View Full Version : Honda Civic / Del Sol (1992 - 2000)
- any way to get factory keyless to work with an aftermarket radio?
- SkyeC's Garage Sale! (B-series, EG, SRR, Goodridge, misc)
- EKcivic Handling
- VIN decoding
- Jdm d15b rods
- What to do about the vin on a dash swap?
- hairdryer on spraypaint?
- ls motor??
- blown tie rod boot?
- need help removing auto tranny from 2000 civic
- Where to buy Brembo Rotors?
- Turbo D Finally Died
- Del Sol cruise, nad fuse help
- d15 vtec question
- how to aim headlights on an eg?
- IAT Question Bseries swap
- About How Much Would It Cost to Replace a ripped cv boot?
- Where to Find a ECU map ?
- 2000 civic driver side mount..
- Swapping a 1st gen B16 into a 99 ex sensors
- cold idle
- child seat brackets.. part to cover hole??
- Timing belt question [which one?]
- Trunk Weatherstripping?!
- Seafoam= Good Or Bad
- All motor....
- 94 not idling smooth
- interrior panel light conversion
- New Interior...
- How to take out a bolt that is stripped?
- 2000 civic fender removal
- HELP! Can't find fog light plug (the one behind the fog light switch)
- Turbo + Individual Throttle Bodies???
- Back order on head bolts, now what?
- Coupe front end on a Sedan
- nitrogen ?
- i dont know what i should do...b20 or bore out a b16
- Trick my ECU into fixing my timing ???????
- where the hell is the water temperature sensor
- Just replace one shock or both?
- eg disc conversion ?
- Honda VTI (SI) (B16A2 Engine) serious problem
- For the b16b haters, A few pics of the beater on the mustang dyno (near stock)
- French newbie with D16Z6 HB
- What Gauges Do You Suggest?
- Bigger injectors OR FPR
- WTT: Carbon Fiber Z3 fenders for stock coupe/hatch fenders
- brakes?
- Tranny bolts
- D15Z1???????
- Front Suspension noise
- Header Prob?
- maintenance issues
- 94 Civic running crappy
- Rear Swaybar problem on 92 Si Hatch
- Help on uberdata setup for Y8
- gsr rotors civic brakes
- Portland, Oregon
- Spark plug wires wont stay connected?!?
- My review of the Korbach frame locks on my HX
- How do you takke out an auto shifter?
- Tranny noise
- OEM airbox fitment/interchangeability question
- Greddy or Skunk2
- Varying Idle, TWO different idles, Then Overheating..... HELP
- 99-00 oem tail lights
- Slop in drivetrain????
- Fluid for a ctr tranny?
- pics request: front end conversion
- chipped hx?
- Constant tranny noise, thought I knew what it was but now Im not sure (SEARCHED)
- LOUD AZZ WHINING FROM DEAD STOP
- sun pro?
- cleanin out cat
- catalytic converter replacement?
- skunk 2 camber sounds like the titanic
- 2000 civic si OEM strut bar question
- Code 4 ckp sensor... help!!!! n(new jdm b16a swap into EK)
- ~my 98 civic~
- water pump?
- tweeters in ej
- o2 power wire color
- where to find abs plastic duckbill wing for EG
- 2.5" exhaust piping to stock muffler?
- which setup for daily driver b18b-t vs lstvec
- Speedometer Doesnt Work??? HELP, Please!!!
- tail lights
- injectors are all the same sohc's d15 d16?
- carbon fiber hatch......?
- will an exhaust made for an 92-95 hatch fit a 92-95 2 door?
- 4door windshield fit a hatch?
- Civic Type R Color ?
- How can i make it faster
- What does it take to do manual swap 02 civic
- RSR EXMAG Fittment?
- What struts?
- Windshield wiper motor? :(
- newbie here: having problems w/ my ´92 1.5 auto. CIVIC
- New horn wont turn off w/o pulling the fuse?
- Power window problem with my 1999 Civic EX coupe
- primary oxygen sensor "HEATER"
- skunk 2 or tanabe
- Lug Nut Torque?
- what websites can i go to to find the hp of stock motors.
- EK w gsr need some help on power steering
- Omni Power Test Pipe..anyone have it?
- What sohc swap should i do ?
- Just installed Korbach Frame Locks on my EG...
- 99 civic dome light problems...
- lower control arm bolt broke!!!
- light crank pulley
- will a gsr intake arm fit a 92-95 civic stock intake
- exhaust rattling
- y7 /z6 mini me problems
- DO ITR seat bolt into EG and EK?
- Firewall question
- Humming/whining sound from left dash area...
- Starting Problems
- what to do with my b18c?
- 92 civic start up woes...:(
- Import Shop Input...
- Cable tranny?
- MODS A little help please....Anyone want a Free Monthly Magazine?
- 92Si disk brake setup conversion
- Should I be worried?
- Crack In Tail Lights = Fixable???
- gsr sway bar on civic
- 2000 cx with a 93 ex......
- a question about tail lights
- distrubutor and spark plug wires config. which 1 goes in which
- Oxygen Malfunction ?
- intake ?
- Running Lean?
- power mirror's messing up help
- NEWB QUESTION - d16z6 swap
- what type of bolt goes here?!!
- help...i need somebody(weird clikkity clank)......
- what to do first, bottom or top end
- ima newbie
- Rust on the EG rear quarter panel
- 99 Accord CD player into a 94 DX hatch. Need help.
- rota gt3 !!!! hooooook it uppp
- is this an acceptable radiator?
- rota gt3s? hoook it up
- d16 turbo
- anybody have pics of 15's on an ek
- HELP: air/fuel and o2 sensor question (legitimate)
- Good deal on Bilstein shock with ground control coilovers?
- Del Sol PhotoShoot. Tell me what you think:
- how can tell if i got an lsd tranny
- New b16 swap (97 Ek with OBD1 B16a) Code 14 IACV
- New 1.6 el cluster low fuel light
- help: will o2 sensor rib my hp?
- Reverse Lights. Please help 94 civic 97 b18b1 91 integra cable tranny...HELP PLEASE!
- will these fit? help ...
- short shifter helpp
- is this a good turbo setup
- what engine is this?(minime info)
- S2000 Gage cluster
- Suspension question!!!
- code 33? yeah i serached wont search just 33 :/
- Noob Engine Swap???
- white spark plug on b16a
- valve adjustment after cam install?
- 00' si got broken into...
- 02 fuse
- hks exhaust question
- When my car warms up the shift knob vibrates, is this normal?
- N00b!
- Parts List. Add What I'm Missing..(posted in allmotor as well - too slow)
- valves???
- Question about short shifters?
- b16a head gasket/internals question
- Help! Parts # for front O2 sensor, 00 Si
- WTB speed sensor, Throttle body, gasket set, rims and with tires perferably rotas, cf hood
- d16y7 O2 question..please help
- mugen bumper
- help with using aircraft remover, paint wont come off.
- LS SWAP/HEADER DOESN,T FIT
- Climate Control Relocation?
- NEED HELP ASAP!!!
- Del Sol S or Si?
- de-riceifying my riced up civic
- ek hatch wheels pic request kinda
- eg rear spoiler installation...
- Suspension Question...
- B16A2
- starter bad on em1 so soon!!
- Cam Gear Install -NEED HELP-
- where is the b16a tps sensor?
- Srs light codes meaning
- boost reliability help
- broke the hood release plastic tab
- Compatibility of SI -vs- EX/DX struts??
- Spoon N1 question for EG hatchback
- ZCs, D15B's, and D16A's
- clutch line
- Headlight reminder beeper
- Type R shift knob question???
- OBX LSD Help
- Which SS brake lines on EG w/GSR brakes? Pls Help!
- Power steering to maual conversion (pump removal)???
- 97 Hatch swap...
- o2 sensor question for OBD2
- Importance of water pump replacement?
- Need Help!
- ~~~~2000 Civic Si Help~~~~~~~~~~
- preventing theft help
- pls help me with my hatch
- Axle-Back Exhaust Muffler........ ?
- popping noise when car jerks
- Lights Dim @ around 3700-3900rpm
- OBD1 or OBD2...?
- dont know what to do
- Paint on valve cover....
- Hoist mounting points for a MT 93 DX HB?
- Civic radiator ????????????
- How do you tell spring rates
- Any of you with 92-95 who have installed an aftermarket deck...
- Tune-ups at 100k? DIY or pay?
- Good price on a block?
- car idles crazy
- Civic window visors?
- LED shift knob
- HELP what emergency brake cable can I use
- how do i read my oil pressure gauge?..what to look for?
- 94 Civic running rough....HELP
- Tow hooks + rusted bolts = WTF???
- Password Carbon Fiber PowerChamber intake EK
- brakes ......... help
- must have vtech power!
- Where to buy CASPER SHIELDS?
- Dash swap now SRS light on searched need help
- Overheating again
- Depo foglights problem
- good slotted rotors and pads that fit hx rims
- air fuel ratio????
- Rear Lip Question
- FRAME REPAIR SHOPS IN BAY AREA?
- D16y7 fans wont turn on, missing a sensor? coolant temp/sender?
- desperately need help! OVERHEATING 99 civic si
- just finished my swap but need help on SOme BUGS
- Chicago land area, shop needed, and Questions??
- 96+ springs
- hybrid car not doing so good...
- in the cross roads!
- Any suggestions on new mods?.
- question about rev limit on 96 ex auto
- CEL 67?
- rpm problems after head change
