View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Wiring a coupe with manual windows/locks for power windows/locks
- when to change spark plugs--CR???
- Lots and questions need help
- d15b7 16v delsol motor running on my d15b8 CX 8v motor's ECU
- How does aftermarket Intake/Header/Exhaust affect fuel economy?
- Will an EK exhaust bolt up to an EG?
- 89 Civic Hatchback
- Motor 2 tranny question
- does anyone have a 99-00 p2p ecu layout?
- Need more information on 96-00 Civic Hatchbacks.
- Pics of Vtecvoodoo's Shinestreet SO CAL meet (post your pics...56k stay away)
- spark plugs
- miata wheels on a civic
- 95 into a 98>?
- another EH3 hit by thieves!!
- fog lights
- I need a car alarm Install diagram, please help
- Coupe / Sedan front bumper Q
- Dimensions for oili filter on my 93 Si sohc vtec engine?
- boost leak???
- 92 Engine wires/harness ...VTEC??
- Please PLease help (Miata Wheels)
- turbo on 1.5
- need opinions: exhaust
- need a little help,92vx question
- Speedometer Cable?
- "Honda Chemicals"
- Car Fax Report needed
- Rear Wiper Plug
- new block install: water pump question and crank pulley removal.. help
- helms are up
- help w/ my headlights
- widest tire that can fit on HX wheels???
- how hard is swappin from under car???
- Code 41
- Picture of my 02 sensor
- Painting my side-skirts? Do at home? Do at body shop?
- type r grille
- gauge cluster swap question
- tryin to install BMW HID's in my 2000 civic
- Rear Strut Bar on a 98 Hatch.
- d16y8 swap into 94 cx
- Moroso Crank Pulley Tool
- 1st gear pops out. why?
- HELP! neeed some major advise
- Fried 02 sensor
- Tranny swap question (already seached...alot)
- I got springs, now i need shocks!
- clutch, clutch MC, slave cyl. changed...not what I expected??
- how to clean engines
- Help! Problem with my Gasket?
- LS/GSR gauge needles on EG cluster?
- 00 si grille
- Installation Instructions For A/C
- part number question
- My 3rd gear Grinds?
- Hello and i need some advice from the experts!
- How do I remove the damper mounting collar on the rear shocks?
- Integra mirrors on an eg?
- ex clutch/flywheel in dx tranny?
- Went to the track today..my b18 vs friends b20
- please help ( sos x 4)!!!!!!! 00b18ls in 97 cx help!!!!!!!!!!
- wuz up
- Supercharger cams
- smog ref. carb number help
- Specs on my motor...
- Need help on rim size ASAP!
- water pump?
- 6th gen EX emblem..........
- from 1.5L to GSR, wat should i expect??
- Car wouldn't start...
- D16y7Will it work?
- gsr front brakes on EK=bad camber????
- itr motor in eg hatch....
- 94 95 automatic TCM pinouts
- CF Hood Picts - Some Fitment Picts
- my coupe
- anybody crusin sac tonight?
- Spoon Sports header install + (half-assed) review + pics
- RIM size, do they rub?
- Radiator still overheating..
- Eagle something rim cleaner... dangerous???
- Help! steering rack arms
- GSR swap, complete changeover, want to hear about your EXPERIENCES!!!
- JDM gsr vavle clearances
- 92-95 EX/Si cluster problem - temp
- How do I know which intake manifold?
- cheap high flow cat?
- Trade Konig Monsoons for sir rims
- Help getting the hangers on WS B-pipe?
- Strange clunking sound from fuel filter WTF?
- Bleed brake order for '93 del sol?
- Newbie ??? Need some more pickup!!!!!
- replace shocks with springs?
- need help: exhaust broke
- another gas mileage drop question
- Need Help With Tranny/Axle Problem Please
- My piece of poo motor is done, well not quite...CAUSE IT WONT START
- misfire!
- 99-00 civic si foglamps 2d vs 4d
- eg headlights any diff?????
- Help! Axles
- Anyone using 15" Black Racing ProN1 on their 99-00 Si/SiR?
- The BEST fake seats you can buy!!?!? what kind?
- **RIPOFF** $25,000.00 Civic Hatchback RHD **RIPOFF!**
- Sticky yellow stuff on my spark plug?
- Will Z6 Cam and valvetrain work in a Y8 head?
- c 8's on red eg
- oo ls in a 97 hatch
- How much to install 5 lug conver. on a civic.
- Project Civic
- Pics of my Ride
- Shaving rear civic sticker, need help
- Misfire, Help!!!
- installing cv axles tommorow morning.
- Steel Grey Slipstreams Pictures?
- cleaning headlights?
- h22 questions
- Picked up my ITR motor finally. Pics.... 56K grab a snickers
- is hasport the only place that makes mounts to use cable tranny on the eg?
- swaping parts
- Tranny swap help?
- Location of fuel pump wiring
- what is the quickest way to remove rear struts?
- corner light Q
- Electrical Problem maybe?
- wiring diagram for 98 civic ex and 95 integra LS
- Just bought a '94 Del Sol VTEC.. couple quick questions..
- type r cams in b16 head?
- Anyone try picking up engines in their hatches? For example a B18 or H22?
- fs check out my car!!!!
- all motor cams for b18c1
- Eg6turbo's new rims- 56k its worth the wait
- SPEC Clutch.
- My del Sol ... what engine???
- B16a Swap. Need Heater hoses.
- D16 tranny help
- White EG with cf hood, lower..............
- Car wont Start
- kyb agx strut leaking
- rear sway bar...what do i need?
- Skunk2 camber kit installation
- is there sales tacx on trade ins?
- Squeaky Squeakerton Cx
- problem with my friend's car
- Compression numbers on 97 civic EX
- Taillights not working --> Checked fuses & bulbs, any ideas?
- Need 15" steelies
- DC2 R steering wheel on EG Ferio
- Anyone have a Blown Z6 block or eng i could have.
- Need help on my eg body work.
- Need so help with brakes on a 00 SI
- Where did you get your Omori gauge(s)?
- help with jdm climate control install,
- ACT clutch disk with Factory Pressure plate
- Car stutters when I'm Driving
- Goldline with kyb-agx??
- who has had a blown d16
- 99-00 cup holder into 96-98
- problem with speedometer
- if u had 5000 would u buy a b16 rex for 3500, or eg no b16 for about 4?
- CTR style wing
- need help with JDM B20B swap in a 93 civic coupe .. auto-to-manual conversion
- i hate theives
- broken latch on cf hood
- Michigan Users
- I got a white 99' ek, what rims should I get?
- Car overheating when A/C is on. Help please.
- wrx tdo4L on d16a6?
- Got a 94' Hatch Today... I need a swap.
- TOTALED:How much did you get back from insurance?(92 CX)
- Best tranny for..........
- eg
- what kinda bolts and nuts for type-r strut bar on a eg?
- what does it take to put a 99 si in 12s
- Want to know what people think of Rays Civic......
- Short shifters
- CF Duckbill Wing - Comparason Picts & Specs
- too much oil?
- EG or DC2 Tein SS setup ?
- 92-95 civic cat??????????????????????????????????????????????? ??????
- still wont start
- civic 4dr strut bar and civic hatchback strut bar
- Parking brake wires yO!
- best place to get duckbill spoiler from?
- motor mount question??
- si cluster in a 98 cx??? problems
- AEM Brakes w/ Rotas???
- sohc vtec question
- advan model 6?
- new, new 1/4 times from Bristol
- b18b specs?
- Reinstalling stock front A arms?
- what cam for a 00 EX?
- CF Duckbill on EG...
- How Fast can you go ? pic everybody
- jdm b18c and jdm itr b18c-R how to tell the difference?
- 215 Azenis on EM1
- Really strange question about a motor swap...
- Anyone do a b20 bottom end swap in a 99-00 SI?
- Shocks or Road
- how to take apart the roof for del sol?
- opinion on tenzo rally seats
- nos jet sizes charts
- What kinda cluster should I go with in my VX??
- insane crazy wiring harness will it work
- EJ vs Teg FRONT brakes...
- some basic maintenance questions
- Motor boost?
- electrical ? for eg cluster, plz read..
- i few last guestions befor i do my swap
- New Pics of my hatch after a wash and wax! 56K well OK.
- 15.7 in 93 VX w/ LS...WTF!!!
- Tach needle is bouncing around
- Toda spec B's?
- Tires for R16
- quick tranny Q, will it fit? Need answer ASAP. Thanks
- Si/SiR Question
- Need Paint Code for 1996 Green EK
- Pulled off whole front....please read THIS
- 99-00 SI front brakes/suspension fit on EG?
- How low can u go on stock struts? kinda ricey question.
- Can hf knuckles use SI axles?
- Struts Blown????
- buying a civic...
- Nos and Civics
- Flushing out a engine block from debris and headgasket material
- Where to buy this? Its can be JDM or Canadian
- 8k and 6k? spring rate in lbs.
- exhaust question?
- Noisy drum brakes
- What do you guys use in your trannys?
- looking for something....
- AEM V2. My impression and a pic.
- ** VTec Lines **
- anybody deal w/ hybrid garage??
- APEX exhaust and 1.5 drop?
- mugen racin chip
- Quick ECU Question
- B18C and B16A Spark plug wires. Is there a difference?
- Carsound 2.5" cat or J's Racing straight pipe
- Suspension Opinions
- vetc wiring for obd2 engine to obd1 ecu????
- fender question(yes/no)..............
- Clicking noise when I turn
- Clanging noise in back left wheel area after coilovers
- just wondering how much this car is worth
- D-Series Q's - Stroker kits? D17 crank in D16? I need some answers!
- Civic Type R rims
- Anyone had experience with Matrix HID kits?
