View Full Version : Honda Civic / Del Sol (1992 - 2000)
- cool "whirring" noise
- rear shock. strut question
- taking the fast idle valve off
- Problems with stock manifold
- Is a 2.5in exhaust too breathy for a nearly stock B16?
- a real dumb question but need help????
- EXHAUST VALVE? WTF
- FOGGY WINDOWS
- Emergeny Brake Light?
- I need help finding something
- 1999 Civic Si (B16A) bore?
- Tire Question (IM SORRY, I SEARCHED)
- whats the widest rim u can put into a hb and be daily driven?
- carfax
- Shocks issues?....
- Will the SRR rear lower control arms made for the EG fit on the del sol?
- Full Tune-UP D series engine
- d16z6 timing marks
- Just Got 95 civic EX what should I start with ???
- Will 2000 Si stock exhaust fit 92-95 coupe?
- parts for a motor swap
- Info on this shop in vegas..
- anyone know how loud a tsudo n1 is??
- hello, new to civics
- problem with b18a1 in 93 hb
- hondata issues
- LS TURBO QUESTION
- I know I new to this site but nonetheless I am selling some wheels. (anyone interested click here)
- Easy Wiring Question
- My 94 civic si hatch
- Need Battery Relocation Advise ASAP
- b18b1 swap into 99 ex
- Pann Auto in San Diego any good?
- how many speakers in a del sol
- what distributor do i need
- cleaning intake manifold
- Official Clutch Review Thread
- which valve springs for zex 59300 cam
- Tire sizes
- Venom Intake manifold + Welded Collant TB, Do I need the IACV...
- The aftermath of my baby being stolen *PICS*
- anybody know what mount this is
- Tranny install ?s
- question about brakes and the metal clips
- engine ?
- crower cams and civics???
- manual conversion
- Aero Turbine muffler...
- Running really rich at low rpms??? Car is not acting right!
- anyone know anything about these?
- Anybody using del Sol headlight covers?
- Guys without heat in your cars what are you using for heat?
- b16a2 making weird noises....
- --- NEED HELP ASAP!! P75 users ---
- Latest Korbach Frame Lock Review
- gas?
- Converting my 92 hatch to 4 wheel drive
- pulley kit
- engine needed
- Seat belt retraction 92-95 civic and 93 del sol.
- car is running sluggish at low RPM
- B16 transmission
- WhichStock Springs are for the front and which for the Rear?
- Just wanna say thanks to everyone
- Want some suggestion on what to do with my Del Sol
- question about tranny?
- Civic VX failed NOx, EGR system not working
- Low Beam Headlights Dont Work? Civic 01
- instrument panel/dash
- Del sol Side panel
- b16a question
- What is the best and most effective way to remove tint from the rear window?
- bad bearing in tranny d16z6??
- Turbo inf.?
- which wheels?
- Info for people without reciepts for aftermarket products if car gets jacked
- Nitrous Bottle Needs to be Filled in San Antonio
- bad tranny bad gas mileage???
- A few SI questions
- Help needed with stock cam specifications..
- Q? about civic EX
- QUICK LSD Question
- Howling noise on RPM reduction
- PCV system/Breather hose question
- o2 sensor repair ?
- Airbag Removal is a Felony? and discussing other stupid laws in California
- steering wheel quick release?
- ctr rear lca's?
- wheel size
- dx to ex tranny swap
- Will rear EJ1 springs go into EH3's rear?
- shaking on 2nd gear on my ej Help!!!!
- where do i buy a 2nd gear synchro
- ANTI-THEIFT
- Clutch problem when car is not driven for a while
- b18 swap?
- water somewhere.. ?!?! help
- JDM H23A question
- List of trannies
- White reverse lights are flickering
- sudden battery dying problem in EG
- Need to know
- ferio door panels
- Check Engine Promblem! OBDII P0133 Promblem!
- 99 Stock Radio
- brake pedal goes to floor
- One month and about a 1,000 miles later
- spotted: black eg in northern illinois.. are you on h-t?
- hella supertone install in 99si
- Auto ECU to manual
- Got speeding ticket, need speedo calibrated....help...
- reading cel code vid ?
- Power Steering Question (High Pressure Hose)
- hatch/coupe 1/4 transferable?
- B16A VS B16 SIR2
- jdm poses have gotten out of hand...
- Welp i guess i can join the "blow'd up motor club"
- how much does a del sol weigh
- Suggestions
- Car Stolen
- How much does it cost to repair a blown head gasket?
- Help with my buddy's Civic!
- Messed up needle
- will a 93-96 cf del sol hood fit a 92- 95 hatch?
- help w/ radio wireharness
- after hydrid swap reverse lights didn't work
- need help! whats the DL on tsudo on ebay??
- PROBLEMS! Please help!
- CEL code 67 on an EK, whats it mean?
- Throttle body whistle
- disc brake conversion how to ...help!!!!!! confused
- no spark?????
- Want to find a wing but cant...
- CEL won't go off
- Clearance of forums
- Anyone have a Stock bumper for a 95 civic coupe?
- turbo set up questions
- real weights
- best flywheel????
- Should used cams be prepared for storage?
- How to access open door switch for unique lighting applications
- What remote to get?
- Need help... Car is idling at 0 rpms and is engaging vtec late
- Please help with console
- Pricing on civic 95 maintenance
- SRS airbag light
- Trannies in a 95 Civic Coupe
- 96-98 radio-side pocket.
- how bad is fiberglass really?
- Getting ready to put on my exhaust tomorrow
- camber kits?
- B20 into del sol – shopping list « »
- '99 Si gauge cluster in a '93 eg hatch?
- What engine is in my civic
- How to find out if your engine is stolen
- Smashed Mirror
- Which aem cai with skunk2 on gsr.
- would prelude 5lug fit a EK?
- AC question
- Crap...
- EP seats in EK, will center armrest fit?
- blew the motor
- starter issues
- how about skunk2 ?
- HELP! full coilover problem
- which b-series headers bolt to stock civic cat 92-95
- crx seats?
- CEL 45 Fuel system too rich/lean & SRS blinks "10" & "3" TECH HELP
- I THINK I GOT SCREWED!!
- Hemls repair manual for 03 civic
- Any DIY transmission fluid change procedure?
- What is recommended synthetic egine oil for 95 civic LX?
- Any other good forun for Honda Civic beside this one?
- need help with dss axels
- Can I take my 1989 camry seats and put them on 95 honda civic LX?
- changed interior and now there's problems.
- uberdata? who invented it?
- Civic EX/Si Shocks/Springs Question
- Hi.I am new here. Where can I get more topic on 95 civic.
- Fuel filter and transmission
- question about injectors
- SRS light wont go off
- tilted catback
- anyone running ls/vtec or b20/vtec?
- p28 in a 95 vx...
- DC SPORTS Lower Tie bar from Integra to EK4?
- My EG broken into AGAIN
- rotor installation
- Rear defroster
- Whats Wrong With My Brakes.....
- Changing dash lights: climate control, gauges, etc
- SOHC Turbo
- b18c5 into eg..searched 2 hrs.. what I know so far.
- NEED HELP ON EVERYTHING(1st car)
- Need help with 99 Si headunit
- D16y8, install CD player- car wont start
- got er done.................thanks to all ..........more...
- Del Sol yellow aux lights?
- 92-00 and 99-00 SI any difference?
- headlamp relay...
- need some info about valve spring, B16A
- B17a1 Oil Pan?
- Greddy Exhaust?
- accord 01 CD player fit my 95 civic?
- abs brakes
- Small clip of my b16 eg doing a pass
- wiring up vtec soleniod Which wire is the ground.
- What are some good traction control bars.
- Civic Sway Bars
- question about removing tranny.
- a few Q's bout B18B into EJ8.***searched***
- Head codes: PR3-X....
- Tokico HP strut
- how to install shiftlight?
- 300zx turbo on a B16A2?
- installing gauges in eg hatch
- Springs problem
- what wheels
- help with obx lsd install..
- what do you really use your vafc/safc for?
- recommended honda repair shops, New York
- building a head
- Motor mount question
- how to program remote without factory cd player on '99 civic
- interior diagram of a del Sol door
- TOP FUEL POWER NEO
- Gauge Cluster Problem - 92 Eg hatch
- stage 1 crower cam?
- Tie bar on 97 Civic DX
- check code on 96 civic??? possible and where
- Strange ad in some of the topics....
- how do i adjust my b &m fpr?
- [FAQ] Understanding How A/F Gauges Work
- Just finished swap (3rd swap) Now drivers side headlights, tailights and signal malfunctioning.
- APEXI POWER INTAKE
- rigid 3pt strut fitment help
- Will raising my compression do anything for me right now?
- Del sol gas mileage???
- Evasive Motorsports Carbon Fiber Hood, Searched
- when i am driving, and i hit the gas the rpms dont go above 4000? need help bad
- HONDA CIVC MOTOR SWAP WITH THE SRT-4 or LANCER EVO!!!
- is it worth buyin a ex-turboed JDM second gen B16A???
- 195/60/15 winter tires...too big for eg coupe?
- Installing temp gauge in eg hatch
- Help!!!HELP111HeLp !!!!!
- JDM EG8 Question
- LSD ?'s from Civic newb....brands...
- RIM TOUCH UP PAINT
- help!!!
- Pics of timing belt damage....not tooo bad...
