View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Help on how to install radiator
- Dual Stage MBC w/ LED Light
- Head Lights dim when vtec hits (93 ex)
- what ecu to use for ls swap?
- security camera
- 92 civic questions
- Best engine to go for ... 95 Civic DX Automatic
- REAR LIP FOR 00 Civic SI???
- Anybody recover their rear package tray ( eg coupe) What did u use, pics?
- Idle surge only during warm up...
- SiR cluster work in a 93 dx civic hatch
- QUICK!!!! will a gsr aem cai fit my 98 civic ex coupe????
- EG cx hatch price
- Power washing block / tranny outside of car.
- Not Important, Just Wondering
- MY NEW CUP HOLDERS y0!...
- Will an integra dash fit in my 4dr civic? Also got a turbo question.
- What do I need to swap my 95 Civic DX from Auto to manual! Coulnd't find with search
- rear disc conversion civic question
- Jackson Racing liquid intercooling system
- installing Foglights in EK
- Will GReddy Turbo Kit work on 95 Civic DX
- What would this Ek be worth to you.
- Knock Sensor Question
- fpr on d16y7
- :: Del Sol at the track with Yoko A032...
- 93+ Coupe's running a header with 2.5" collector, how long is your cat?
- rhd front clip
- itr valves.
- HELP!!!
- confused about what gen. my b16 is?????
- ATTN:all EK owners!!!
- Draft:civic brake upgrades
- what kinda rim is this???
- Temp problems
- This may be a wierd question but...
- Performance of LS motor in Eg........
- Got a presant today
- anyone in here from spokane wa?
- Rotas and oem lugs
- cluster swap question?
- 92-95 civic ECU
- APEX springs?
- b18b 96 hatch vs rsx type s
- different dizzy plug?
- Droppin '96 Civic Which Springs Are Good?
- Remove tape deck, add compartment
- help! lsvtec burning oil!? need ht diagnosis!
- gsr cluster install help
- Brembo Blanks or Honda OEM
- Stock Airbox vs. CAI question
- Venom Intake Manifold Setup.... how to?
- does anybody know how to remove the accelerator pedal on my 98 civic hb?
- DIY corner lamp question
- No more rust on fenders?
- Which coilovers is the best for my civic 4dr?
- Stock Parts
- 2000 Civic Starts hard when fuel is low.
- *****NEED CARFAX PLEASE*****
- What to do leather seats in front ??? Options
- just a little survey....are most EG, EK owners all show or all GO!!!
- 02 sensor
- 2000 coupe tail lights fit 94 coupe?
- How much PSI (boost) are you running on 550 injectors.
- d16y7 no start
- you at this crack head delsol....
- Which Vtec controller would you recommend, Apexi or Fields??
- Si Rear Disc Conversion Help
- can main bearing caps be swapped between Z6 blocks?
- dc header= loud valves
- Recaro Speeds: how do i use my stock seat belts..............
- Headlight replacement Model Year 2000 Civic Sedan
- STR cam sprockets slipped.
- Where did u put your dynomat to stop system rattle ( civic coupe)
- clutch replacement done properly?
- Can I swap in a different ECU?
- help on a sub box for an Ek hatch....
- fast automatic?
- obd1 to obd2 complete wiring harness & gsr ecu
- help..... turbo d16 pisons
- bearings
- Where to get best deal on Fiber Images CF hood for eg hatch???
- anyone have a "type arrr" rear lip?
- buying h22a and putting it into an eg (i have got questions??)
- Gas smell from exhaust
- 98 civic hatchback clicks while doing left turns
- modding a d16y7, anyone in here with this setup?
- hooking up a switch to my fan on radiator...
- seats
- More cooling problems..(searched)
- auto to stick conversion
- Front Splitters???
- YES!!! another knock sensor question
- Miss firing? What's goin' on-HELP!?
- Are there any benefits of installing an AEM intake on my stock VX hatch?
- I need All the torque Specs for a first generation b16a?
- I need a vacuum diagram asap
- Does anybody have a TRUE pic
- fuel guage sending unit?
- How to clean Carbon Fiber?
- question about hub/brake assembly
- VX v.s. DX throttle body??? Help???
- well i wake up this morning at 5:00 and my car is gone
- half way done with b16 swap in 96ek got a few wiring q's?
- What Does It Mean If SRS Light Flashes When Jumping Ecu?
- PIC REQUEST: HONDA DEL SOL WITH ROTA CIRCUIT 8'S
- Problem?
- Rear 6x9 speakers whats a good set that have good Bass?
- D Series Transmission Tech
- 04 civic engine swap
- What's your temperature guage say?
- 94-00 teg exhaust on sedan?
- question about Si disks...
- CAT PROBLAMS, need to know length between collector and end of cat?
- **6th Gen's** Post your INTERIOR shots
- b20 block
- HELP! engine not getting spark
- d16z6 or d16y8 on a 92 cx hatch?
- Neuspeed/Koni shocks + Kyb Boot compatible? (Searched and 0 results)
- broken door lock mechanism (stuck in lock position)
- RS*R Individia (cat-back) for EG9 be worth.
- valve cover rubs hood?
- Oil change, 3000 or 7500...
- Please quit giving out mis-information
- carfax request
- weird sound after clutch install
- where can i find rota flights??
- exhaust on a 99 civic
- Nitrous on a 2000 Si
- Si muffler on EG coupe
- Do the make 1997 JDM style Black housing without those lines at the corners?
- Questions OEM Fog lights on Si
- 96-97 Black Housing 99-00 Black housing
- clutch feels wierd
- ATTN: STOLEN EK HATCH IN ATL: PLEASE LOOK OUT FOR IT!!!!
- I just got my skunk2 IM but what else do i need to complete the intake system?
- Black housing Projectors...or....JDM headlamps...
- 03 si rims on an ek hatch
- prelude cluster into a civic?
- brake not stopping like before
- Front end shaking....(not brakes)
- Re-sleeving???????
- Any benefits to ARP flywheel bolts?
- What to do? What to do?
- How to get axle back into spindle?
- 7gen ('01) civic rear brake help
- SRS Light wont go away
- A/C Question????
- b18b axels need quick answer searched
- best chip for sohc vtec
- Eagle rods and block notching?
- engine help for a b16a2................
- Opinions on this setup... thank you
- easy air/fuel ration question (for some)...
- Anyone think about to do this conversion?
- How do i tighten my E-Brake?
- Differences in Si TB and GSR TB
- Cleaning headliner
- Brakes, fluid, problem
- need a carfax
- Motor ?or well kinda
- will gsr oil pan fit a 2000 b16 motor??????
- Quick question
- greddy sp2 or something else
- NewB question: wheel fitment
- Any good shops in the NW?
- RSX and EP seats airbag blockoff plate...
- Need More Power!!!
- removing steering wheel
- wut rims for a 95 civic coupe
- idle and timing questions
- shaky steering wheel?
- JDM cat flange compared to UK/US flange Picture?
- what are those little metal pieces that the tire shop put on your car?
- RUST!!!!!!!!!!!
- I need a painter
- Si leather seats front.... but what about back do they fitt?
- tranny code for 99 b16
- ? about FL ride height laws
- really stupid noob question
- Quick Question
- Newb question on CAR BATTERIES
- Rear Bumper removal, (EM1 Coupes)
- gsr dash in a 5th gen hatch
- trans question 92-95 civic
- which cams to buy?
- need help on identifying 99-00 Si (b16a3) cams & 00-01 GSR(b18c1) cams NEED PICS
- Brand New VIS bodykit 2dr 96-98 Civic 4sale!
- Those running an ITR sway with Beaks kit. . .
- OT: 2nd Gear's Stuck!
- B16B ECU in a B16A?
- Engine Swap / State Ref
- obd1 engine side pin removal?
- heater core 93 cx ?
- Knife the stock flywheel?
- Suspension ?? *SEARCHED*
- Gauge Pod?
- My Engine Code Means What, Newbie needs help....
- what to do buy 98 prelude sh or fix del sol si
- engine codes...help
- Many Honda Parts 4 Sale
- OBX header for my stock one?
- Brake Rotors for a 96 Civic CX
- Engine Troubles
- Front Mount Intake
- Need to know decent prop valve prices, so i dont get ripped off
- Stage 2 Cams in a b16 w/ 150,000miles...??????????
- Are 94+ integra shocks the same as 92-95 civic shocks, firmness wise?
- recaros what yall think
- Need a measurement
- ? about d16y8 into a delsol
- 99 civic with d16y7 wanna be in 11's?
- where to buy a jdm / usdm tranny
- What A/C Bracket
- 95 EG sir rear disk brake work on a ek hatch?
- 96-00 civic 4 door and coupe rear seats fold down?
- tegra back seats
- Massimo Performance...Do they exist???
- warning about JUN flywheel
- replacing front caliper...help
- What should I do about my clutch
- sea foam any good to run through motor
- b18c 300 bux!?!? too good to be true?
- Type R intake question
- Dyno Results: What do you think
- Need help Removing ABS - 94 Civic SI
- R1 competition meters/gauges opinions
- Questions about starting car
- need some help, car keeps stalling when i slow down
- stock curb weight of hatch/sedan? (i searched)
- Brake vibration question for all
- Pics of my turbo ferio
- 99 sohc ecu pinout needed.
- Check out the wheels on this site!!!
- RUNNING HEADERS OUT.....HOW MUCH IS REALLY GAINED @ TRACKS???
- Front bumper removal w/o exploding the air bag?????????????????
- Question about tranny mounts for a swap
- SOcket Side marker
- how reliable is a d-series turbo setup?
- Civic Camera Bar
- Brake upgrade for 95 coupe
- what size fuse for 95 sol si brake light?
- which engine to pick?????????help desperate need of help
- What cat to use on a b16a swap into eg wih apexi exhaust sytem?
- turbo fitment with integra fluidyne radiator
- City lights for our EG's...!!! (calling all ppl who have them)
- I need your guys help(engines)
- JDM exhaust manifold
- Tire Pressure
- Problem with my clutch
