View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Popping noise when depressing brake pedal?
- My oil pan bolt!
- Stock airbox with ram air works?
- How do i put 00 Si Fuel Injector into JDM B16A II
- JDM Center Console and Arm Rest
- Type R suspension
- Vtec Controller
- Need help about fixing up car
- Comptech Icebox for ITR does fit into EH2, but I still have a question.
- questions for those with tenzo-r seats...
- Help with suspension noise on 00 Si?
- 99-00 Si Lip fit on eg
- craaaappp!! (more probs i guess)
- Opinions on best overall EG hatch
- question about brakes/rims
- how do i insert pics???
- Hey check out my homemade mesh grill and let me know what yall think
- Compatiblity of 5th gen exhuast systems..
- Can get this darn transmission on!
- Spark Plugs
- a 94 civic hatchbak
- HOW do you get the center console off of an EK?
- jsut installed my NSX brakes and appropriate hardware
- Question about pipeing for exhausts and General parts
- OEM SI grill for sell anyone
- Oil filters and Iridium Spark Plugs?
- Exhaust question
- Test Pipe?
- how do i post a picture?
- Good Price??? Si side sills
- what wheels are these?
- New Hondata Version s200
- Disable the "service required" lite?
- how Long until i can change my avatar?
- Help plz !! RIMS !! what the !?
- Koni Yellow Interchangeability
- 99-00 Si ECU . . .
- This a good plan for my 95 civic?
- 92-95 carpet,where can i order some.
- What header would Fit?
- low idle problem
- valve adjustment....idles wierd now.
- How do I get my emblems off
- Where did you buy your EG spoiler?
- does eibach make thousand pound springs?
- What do you consider to be a civic's arch rival?
- to paint or not to paint....that is the question
- Used/Imported JDM Wheels?
- need a 92-95 si !!!
- 96 gsr brake system to 98 hatch?
- Civic SI 2002 POWER & the AC
- is there a turbo kit for a 2002 civic ex?
- Didn't get throttle cable with my swap, Little help
- Went to the track for the first time
- any ne got the shematic for a obd2 distributor???
- has anyone ever changed the stripe on del sol seats?
- Hey, if this is all bad then please inform me....
- Bolts Seized on rear cross arm!!!!!!!!
- bolt pattern
- 'Teg door panels in 92-95 Civics?
- installed new wiring harness, now my idle is going nuts...HELP
- WTF does the Hondata intake manifold do for B series?
- will a 92 hatch si muffler bolt rite up to a 96 hatch cx?
- Where to buy Del Sol VTEC radiator (besides Honda)?
- Can anyone help me replace windows?
- anyone from houston
- Honda Recall!!!!!
- 96 Integra gauge cluster work in 94 civic????
- tranny mount bolt strip
- Well its time to buy a new header, any suggestions?
- Japanese Civic History page.... Cool!
- automatic civic throttle body
- Off-Topic... but I dont care. READ ME.
- arospeed coilovers
- ITR master cylinder swap ?'s
- Look...Possible Project.
- rear trailing arms: drum vs disc
- will this header fit?
- Venom Injectors Overall opinion?
- Vibrations and shudders???
- Dark blue EG's
- jg head
- h22a in civic + a/c & p/s = possible?
- Which D mounts can i keep when doing B swap?
- 92 CX + 95 Teg PS steering rack... What pump do i need?
- Heads up.....Importautosalvage has developed into two companies.
- EG H22 swap?
- hard starting
- anyone in dfw area going to the super street tour tonight!
- Is an AEM CAI insulated?
- suspension questions?
- ECU question
- Apexi VAFC on D15Y7?
- Manifold differences?
- Where can I get a JDM Airbox?
- injectors
- JDM B18C-R swap into my Delslow
- Next $15 mod............
- affordable suspension setup for eg...
- catalyc converter question
- scammed by GLOCK? (steve zahorsky)
- Everyone please need help for engine, toda spec a tunning ...big time
- 99 LX Auto------D4 gear light blinking???
- Good track tires
- Wierd clanking noise??????????
- IPS Fall Specials
- pic of my car what do you htink
- making the front grill
- Engines?
- Shifting Problems
- is my car running too rich?
- kyokugen lug nuts
- Rear Disc Brake, $$$? Into a 95civic....
- quick rubbing question
- Is there a difference in tension for springs made for Del Sol's and Civics'?
- where does everyone who owns an eg/ek work at?
- What is the general term for your finishing speed (MPH) in a 1/4 mile race?
- Thank you Honda-tech.com!!!!
- 92 teg GSR, what 1/4 miles times?
- why do civic si's weight so much?
- Where do the stock vaccum lines go?
- how can i instant message someone
- Rev-limiter changes on its own
- Did anyone try Throttle Body/Intake Manifold Coolant Bypass??
- Look what a 2003 Civic Si/SiR can do
- best tranny?
- REVIEW: Ground Controls/Koni Yellows + Falken Azenis......92 civic
- Prices on fiberglass parts for a 92 civic???????
- last couple axle replacement question.. i promise!
- is this worth the money??(civic cx) it has 110k
- has any body seen this civic before in your lifes
- my new car is dead
- gotta q for the del sol's owner
- Selling full D16Y Swap from a 2000 Civic. Only 40K Mi!!
- Racing seat for you and stock seat for your passenger.
- Del Cluster to Amber...
- autodynamic.com's side skirt
- Coilover Installation
- damage crank?
- vid of my exhaust LOL
- best way to take off hub nut?
- Problem: Exhaust note.
- Halogen reverse light
- OT: best clutch for 95 civic EX??
- 2000 Civic AC Controls On A 1998 Civic
- Falken Azenis sizes
- stock b16b dyno?
- The dealership loved my car and now I feel violated.
- Anyone have the "type-r" bodykit for EG hatches from autodynamic?
- H22A question.
- Del Sol seats or USDM Type R seats?
- My pictures of the Irvine Meet....
- help needed reset the airbag
- I need all your opinions on what to do....
- Intake.
- Mugen Lip
- JUN Cams: Anyone want a set?
- SOHC Tranny Options
- Is it worth it? Staying obd-II w/vafc or going OBD-I w/vafc ????
- i never made it to the irvine meet on saturday because.............
- ATTN: EK HBs with rear Integra seats.
- Powershifting...
- where can i get floor mat?
- UR flywheel Q......
- b16a vs b18c header ?
- Just to drool over. (Clean hatch :- P)
- HC5-HDSS ACT clutch, NIB!!!
- ok, those w/ mugens wheels, what lugs u use/prefer? also RNR pics....
- Can't open the hood. What to do?
- Anyone know of a place in Chicago that will do alignment on a lowered car?
- How much more gain going from ITR to GSR engine?? Worth it???
- How low can you go with TEIN SS and the ZEAL B's?
- 6 puck clutch break in Yes or No?
- Body Kits
- rear disc conversion
- Civic seats vs Integra seats
- 1992 Civic Si hatchback w/1999gsr swap----integra type r intake manifold ????
- A pic of my car. What do you guys think?
- Power Steering on 92 CX hybrid
- Motor mount prices!!!!1
- Nopi, who's going?
- Richmond, VA meat 10/5!!
- CTR cams with stock cam gears
- ips racing?
- ***Update*** I whine no more as Honda has finally dug up a brand new ITR shortblock for me.
- To "bar" or not to "bar" - that is the question?
- Anyone take there muffler off there stock 5th gen civic coupe????
- o2/mil eliminator question?
- HELP!!!!
- running jdm itr motor on p73 ecu
- ebay tie bars/strut bars
- mugen lowdown suspension
- Honda Civic Pikes Peak Video...
- Chipped P28
- valve cover question
- need help about sohc vtec turbo (not my area)
- Mini Me Setup?
- Can't fill up my gas tank.
- what makes u go from...
- stanley anyone?
- Anyone with EGs have 15s? What size tires do you have?
- Does this D-series cam look ok?
- my 1/4 mile time in my 92 hatch
- cams for d16y7?
- S2000 Gauge Cluster in 95 Civic Coupe
- what is the specs on the stock d16z6 cam?
- civic del sol pics
- Car Fax help
- ls vtec
- shift linkage help
- name this header..
- Preventing theft
- What's a good platform to swap a full ITR engine+tranny+brake/suspension? EG? EK?
- bout to b18c1 my ride... need some recommendations...
- Steering Wheel Fitment Questions
- Fixing the little door in the dash of a del Sol
- Honda Transmission Problems
- My new car =)
- power steering question
- molca salsa or the hat get together?
- my 98 civic..tell me what you think
- Differences in trims? [help!]
- Who here is looking for a 96 EK?
- vafc how do i adjust the ......
- 97 Civic DX users?
- First time at Drag Strip! my times,cars,etc.
- thinking about b16 what are yall 5th gens running?
- pics of eg's with rollcages
- Car running like crap
- 60 ft times what do u guys think i should be running
- wheel fittings and steelies
- Racing heads and porting
- is it worth it?
- Just wanted to say it had a BLAST at the meet today in IRVINE! nice cars!
- speed sensor
- Price on 94 Civic Si
- Corbeau Targa Rs
- What about this?
- h22a
- Heater problem - troubleshooting techniques for an EG heater!
- which wire do i hook up the a/f to on my o2..?
- Exhaust is spitting out crap?
- will 205/50/15 tires fit 195/55/15??
- EG Si owners....Got a question...
- fellas, i think my syncros are off!
- FS: Civic Si rear sway bar
- How much do the stock steelies weigh on 92-00 civics?
- I made my own grill. Tell me what u guys think
- blew something
- hondata's, what the f?
