View Full Version : Honda Civic / Del Sol (1992 - 2000)
- mini-me swap
- Is there a difference in the accuracy of the factory tachs (VX vs SI/EX vs JDM)?
- Got Carjacked in Hartford, CT
- cx head to dx head?
- n00b checking in... just bought a new ride
- Plugs
- Rear drum brake making clunking noise
- Stuck suspension bolts
- Passenger side auto down feature for power windows?
- 2000 Civic Dx
- 99-00 civic si jdm foglights
- TYPE R four bolt conversian question
- Question about 96-00 EK door panels
- thinking of buying a civic HB
- fuel pump help......im stupid!
- What's the break-in procedure for new pads and rotors??
- oil pressure
- b18 engine for sale
- Getting ready to upgrade exhaust system.
- Timing belt
- Which oval muffler is better for 00'' si ?
- 97 Civic DX, to EX manifold conversion!
- help car throwing code
- GF's 00 DX h/b one of the belts is making noises.
- JDM GSR CLUSter
- is d16y7 intake manifold the same as d16y8 mani?
- rubbing noise from rear drums before and after changing shoes......help!
- Stock Airbox
- Is there anywhere to look up a tranny serial number to find out what D-series it originally belonged
- quick question. plz help
- Stock Airbox
- Quick Question
- Weight?????
- Need assitance in installing an afermarket Fuel Pressure Regulator for 1993 honda del
- Gushing Transmission Fluid
- 01 to 97 dome light swap?
- jdmcarboy.com
- hatch weight
- 12 inch SPAL Slim Fan, How did you guys mate yours to Koyo Half sized radiator cleanly?
- vtec
- Will a EGR Control Box from a 93 DX work in a 93 VX?
- Need Info mating Z6 w/ Y7 *searched*
- water problem
- wtf i dunno understand why i still cant post in apperance its been like 3 weeks.....?????
- Thermostat question.
- Good plugs but are the wires ok??
- would a B-18 header fit a B-16
- search down, d16z6 valve cover and d16y8 valve cover interchangeable?
- CX Clock panel removal????
- New Owner!
- Rod Bearing: Sorry Search is Down
- Turbo d16 or b16!?!?
- stop leak coolant
- Rear Main Seal
- tires/rims on civic question.. please reply
- CLUTCH PROBLEMS
- Somewhere to buy instead of dealership
- D16Y5 HX Head Swap *Pic Request* onto y7/b7/b2 block (mini-me)
- h22 ek swap
- WHAT TO BUY!
- brakes mushy to point of dangerous in low RPM
- Cant get AXLE in
- Rattling noise when engine is cold and in gear (auto).
- need help with brakes!!!
- Is there a sure fire way to tell if your piston rings are bad?
- Need a 96+ Vtec harness
- del sol dash
- *****HELP WITH REDLINE ON B16A SWAP*****
- need exhaust shop: custom exhaust wanted
- Project Mu B-Force 93-95 civic ABS brake pads, and whatever is interchangable.
- Honda hardware for 92-95 ex lip
- DC Emracing bars on EG?
- found this today cant be good what wire/plug is this?
- Anyone who's ever wired up JDM yellow stanley fogs into a USDM EG PLEASE COME IN!!!!!!
- search function down/out of service.
- GSR abs sensors on EM1
- ek squad?
- Shifter linkage
- 14x5 SI Wheel?
- Plastic Rear tail gates EG6
- How 2 convert 96-98 climate control to a 99-00 climate control? PLS.
- Car smokes but dont know why....
- Climate Control Bulbs...
- Wheel question
- m3 mirror with light wiring
- 6-Point Cusco cage for EK: Will it fit an EM1?
- Audio/Video....!!!
- help jumper code
- Rear wheel stud
- For Sale So Cali
- O2 sensor replacement: Which wires are which?
- Drum to disk?
- delsol weight?
- k20 in a eg6
- will si and vtec model del sol's exhaust interchange?
- 91integra rear disks?
- Painting Wings West Urethane Lip
- Cluster Gauge Needles
- swap trouble
- EG civic oem factory colors?
- rad blew up??
- search down... Apex World Sport 2 fitment question
- valve adjustments on a b16a same on all Honda's?
- pic of greddy lip installed??
- p28 keeps blowing ecu fuse, HELP
- vavle cover leaks
- Which Air Intake?
- will ls rotors fit on a civic hub with civic calipers?
- Rear defuser?
- Problems with the 1st gear
- d16z6 vtec
- After driving car is really hot and smoke comes out but thermostat shows OK??
- where can i find a helms manual book for my 95ex?
- ? on buddy club condensor (grounding kit)
- Mounting a camera inside eg or outside? How?
- i need a wiring diagram (3 bar map sensor for single cam turbo)
- D-series w/ 5lug conversions
- can anyone...
- burned clutch, or did my car just say screw it?!? need some help. =/
- search function ##### please help
- eg radiator support question?
- 95 coupe stolen in Tacoma, WA
- Type R motor in Del Slo?
- help with avid h22 mount kit for eg
- WIRING PROBLEM
- ek fogs with intercooler piping?
- After axle change, car jerks right when I take off...
- 92 Red drag civic stolen today in La Palma, Ca.
- obd2a and obd2b distributor?
- tranny problems
- Cel light (which wires?)
- Car shakes after axle install
- Tein Adjustment Knob
- valvetrain noise on zc
- Head gasket or new engine
- Prouduction numbers...Hatches...?
- stock EG civic seats-how much do they weigh?
- tail lights..???
- not catching gear
- Need Help With CEL
- What's the lowest weight you've gotten a CX hatch down to?
- 92-00 Civic / Del Sol
- S20 tranny? and what is a P07 ECU?
- i have a question?
- 97 Del Sol Engine Harness
- FS: Brand new ignitor/ICM for Integra, Civic, CRX
- b18a1
- 92 honda civic hatchback nrg engine damper
- Cheapest place online to get JDM stanley corners for EG
- gsr cams vs b16
- Where to buy a D-series motor???
- question about apex exhausts?
- all motor b16
- Hatchy wit a bad GSR HELP!! ........ IM SENSORS OR WHAT?
- window wires
- Will '00 seats fit in my eg?
- Did search, all that came are classifieds. EK rear bumper on EG coupe.
- The plan (Opinions welcome!)
- Unorthodox
- other honda model exhaust pipes for civic??
- Pic request: 96-00 Hatch with the Vibrant Flat Black Muffler
- question on valvetrain on a b16a2
- Best 98' Hatch Sidemarker Template???
- 93 d15b7 idle problems
- 93 Civic Si
- 95 civic a/c system PAG oil Capacity
- jdm cluster and clock - whats going on?
- i'm new to honda-tech.
- sohc turbo
- Anybody else getting wierd IMs?
- car not idling...
- OEM products... Taiwan? Good or bad?
- where to find trunk shocks
- Ebay Strut Braces
- some cheap mfg sales websites
- u think i should buy this? and how much shuould i pay?
- b16a 94eg help
- 98 itr tranny on b16
- ALL-MOTOR HX...is it possible?
- 93 Civic Hatchback Suspension Knock
- How do u hook up Power Folding CTR mirrors..
- Problem starting stock EG ex(auto).
- Cabel Tranny in a civic coupe
- question about optima battery... help
- Fuse Under hood for ECU
- What does this color of my sparkplugs represent?
- 96-00 civic a/c fan fits del sol ?
- D15 transmission bolts reused on a b16??
- Normal amount of oil in catch can?
- Bad Bushing, bad!
- TRANSMISSION CODE????
- new distributor and now cel
- new york inspection
- ..::Attention New Yorkers::.. Inspection Question
- Engine needed: Civic VX (D15Z1)
- b18 maximum bore size
- need help, can i used obd0 on my b16 2nd gen obd1?
- quick ?
- weigh of the manual roof?
- Would you buy euro / EUDM EG headlights?
- cabel gear and hydraulic gear
- What would be a next upgrade...
- 95 EG Camber Kits
- motor mounts
- b18c4 into eg hatch mount problems (searched)
- what should i do with this.....b18c5
- b16a build newb
- Bolt size for EK hood?
- coilover sleeves + KYBs - need help!
- For Sale: I have an auto meter ultra lite air fuel guage and a couple transmissions
- Newly swapped B18b into VX hatch 94
- Vtec head
- eg rear seat in ek?
- new d16z6 swap: shifting doesn't feel right
- what to do next...any suggestions?
- Fields Vtec Controller ?
- taking out the stock civic deck
- Honda Type 2 Coolant the blue stuff
- What can I swap from a da?
- Gap between headlight..
- what is the del sol???
- Please identify this Honda OEM Part # For Del Sol
- should i buy a civic CX
- Loking to swap.
- neutral safety switch making my car not start?
- Which do you think is better? Wilwood brakes or Baer brakes?
- anything "wrong" with Ebay seats?
- misfortune with my 00 si
- D15B8 Firing Order
- 98-00 civic
- Spoon Brake Rotors?
- 1997 HX Need Help
- heat shield
- need help with "D" engine swap..
- need info about the eg6
- Speedometer keeps going out!!
- no spark
- Quiet while still good performing exhaust
- GSR cams or others in my Si........
- 200k miles on hatch.. time to replace drums?
- Need Help!
- how do i make foglights yellow???
- what distributor to use? odb2 engine obd1 chassis
- Code 14 won't go away!! HELP!!!!!!!!!
- AC + Throttle Body
- wat stage clutch should i get for a sohc turbo
- How do you adjust?
- greddy bolt on turbo kit
- QUESTION ABOUT BRAKES ON EG
- QUESTION ABOUT SUSEPENSION ON EG
