View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Fluctuating Gas Gauge...Any help?
- Will 99-00 lip fit 96-98?
- ecu wiring harness
- what are the biggest cams i can run on a stock b20/vtec setup??
- Help with d series
- Stainless End fittings size help and info
- request pixs of rolled over EG w/ auto power. (searched)
- turbo
- first start attempt and solid cel
- chip
- interior lighing ceiling.
- missing link. and Vafc and crome?
- should i paint
- wireing ftps into 96 dx. ff-squad.com referred
- e-brake light
- Password: JDM.
- Differentiate between auto to standard swap and standard to standard swap - Need HELP please!
- 97 civic coupe dash lights dead after installing aftermarket stereo
- (92 Civic dx) New brake pads are 1/2 inch shorter than old pads.
- 00 civic si problem
- can a z6 head fit in a y7's block?
- ls vtec with ls pistons, skunk 2 valvetrain and skunk2 tuner stage 3 cams problem
- 9.3mm plug wires
- help, my radiator fan is not working.
- Del Sol Question!!!
- Radiator is not working
- HELP! axles are moving in neutrol gear.
- Learned something new about JDM ecu's
- EG suspension
- Engine
- CAN STOCK INTERNALS HOLD?????B20VTEC turbo vs lsvtec turbo
- how much nitrous is safe for this setup?
- where can i buy a OBD1 on crome?
- 93 Civic Climate Control
- B18A Swap into 1992 CX HB?What parts do i need to get from both cars?
- idle control valve took a crap.
- VX with EX motor harness & 02 sensor?
- clutch problem on 96 hx
- Google Street View and my del sol....
- Please part number for new locks w/ key.....
- Aftermarket taillights
- stock bumpstop on gc/konis
- what half shaft to use with my h22a4 swap???
- what ecu is p28-346??? del sol obd2??
- witch head bolt?
- Bar'ing: LS MOTOR
- Best way to remove "Civic DX" sticker...
- HELP!!Squealing Noise When I Start My Car?
- DX EK (D16Y7) aftermarket cats? What do people use?
- BEST PARTS SITE!
- For those who has hasport mounts
- oil squriter removel
- 2000 ex civic project
- I Smell Clutch While in Neutral
- type r replica rims
- suspect fueling problem
- EG6 SIR interior help
- What can i do to make my car quieter?
- Extra plug after doing LS swap
- wiring problem
- NEED HELP !!!!!!!!!!!!
- Slight bog?
- Price of couple things im looking to add
- Cluster Problem
- stock tire size
- Strut bar
- bolts for window roler what size?
- D16Z6 intake mani onto D16Y7?
- ??will obd1 dohc zc would wire up perfectly to eg6 si??
- pinging on my right hand-side
- Misfire
- exhaust leak - possible cracked manifold, unsure
- dropped a cyl + lots of steam from exh. HELP pls!!
- front bumper falling off/too low in the snow/acting as a snow plow
- Car Jerks During Acceleration
- need help!!!
- what rear mount to use for my 92 h22a4 civic???
- Si Engine Harness In 99-00 CX
- 1999-2000 ek sir?
- Ek Dash
- Beaks or ASR?
- Tranny Motor Mount failing
- ANY THREADS OF EG PICTURES/EG SQUADS?
- EG Front End Assembly
- Need more Tourqe and HP..........................
- High flow cat. converter/ test pipe
- O2 signal wire on a OBD1 where is it?
- Bulbs in 97 civic dx climate control
- my 94 civic turbo build thread :D
- B16 NO VTEC
- B16 Crank pulley came off and now car won't startd the battery light comes on
- Start Up Issu,
- Integra cluster in EK civic
- muffler problem!!!
- When doing a core change for axles on .... please help...
- D16Z6 to h22a engine swap
- injector resistors
- Can I put my car up for sale here in this forum or no?
- steering rack bushings?
- Throwout, and pilot bearing help
- putting a v-tec head in a d16y7? is it worth it?
- HELP WITH LEAKING OIL FROM ENGINE!!!!
- ek9 power folding mirrors
- b16b head vs b16a head how to tell apart?
- vtec solenoid problems
- Can't turn my shock body.......frustrated !!
- lookin for pics of black ek coupes
- tail light on eg vs ej1
- Front lip.
- b16a3 ek swap status....
- Cat problem
- 99 civic ECU Problem
- CLUTCH QUESTIONS, PLEASE HELP
- What to do with cut dimmer wire ???
- Wire colors?
- pipe question?
- timing belt noise
- Horn Hook up with quick release
- idle problem
- Thinking about getting a chipped ECU from phearable.. couple of questions..
- WHICH WAY TO GO?
- Forcing a shift in an automatic transmission
- quick question rims?
- 96 ek---obd II ls swap BLOWN MOTOR
- Need some info on f22b into EK
- new to importationism
- Stock axleback for EG hatch ?
- noob just trying to sell things...
- adjust my idle?
- 97 ek hatch, gas guage not working?
- eagle and crowler parts should I use ?
- dc to ek suspension compatability....
- CEL map sensor and idle control.... how to fix?
- How do i get rid of the trial account?
- Urgent! 93 Civic EX Power Window wiring diagram passenger side!
- del sol RLCA with ek hatch????
- knock sensor needed ASAP
- Miles & Speedometer not working...
- Cassette Player Console Replacement
- How to replace broken rear motor mount on a b16a engine
- how i got my car to run Whooo hooo!
- Is Intake Manifold Build-Up Normal?
- importing an ek9....
- Best way to get at least 200HP out of an auto D16 w/stock internals?
- help, car has very rough start then oil coming out of filter.
- How to Wire a Boost gauge
- Intermittant CEL question
- need help for my ek
- ls ecu in d16y7
- LSD on a d16
- HELP?CAN BAD SPARKPLUG SEALS CAUSE SMOKE????
- anyone have a bolts diagram for a ek hatch rear spoiler?
- Removing sound deadening material w/o ice.
- driveshafts???
- How do you remove the ashtray in the console for the rear?
- Help installing a C-Pillar Bar in a 93 Hatch..
- ignitor questionable
- Battery Light
- Help 92 Civic Hatch Radio Removal
- intake question
- gsr cluster into EK
- Which OEM rubber intake tube flows better? EDM 91-95 Civic 1.6 ESi vs. USDM 92-95 Civic EX/Si (pics
- electrical problems?
- OBD-II to VAFC-II install.
- FMU and MPG does smaller = more?
- Noise after crank up?
- Sedan Japan Made???
- rear disc conversion?
- overdrive question
- 95 hb si
- Carbon Fiber
- 20 mpg???
- Anyone have just a rear set of mudguards ?
- Brake Pads?
- D15b throttle body
- 94 civic si rear brakes
- Who's car is this?
- help car runs out of gas at 1/2 tank
- failed pressure test @ AZ emissions/inspection
- Need advice on Refing my car *searched* help!
- SHOW ME YOUR GRAY EK'S!
- Moly Grease on my suspension
- aftermarket steering wheel
- 92eg, installing actuators for power door locks?
- I need some answers!!!!!!
- what are these motor mount rubbers called?
- One more rear brake conversion question
- should i use itbs or a turbo on a d16
- 1997 honda civic hx cvt transmission to 97 civic dx manual swap
- resistor box plug in
- si
- What should i look for prior to purchasing a car?
- Acura 1.6 EL front end?
- what do you guys get for MPG?
- Windshield Wiper motor replacement
- Wow is this true???
- b16 eg, cold start problems....
- h22 supercharged
- CEL code P0505. what to do?
- FOG LIGHTS!!!!!!!!!!!
- Gear swap in a b-series transmission
- engine type question
- Will this fit?
- ek interior color question...?
- auto to manual question
- Please!!! I need help with my SI decision...
- car dies when cold start
- I have a problem with Power door locks!!!
- Issues with voltage, speed sensor, and pulsing lights.
- b16 Tranny?
- spark issues
- tranny swap
- Skunk2 Intake Manifold and Skunk2 Throttle Body Question...
- cel #65
- building a d16z6
- Ok I need Help with a 02 problem
- why wont
- does anyone know what kind of bumper this is
- help with codes part 2
- Exhaust Leak
- 5lug question...
- Swapping My Teg into a civic...in a way
- map sensor codes and 3000 rpm rev limiter HELP!!!!
- Cant get door panel on!!
- Results of main relay test. Now I have a ?? PLEASE HELP!!!!!
- armrest
- what do you guys think about these rims
- Clutch
- cluster????
- SMOKE
- Help with sound system!
- Rear Disc brake Caliper
- 96 civic coupe navigation
- stripped flywheel bolts
- Is there money to be made buying a Del Sol shell?
- OBD1 Gsr in OBD2a Civic Dx CEL Help
- B16A and B18C water pump and timing belt compatible?
- Where does everyone buy their
- help check engine light
- wrapping seats, visors, headliners
- RE USING HEAD GASKETS?
- Aftermarket pistons - standard or oversize?
- 97 dx head swap
- drum brake problem
- intake manifold.
- Fuel economy
- B18b or B16 to hit 13s?
- Going form boost back to NA
- BITCH PIN TOOL ?
- b20 vtec turbo
