View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what RPM's should i launch at,at the track?
- HELP-BAR(ing) An LS into A EG
- just purchased 97 civic EX coupe (EJ8)
- high compression or low compression with a turbo
- disc brakes all around but need help with brake lines????
- Cant get rid of my idle problem after everything...and yesss I have searched.
- need ex harness
- LS SWAP IN EM1 ??
- vtec aint poppin
- Ok, some questions before I start this summer.
- gsr throttle cable part number
- Slick Size
- Does an obd2 b series alternator fit on an obd2 d series?
- any difference between vx ecu p07-a00 and p07-a01
- couple of questions
- problems with axles breaking i need help!!!!
- Best tread life tires on 00' Sedan?
- Just purchased 1996 Del Sol DOHC VTEC
- anyone have a spare p2t ecu i can rent?
- Code 14 IACV question
- I need your opinion on what wheels to purchase?
- EG cluster lights
- crazy idle problem
- clutch sinks
- 99-00 front end grille interchangeable?
- STOLEN HONDA CIVIC
- Manual - Power doors
- My Ek4 SiR project thread!!
- Steel Vs. Billet
- Civic wont crank / no CEL /w ignition on
- sohc dip stick ???
- Possibly going to be new to the Honda world
- d16 motor rpm surging
- Wanting to learn about Civics
- leaking oil any ideas?
- which car?
- Weird Downshifting squeak noise!!!
- speedometer!! help
- BBP 4-2-1 header review (cheap Ebay brand)
- Replace OEM eg Hatch Spoiler
- wire harness question?
- Will this trans work?
- D16Y5 into DX couple, have questions.
- timing problem d15z1 swap
- I need some help on swaping engine
- Anyone ever wired up the gas light on eg6 cluster?
- Can someone help press out a hub bearing for a 98 civic
- Eg Coupe w/ Gsr Hub+Rotor problems
- ls/vtec wants to get boosted
- Barely failed emissions, any input on the cause
- Oil pan gasket?
- 92 eg hatch..
- What can I use to cap off a un used coolant hose
- Miata "Daisy" wheels on a 92-95 civic Coupe?
- Bought a 96 dx coupe quick ?s
- Radiator Screw?
- Ek - Godspeed crossbar install help
- Rear sway bar links
- Stock Exhaust Info for EG 94 LX
- Ignition Fuse Keeps Blowing Out
- EG (EJ1) Wont Start... not even the dash lights
- re-building the civic need help
- Rebuilding
- White Smoke Problem
- Re-thinking my exhaust
- ECU/tuning info
- white smoke problems????
- messed up suspension help?
- looking for a d16y8
- need help ASAP
- what kind of centric ring i need?
- 95 ej coupe i need your opinion
- zc Rebuild engine smokes??
- Swap problems
- 99' HX code 1399
- D16Y7 + D16Z6 head?
- Denji-Projector-Hid questions!!
- NO SPARK? NO POWER ALSO? CAR WONT CRANK? HELPP ME!!
- Engine shakes more than i'd like
- Rear Lip
- Throttle Cable, b18c
- How to: del sol rear compartment and fuel pump removal [26 pics]
- b18b or d15-vtec
- eg hatch with b16a (car wont start up??)
- function and form type 1
- What bay colour?
- Honda S2000 seats in an EG6
- OBD2A/OBD2B ecu connector pins the same?
- 1995 civic ex battery light.
- D4 Light bulb?
- Oil iN my sparK plugs and else where
- Wiring Guru's! Fog light Help
- idle problem please helpp!!
- cel code p0505
- coolant leak?
- help with obd2b gsr ecu
- b16 in an ej
- Best site to buy swap from?
- Wiring Water Temp Gauge
- NEED HELP
- sunroof broke, finding a pa junkyard?
- Y7 SKUNK2 IM GSR TB
- gsr oem muffler?
- 94 dx coupe cut out while driving in the rain
- 98 Y8 Civic D16B to D15B swap
- sunroof wont open
- new plug wires and no numbering.
- Turbo EG..
- 96-00 civic driver side mount bracket?
- steering rack guide adjustment
- Shock tower pin outs for the 93 OBD1, SOHC, non-Vtec, D15
- 99-00 Chargespeed lip on a 96-98
- My civic is all stock but i want....
- need help with slave cylinder and clutch line.
- help.. after swap problems.. smoking, bogging
- Need some advice with disc brake conv. pricing
- Civic 94 ej1 d16y7 recomendation
- 95 honda civic suspension
- H22a swap into 95 Civic tranny mount question
- si rear seat problems
- B16 manifold question
- HELP! Rear door stuck!
- 00 Si bogs in lower RPMs
- 1995 1.5 Honda Civic Timing Belt
- Looking ofr a good short ram intake.
- where to buy front bumper????
- Rattle when car is cold
- Hub swap for civic Help Needed!
- ECU fuse keeps breaking.
- eg gas going the wrong way???
- new member from oklahoma city
- d15b obd2 swap help
- B20 swap into 95 delsol
- finally got some rear seats in
- NEED HELP - 96 Del sol turning - not starting
- Aftermarket Rear Lip Install help *POLY LIP*
- Turn Signal is Sticking, Help!
- Coolant Leak! Help!
- Horn doesn't work after I removed the srs airbag wiring. Why???
- Parking Brake not holding car.
- Anyone know the thread size for the outer tie rod on a ek?
- smoking at 5- 7500 prm
- What Transmission
- 92 CIVIC SI BACK WHEEL MOVING
- radio code
- any one here from austin
- rim ideas
- rear disc conversion.. what prop valve
- Integra axel back on eg hatch?
- Torque steer on 96 EK
- where can i find these? (eg hatchback nose mask)
- h22 turbo on hatchback 93
- VTEC solenoid question
- p75 W/ My D15 Single Cam, Shitty!
- OBD1 ECU question
- f22b1 into eg
- need some help
- Power lock doors on a non power lock sol
- d15b7 header help
- Is this master clutch cylinder leaking? (pic inside)
- EG6 with LSD??
- d16 idle problem
- Switching gears
- How do I tell if I have a Walbro 255 Fuel Pump?
- afc neo core not working.
- needing 4 door 96-00 parts-* help a brother out*!
- no brakes in eg hatch help me!
- Turn Signal issue please help..
- what years/body types can I get windshield molding from for my civic?
- need help with engine wires!
- Need Honda part number for sidemarker bulb sockets
- Wiring third bulb on Del Sol 1 piece headlight
- Apexi N1 muffler worth it?
- 00' civic lighting questions, and some funny pics.
- sway bar question?
- Sir double din dash, options?
- Gauge Cluster/ Wiring Harness Issues
- OBD1 EK (GSR) want to revert to OBD2
- Wiper Malfunction, can't solve
- help installing eg ferio wing
- Bumper civic 96-98 'look 99-01'
- New eg6 owner. need help
- Tire Size question
- 100k Maintenance suggestions besides TBelt/wtr pump?
- Sudden noticable gas mileage drop ('00 Civic EX)
- No Start... No power Any Ideas?
- 96' EK project
- slave cylinder ?
- 1994 civic h/b ls swap axle problem
- Hello( Don't know if this is the right place)
- high rpm
- after 2 sec prime i have 0 fuel pressure.
- New member radiator recomendation
- Help with idle and gas mileage!
- OMG D4 flashing on 99 civic dx need help
- koni ground control
- help gsr wont start
- 99-00 front end
- A/F ratio change with CAI?
- New to Honda-tech Kinda
- b16 issue..
- Passanger side low beam does not work.
- blown head gasket.
- Hello Honda-Tech
- EG spoon mirror
- New guy with a hatch
- Hi
- skunk2 intake mani/tb question? and piping question
- how do i take pedals off a 2000 civic
- Need suspension help ASAP
- sry if wrong thread to post in, my build so far..
- ek to eg
- Where can I find a new IACV?
- My first b-series swap almost ready to go - a few questions.
- help with sprockets and stock cam
- CHECK ENGINE COMES ON WEN I REV PAST 7
- mini re build
- Will these rotas fit my car?
- D16 ARP Head bolts overtorque
- B16 Valve Cover Stud size?
- 96-00 civic POWER CTR Replica Side Mirrors
- OBD changeover question
- water pump and timing belt for JDM D15B non-vtec
- brake booster problem or master cylinder...
- For anyone and everyone with a speedo problem...
- Someone help Please
- How to test fuel pump?
- ELD code 20 help
- No spark, No start
- Question About a Test Pipe
- Axle Nut size? 1998 4door Civic
- Car not starting problem Need Help ASAP!!!!!!!
- header question
- mini me z6 head y7 block
- What options do I have for brake upgrades for my EH3?
- weird temp issue
- 95 eg...steering feels loose
- removing fender on 98 coupe
- Recommended clutch kit for my 94 EG?
- EK truck
- ej1 left side turn signals are faster than right side
- how do you take off th door sills??? 93 civic
- i need to know if
- cx to vx wiring
- 98 civic headers
- WTF is this plug for in my EM1?? LOOK!
- k20 gear ratios
- new alternator, no start
- whining/grinding noise in 5th!!!!!!
- Just got my first ej1 coupe!!
