View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How to install EG JDM climate control ?
- integra dash in civic
- best set up for a turbo
- Question about MSD SCI/Cap/Coil
- updated pics of my eg sedan **56k grad some coffee**
- clear headlights?? please help
- Starting Problems! Help!
- do i need amber corners?
- Question about adding a strut tower brace and adding oil.....
- Exhaust Problem *Paint Picture Included!*
- new member... How can I post in the classifides?
- It's Finally Coming Together: Project b18C5 Killa
- can nybody help out on taking off my wheel locks???!?! plz!
- Why is my clutch release bearing bad at 73,000 miles?
- drives door locks/unlocks from inside but not outside
- help: wut mods to i need to do for RHD
- 000
- Is this EK worth buying for $4000?
- will a jdm p73 be plug and play with a usdm p73???
- VTEC in neutral?
- Distributor signal wire question.
- to distributer or fuel pump
- People with hyper ground system.. wheres the best place to ground?
- PLEASE help me out!
- Off Topic but I'm leaving for Vegas.....
- High Compression D16Y8 - Need Some input
- piping diameter ek4?
- reccommendations for buying injen sri extension
- can a car with a salvaged title be changed to clean?
- question about Y8 head on Y7
- Crazy ECU Code
- Camber kit compatibility issues, need help quick.
- EK hatch seat rail bolt on to EG hatch ???
- Springs for Comfort: Neuspeed vs H&R
- TELL ME WHAT TO DO~~~~
- JDM CTR rear crossmember/subframe onto USDM Civic Sedean/Acura 1.6EL?
- wanted to know what u guys think my EG is WORTH?
- ITR Brakes$$$-from where?
- Spoon Chip in a P28???
- Short RAM vs. Cold Air Intakes
- Snapped bolt in rear lower control arm. How can I get it out?
- B series clutch disk....cable vs. hydro...which is mine, do i have both?
- Dropped my car tonight.. (pics)
- Spinning ball joint!! Help!!!
- Changing timing belt RIGHT NOW. URGENT help!!!!
- Just finished the SWAP... b18b/GSR tranny.... damn Im happy.......
- 6 gear manual in an EM2?
- turn signals/parking lights problem!! help~~
- what is ur exhaust setup?
- d-series dis. on b-series block????
- EG wiring Harness
- Super charge on d16z6
- Can you use 00 EX springs on an 00 SI?
- Idle Problem with my GSR Hatchback...
- Which Exhaust RSR EX Mag or GTII???
- Honda Newbie with some quick questions...
- few newbie questions
- STILL questions about Springs and Shocks (S&S)
- Help!!!!!!!!Engine idel
- Amber spray tint...
- Ignition Switch Swap (Pic)
- Springs & Shocks
- what can a 99ex with greddy turbo kit rev to?
- Trunk lid problems
- new user.... my car.... its okay...
- how hard would it be if....
- Am I Phucked?
- Custom 2 1/4 inch resonator
- HELP!!1 VTEC is not OPENING!!!
- whats a good name brand spring?
- Mini-me with D16z6 head on D15Z1?
- Racing Hart Distributor in NC...
- how do they sound? spoon vs magnaflow sound clip inside
- Jerky, stagnate acceleration...
- idle problem after driving fast!
- Pic of my hatch first time post here
- Es Oval Pics
- Motor Mounts?
- brakes
- how to fix noisy targa on del sol?
- finally put my foot down. 11 psi
- where can I get Jdm tailights for eg?
- How do I post pics?
- Special tool for flywheel
- Axle need to be removed?
- Type Zero Sideskirts...
- External coil?
- 96 vtec harness for sale
- My car. What do you think.
- timing belt tension question
- New Idea For My Car.
- obdIIa vtec harness..I NEED ONE_
- role cage???
- Del Sol Seats..
- 2nd slipping!!
- Front lip on a hatch cx
- HmotorsOnline
- Urgent assistant regarding soaked carpet/leaking car (94 SI)
- injectors
- installing a transmission w/o trans jack
- Secondary o2 Sensor into B16 Hatch
- Need 96-98 ecu pinout diagram
- S2000 rims
- car almost stalls
- lca's sway bar __mm to big for a hatch?
- Doing Clutch Job
- IMPORTANT QUESTION!! Need feedback ASAP...
- Changing transmission oil seal, need help **pics **
- pic request 215/45/16 azenis on your car
- Newb Headlight install help...
- need a part # check please
- How many replace the tensioner when doing a timing belt?
- Can't have anything nice ***PICS***
- B18C1 Exhaust Muffler? Magnaflow or Es Oval?
- What do i do....(wiring issue)
- Stock B16 running VERY rich
- Shock/Spring install
- After doing donuts on ice... car gets louder
- I need to know what is included in a JDM 5 lug conversion
- opinions on what should be done about my exhaust dilemma...
- My personal Osaka order experience...
- D16Y8 T-Belt or Swap?
- throttle cable install
- i finally did the swap
- quick injector ?
- Anybody know of a good tint shop in the hartford, ct area?
- VTEC--HOW DO I PUT IT IN MY CAR?
- Carfax please
- Help with b18c1 into eg exhaust question
- what are the 98 hb's shell/body made out of? Aluminum?
- Ist post w/ pic of my car
- help me choose btw tein flex's and ss's for my ek
- Is it hard to convert auto to manual (97 civic Ex)
- Some pics of my car with the new wheels.
- what is everything I would need to build a d16z6?
- Look what the UPS man brought me =) !
- 98 gsr motor into 92 si
- Exhaust Choices?
- AFTERMARKET FUEL RAIL....????
- How can you legally drive a real JDM SirII?
- ****!!!!POST PICS OF YOUR EK'S!!!!****
- 2nd Gear SCRATCHIN!
- I need flywheel help...
- guage cluster questinon
- 4wd on a civic?
- What clutch with d15b vtec?
- Type R boot for '03 Si
- anyone w/ ebay spoon mirrors?
- quick tranny question!
- Del Sol VTEC - Vortech Supercharger
- which tranny is better
- are 92 civics pre wired for vtec
- HKS hi-power exhaust (so cal)
- website....
- My 95 4dr Civic *Pics* Before Wreck,After Wreck,and After Body and Paint Shop (56k Please get Cable)
- del sol s vtec???
- problem wit scraping fender...
- pipes
- Just got back from the track (drag) - new times
- GSR TB onto y8 IM, what is needed?
- flywheel...how to identify them...
- exhaust help!!??
- Failed emissions barely on co... help...
- Carby
- Help!! shift cable on a AT removal question
- Power to B18C w/o ECU
- How do you guys jack up your car
- 98 DX Clucth work in 94 del Sol S????
- what bolts to use on 99-00 SI spoiler?
- Just got a 92 VX Hatch
- d16y8 manifold leaks on d16z6 head!!!!!
- 4 those with EG Foglights, got a question........
- will 2 door fenders fit a 4 door?
- transmission will only drive in first gear??? WTF did i do wrong?????????? help needed badly
- '94 GS-R exhaust on '99 Si?
- Compustar Keyless for $249.99 Good Buy?
- Broke VSS bracket Anyone got another one for sale PIC
- how to install new driverside window?
- K-series oil filter on a B-series
- Tien SS problem!!!
- AEM Tuned CAI vs AEM Shorty on SOHC Edelbrock Manifold. +9.6mid +5peak
- Tell me what you think.......
- funny THUD noise when driving.. could it be this...
- how to connect sidemarkers???
- b16a lsd
- free carfax on 11/14/03 until 5:30
- del sol seats OWNERS!
- 92 blue Velvet Si
- JG Edelbrock performer X, or AEBS Typhoon?
- Just Got My Car Painted... 56K Has My Sympathy...
- Sway bar question
- How do i take my shift rod out?
- How do i take my e-brake handle off?
- Blew my head gasket have many options give me your opinions
- Grinding noise....help =/
- Replacing the Throw out Bearing
- radiator problems check it out
- gsr hatch?
- d-series & b-series
- ?Suspension?
- b16 w/ stock tranny
- What would you guys choose? Koni's with springs or Tein Basics?
- engine acting up !!! HELP !!!
- B18C5 or a B16B which one for a 1998 civic 4dr?
- Ack... How do I know I need more PS fluid
- 92 Vx Brake rotors question
- HOW to ship a motor???
- sohc vtec del sol?????'s
- SR20DET in an EK?
- What does a stock DX dyno at??? I know I know dumb question....
- u think i should do it??
- Honda delsol si automatic ?
- 96 and 98
- My girlfriends mom wants a spoiler for her new car, where should I direct her?
- I'm selling my EG and EK... I know wrong place, but how do I get it on the Vehicle Classifieds???
- opinions on my trade-
- winter tires?
- E series engine
- removing painted pin stripes?
- limited slip for d series?
- INTAKE MANIFOLD BACKFIRES-97 civic LX
- Question about CTR door panels..
- how much does stock b16 flywheel weigh?
- turn signal doesn't click off when cold?
- u.k eg vti - u.s equivalent
- salvage yards
- best D series flywheel
- JDM DC5 door panel
- KYB AGX's...How low for How long???
- ITR intake on EK or EG...need pics and opinions please
- For those with B&M Short Shifters
- Got to have AC!
- What do you think of these aero mirrors?
- sleeves?
- best flywheel
- disabling the entire doorlock system
- FOCK THIEF!!!!!
- deer and honda's don't mix well......... my poor car:(
- my ek 4 door
- I think I just broke my axle's, EG w/H22 Where to get axle's at? OC, CA.
- Name these wheels!!!....if you can..
- 98 to 00 front end conversion??
- Recommendations for a car cover?
- how do you drop your cars so low?
- I never thought I'd see this shit.....
- 92-95 Windshield Price...
- EGs with World Sport Damper coilovers
- Problem
- denji projectors
