View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Funny smell and winding noise
- Lower Spring Questions??
- Current drain test?
- Question about 99 Civic climate control?
- Seat question, searched with no avail... :(
- awd civic
- Revaping my 93 civic 2dr coupe need help.
- ECU problems. need help (CEL)
- Window Tint Question
- Apex World Sport & the Sol's....
- Quick Dizzy question
- Black or Black with silver lip????
- AC Condensor Pusher Fan mounting
- Del Sol and Apex WS....
- Ignition Switch? Advice needed...
- Carbon Fiber Hood Reinforcement on the Underside
- Pedals
- OEM rear sway bar sizes..?
- stupid question
- will a four door back bumper fit my 2000 ex
- ac tension pulley question
- Invida Sway bar installed Sqweaks on dips, turns? EK hatch
- my setup
- Would you guys recommend a Flex-Pipe as a Str8 Pipe????? INPUT NEEDED!!!!!!
- help quickly
- Can I use stock lug nut in my rota rims?
- Help selecting exhaust.
- Help please (cv boot install)
- Stock HP
- D16 axles
- Use b7 head or get a z6?
- H22a build for my 94 civic si hatch
- How Do You Remove The E Brake Cable Off A Integra For Rear Disk For My Hatch?
- Honda can do that???
- B18b swap help..
- battery light
- CEL 72, 73, 74
- problem with a b21a ...head gasket??
- Help: Squeeling belt
- boomslang 0bd1 to obd2 jumper harnes
- Timing on a D16
- gsr idle problems?
- Sunroof problem
- lookin for a d16y7 tranny
- tranny swap
- Has anyone used this ProClutch radiator from Ebay??
- Safe boosting
- how to use a timing light.
- eg hatch in CW???
- Rear strut bars.. who makes em?
- Radiator fan sensor question.
- Flash Options
- The best b16?
- Paint my Radiator ???
- Are civic and integra tps same
- Help with b16 tranny
- (searched) Just Want a confirmation.
- IACV HELP!!!....Member IVI IM LOOKING AT YOU!!!!
- 96-98 Civic HElp! electrical and car alarm issues, wire issues
- S-AFC II knock settings
- Is stock d16z6 ignition timing supposed to be set at 16btc?
- A mind boggling question about cams.........
- Airbag blockoff tray?
- 300$ for a d16z6 good price?
- B16A2 vs. B16A3
- b16a2 wiring harness on a sohc d16?
- EK bumper question
- 93 cs with b16a2 mount problem
- AWD JDM EG?
- JDM D-Series Final Drive
- Ever heard of KMS??
- Throttle wire bracket
- HELP...obd2b d16y8 into obd1 del sol chasis
- 1995 dx hatch for sale. Racing hart rims for sale
- should i be worried about oil slightly over full mark?
- Battery Type
- AC Bracket, part #s??
- Help!!! ep3 si seat in a eg civic
- Civic is giving me problems
- What strut bars are these in this hatch (PIC INSIDE)
- 5-Lug Conversion Question (Spindle)
- Colorado Emission
- Squeal Coming from the front?
- Clutch Master (Stage 5)?
- iak valve
- SOHC exhaust heatshield
- Anyone who hasn't modified their Civic?
- ugly cam gear case
- 91 octane... will it hurt me?
- new timing belt makes noise??
- HELP!! car wont turn off
- Back to that half throtle hesitation problem ..
- spal windows help
- low gas mileage...
- b16 + Uberdata+p28=CEL
- What harness do i use for 99 GSR into a 96 EK? SI HARNESS? EX SOHC HARNESS?
- Another civic stolen...Manchester, NH
- i need some information .. PLEASE HELP
- Car not starting all the time!!
- coilover need help
- Jumped Timing
- can you help me .......
- help with my lsd install?? final drive b16a diffent than others?
- car is over heating help
- help my gm sucks
- cv boot install
- are the storys all lies
- SRS
- OBDIIa or OBDIIb????
- stock civic
- Installing water pump help!!
- 99-00 Front End
- Has anyone made a home made intake for a D16Y8?
- know how to install this?
- FULL STAINLESS BRAIDED SETUP <CAN IT BE DONE>
- Would you buy??
- ES Race exhaust, B16 EG::info request::
- where to find weight of engines?
- 94 EG CX BRAKE UPGRADE
- Performance Shop Who Makes Harnesses? Help! So Cal Area
- Question: How to clean mud gaurds
- >>>need help on del sol glove box????<<<
- Using Legend Calipers on the EG
- eg hatchbacks
- EK Pics w/ Aftermarket Steerling Wheel pictues!
- 93 ex coupe power window problem
- ACT Clutch Pedal hieght
- Where do I find a jdm hatch conversion?
- THE CHEAPEST PRICES FOR BODYPARTS STUFF
- Brake Pad Clips...
- one question...HOW MUCH IS A LSD TRANNY?
- 98 civic A/C on 95 civic Possible???
- Rapid blinker function???
- eg6 sir front brakes
- HELP: eletric key lock problem on......
- IDLE PROB!
- doing auto to manual swap, have some weird questions
- im sorry but i need to know piston sizes and compression ratios for b-series?
- ??? about GSR DUAL STAGE INTAKE MANIFOLD
- Anyone have pics of a Black EK with Rota Slipstreams?
- Tubes in trunk????
- Please Help. What Ecu should i use in my swap. Harness Problem.
- Code 22 / check engine light
- ek right hand drive conv...
- B16A ECU to D16Z9?
- How much is a theft recovery 2000 civic si worth
- fuel pump problem? tough to start after driving more than an hour?
- Replace AC compressor? Cost? Retrofit?
- ZC Swap and A/C System Q?
- Engine check light
- i broke off the bolt that bolts down the valve cover
- b16 idol?
- Climate contorl/Heater
- 98 ex
- Vx Vtec head on d15b7?
- mini me
- Tanabe USA still looking for a 01 Civic
- Offset Question, EG Hatch::*
- d16y8 wiring harness in a cx question
- NEED TO ADD A/C TO MY CAR! WHERE CAN I GO TO GET OEM PARTS CHEAP!?!
- Just weighed my ol' 93 DX coupe
- Does AC cause more timing?
- Head Package Ass Whooping
- j spec sohc?
- Broke 2 Wheel Studs :(
- Siebon CF rear lip
- how do I empty my prestone?
- Hit 200k miles today
- just got a b18 about to do swap
- tranny went in my d16y7
- Alternator, battery, please help 98 civic
- ITR exhaust on civic.
- Car Seems to Flood when i try to start it?
- What's going on?
- does anyone know if teg suspension will fit on a eg coupe?
- car has trouble starting...
- axles
- Help after swap. No CEL at ALL and no fuel pump!!!!!!!!!!!!!!!!
- possible to build a d15z1 block?
- DC2-R Subframe on EG!!
- ecu questions
- Fresh motor, no spark or oil pressure
- Steps to turbo-ing a D16Z6
- 5 lug conversion question again
- Looking for good price on D16Z6 turbo kit
- y5 y8 z6 vtec solenoid questions?
- Cheapest price for lips
- shatter-proof window film???
- d16z6 vs. b18b
- ST rear sway bar on eg hatch....lower strut bolt to short?
- NEED ASAP helms type Body repair manual link. Helms has them discontinued!!!
- Can the B16A1 crank fit B18C5 ?..
- AC compressor
- Adding a resonator to the exhaust system
- sweet jdm intake
- eg civic overheating...
- b16 with gsr timing belt (SEARCHED)
- NSX brake caliper question
- Carbon Fiber hood
- EK9 DX engine build-up
- REMOVING spray paint from a body kit......yes its bad.....
- Coilover problem
- Window Regulator capatability?
- Calling D-series tranny experts!! HELP NEEDED!!!
- Will a acura cl motor fit in a 94 civic?
- GSR into a 1990 Civic H/B
- Bench bleeding---air is being sucked back in!
- code 41 primary 02 heater..mini-me /p28
- How to identify a stolen 1993 HONDA CIVIC which VIN was removed?
- How Do I Interpret Gear Ratios?
- HELP... DRIVING AND THEN BOOM OVERHEATING LIKE A MUTHA
- code 14 OBD I: IAC valve
- Greddy/Earl's Oil cooler & brake duct setup on 99-00' EM1 Si
- Dome light Question? (Searched)
- Autometer idles at 6000 rpm need help
- how many "amps" on your ek battery?
- help
- How To Touch Up Spoon SW388's?
- differnce in ek coupe and hatch exhaust length?
- who has a heavily modded car as a daily driver...
- NOOB questions
- loose shift linkage
- will fenders and a hood from a 92-95 2 dr sedan fit a hatch?
- Somewhat Random Bogging
- air condition ??? need help
- cluster
- Possible rod knock?
- Problems with LS into CX...easy swap,hard problem
- Where to get injectors professionally cleaned?
- bad vibration in steering wheel?
- Help, car will not go into gear.
- d15b compression? what should it be, or at least what is decent
- codes
- OVERHEATING
- trans oil
- Why does my idle drop when I hit the brake?
- GSR swap still not running? Help?
- Where is the best place find a usdm H22
- tranny?
- JDM b16 car wont idle
- distributor
- EK radiator support???
- Sunpro Tach Installation Help
- bumper for jdm fogs
- What Did I Buy?
- where do you buy your built short blocks?
- can u swap a driverside sparco seat bracket to a recaro seat?
- AUTOMATIC to MANUAL
- b20 ek doesn't crank, main relay doesn't click, check engine doesn't come on.
- FS: 96-00 HONDA CIVIC HB Parts
