View Full Version : Honda Civic / Del Sol (1992 - 2000)
- where to buy it ??? 59500 cam
- alex cooling plate?
- noir exhaust and rear itr swaybar fitment problem
- Dumb question Can too much oil cause a car to run poorly???
- 99 jdm fog lights install running into problems.
- rc or precision?
- Any reputable honda tuning shops in the 253 tacoma area?
- em1 parts.
- integra brake lines ..onto Em1?
- ***COUPLE QUESTIONS: NOISE WHILE BRAKING, OBD2 TO OBD1 CONVERSION W/O A DIFFERENT ECU?***
- Civic Radiator...HELP!!!
- Benen tow hooks
- slave cylinder
- WHY IS MY ACCOUNT NOT WORKING???
- tryin to figure out filter size
- What is that thing called on hatches's rear window hatch?
- Need Tips/Advice on Wire Harness Removal Please!!!
- NEED HELP plz its my only car ( black smoke) grr
- 99 civic wont start
- Low RPM Running pig rich, no power after warming up.
- D16Y8 and D16Y7 injector close up picture? anyone
- exhaust / mufflers help
- I've run out of ideas... help!
- 1999 civic dx hatch with b18b1 swap NEED HELP.........
- header collector to downpipe flange problem
- 1999-2000 Honda Civic Si - FOGLIGHT SWITCH HELP!
- D16Y8 Idle issue
- DIY on disc conversion
- power window conversion with rear wiper
- integra front and rear seats in eg?
- Would a 92-93 Integra linakge fit an eg with b16?
- Hytech Replica Header yay or nay?
- headers on a gsr civic (what kind)
- Turbo JDM B18C Package on eBay.
- Grinding noise when turning sharp
- Help
- Idle Surge
- manual steering rack maintenance
- help please!!!
- My "Sol" searching is over
- codes 71 and 72
- Quick question (searched): How many o2 sensors for d15b7
- d16y8 with high idle , pulses to 3500 then drops to 2000 rpms help
- 15" buddyclub P1 SF wheels fits 282 mm discs and calipers?
- Sleeper Exhaust
- oil
- wireing a iacv
- what would i use?
- 99-00 OEM foglight help.
- which ecu to get auto-manual
- shock tower engine harness electrical connector removal
- rear disc brake piston
- Is it worth 1400?
- CHECK ENGINE LIGHT!!!!!!
- what ecu?searched
- Just bought a 97 civic
- P2R K20A2 EK Hatch
- TURBO SETUP
- Interior Paint for Type K Classy Gray - Dark Gray
- REDLINE TUNER TV
- PLEASE HELP....
- Windshield question.
- Replacing Passenger side Quarter glass
- any comment my civic
- blox racing camber kit?
- LOOKING FOR PERFORMANCE UPGRADES FOR 94 GSR
- Will 96-00 Civic Rear Shocks fit 94-01 integra
- iab troubleshoot
- Which is better?? the Mugent twin loop, Spoon N1 or Spoon Street Type?
- Has anyone heard how this muffler sounds? or even bought one?
- What do you guys think of these fog lights for the eg?
- best motor for autocross
- Del Sol will not rev over 4,000 RPMs
- request: standard equipment sheet for 92-95 honda civic sir and sir-ii in japan
- 92 civic side skirts
- Bought a motor: What should I replace before the swap?
- crank bolt..
- SIR Cluster
- what is this?
- Wheel Size and offsets?
- I just turbo'd my civic.
- boosting a GSR?
- starting problems please help
- Swap for my 1998 EK3
- valve adjustment screw
- What the heck does this go too/ do
- bubbling at about 3 grand..
- Brake boosters
- DOES EK COUPE HEADLINER FIT HATCH?
- 02 sensor voltage???
- key wont come out???
- little help here
- power problems
- dos and donts of stripping a car??
- How far do i cut the bumpstop?
- front bumper on a 94 civic sedan
- Need help fast. Iacv sensor...
- battery
- Where to buy good stock catalytic converters that will pass smog?
- What kind of power can i expect from this ?
- Civic Coupe Rear Lip Question i SEARCHED I PROMISE
- new em1 forum poll
- Did i get the wrong bushings?!?!
- I need an Oxygen Sensor for my 1998 civic
- 1992 honda civic hatchback
- what does h22 redline at?
- idle problem 94 civic dx 1.5
- Knock Sensor question
- for the electrical guru's
- power steering fluid
- Bought me a Del Sol.
- 96 civic dx w/ obd1 gsr swap
- DC2 Gauges in EG cluster
- Quick axle ?
- NEED HELP!!!! CANT REPLY ON FOR SALE FORUM...NEWBIE
- ecu question
- Logging my EJ Project if anyone is interested.
- Dyno Sheets for B series headers?
- Throwing a code 13....help
- creaky rear end
- to much oil wtf??
- EK hatch damper
- Lots of questions, take a look.
- Carbon fiber
- quick question... boosting d-series
- EG HID retrofit?
- NEED HELP.
- driving with warped rotors?
- Heater blowing cold air?
- gonna pick up a b16a obd1
- Shift linkage
- QUiet exhaust for a 99 civic turbo?
- h22 swap vs. d16 turbo
- off a tooth? (pic of cam gears under timing light)
- 92 Integra front seats in 95 Civic 4door
- Mounting aftermarket header to stock exhaust... HELP!
- low idle problem
- civic fan dead, no heater.
- ls weird idle on 94 si hatch.
- need your opinion
- Is this the factory grille? (EM1)
- Passenger side rear rim chewing through inside edge of tires
- adapting coilovers?
- how to clean sard sport ex filter
- What year is my B16a Head? Pic inside
- Main relay
- Type of Transmission Fluid for my trans?
- Tightening Emergency Brake?
- 2000 Civic SI?
- Head Gasket?
- Has anybody swapped a JDM tach into a US EG cluster?
- car won't start. bad distributor???
- crank angle sensor use to run individual coils
- Thermostat, slow to open....would this effect the heater output???
- clutch burning
- Long question but I need help!!
- Sedan Lip?
- Buzzing Sound
- Heater/Blower Unit Compatibility
- Check engine light and roof llight (transtop)
- why is my car shaking?
- my 96 honda civic sedan (jdm b18b)
- p30 ac bracket in EK for b series swap.
- Yet another annoying idle prob
- VTEC POINT WITH AGGRESSIVE CAMS,B16A2?
- Dont know the dam bolt size!!!! Help
- uneven rear disc braking ... help
- fuel pressure question???
- Boost for my Automatic? D16Y8
- i need help....
- Electric problems - HELP
- Identify this dowell
- Del Sol Suspension
- Storage question
- Noobie
- 00' Civic SI Turbo Build *PICS*
- 2.5 inch cat to a 2.36 exhaust.. will it fit?
- Need Help With Dome Light
- SIDE SKIRTS FOR 96 EK HATCHBACK???
- Overheating toubles
- cruise control
- 97 Civic EX looking for mods?
- my civic wont start
- motor mount or torque mount
- anyone ever use DA integra shocks on a civic?
- hey exhaust queation
- new member
- alternator belt
- 93 civic hatch lip on sedan?
- Coilovers. do you have to cut bump stop?
- headliner
- si wheels
- H22A v. B18C-R
- honda tech: i need your help reallly bad!!!!
- WHERE TO FIND/BUY GSR BRAKES
- Car sometimes have a tough time going into 1st gear
- 96 EK hatch automajic and b16a obd0 questions
- ehhh jdm b16a problem...
- GSR Master Clutch cylinder into 93 cx
- My girls turbo coupe!!!!!!!
- WILL EK COUPE CARPET FIT AN EK HATCH.
- h22 92-96 or 97 up?
- Upgrading JDM B16a Intake Manifold & Throttle Body
- green eg (philly)
- D16z6 Turbo
- toda springs with spec A's or not with stock (been seaching for days)
- Fuel pump doesn't come on everytime??? HELP!!!!
- need help on tranny
- So the winter temperatures are starting to set in...
- SIR cluster
- ek with h22
- I'm new and looking for a 99-2000 SI
- Am I in dager of hydroblock???
- SRS question!!
- VFAC Questions
- 1st engine build ?'s
- Y7 to Y8 intake mani swap
- help with resealing a headlight!!
- comptech lower brace and 22mm ctr sway, compatible?
- disc upgrade
- 96-00 ek bumper interchangeability questions
- weird iddel prolbem....
- Car misses when at rest
- Miss fire, Lack of power Below 5000RPM (My Vtec change over)
- Oil Burning Problem on my Z6
- h22 shifting link
- Help 94 HB Civic Dx Dies After 30 minutes of driving!!!!!
- Aftermarket LCA for 99 civic SI?
- would i adjust my valves differently???
- Car suddenly driving really loudly
- Integra gsr?
- New to HT
- Couple of questions... Easy, hopefully.
- lowering spring question
- Intake mani. swap...
- will this work for my 93' Si hatch?
- I think I have a clutch problem..?
- Would a H4 HID kit from an EK fit an EG?
- state ref?
- need help . clutch sinking in :(
- ls vtec in my coupe knocking!
- somethings funnie on my idle
- help with turbo
- jdm p30 question?
- what is all needed for cruise control?
- gas mileage
- Help? Cant find hp/tq numbers!
- Del Sol Lip
- Streetstyler.com
