View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Cluster options
- Hard time starting, Car dies sometimes, Code 3 CEL
- 14K RPM civic for sale - check this out
- video of my car with motor swap
- H22 Ek a/c?
- upper caliper pivot slide sized...
- 2.5 exhaust on d16z6
- fule pump wont turn on
- CEL code 43, anyone might have something on the mind that i dont
- i need help!
- what kind of paint to use?
- 93 Civic 4-door, windshield
- Whoa, exhaust problems like crazy . . .
- wtb ek9
- Del Sol Suspension Problem
- Proper ECU for a 98 civic with 99b16a2 motor???
- any tips for passing smog with a high-mileage d15b7, california san diego.
- D15b....Engine idling really low?
- looking to have some fun with my Sol. I need some help first
- B18c vs ls Vtec
- 00 EJ8 having trouble starting
- what belt do I need to get rid of my AC
- bearings
- Stock exhaust question...
- Any problems with buying reman calipers?
- b-series exhaust
- can a bad IM gasket cause this.......kinda long
- could someone PLEASE!!! get me a pic or 2?
- Tranny or Clutch problem, not sure which???
- WHAT OBD2 ECU?
- grounds/stabilizer
- intercooler fan
- IAT Sensor
- mugen valve cover
- looking for suggestions on audio in a civic dx hatch
- whats better super charged/turbo charged b16
- 99 si transmission
- quick brake conversion question
- Help with my dash swap PLEASE!!
- h22 delsol swap went well except:
- throttle sticks
- rwd civic s2000 engine
- Anyone ever modified stock Del Sol roof panel for tinted panel??
- Belt Squeak
- about to chip my jdm p30 ecu, got a couple questions! ***PICS***
- MPG conversion?
- ECU/Audio problem?
- Manual StartUp
- turbos
- anyone got pics of a 99 Si cluster fitting in an 95 eg civic?
- ODB1 ODB0 help!!!
- Lexan / Polycarbonate hatch window
- Civic Overheating?
- Skunk 2 LCAs
- 99 civic si left signals dont work!
- dpfi -> mpfi redo question
- b16 smoking problem
- Help, snapped a valve cover stud!!!
- difference of b18b1 valve covers
- 95 civc B18A1 swap.
- Need Help. Civic Throwing A CODE!
- which tranny... i know its an old topic! sorry:)
- 96 air conditioning in a 92 civic problems
- engine code 14
- CKF problem
- Is there a JDM ECU for an auto tranny SOHC d16y8 DEL SOL?
- IACV HELP????
- O-2 sensors..
- Anyone want an EG ??
- NEED THE PAINT CODE FOR CHAMPIONSHIP WHITE!!!!
- 96 del sol gsr swap
- help please..
- help not enough oil to head D16Y8
- what kind of axles do i need for my ls vtec going into a 98civic lx
- what ET do i need on my civic hatch
- really quick
- D15b VTEC on a budget
- my dad blew my engine
- 17" rims on a del sol
- 16's on an ek....
- civic ex 93 fuel pump testing
- TDC/Timing issues?
- golden eagle sleeves/labor
- 1992 Civic SI running rich????
- 92 EG 4 door with a D15b, is boost worth it?
- what engine do you have?
- OIL In Cyl #3 - SparkPlugs Coverred - Smokes A Little, Need Diagnosis
- Help idk whats wrong, cant go over 4500rpms at wot???
- Adding and/or removing a resonator
- need help!! motor help.. please
- what shocks should i get?
- will a d16z6 wiring harnes work for my obd1 ls vtec swap?
- SHOULD I TRADE MY CAR!?!?!?! PLEASE HELP ME
- timing issues please help
- i need a 92 95 civic 4dr
- Cluster Problem....
- Jdm Sir cluster quick question
- Does this look right? (56k warning)
- D16Z6 and D16A6 Water Pump Interchangable?
- Whats the take on this item here? Never seen it before.....might work well for some who arent close
- will a burnout hurt my tranny/axles?
- CM fuel filters
- Aeromotive FPR or Turbosmart FPR
- would this harness work my car?
- Lug Nut Pattern
- turbo b16 injectors
- Pistons
- My 99 civic hiccups at start-up
- air intake
- B18C - install
- need to know which is radio fuse
- d16z6 head on a 2000 civic hx?
- About to install a header, got a quickie Q
- would a bad ground cause temp gaudge to fluctuate?
- spark plug wire ?
- where to buy less expensive Oxygen sensor, '95 civic???
- Autozone Stuff
- suspension bolt rusted help.
- problem with my 2000 turbo si
- shift cables for h22 delsol
- autozone axles
- No spark....
- Yes, you heard it first... I *REGRET* not sticking to my D
- New pistons in and motor sounds mean!!
- 92 civic 134a converted, service plug problem
- Not a car problem.
- Transmission / clutch help. please!!!
- how could i fix
- I OVERHEATED!!! WTF... HELP!!!!!!
- Good coilovers for EK!!! HELP PLEASE!!
- About a suspention package for my 92 hatch,
- K&N filters...
- which intake manifold for a d16z6 engine.
- Coolant always low after 2-3 weeks?
- Integra 4wdb conversion...brakes lock up
- spun a$$ bearing.....
- i need help
- choices for exhaust system for my 92 DX with a d16 engine.
- shift linkage ???????
- Driver Side Window Trouble
- broken axles
- looking for the delsol how-to site
- help diagnose
- *confused* obd2a to obd1
- rpm question
- Suspension on an EK hatch lmk
- does ek's come with sunroof?
- wiring for a b18a1 block+b16 head (ls vtec)
- is it worth buying a "new" head for a 92 civic
- P06 non-vtec to VTEC
- plz help me
- swap is done
- my axle keeps popping out
- Will a stock 2000 prelude spring fit in a eg?
- Throwing a CEL p1362.....
- CEL !!!!!!!!!!!!!!!!!!!!!!!! SPARATICALLY
- Help! Im leaking out of my shift linkage on the tranny-
- Seat rail for SRD's *pls help a tall man out*
- Valve Adjustment
- VTEC CEL
- 2 problems with JDM B16 1st gen.
- car overheating
- del sol cluster in a eg??
- endlinks? other suspension questions
- CEL Code 23, Knock Sensor
- LX Exhaust
- Headers....Yes or No?????
- License plate question
- *Big Problem HELP!* Car backfires, cant start
- boosted b18c1 ticking/white smoke help...searched nothing came up
- Civic won't start?
- brake dust shield?
- best weight for a 95 ex tranny fluid?
- OBD2 port not working?
- just got a 98 DX.... so now what?
- Online scammer: autopartswarehouse.com
- Type R pistons w/ gsr head?
- question about civic
- advanced timing, and knocking, how to help?
- how is this hid kit?
- What Civic did these rims come from?
- how many times can you resurface a flywheel?
- Racing Steering wheel
- Compression question
- b18c owners need some help...
- Apexi NOIR owners...
- DTC 7 on a p30 chipped, it wont go away!
- Brakes.. NEED HELP!!
- ECU question... help please read (p28 manual ecuneeded, I've got paypal and $)
- 95 dx altenator?
- knocking noise under valve cover? is it valves?
- Upper Ball Joint....I Have Searched.
- A/C Bracket being a PITA 96 b16a2 civic
- lowering- is 2" too much?
- spark plug poped out =( need help...searched...
- LOOKING $ A PIC OF WHAT A STRIPPED SI (99-00) LOOKS LIKE AFTER THE HARM....
- Will a clutch from a 95 civic fit an 87 crx?
- ls ecu and vtec.... ?
- Heater cable holder (?) part number help
- What the hell is wrong with my car now?
- code 43 HELP @@#$^(@#$^()&@)#!@
- broke this bolt... any ideas why?!
- changing stage 2 cams to turbo profile- reuse valve train?
- SAFETY??? help
- which Pipe A is this...
- clank clank
- Dumb Question searched but still couldnt find-
- clutch slave ques.
- Is my engine Vtech?
- radiator problem on my eg.
- Gsr rear sway bar on EG
- b20 conversion on my 00 ek9
- Question about my new cluster
- lowering seat position...?
- PLEASE NEED A ANSWER WHAT WILL FIT?
- Use Stock Wiring Harness? B16a into EG.
- Swapping a LS into a 2000 Civic Dx
- Pulled over............COP was full of it!
- [B]Engine Swap Issue[/B]
- Guaging interest, would anyone want window visors?
- Engine rebuild - is this head trash?
- SO why did you decide to own a civic?
- Compression Numbers for Mini-Me swap and what is the ratio?
- Hondata and next step
- H22 Type S vs. B20V-tec
- Noob Question about turbokit fitment
- d15b2 problems...bad
- Del Sol Front Swap
- EM1 factory rear subframe reinforcement - yes/no?
- What to pull of a 2000 Si
- Rust forming on car
- Part number question
- Misfire and sputtering
- 00 Si shutting off while driving
- horn problems on my 94 EG
- HELP ME OUT PLEASE!!!!!!!!!!
- 98 h22a4 motor in a 94 del sol wiring help
- my civic bogs
- d4 light flashing erratically
- Will 96-00 AC lines fit an EG?
- Backfiring_how do i make my car stop backfiring?
- motor mounts need some help
- front end swap
- finished my buddys lsvtec but the motor dies when he steps on the gas!
- Hrm...is there an equation... I can't find it
- tach rpm problems???? rpms jumping around.
- fuel pump question (yes i searched)
- PIC REQUEST: OIL PICKUP GASKET B16A2
- Best Header for B16
