View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what size es tuning should i get?
- b18c or k swap
- 2001 civic coilovers on EK
- 6th gen cluster swap
- 96 gsr wiring harness
- '97 civic coupe headlight tuck ????
- Only the fan turns on when trying to start..
- what would you do if you were in my situation?
- what kind of head is a y7?
- cold air intake on an automatic. good or bad?
- High Beams keep blowing
- rusty hood brown color
- Which one is better?Steel or aluminium flywheel?
- Turn over no start
- Routing for rear screen washer tube?
- looking for some opinions
- possible water in engine??
- d16y8 swap problems
- 97 civic fan problem
- 96 civic with b18c1 motor help
- Insanely High Idle
- Good or bad clutch purchase. need some imput!!!!!
- ej8,ek,em1 headlight & component tuck guide
- need help.... Please
- blox type c camshaft questions!!!!! NEED HELP!
- Trans/clutch noise..
- Why does my car idle go down to 500 when putting the ac on full. Help!!
- Can I use these injectors on my b20 vtec
- I need SPOON EG YELLOW COLOR CODE!
- Radiator support off of eBay?
- Replacing Swaybar Endlinks
- OK idle Problem checked past posts need more info
- Y is my car overheating?
- 1993 civic ex
- Pic Request: Innovative Cable trans on B in hydro car kit
- IDLE AIR CONTROL VALVE
- EG TURBO overheating NEED HELP
- Honda Civic 92. Passenger Side Creaking
- IACV Question.
- 94 del sol suspension squeak help me diagnose please.
- Check out the deal of the century
- where's all my coolant disappearing to??
- Need help with B.A.R. need help fast.
- d16y5 block y8 head
- Frustrating Stalling Issue
- Exhaust Question
- Code 41 on a 1994 Civic CX
- ls wireing help asap !!
- Correct starter for 94 Civic DX
- ideling and miss fire problem
- 92 hatch help
- Does anyone have some torq specs for a d series motor?
- 98 civic hatch starting/stalling problems
- EK civic overheating problem
- Ek engine wiring Help (motor change) auto to manual
- Wanting to do disc brakes all around 97ex help plz
- oil ports line up
- 99 Civic SI overheating issues
- build thread for SI!
- EG suspension issue
- From a EK to a EG?
- B18a1 Help
- Knock Sensor
- Why is my civic Idling weird
- 1993 D15b7 to JDM D15b Swap
- ECU Confusion! Help!
- EM1 or EP3?
- Car to low for alignment rack
- Scratched Engine bearings ? ?
- help! how to rebuild motor
- 1996 hatch
- Transmission mount Bolt question
- my car....(pics)
- Gauge Light Problem Help
- Never really took care of my car...
- new uglyness from texas
- how much power loss intalling a stock cat? how much less noice with a cat??
- clutch...
- help! limp home mode
- d16 head question help please
- help....
- Can you check a CEL without a CEL in your cluster?
- obd2 vs obd2(b)
- Axle Help!!!!
- i need rear complete panels for my hatch
- b-swapped guys/gals come inside please!!
- NNED HELP!!96-00 CIVIC ALTENATOR PROBLEMS???
- ECU recomendation?
- how to fix my fan problem on my hatch b series swap
- Weatherstripping for 96-98 Rear Lip?
- help only 3.5 v
- High reved B16a2 :(
- Air conditioner problem
- Is tthis a 92-95 Spoiler on my 2000 EX?
- 98 civic EX that won't start
- Eg Wiring Experts chime in...
- Del Sol DOHC VTEC BRAKE PADS
- brake lights not working?!!!
- b18b serious issues!
- 95 SI BRAKE CHANGING PROBLEM!!HELP
- h22a t bracket in a eg
- I May Put An 06 RSX Type S K20 Motor In My EG I've Researched Just Need More Info???
- d16y7 oil problems
- MAX Voltage I should Expect at battery. EG/GSR Swap
- JDM OR EDM cluster?
- Spark Plug issue
- how to pull out del sol center vent?
- D to f engine swap help
- Ignition Options (Type R swap)
- where can i get nex cat for my em1 ? Cali car
- Swapping y8 into a 96 DX.
- what engine comes on civic 93 DXi Hatch
- Where is my coolant going ? ut oh..
- Removing Civic Floor Harness *HELP*
- timing for B-series motor
- sohc builds?
- rear disk conversion ques..
- New here.
- torque specs
- Compare ES Tuning to Apexi WSII
- J32A2 swap + rwd civic?
- Emissions complications. UGH.
- D16 manifold on a D15 engine
- civic cx oxigen sensor
- will ef springs work on ej?
- High rev on start up
- <br>Brake lights<br>
- car cranks but no fuel and no spark. HELP!!
- OBD2b IAB wiring
- Looking for CRX del Sol MOTEGI Seat covers
- RE:Economical Security Measures~!
- 2nd Gen B20
- Is a LS b18b1 a great setup in a eg 4dr.
- can you get a new vin sticker from the dealer?
- [YA'M - France] A CraZy CiViC CouPe
- Steering rack tie rod ends - the same?
- RADIATOR FLUSH - quick question
- Which engine mount/bushing/bracket with DC subframe?
- is there a difference between rear wheel bearings??? for either drums and rear discs
- i need help
- my new eg hatch
- Replacing exhaust bolts
- boost/tuning questions
- Rust in Gas Tank..
- Why does my rear always go down after adjusting the coilovers up.
- ARC Induction box question
- Stolen MARYLAND, 99 Civic Hatchback. Dark Amethyst
- VSS question
- GSR swapped 99 civic Start up problem!!!
- Radiator/cooling system issues
- b16a clutch?
- Identifying head by it's markings..
- inspecting head, help me look for damage (pics)
- What transmission for F20B?
- JDM civic thin side molding color codes...
- Best/Cheapest EG/EH Duckbill? OEM Wing and 3rd Light MELTED!
- 95 Honda Civic Hatchback - Where to start?
- 1997 civic ex not starting
- Post Valve set electrical issue
- B18b vs B18c, feel similar?
- rust hood help
- 00 civic downstream o2 sensor?
- speedo problem.... help me honda experts
- 3 to 2 pin iacv help
- 1994 Civic Cx Chuggin
- is this t kit worth it?
- non-constant source for gauge lighting
- horn stopped working
- thermostat housing issue
- please identify this lsd
- what is this car worth
- Need advice! Sell or Keep? I'm getting nickel and dimed to death!
- Info on how to change wheel studs
- Power door internals int Non power doors? poosible?
- 93 civic with b18b1...what is the stock rpm cut off? PICS INSIDE
- give it gas and it dies!!!
- B16 turbo having trouble boosting up.
- VTEC wiring ?, searched and FAQ
- y8 to z6 swap???
- Transmission problem HELP !!!
- 2 Broken Cranks?! WTF
- New EG hatch... a few problems.
- 97 Honda Civic upgrade ideas??
- ac removal help
- Help: B18A into EJ6 (1996 Civic)
- Pics of a 1995 Honda Civic -7sinsphoto
- Another A/C broke thread
- *98 civic dx build ek4 exterior/ek9 interior b20
- Yet another eg ls turbo ques
- window motor/reg
- My Project..the dreaded beginning lol
- Manually trunk release..
- These plugs suppose to go anywhere
- Installing Y8 head on Y7 engine whats CR
- Integra/Civic transmission bolts
- Check for lsd with the trans in the car?
- D16 Rebuild HELP
- 97 civic owned for a yr what u think
- throttle cable question eg 4 door ls swap
- Obd1 B20B overheating issue
- 97 Civic Lower Control Arm Nut issue..
- trying to do a clutch on stock eg d15
- 94 eg still wont start
- obd1 jdm15bV wiring help
- alarm wiring
- Fog light mounting bracket
- RX729 hella flush EK 4dr Civic
- F20B with H22 Head?! What works what doesn't?
- mufflers??
- D16-Y8
- 95 Ex Coupe
- Fuel pump is having problems priming
- wiring knock sensor
- B18b in 92 Eg Hatch with Map issues
- leaking coolant and rusty coolant
- Head Gasket??
- B16B What Makes it Worth It?
- Secondary o2 GSR question
- Where can I buy a 95 Civic alternator pigtail plug?
- my black ej1
- Drilled and Slotted Brake Rotors?
- 92 civic hatch with b18c1 swap Q's
- cel with headers
- whats better a b16 head or gsr for ls vtec
- '00 Si Power Locks Remote
- d16z6 to b18b1
- K20/K24 BUILD TRANNY QUESTION
- 99 CIVIC DX HATCH POWER WINDOWS POWER LOCKS
- 98 Honda Civic 1500RPM surge need help!!
- simple question
- Just switched to a new Japanese synthetic motor oil.
- s2000 cluster in 96 hatchback
- Looking for replacement tire on 93 del Sol si
- iat code 10!!
- piggy back/ flash program???
- F*$K Valve cover bolts broke
- all power windows wont roll down!
- Cant get past 3500 rpm, throwing codes 3,7,10
- fuse box not working
- car paint removal ques.
- 8th gen side mirrors on EK
- disconnected my brake booster, help needed! EJ1
- help please!
- del sol overheating need help
- 1993 Overheating Honda Del Sol
- SideMarker Install
- integra rotors andbrakes on a 96 dx?
- Tried to fix previous idle problem...now stuck with new idle problem :(
- My Car is overheating! I'm stumped
- in need of help with wire issue
