View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Spark plug wires testing?
- quick question guys!
- 92 Civic DX/b18c swap and wire tuck - won't start
- h22 swap eg strange electronic sound
- Lug Nut Size
- EG Front Subframe, compliance bushing bracket bolts
- Bellowing white smoke upon start up. Please help -- for the techs
- tps adjustment 97 civic w/obd1 h22a
- 97 honda civic ( no reverse or 5th gear )
- civic 98 lx not start...
- fluctuating RPM's d15b7 no cel's
- Horrible gas mileage during the winter?
- 93 DX - won't start after head work and head gasket replacement
- Starts with remote but not with key
- Failed CA smog NOx too high..
- d16y8 camshaft/crankshaft seal leaks. labor cost?
- P28 ECU not looking for o2?????
- Gear Rattle Noise Light Weight Flywheel
- anyone know how to wire a distributer plugs from obd1 to obd2
- 99 civic lowering question
- PLEASE HELP: Problem Starting 92EG
- 99 civic headlights on 00 civic?
- Probability of damaged head after timing belt break
- bad idle surge on 92EG with b18 swap
- FAQ: How do I wire VTEC?
- I need help installing a power steering pump
- D16A6 with D16Z6 parts possible?
- b18 eg dont want to stay on unless i stay on the gas
- please help: b18 on eg. gets hesitant when cold
- You think I need a new Flywheel???
- 93 Eg coupe fuel system problems
- Erratic speedo under WOT
- ITR EXHAUST ON AN EG HATCH?
- Gsr into ek hatch bogs down
- Auto/manuel Z6 harness question
- Want a little more power out of my daily.
- valve stem seal replacement?
- Need OEM or OEM replacement body parts at good price
- B-Series VTEC Oil Inspection Port Bolt Problem
- Aftermarket exhaust manifold heat shield?
- 93 hatch GSR rebuild
- 95 Civic dx build
- Scraping sound when I come off the gas; 1999 Honda Civic EX D16y8
- Clorox In gas tank - starts with starting fluild
- First Fix for 96 Civic DX - Damaged Crankshaft Keyway
- B16A2 High Compression Help
- EG Suspension and Brakes Upgrade List
- 92 civic sedan - looking for engine and body build ideas
- 97' civic engine choking
- Bad Gas mileage? 1996 Civic Hatchback
- 00 EM1 -- Rear brake sticking and cruise control problem
- Idle 3k in Neutral?
- What would be better in a JDM B16A -- SPOON OR EAGLE / WISECO?
- WHERE CAN I FIND A B16 WITH VTEC ENGINE FOR CHEAP????
- How High can I rev??
- Del Sol battery relocation kit -- tray mounted like this (see pics) safe enough?
- eg sedan -- installed skunk2 lower control arms and they are making noise
- VTEC Solenoid Gasket OEM part number
- D16z6 manaul civic ex-rough idle, missing and bouncing off the revvy at 3500 rpms.
- Idle problem - tune up, iacv, fitv clean
- Fuel gauge up and down civic 98 lx...Why?
- EK CODE 0 PROBLEM???????????????
- 97 civic missing cat and 2nd o2 sensor?
- Eg Hatch - questions about b18c build, transmission, and body mods
- 96 Civic Turbo smoking off and on??
- RPM gauge not working but speed is
- mr clean... carpet clean
- Everything is good, but 95 Civic DX won't start.
- 93 del sol, b18b tps cel ( code 7)
- Mounts the same eg/ek but different brackets?
- fuel return line
- my del sol will not stay running
- 95 Civic/d15b vtec - Idle screw does not adjust idle speed
- 95 Civic AC System Recharge
- code 11? p30 ecu (del sol b16a swap)
- 93 Civic Si Randomly Dies? Bad ICM or coil?
- ***D15B VTEC IN A 94 CIVIC EX STUMBLING ISSUES PLEASE HELP****
- Buying a low mileage 2000 Civic EX. What should I service right away?
- k series to b series
- 4000 rpm idle WTF
- lc-1 install anybody? no green wire? bad?
- How swap auto eg to manual?
- 98 Civic/D16Y7 - Idle surge that stops when throttle body port is covered
- Alarm system problem / goes off while driving
- Noise after letting go the clutch pedal
- Over heating with thermostat in and fine with it out.
- Del sol won't lock or unlock from outside
- Mini me swap 96 y8 head and IM on 2000 civic Air injection issue?
- What service manual should I get?
- 00 SiR, turbocharged on the stock motor won't run anymore
- 1999 Civic Radio Code
- got cel p1298 please help
- thud sound from passanger rear tire
- Whats my 98 Honda civic DX worth ?
- No 3rd Gear ????
- ConsistentMisfire/BadColdStart/NoStart
- Civic 98 LX CAI or Short Ram Intake?
- i have 2 cel codes... how to fix??
- RHD EG/EJ Conversion
- 94 civic coupe/B16A -- Some ECU Questions
- D16z6 weird noise on start up(video)
- eg foglight question (cabin wiring)
- 98 B18C5 Valve guides need replacing?
- 95del sol...need new horn!
- jdm gsr not shifting in smooth and misses shift please help
- Parts for an EK 1996
- Another Idle Issue thread
- 99ek getting ready for Gsr swap
- Tach/Speedo/Odometer/Signals out? HELP!
- EBP EM1 Build Thread
- "mounting" 96-00 OEM city lights
- power or manual steering rack??
- B16a cranks but no start.
- Cruise control wiring
- 97 Ek hatch JDM P73?
- OBD2B Distributor Plug Wire
- 94 Hatch Cabin Harness Question
- d16 to b16 swap help please
- Jdm B16A Rev Limiter 3500 Problem
- TPS sensor questions
- EG Coupe Master Cylinder question
- Which heads fit the d16z6?
- DOHC VTEC Del Sol 95
- Will 94-00 Integra shift linkage fit my 99 EX Civic/B-series swap?
- eg b series automatic
- Can EM1 Strut bar fit EK4 as well?
- new $300 build love my del slow
- EK Wing Width???
- D16Z6 coolant in cylinders, HELP!
- 98 Civic EX - looking for better MPG
- What would be a good snappy swap for a eg hatch?
- Wondering..can i bar'd my jdm b16a in a ek sedan ex
- civic acts like it hits rev limiter then stalls!!!
- fitv and iacv for jdm d15b
- Best way to import rhd ek9 from Dominican Republic to USA
- EJ / EK SIR replica lip on ebay
- Help@ y7/y8 Mini me Endlessly Retarding Ignition
- Can engine running rich make O2 sensor go bad.
- Eg coupe dash harness in a 94 dx hatch?
- 95 ex will not reve past 74k with swap help
- ls/vtec or ls build??
- 93 ej2 coupe wont get spark
- ls/vtec project help!
- Changing from synthetic back to regular motor oil
- 98 civic cam gear
- How do i remove y7 throttle body ?
- D16z6 oil pressure switch
- Help identifying window piece for 92-95 civic sedan
- 98 civic underdrive belts
- Advice on moving a shell with no suspension?
- D16Z6 weird noise/knock/ping/tap?
- Help Identifying Screw
- 94 civic sputter
- registering a real eg6
- 95 lx, with d16y7 swap - ecu and harness question
- I cleaned my iacv and fitv but....
- Block d16y7, head p2a, intake p08, ECU p05 and p06 - Is this stuff compatible?
- 98 Civic (40 miles/2.7 gallons = 15 mpg)
- 75 psi
- Doing something wrong to get '97 LX ABS codes?
- is my engine stock or swap?
- Maybe Iacv, please watch video
- B18 EK - 75 psi fuel pressure
- Will a 96-2000 D15B fit where a 92-95 D15 sat...
- Honda emblem/ badge
- Bogging and idle problems after JDM B16A swap in ek sedan
- 98 DX ..radio wont get power!
- questions on a '93 Del Sol Si Build
- Wtf! need major help on this one. 2 ecu fried in two weeks...
- Axle length
- del sol vs civic stock downpipe?
- GSR swap in 98 Civic
- 97 sedan smog fail??
- ** d15b/z6 head, 6000 rev limit, need answers??**
- oil restrictor removal for zc block?
- Whci
- stumped on valve cover gasket leak.
- OEM side skirts Help
- VTEC Solenoid Bolt Size
- B16 trans 5th gear pops out
- Can't fix misfires on 98 civic
- HELP!! Civic lx engine stays on only as long as I pump the gas
- HELP!!
- 99 Ej8 with a B16a2 swap having issues
- J-Spec Auto Sports?
- 96-98 / 99-00 D16Y8 exhaust manifold: Length?
- 96 Civic - passenger power window doesn't work
- problems with obd2b to obd1 swap
- Trendy budget build daily driver.
- EG Sedan Lower Control Arm Bushing
- eg hatch trunk seal
- abs rear disk conversion on 99 ek
- B16A2 Wiring harness (obd2)
- frozen stick ?
- My Gas Mileage Sucks
- how much do u think an 1996 ek coupe is worth?
- EJ6 to EK9 Build*PIX*DIY*RHD*
- What power windows & locks Door Panels Fit on 99 DX Hatch?
- making an ls/vtec
- 00 Civic EX - Hesitation/Misfire Issues
- 99 Civic - need help with lsv swap
- Honda civic 98 lx 800 rpm parked...
- Rear drivers side door wont open
- Any one used Felpro Head Gasket? Any experiences?
- Stripped out seat bolt holes.
- How do you know if your rack is bad?
- EG/D16Z6 sounds like a Subaru WRX STi!!
- b18b/93 del sol won't start - good spark, getting fuel, timing is set
- knock sensor wiring to civic 92-95
- 1999 Turbocharged EK build...Precision 6262 or Silver Surfer Reaper???
- Need the end connector for the speed sensor wire..
- 2 cels and 2 sensors not connected help?
- need help with si guage cluster speedo not working?
- Need help with leaking radiator drain plug
- Official EJ Squad, on H-T?
- Loud grinding noise after flywheel/clutch job
- Check oil light flickering on my 97 ej6
- How to install manual steering rack in 94 del sol?
- 98 civic brake lock up.. Already searched
- 2000 front end on a eg
- low rpm 1.8-2.4k engine seems to hesitates
- 00 Si -- Compression and Leakdown Test Today
- found 92 si hatch.... what should i look for??
- Will a 94-97 DC Cluster swap in my factory EG clusters place?
- Stupid radiator cap question
- Weird Power Loss Around 4-6k Rpm
- What is this sensor? 98 Civic DX
- Subs in rear speaker compartments
- d16y7 Ignition timing help??
- Rear hatch window shocks
- 95 civic wont start. No injector pulse
- Codes p1870, p0141, p1509, p1882 after swapping 99 D16Y5 and auto ECU into 5-speed
- Leaking rack and pinion
- Overheating civic - radiator fan won't run and there's no heat in cabin
- Help with del sol trunk lid
- Del Sol... won't start when hot, not Main Relay
- im stuck on the side of the road with a code 6 15 43
- Help with CEL codes and weird noise when starting...
- should i replace t-stat housing??
- Quick push button start question
- What is the best brand radiator for $200
- Cool, someone tightened this crank bolt with no pulley on it.
- Voltage on ECU D2 pin for Brake Pedal signal
- 99 DX - Help with P0118
- 00 Civic SI/LS-Vtec swap - How difficult is ODB2 tuning?
- Can you tell me if something is missing from this 99 Civic EX intake system?
- Interested in buying an eg sir
- 2000 civic ex headlights delay when cold
- 92 Civic Si -- Intermittent wipers don't work. What ICU is compatible with my car??
