block
- Clutch Question
- ball joint on cx hatch
- Why does my ICM make a weird noise when a test light is applied to it?
- dmv question help
- osram silverstar or sylvania silverstar??
- The Best EG Swap!!!
- figured out my noise... HELP
- Shaking while braking...
- 1999 civic EX vs 1992 Lexus sc300
- Question on ECU
- Automatic JDM cluster to Manual EJ1?
- obd0 motor in a ej1?
- altenator belt
- Del Sol disk conversion questions
- are these real
- h22 fuel injectors into d16z6
- d-series tranny question.
- b16 swap mount help
- driving with no hood...legal?
- Supercharge Any Civic........wtf is this?
- Wont start after new starter installed, checked spark and fuel, both good... *searched*
- slow 1/4 mile times
- Jdm foglights
- dropzone
- Gets a l'il hot. Thinkin' head gasket bad? Do I NEED to have my head machined???
- Exhaust piping + size
- Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating
- Coverting from 4x100 to 4x114 HELP!
- tranny problem
- quick swap question, searched, no spark, 2000 ls swap in 94 cx
- gas mileage too good to be true?
- JDM Engine Passing Smog
- MC Reservoir fitment - 13/16 vs 15/16
- OBD2 H23 Vtec in a eg.. Need alittle help
- IACV Code on 99 LS motor
- WTB: 99-00 oem si grill
