View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Honda Precision 440cc fuel injectors?! Fitment problems?
- 93 del sol rear disc swap shopping list...
- Lower ball joint removal on 95 ex?
- pinging in overdrive or a low gear while accerating?
- LS-VTEC No Spark ICM problem?
- Need Help With AEM Uego wideband
- VSM EJ8 2010 Update !
- My Del Sol won't start
- PICS of Integra AEM CAI, in an EG.
- tuning
- Electric problem on my 97 Hatch
- injector question ??
- vtec controller or ecu tuning? differences?
- head swap questions...
- ek stock air filter/housing
- b18b swap, cheap???
- My samba green del sol, bad pics.
- help with interchange
- New distributor cap issues???
- honda del sol heater blowin cold air
- b18c1 turns over but wont start.help
- Newbie question about "I/H/E"...
- 2000 Civic Si - New Member from Kansas City
- Blocked Immobiliser on 2000 Civic Vti EK4
- removing abs on a 93 del sol.....
- 1999 civic SI- does it have ABS in rear
- 5 speed conversion
- Help With Wiring!!
- 93 Civic Dx Passenger Side Fender
- turn signals not working on 00 si.. help please
- Axle question
- looking for it.
- Coolant leak arount alternator ?
- Overheating thermostat question?
- Turbo size
- leaking antifreeze from bolt in blockloosing antifreeze threw back of block??
- Strange problem after installing glow gauges on del sol
- 1998 Honda Civic Electrical Problem
- Car idling funny
- heater problem, Im hoping it not the heater core.
- Ground Problem
- can i swap lca's
- ground question...!!!!
- New from Indiana
- EK floor mats
- installing remote start need input.
- in-dash wiring harness
- Info needed on Engines & Parts
- Wheel bearings are going out on the sol, swap to rear discs now?
- S20 / S40 Hybrid - Can't get housing together
- obd1 z6 in an obd2a 96 civic, what to expect?
- where can i get this diffuser?
- sunroof help
- 95 civic idle tried alot of things
- Silencer Fitment
- 96-98 Civic How to change ac lights????
- Need HELP with B18C
- problem with my SI gauge (rpm)
- upgrade camshaft for d16y8
- pcv black box, where do the lines go? one to back of block and other to??
- Climate bulb went out.
- GC/KONI SPRING RATES????
- Determining Cause of Squeeks?
- need help for basemap
- i i put my eg forks on ef front shocks thell fit on my eg right?
- What COilovers should i GET??
- Wild electrical problems...I think?
- RSX Type S steering wheel in an EG?
- boosted coupe b16 swap
- ACL Or OEM rod bearings
- Are EK 4drs and EK 2drs(hatchback) parts interchangeable?
- Looking For Help About My Civic.
- Your eBay Turbo Kit Opinions/Suggestions
- Getting seats: Integra vs. Prelude
- Del Sol mud flaps?
- EK Axleback on EG?
- 99 ex civic motor mount up tp a 95 cvic tranny?
- Will this hinder performance? (exhaust related)
- 1999 Honda Civic EX engine swap
- 1999 Honda Civic F20b cold start problem...
- SUPER FRUSTRATING ISB JOB
- tuning b16a
- Stock B16
- Steering wheel when cold
- started my first build need advice
- need 92 civic sedan
- 96 Civic Emissions Help
- Stubborn Crank Pulley Bolt
- Are B series VSS's the same for manual transmission?
- blown civic mb2
- need help
- SI gauge problem
- D15B2 Wont Start.
- pcv and catch can installation help!! PICS**
- how many bolt on pcv box?
- Please Need some Feed back!!!!
- Looking for y8, all I can find is sohc d15 vtec 4sale
- 1999 civic ex, 2 quick questions
- Why is it hard to shift in my Civic Si (EH3) ?
- k24 on a 4dr civic
- Another question for the EK Hatch pros:
- c-fiber del sol?
- Broken lock...inside
- EK Sidemarkers Bulb
- b18b1 in limp mode?
- Need help dose a dc2 teggy brake master cylinder fit on my 2000 dx civic???l
- b20vtec high compression engine
- Crank pully tool
- ANYONE DONE A 5 LUG SWAP ON EM1?HELP
- em1 shift knob compared to ej8 shift knob
- ecu differences?
- Carbon Fiber Hood Problem
- b16 cable trans
- jdmb18c head build
- 99 EK
- front lips abs or poly
- bog/mis/hesitation UNDER 2500 RPM ONLY!!
- Tokico Illumina & GC reassembly order
- TPS won't calibrate correctly.
- boosted stroker kit?
- ecu pinout HELP!!!
- 99 fogs installed... but wont work!
- need help on harness
- D16Y7 tranny to D16Z6 block
- 01 gsr in 95 eg
- rev-limit/ecu/speedo problem update..
- need help bad please!!
- Crazy lost of water in radiator..
- p2p in em1 (explanation inside)
- Jumper Harness problems
- My Civic Gsr stalled and won't start? any advice HT?
- 92 Civic Hatch Electrical Problems
- dead batteries, cut wires and constant draw..what gives??
- Help:: My car is bogging/struggling on start up??
- Del Sol or Coupe
- My JDM SiR EG hatch
- 1998 Civic EX 4 door - what rear seats from other honda's are interchangeable?
- parking lights work but not brake light
- engine wont start
- ::TURBO b16 or TURBO H22::
- trying to remove PS but..
- H22 EG Hatch Build (56K = BAD IDEA)
- Best Price For B16 Motor?
- Where to find primary O2 plug?
- muffler question..
- help me out
- radiator fan not working
- b20vtec in ek hatch helpppp!!!!
- HELP Cluster
- B18c Type r in Ek hatch Running good... then bad..... then good.....then bad...
- Having issues starting car...
- b20vtec tune cost? good tuners in L.a?
- EG hatch KEEPS DYING!? WTF?!?!?!?!?!
- What are these wires for? 97 Del sol S
- b20vtec smog check
- quick help manual vs auto
- HELPPPP!!!!
- eg and ek hubs..
- 97 civic w/ jdm gsr throwing 3 cel codes
- Subwoofer Question
- What does this green light mean in my cluster?
- Swap Question 00si into 98dx
- HELP!!!!! tps issue?
- Car won't start after installing spoon ECU
- Civic vs integra windsheilds
- car will not start
- smallest diameter rims ej
- B18C Swap, Rear Engine Mount
- Heat Works A/C Doesn't
- DIY 95 civic lx dash swap to 95 ex
- Turbo GSR in 92 EG Hatch build
- heat and AC MODE control not working..help
- b20 type r turbo problems
- Mismatching Keys
- B18B + manual trans swap into 93 EG, Automatic!
- Identifying ECU's
- HOW TO: RSX windshield washers onto 96-00 Civic
- Where do you add automatic transmission fluid in 92-95 honda civic?
- delsol seat ?
- Speedometer Needle Jumps
- Car broke this morning
- New Mexico b16
- short ram intake noise
- here's a good laugh
- Wheel squealing when turned
- cold water spray on hot engine bay?result
- del sol logo-ish, need help finding
- HELP!!!!
- keyless door handles on 96-00 civic hatch
- cabin harness question
- 94+ GSR cluster in 6th gen Civic
- 10,000$ later...
- 99-00 civic headlight help
- Valve tick when WARM?
- short hub question..
- Progress On My Hatch Build
- need help. 5 speed to auto and overheating
- Swaps: how to determine if there legit...
- removing the emmision
- ENGINE WONT START!! HELP
- SUSPENSION PLZ ADVS THX !!!! (HELP)
- D16Z6 VTEC Solenoid Gasket Part#? Does ANYONE know?
- Del Sol Conversions~YOURS/MINEZ
- Please set me straight on 92-95 LCA/toe link vs 96-00.
- EG CIVIC EXTREMELY SOFT BRAKES
- 96-97 del sol cluster in a 95
- Honda civic cx
- Crazy MPG loss since new tires & alignment?!
- ECM/PCM Location?
- 96ek coupe
- CODE "0" HELP!!
- D16z6, dies on hot starts!?
- Race with a mustang.
- Please help!! 2 problems
- Wheel/tire decisions
- Skunk2 IM Clearence on a H22A Del Sol
- car cranks but will not turn over 94 Civic LX
- jdm 92 si eg b18c turbo build
- crx seats
- Need HELP..civic b16a2 obd2 intake vacuum hose
- Side mirror question
- Question for all the EK gurus out there...
- turbo ek
- DC cluster in EG dash? Cant find the post!!
- vss questions, help needed plz...
- Need help with putting Rear bench back in..
- D Series Parts Compatibility
- Stroker Kits
- 92 civic hb carpet help!!!
- bent rear subframe.
- Steering wheel
- undecided on headlights need help...
- rebuild questions
- B16A Head Gasket Change
- ECU problems, please help! :(
- power steering coming out of Boot?
- power windows conversion
- My Intro: Just bought a 97 EK Hatch
- A/C bracket for my LS into EK swap
- b series axles
- 93 civic idle issue HELP :|
- 93 CIVIC EX runs lousy when warm....
- Tail end wants to swing out while driving
- s2000 seats fit?
- Integra Alternators Differences
- purges
- new to forum need help
- 94 Civic SiR
- eg with integra axleback?
