View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 99-00 Si abs or no?
- i know 92's are wired for vtec but......anyone got the answer
- differences in exhaust between eg and ek hatch backs
- SRS Light Question
- Searched, researched... Door honge pins?
- Cranks.
- Power window (Searched)
- Daily driver suspension
- Engine Oil as Transmission Fluid!?
- Ctr thin side moldings
- Timing issue! Help!
- Wiring problem NEED HELP ASAP
- spark plugs
- crazy idle! drop as soon as car comes to a complete stop HELP!
- fast and furious 3?
- cluster clock problem
- Quick question need answer ASAP
- battery died
- Question abuot intake manifold??
- Need help hit curb!!
- Clutch Pedal Adjustment on '00 Si
- Retro-Fit TSX projector hids into 92 hatch with stock headlights?
- SPARKPLUG WIRES HELP
- I Need Help
- prelude and type R brake clearance...
- What Ignitor Will Work In My Civic?
- d16z6 vtec not workin
- b-series axles
- Del Sol MAP Sensor
- ls tranny shift linkage
- I don't know whether to do my exhaust myself or not...
- tires Bald inside
- Megan Drift Spec exhaust?
- advice, axle-back muffler for '00 hatch to match hks pipes from cat-back
- How do i install front grill mesh?
- i need help bad !!!!!!!!!!!! (already have searched)
- timing belt question
- ticking sound + b16a3
- my friend's tranny is shot in his '00 Si...will a GSR tranny work?
- Selling my Sol
- Are the fuel pump assemblys different between a 92-95 civic and 94 delsol?
- 93 dx auto to manual with a b serie swap
- New Bentley GTC
- how do i shim my oil pump?
- H22A vs B18c5
- Car still hesitating badley Need help badly!!!!!
- Does this sound like a good price?
- New build first start up and bogs out and dies, need help plz
- Whats the best TB and IM for z6 head?
- Need help: Helms manual for EG in pdf format
- Restart of B16 A2 rally civic
- y8 manifold on y7 head
- ECU and/or CAS problems
- IS MY TRANNY BLOWN, HOW TO KNOW?!?!
- Is a d16y7 crank main interchangeable with a Z6?
- will a 5th gen prelude steering wheel fit an ek
- act stage 2 ????'s i think its foxed
- EK Type R cams??
- Need to know where the fuel pump fuse for eg6 95
- hks boost controller install HELP!
- OBD2 to OBD1-Motor swap
- S2000 TB on Y8 Manifold?!?
- LS exhaust help
- skunk 2 mani vs obx mani
- Opening up 96-00 hatchback tail lights?
- anyone wanna trade there 2dr for my 4dr?
- ITR TB and IM on z6 head???
- HELP!! temp. guage gets to 3/4 before fan comes on!!!!
- Exhaust Help.
- b18c ->eg shift linkage question.
- injectors or fuel filter
- need a little help on a lsvtec turbo swap
- CLUTCH PROBLEMS help me please!!!!!!!!
- 95 Civic headlight chime
- NOS Window Switch Question
- Brand new B16 turns over but sounds like no compression
- JDM motorized trunk pics
- what does the rear t-bracket mount onto on the engine? (pic?)
- Looking for a replica C-west for 96-98
- PIC REQUEST: eg rear motor mount assembly!
- No Low End Power
- CTR rear sway bar?
- major problem with new tien suspension on a H22 swap
- Cable to Hydrolic transmission
- Colored Lug Nut Thread
- H or B Series
- Can i use a jdm automatic P30 ECM in my 92 si 5 speed B16????Help
- what happens if theres air in the hydro clutch system?
- !!!!!Stolen Car Alert!!!!!! Northeast Philadelphia
- what is the best suspension for a cx hatch??
- Cneter Caps question?
- Brake Issues on Civic EG
- question searched
- 00 B16B into 99ex wiring help please...
- DA forks on EK
- for those of you who didn't think there was justice
- ~^~ is this a good price????? ~^~
- WTB: STOCK CIVIC SPRING
- electrical problem
- More power out of my 97 dx
- Clutch Problem
- help me out here
- wirring harness
- Reverse lights dont work? (searched)
- EG Front Swaybar & H brace ?s
- Are my gauges suppose to be amber?
- Will this chip on the crank pulley hurt anything?
- Plz help on a 95 Civic
- Autozone wouldn't help my ass!
- D-Series Tranny Gear Swapping ?'s
- i guess its a noob q.
- rear quarter panel glass
- **boosted H22 in eg** pic and question request
- 96 Integra LS tranny 4 sale $500obo
- odb 1 or odb 2 alternator??
- ls vtec in an EK
- *PICS REQUEST* JohnnyRace 6" Intercooler + 92-95 Sedan w/ foglights?
- Type R intake on a SOHC engine
- will a SAFC II work in my car?
- amber corners difference
- Car produce rotten eggs smell!! And bogg'n on 2nd GEAR!
- hx motor into an ex?
- EK Sidemarkers Wiring Questions
- simple question...just need an answer
- jdm type r swap? try to get oem ecu, or just a chipped p28? and other questions
- ac not working
- Sub frame tear...where to get it fixed?
- how do u post pics
- sri question
- 96-98 ECU???????
- Engine Check Light
- 97 Civic LX 02 problem......
- speedo bouncing and strange ticking/banging noise at startup?
- radiator hose
- What are the best ways to get more power out of a D15B7 motor
- what alternators will fit on my d series? ASAP
- Where can I get Mr. Alex parts from?
- what motor to build?
- i spun a rod bearing and need some help..
- OEM Steering Wheel options AND keep cruise control
- EK9 springs and shocks on EK3 hatch
- just fired the h23vtec up for the 1st time
- Find Car Specifications by VIN
- b16 head advice
- Transmission....
- CEL code 43 and acceleration problems?
- Trying to find another project car!!
- looking for new interior pieces!
- tuning with bolt ons?
- SI RED, and milano red.
- new rear quarter panels
- Question on a Tick.
- read another thread..just a little FYI for noobs..
- MOTOR SWAP QUESTION
- is it possible to retrofit a gs400 hid kit into 96-00 civic
- removing axle from halfshaft
- light bulbs??
- My Civic's givin me a Headache
- Will HX rims fit on my 2000 EX?
- Headers $ ?
- Transmission Help
- how many 02 sensors for a gsr motor
- Daylight running lights???
- EJ8, EH9, EM1... Wtf is this shit?
- civic 99 si w/itr b18c swap and with 3 inch exhaust piping
- I thought it was clutch release...HELP!!!!
- hesitation problem
- Best Motor for an EK??
- New to the board, question about my 92 sedan dx
- bumper support question
- obd2 code 10 or po113 intake air temperature high input help
- THROTTLE BODY question!
- Color Code Question
- Question with timing belt cover.
- i need info about civics EG EJ EH
- my clock resets when i turn off the car!
- Quick Headlight Question
- will this cat work?
- 97 civic axle back muffler length?
- replaceing 16y7 headers with y8?
- H22a resistor box missing
- struts / lowering
- vtech
- JDM to USDM wiring harness
- Atlanta Emissions ASAP!!!!!
- Ek coupe
- Starter won't engage - need help!
- Problem with my radiator fan, goes off and on after the key is out of ignition
- How do the fuction form coilovers ride?
- Clutch Springs and engine "movement"
- flywheel torqing
- OBD0 LS into a EG- HELP
- noob question
- y8 cam in z6, milled head timing questions?
- 92 - 95 Civic Hatchback Side Skirt???
- 5 lug in eh hatch help!!!
- diagrams for passenger door locking mechanism
- Resonator out
- cluster items not working right on a 99-00 EK
- highest CR that anyone has passed smog with?
- b-series mount
- b series mounts for EM2?
- D-SERIES VTEC?????
- How much heavier IS a 4dr over a hatchback?
- b-series axle question
- AEM FPR/Fuel rail help?!
- single or dual bend short shifter?
- D15B(JDM) with PM3-12 Head code
- 00 civic strut bars?
- Rubbing noise please help
- Bypass clutch switch?
- clicking noise? Delsol?
- indash dvd player in delsol?
- Which wires are which on VTEC solenoid, Pic inside
- vtec wire on a p30 searched cant find anything
- GSR in EK heater hoses
- 96 civic coupe 4/SALE!
- 96 civic 00 front end help pls
- radiator fan problem?
- Which setup is better?
- how to tell if your car is JDM without looking at code on block
- Detonation Problem
- b18 swap
- RIP My 98 Civic EX 4-26-06
- Lower Radiator Hoses
- Problem with my b16
- Swap Help EK w/ B18C1 + EG w/ D16Y8
- quicky on using metal breather hose or new rubber
- what motor would make my e.g. fast!
- Brake Calipers
- Haters in San Diego. Radio stolen.
- Help 99 civic cx brackets?
- B16 engine wiring harness. Before or after putting motor in?
- oil catch can install???
- 02 sensor
- is this normal?
- Carbon Fiber - Recoating?
- type r exhaust
- Cheapest place to get the J's Racing intake?
- comptech itr intake on swapped ek
- itr wire install in eg?
- Help!!! Civic Runs on 2 cylinders?????????
- crooked steering wheel
- Help My Brake lights are trippin
- underdrive pulleys HELP
- Auto to 5 speed conversion
- air bag disconnect
- oka i just got a B16a2 for my 93 honda civic HB i got some Blox stage1 cams but how can i tell which
