View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Bisimoto D series Header dyno
- body parts needed..
- question about si vs. other hatchback models
- Emission Testing Blues
- Civic peformance engine mount
- Dash conversions......
- 92-95 civic ECU question
- Problems with setting VAFC
- new valve cover + old valve cover gasket???
- axle-back and cat-back
- b16a Civic (AirCare) - How do ppl in Cali do it?
- FUEL PRESURE INFORMATION
- This rotor is driving me nuts!!!!
- 99-00 B16 Tranny
- EG speed Odometer not working. Just suddenly stopped..help..
- shot peening rods??????
- Question about wheel bearings
- Can a d16y8 head bolt-onto a d16z6?
- anyone know the offset of SI rims?
- engine swap 03 civic coupe
- how many inches does the ctr rear lip add?
- Compression test results inside
- 93 VX Hatch Questions
- help with code 9!
- will exhaust manifolds from a d-15 fit on the later model EK d-16y7/ Y8 models
- tps or something else?
- You guys have any info on swapping K series into an EK?
- possible to put a/c in cx hb?
- Wiring Question?
- Best place to get OEM Parts online?
- Will a b18a1 timing belt cover fit a first gen b16a?
- 92 hatch seats in 00 civic hatch
- Civivc type r grill or si grill for a 97 civic hatch
- WHATS WRONG WITH THIS...... PIC INCL
- Leaking tranny fluid, but cant find a problem
- mugen twin vs spoon n1 *searched, so chill*
- Wierd squeek noise when turned on the car today
- Painting seat fabric?
- Front Hub replacement- keep bearing??
- Stupid stock tape deck not working; anyone else encounter this?
- stock seatbelt on sparco sprint/speed
- Free CarFax Reports!!
- will pulleys help lower my time at the track?
- B-series swap in Del Slow question
- Did the EK come in dark blue?
- does anyone know jack harris's number
- K&N filter question
- any experience with jdmshit jdm type r style titanium upper strut bars?
- gsr shifter fitment.........
- 1995 civic EX
- Tire Size for a 97 ek hatch
- What can you do if your car is leaking oil?
- Trunk dimensions
- HI! I am new!
- will trade my 2000 si for 95-97 del sol
- need help with side markers!
- Neuspeed Sport springs/with Koni yellows?
- Quick Clutch question!!!
- New gauge faces...
- which AC lines to use (b18 in EG)
- IACV
- strange smell coming thru vents
- EG6 brakes fit my 92 civic?
- my car got jack
- B-series oil pans all the same?
- G2 integra suspension into '94 EG. Will it work?
- OEM Honda CD Deck, WTF!
- honda-tech is starting to suck!!
- anyone take a door off?
- which intake manifold is better... b20z or LS intake manifold
- HELP: what engine to do this time?
- When building a new motor, what do I need to replace?
- 5 lug set up ?
- ITR rear sway bar on 98 ex?
- How to take out 99-00 bumper from my civic
- How to remove exterior door handles?
- 93 civic sedan upgrades
- Light on warning chime
- Any other seat brackets (sparco, etc) fit Bride Zetas?
- del sol manual,cd on e bay, any good?
- Radiator question....
- Installing a front sway bar
- Rebuiding D16Z6, ALL MOTOR where to start??
- When installing a new hood, is it impossible to keep the holes from stripping?
- Quick yes/no question..
- Help me cofirm some swap info
- general opinons of del sols
- which one
- Anybody ever seen these fender braces before?
- I need some ac/motor mount help
- how much would you pay for this hatch???
- sway bar reinforcment
- jdm b16a swap in 92 hatch. . . . need help
- another n00b quick question... cluster.... green plug on back...
- testing waters.. how would you pay for this hatch?
- price of IACV???
- Stock intake with b16 in 95 hatch????
- AutoMeter Speedometers and Fuel Gauges on EG Civics
- neuspeed race spring
- Cx making a noise?
- EK/EG
- alignment with lots of negative CAMBER
- Am I in the right forum
- anyone know a good muffler shop?
- ....new cluster...needles.... how to get the needles off..?
- check this ebay item out
- oil light came on today....not low on oil...what could it be?
- took my head off today.....check it out...please post opinions
- Suggestions on new project car
- what size tires....
- Someone Please! Give Me a Car Fax On This VIN#
- Goal 12's:: LSD Needed?::
- BS...TRIAL MEMBER
- Will the rear bumpers swap out on 2dr & 4dr 92-95 Civics?
- CEL question
- what's the weight of a 95 civic dx??
- How to install a 99 civic si front end?
- 120kmi. turbo too risky?
- EXHAUST HELP!!!!!!!
- shotpeend rods
- d series stock crank pulley?
- power windows motor in all the civic and integra are the same?????
- a***CRX or HATCH***
- header rattling
- name that noise*
- how to: replace outer cv boot
- Average price on EG hatch?
- ABS spoon style lips?
- where to find RS brake booster?
- NEED A CARFAX!!
- Should i buy it or not?
- INstrument cluster bulb replacement questions...
- 1993 Honda Civic HB noise from engine
- what about konig heliums?
- headers
- wet ass seats
- ZC Pistons/rods in d16y8
- jus ordered my rims and tiers . . .
- cx to si climate control
- Lucas Tranny Additive?
- who makes rotus?
- can my o2 sensor be bad, with no cel?
- Wich Apexi is right for me?
- EG Rear brake disk conversion
- Is 130k Miles too much to boost (daily driven d16z6)???
- Opinions on Royal Purple lubricants?
- A/C compressor issues I need A/C i`m in louisiana and today were 91 degrees
- Tire Pressure?
- Whats your best MPG???
- Factory Red/Clears
- NEED HELLP!!!JUST INSTALLED A UNORTHODOX CRANK PULLEY!!!!
- dont let ur friends barrow ur car u get it back like this?part 2
- How to sell my car, w/ b18b or not???
- 99 EK Front End Diagram Request
- Clear Corners question
- JIC racing seats....
- Replacing Axles?
- Front brake rotors....newb q's
- Greddy finally comes out with a turbo kit for 96-00 civics!
- Limited Slip Questions...
- Is the D16y7, buildable? Use D16z6 head?
- True or False: Alcohol to pass smog.
- Climate Control
- Suspension Install Price
- How to swap Speedometers? Please help!!!
- how can you tell?
- Wheel seized onto hub
- cel #8
- aem v2
- HELP: Transmission problem
- 95 EX Coupe, Hawk Pads... what fits?
- Whats that little pocket thingie that hides behind the pop-up cupholders in my 96 civic?
- Installing a short shifter today... tools needed?
- HX To EX Tranny swap
- What in all is need mounts/linkage wise to install a b16a sir2 swap into my EG?
- anybody in the minnesota area painting cars ?
- head lights Advice
- painting dx hatchback
- New to Board, help
- B16A2 swap $$??
- Leaky Master Clutch Cylinder...
- Has anyone ever dealt with city-speed.com?
- Brake SET up help...
- D16y8 motor swap
- Will eg coil-overs fit an ek?
- New to the Board have a few questions.
- front conversion
- Ek spoon lip 96-98
- Does the 2dr front bumper fit my 4dr?
- 92 VX vs. 96 CX tranny gearing ratio question
- SRR Lca's....
- Anyone have a Carbing rear lower bar & Beaks rear sway on a 96-00 civic? will it all fit?
- Posting limitations info please!!!
- Where is the best place to buy Greddy Turbo Kits!!!!
- just got back from suspension and exhaust install...WOW
- where to buy comptech headers for cheap?
- quick repair question
- Edelbrock turbo kit for SOHC V-TEC 96-00 civic
- fuel pump fuse?
- carfax(ing) a motor swap ?
- EG6 JDM cluster problem?
- first time at track w/ new hatch, what should i be able to run???
- Stand alone Fuel System.
- Front Lip
- Anybody know a place with 5Zigen Border?
- automatic bodys are diff then 5spd
- wet filter ....good?
- expected 1/4 time
- difference between obd1 and obd0
- ek and itr pics
- Flywheel for STREET turbo set-up
- funny knocking noise???
- Dc2 N1 cat back on 5th gen coupe
- Need help- Why is my Engine blowing white smoke?
- price to fix motor?
- 94 Del Sol transmission in a 96 cx?
- CAMS...ANYONE??
- Question about gear ratio's hoping someone can shed some light for me.
- Please post pics of 99-00 Ek's with OEM fog lights!!!!
- Cam gear
- B series Fuel
- a engine question
- Bad tire wear
- quick question
- Is this bad?
- cheap cheap header...
- Hx Problem
- Quiet axleback for b16 ek?
- Need a price check!
- suspension techniques front sway install
- b18c spark plug gap
- edelbrock dampers
- Anyone ever changed crankshaft bearings on a d16z6?
- best catback for a 93 dx coupe?
- d15 engines
- EP Seats in an EM1??? What rails??
- CEL 22
- Are VX and HX wheel caps the same diameter?
- Is Running Open Header Bad???
- anyone know a ball park estimate of hp gains through porting and polishing the head?
- the n00bish spark plug question...
- Not Sure if vtec is works any help?
- 97 civic exhaust questions????????
- Damn Rust
- 02 sensor CEL prob's
- 92-95 CLUSTER SWAP PROBLEM.... HELP PLEASE!
- MUGEN PIN STRIPES?????
- some del sol model questions
- 96-98 Front and Rear bumper cover confirmation?
