View Full Version : Honda Civic / Del Sol (1992 - 2000)
- new times for the screamer!!!
- lip opinions
- Removing the grill off of an 99' Civic Coupe
- ground wire help
- Vtec Solenoid Filter... Missing? PLEASE Help.
- got a few questions regarding an exhaust and d16y8 cat
- 98 dx gauge cluster swap?
- Stereo/AM gauge question
- EXHAUST QUESTIONS
- help please tell me what the Hell went wrong
- Exhaust outlet?
- Overheating problem
- broken interior lock knob??
- Engine Sputtering
- I need a part # for Sidemarkers.......please help
- identifying skunk2, zex, oem sohc camshaft
- Can someone tell me what this thing on my floor is? (pics)
- help finding some stuff?
- interior conversion
- Tanabe GF210
- EK hatch trunk leak
- on your y8 mani swap what did you do with this
- 92 civic resistor box
- How To Fix My Header Situation?
- axles for b16a2 swap
- D14A2 to D15Z6 swap - please help!
- can i fill the tranny from this hole?
- struts
- putting back stock shifter
- distributir cap arrangement?
- Cam Seal Replacement / Also why am I running so rich?
- Tanabe baffle removal?
- 99-00 OEM foglight wiring
- is this a good deal?
- My moonroof sucks
- JDM Amber clock in my CX Hatch? Do i have the wiring?
- rotor size for 99 civic
- Need Carfax ASAP. who will help me get an EK?
- what do i need to use a gsr radiator in my ek?
- headlight
- Can you help me w/ this?
- gas smell in my eg?
- best place to get VOLK CE28Ns
- keep the color or change it (fixing and painting)?
- I desparately need a pic of the back of an EG gage cluster
- Honda Civic Coupe 2003 I want to lower it
- 96-00 civic coupe carpet into a 99 civic hatch
- close encounters of the 50 kind!
- Honda Access roof storage dimensions?
- what pistons?
- please help! Wiring an code nightmares
- Checking Eng. Code for a 95 DX??
- help trouble codes!
- i hate deer, i hate snow, and i hate crashing! please help me out!
- EG Noob here!
- type R sway bar on EG6
- questions about my dyno run today in my eg...WHAT U THINK
- B16a into eg wanting to use stock box which piping to use?
- 1991 Integra GS Disks on a 96+ civic?
- I have a question
- Just got me a invader carbon fiber hood need advice!!!
- EG6 cluster problems
- D15B VTEC...exhaust Questions..help
- Infinite-Forums
- USDM Integra Front end conversion on 95 Civic Hatch
- Not Running Like a Honda, got suggestions.
- Is it my aftermarket wires, or sign of something serious?
- How do I get front LCA off without that special tool??
- is this a camber kit???
- b16a2 time slip in EG hb with 17's. can i do better?
- my vx
- tryin to find some Vision corners
- 94si
- 98 spec jdm iotr headers
- car idles fine for a min or two , then gets shitty??????????/
- post pics of your roll bars in your car pls.....
- lsvtec bad idle/bog
- Getting Ready - Engine bay Picts 56k No no
- How Do I remove This Shift Cable From An Automatic Tranny
- show me your aftermarket steering wheels.....
- My pops' radiator is overflowing
- Turbo question....
- I have the worse luck, check this out now....
- 00 si rims
- dumb question 4 a 93 dx hb
- distributor timing cause engine to shake?
- Can someone in the Socal area install 2 gauge's with the pod for a friend of mine, he will pay?
- thinking of geting body kit do i need to paint hole car?
- Bride Zeta II Seat Rail Question
- Pullin AC belt on Em1, notice power gains????
- Can I make my CX have intermittent wipers???
- what kind of springs to use??????
- Need quick answer... searched but making sure!
- no o2 sensor = valve tapping???
- Just finished my car
- look what I got for $600
- can I get a pic of an eg on blades
- P72 OBD1 ECU...
- Benen tow hooks
- AC Bracket motor mount
- its been a long day and i need help
- looking for SPOON high tension wires pictures!!!
- licsense pate brackets..??
- 92 civic speedo problems
- 15 grand worth it?
- Domani?
- Where could i find some sort of Write up on how to install springs?
- Stuck in traffic, car overheating
- Dyno'ed the civic today
- HKS Exhaust
- eg radiator in ek
- hola!
- Swappage wont start
- Check engine light: code 7(TPS)??
- is this a good buy? 93 DX
- guage pod installation
- STOLEN HATCH! big reward if found intact
- AEM CAI, STOCK AIR BOX: HOW ABOUT BOTH !!!!!
- Apex N1 Exhaust trouble
- Speedometer problem
- another header ?
- Are all d-series trannies the same for 92-2000 civic si, or ex?
- D series compression Calculator?
- EK brake swap help. please.
- Need help car running rich
- COnverting from Auto to Manual??? (help)
- gsr armrest
- CTR 5-lug brake pads??
- want some info on this car
- Cost of Swap???
- My car is running laggy
- Noise while engaging clutch
- 93 civic hb mid wing or carbon fiber upper duck bill?
- 2000 Honda Civic EX-BEST HP to $$ ratio
- type-r suspension on EK
- Will a CTR LSD fit in a 99-00 Si S4C tranny?
- help with engine decision
- painted my roof **pics**
- D-series Header Poll, I already searched
- What sites do you go to when looking to purchase a vehicle?
- installed my new LCA's **pics**
- Where is the jumper cable for the ECU? 92 Hatch Si
- need help deciding: b20 or gsr hatch?
- Quick Question N Quick Answer Please...
- what are some...
- help quick! i need pics of engine rebuilds, like during the process!!!
- Here's an update on what's going on
- sensor things???
- del sol plate fillers
- wanting something diff than autometer!!!!!!!!
- 99-00 si // can strut bar go backwards // or hit map sensor?
- Pics of my SI...
- Ls engine with GSR tranny?
- CRX Si cam in DX
- clutch is shaking, slipping, and grinding so bad my car can barely move. :(:(:(:(:(
- Air Conditioner Mount
- stainless steel brake lines on an EG with GSR brakes
- How hard is it to install valves?
- pics of my klean LS civc
- 92 ex intermitted problem
- Does anyone know whos car this is. I want to know more about it.
- b16a transplant
- Suggestion please...what weight oil?
- ***New Carbon Fiber front lip/splitter option for EGs.***
- which cam to get with z6/b7 mini me
- p70 ecu?
- carbon fiber repair
- rear wiper for eg hatch
- question about a mini me swap
- Anyone know where to get this part?
- What should I do?
- need help on clutch pedal!!
- HR Sports for a 94-01 Integra fit a 95 civic ex?
- Is there a single cam LSD tranny?
- Honda Civic EG6 with B18 GSR swap? how?
- 96 hatch neuspeed springs camber questions
- Location of o2 sensor wires on ex harness
- Access Visor install on 99-00 ek 56k run for your lives. 640x480
- what cam gear?
- bogging under 4k
- Doors. Are they the same?
- my slow coupe pics, what do you think??
- momo hub issues help!!!
- Does anyone know where i can find a right hand drive EG
- rear disc brake question
- keyless entry for 98 civic ex any help would be great
- HELP! B16 w/ITR intake manifold!
- Does anybody know a good site showing how to install a new head?
- tie rod help
- JDM 4-1 into a stock civic cat?
- Jdm eg bumper with wrap around mouldings?
- ctr with what ecu
- Type R suspension
- some parts for my b18c1...under $1000
- Spring rates
- Carbon Fiber Front Lip for EK??
- anyone have some in depth knowledge of gage clusters?
- tranny gear sets
- need hood and both driver passenger doors for 94 DX hatch
- Put my engine in today... PICS
- tuning del sol on dyno with vafc
- old school ground control coilovers
- Carfax please
- What the best price and place to buy a water pump?
- thoughts on engine mounts
- y8 manifold swap question? which TB gasket
- rsr ti2000 springs
- i am back on the road whoo hoo
- intake manifold gunk, need to clean?
- How Do You Remove Rear Panels In A 93 DX Coupe
- Which pistons for d15 mini me
- Pic request: 15'' black rodas on a black civic si 00
- dc header not fitting!!!!!!!
- So. Cal. swaps?
- 95 civic coupe fender?
- Advice: Cheapest 96 Civic suspension to get?
- how to adjust B&M FPR.. n00bish Q
- 95 civic ex 2 door ??
- Engine code list/ect. [B]THIS IS A LINK[/B]
- SHO vs. honda??
- 93 Civic EX Transmission Findings
- Cleaning an engine!!!
- VTEC weakening out on me...
- Can everyone help with my decision??????
- Newbie here....My Civic R replica
- HELP ASAP!! Bumper from 99 hatch fit a 99 coupe?
- Your Swap
- 2 new small vids with decent cameraing...
- Carbon Fiber Weave ?
- Paradise blue green hatch
- Problem when shifting on WOT
- Groundcontrol or Eibach Pro kit
- newb, lug pattern??
- I wouldn't post something like this
- will this catch can setup work?
- What helped you decide -- EG or EK?
- Need help! Tranny related (sohc)
- No luck selling my Del Sol
- power/weight/1/4mile time..96 dx hatch. HELP!!
- (searched) sporadically soft clutch pedal
- Ground Control Coils **Help needed**
- Spring Compatibility
- A Story of my Hatch/ D15b7 to d16z6 / Pictures / Info / ..bored silly..
- 94 si questions please read...
- need to carry parts in my ciivc, wondering on weight
- DIY/How-To: Sound Deaden your Ceiling/Roof (56k welcome) *pics*
- R.I.P b18c1 EG..
- Tower Bar installation for EK non Si (EX) d16y8 manifold type strut bar
- Creeking sound... 99 civic
- what bulbs in projectors
