View Full Version : Honda Civic / Del Sol (1992 - 2000)
- smoke from spark plugs
- Help Codes PO730 & PO740
- Does the front fender from a coupe fit a hatch? EG series?
- d16y8 IM
- Suspention Question (online store)
- WTF can hold the crank pulley so I can get the bolt off??
- d16y8 Swap
- wheel adapter
- engine rust
- HID Installation!
- My Clutch Sqeaks.... Possible Problem?
- In need of Rails for my Recaro's, someone help shoot me a link
- Del Sol Headlights
- I am new to Del Sols, can anyone help me with this...
- Why are there three missing lights on the guage cluster?
- How To Adjust HIDs...
- freight cost for shipping a usdm h22a1 cost 600-900 dollars!!!?!?!?!?!?
- rear window defroster 97 civic
- Noob needing help for a start up switch
- Field Vtec/air to fuel controller questions!!
- EG HB or EG Sol?
- building a z6 block, from the ground up. need a part list.
- need help removing a z6 intake manifold
- post swap charging issue for b18c1
- Header INSTALL HELP
- Rear Carpet for gutted EG Hatches...
- 03 Civic EX - Electrical issue after body / engine repairs
- Del Sol seat cushion
- How can you tell if your ECU is junk?
- Replacing your front LCA on a 99 Civic Si?????
- HELP!!! Right Turn Signal Wont Light Up In Cluster!?!?!?!?
- Carbon fiber del sol reflector scoop thingy' - your thoughts'
- Del Sol Exhaust Question
- civic springs or teg springs
- White smoke at 5500 RPM
- Interior Carpet
- b18c1 air/fuel/throttle lag inquiry for a newbie
- pic test
- Civic Si
- EK Clutch Question
- Spark plugs not getting spark.
- what intake to install 95 civic with jdm type R engine
- Carbon Fiber Doors
- Where did u get your car re-sprayed?
- Tranny help
- B.A.R. Question (california ppls)
- would a jdm type R tranny mount attach to a 95 civic ex coupe
- problems with B18C5 / EG Swap?
- How do you break in a Motor?
- Is the TPS plug the same on all 96-00 Civics?
- Tail light swap help
- Rotors
- grinding when IN gear?
- D16y8 swap into 92 DX which distributor?
- My brakes are messed...help please!
- ANYONE HEARD OF K-SPORT FULL SUSPENSION?
- knock sensor question..???
- headlight intallation??
- passenger side air bag removal
- What are the steps in installing projector headlighs?
- scrapping noise, i'm thinking it's the axle...
- HELP: my dashboard predicament
- HELP on removing stock spring from strut.
- which tach - autometer or pivot
- Fix up a 1990 240sx or a 1999 Civic Si
- Front suspension changeover...help...
- Mushy feeling when accelerating
- E-brake button sticking
- Honda Civic Sedan Air Conditioner is acting weird
- Am I being offered a fair price (95 Del Sol)?
- Filling Tranny
- do i need to replace my engine block?
- road trip anyone?
- ? for Pro shift light !!
- Need help with shift light!
- suspension grinding
- Idle problem can anybody help
- Dome Light / Map Light Does Not Work
- ecu code 23????
- Slip over Coilovers
- how???
- Header leak causing power loss?
- d series s20 gear box help me find lsd
- Lookin for that wide tire aggressive look...minus the moolahh$$$$
- will these fit on my car?
- New Sol owner, help with parts...
- Want to put Big Brake kit on my 1993 Civic CX.......???
- camber kit problem
- Please help, acceleration problem
- idle problem..engine shut off...!!!
- TEIN Flex or OmniPower coilovers?
- mini-me swap
- help gsr brake conversion on an eg
- Type R/Accord Wagon front brakes on EG HELP...
- I cant find the snyper bumper anywhere for the civic
- CEL Code After Air/Fuel Gauge Install
- who's removed there charcoal canister?
- Clutch Problem..need advice
- aftermarket shoes for rear drums?
- will 185/70SR14 fit on my 1994 cx hatch?
- New To Boards / New Car
- h22 swap in ek hatch. axles??
- Can someone tell me what CEL this is, small video.....
- difference between B series and D series
- loud popping sound?
- Going to do y7/y8 mini me swap.
- how do I remove the height adjust knobs on my drivers seat?
- Handa Accessories?
- will a header for an EF fit my 92 si?
- Electrical issues
- Changing Auto Tranny Gears
- JDM side marker help
- can timing change without adjusting it?
- autometer gauges hookup
- Need help failed emissions
- Should I get a del sol?
- tein s-tech + kyb gr2's + 205/40/17's = HOW MUCH TIRE RUB
- JDM obd2a ecu question!? help!
- Is this right??
- 93 Integra Burnout!!!
- wheel hop
- Quick question on removal of Del sol brackets
- Gauge Cluster question
- is it possible to rebuild a differential??
- aftermarket wheels can be reason of broken wheel bearing?!?
- ITR sideskirts on civic coupe
- Who's using the fake fake j's racing intake??
- removing "CIVIC EX" sticker
- eg rear wheel disk break converison
- alignment question...what should i set the toe to?
- 95 del sol si sohc
- tires
- HOW TO PROPERLY PREPARE A MOTOR FOR A LONG STORAGE???
- spoon hood
- How To: Install Access visors on an EG
- PIC REQUEST
- Quick question: need links for body kit
- turbo muffler on n/a car
- hydro-locked :-/
- Air/defrost problems
- a-pillar:del sol & civic
- Gauge CLuster quit Working
- Will a bad IAT cause my car to bogg and stall?
- car won't start
- What is a good cam for my boosted d15b?
- civic 1,6 esi engine trouble
- Your thoughts on a B20
- New Fram Airhog filters
- LS mesh rims
- any hp difrence in the b16a2
- del sol shift linkage
- Darn Oil Bolt
- maintenance question
- where to find oem style aftermarket side skirts for a 99 si?
- Rear Hatch Template
- question about pulling a vacuum on AC system
- problems with muffler?!
- Does the 92 95 Civic and Del Sol have the same radiator?
- buddy club pro spec exhaust
- Del Sol Auto Trunk Release
- 2.5" on b18b1... anyway to keep it quiet if its N/A?
- rear disc brake conversion parts list
- gas milage mods
- d16z6 compression ratio? its in my friends 92 civic hatch SI V-tec
- Honda script emblem
- TB Bypass on a 98 civic EX
- I was totally wondering ... wasnt sure were to put this....
- 205/40/17 or 205/45/17
- Slicks? on stock axles
- Differences between HF and SI harness??
- tail light question
- Spoon mirrors?
- Question about passenger window?????
- Canadian Honda's?? WTF
- My new Coupe?
- LS Automatic into 95 Civic Ex
- which are better cams ctr or itr could someone help me...need to get some????
- jdm p13 have vtm wire for apexi vafc I hook up?
- How reliable are the CVT transmissions on Civics
- !!! Need Help !!! ... to remove steering and accessories
- anyone have a pic of black gsr front and rear seats in their hatch?
- maintanance required
- My car is idling weird and barely driving HELP!
- emissions and retarding the timing
- im worried about spending so much on swap
- vafc uninstall help
- 99-00 Civic oem fog lights
- cut bumpstops???? tried searching
- ef3/9 rear disks on eh2?
- selling an eh2 shell
- JDM b16 smog??
- Best Camber kit
- Where to get used si rims, i need 2 more?/ Also got a great deal on some si rim
- How many post
- VIN number
- Keyless entry problem...
- Someone help with type-r throttle body and skunk2 manifold on my B20....
- Help Quick (IAT) sensor
- B18A CABLE TRANNY IN 93 DEL SOL
- questions about my HIDs
- Got my p28... now which chip for my b18c swap...VTEC xover point? Rev limit?
- 1993 Civic Won't Start
- Ran with a kinked valve breather hose, now i overheat!!
- will 96-00 2 door coupe Tweeter speaker fit in a 4 door sedan?
- EP brake callipers on an EG?
- My 94 Civic cought on fire...
- anti-sway bar kits
- Changing front brakes
- ride hieght and lowering question?
- jdm b18cr 98 spec, stock headers, cat, custom 2.5" piping, and magnaflow race series exhaust
- Is this a good deal?
- Help me find this part!
- help me plz!!!
- -=-Dropzone Coilovers-=-
- mad shit for sale...u dont wanna skip this
- OMG a n00ber
- 98 civic EX map sensor problems
- Engine knocking
- Needed part number for 95 CX waterpump and what timing belt kits available?
- FUEL INJECTOR SIZES AND SWAP INFO????
- FAQ-98 Civic EX (check engine light- code P1456)
- How to bleed the clutch ?
- does any lsd fit a d13b2 93 civic oz
- FUEL PRESSURE ??????
- For a Friend in dire need!!!!
- lsd
- Help me
- How much should i lower? Pictures please!!!
- VSS Not Working
- Legalize motor swap
- Anybody have a 99-00 si with turbo or s/c ?
- Alright so I think im going with an ls for my 94* cx
- 2000 EX come with rear disk?
- wheels,audio,taillights for sale soon (civic)
- Honda User Manual
- alternator from 95 civic dx to 95 teg ls
- Good All season goodyears or dunlops?
- Emissions testing. Help
- Minnesota Import Shops and Dealers
- Need to remove IntakeMani...will i need new IM gasket?
- Skunk2 Intake Manifold...
- where is the sun roof motor at ?
- Turbo SOHC or LS/Vtec
- INTAKE MANIFOLD
- Suspension Confusion to the MAX
- Omnipower coilovers VS. my current setup
- newb question
- Ground Control Upper Mounts?
- My car can't start, tried everything... wanna cry...
- Are D15Z1 rods the same as D16 rods?
