View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 94 Civic RSX dash?
- head installed valve noise troubleshoot.
- 95 delsol s Swap rebuild advise?
- 99 Civix Ex - What Performance parts?
- Input on Transmission Options
- Driver's side headlight issue
- I think my cars previous owner wrecked it
- Fuel pump Assy. to hard pipe hose
- Weird start
- 99 Civic EX Intermittent ABS light with no AC/heating blower
- which thottle cable/bracket/pulley to use? D16y7
- need help finding good rod and main bearings.
- need help finding these
- Part Number for this Fuel Hose
- OBDI scanner or OBDII to OBDI adapter?
- Traction Bar clearance
- 1999 Civic DX hatch
- CEL 8 - TDC Sensor
- Check engine Codes
- Anyone finding that engine temp low in winter?
- Noisy water pump - and new...
- another random no start issue :(
- civic choke and sputter when press gas
- quick check up on ek b20 swap
- Parts for the front end
- Omni power vs oem clutch master cylinders
- 4lug ITR brake HELP!
- Fuel Rail Question.
- Idle issue
- EM1 Engine noise, Thoughts?
- d15b7 block/d16z6 head - What timing belt?
- 96 civic ex b18a1 obd-0 swap help
- coolant temp fluctuating and oil leak
- Facelift to Pre-Facelift Conversion.
- d16y8 with obd1 throttle body help!
- Valve ticking
- Opinion on Seat Belts
- Another misfire question. HELP??
- Idle Air Control Valve Phillips Screws for coolant pipes
- 94 civic dx: starts with gas pedel pressed but stalls
- need help/opinion removing 99 civic si alternator
- 1993 Civic strange noise.
- Delsol Seat Identification
- 99 Honda Civic very sluggish
- Blower Motor Issue
- 2000 si code p0420 black smoke
- civic lx wont start/high revs
- Need help with my 1996 Honda Civic (Atlanta)
- 1994 honda civic ex 2 door coupe wanting to install turbo
- Question about seats.
- Just bought it this morning
- 96 Civic Emissions/Drive Cycle
- Canadian SI edition?!
- Officially Stumped - Idle from hell
- Brake Booster Nipple on Intake Manifold
- EG Civic Muffler??
- help with my civic ex 97
- Mystery White Smoke.....
- 93 DX engine swap from 95 CX
- Few questions about my new civic
- Identify this Honda rim?
- Rebuilding B4RA transmission
- Beefing up suspension of civic sedan
- Strange clicking
- Leaking oil from passenger side sensor on block
- 92 EG Collision Help plz!
- Eg Dx Hatch Power Doors
- Clutch fluid change?
- Are OEM Honda parts built in CHINA???
- Need help, obd1 engine inside obd2 civic hatchback
- difference between TPS plug and ECU
- 93 Civic Htchbck JDM carb D15B swap, various questions as I go through the car.
- No start on a Civic 93 DX hatchback
- civic won't rev until fully warm
- Mini me build
- 1996 Civic - cannot remove brake shoe/housing thing
- Limp mode or what ??
- 93 Ex manual Trans Issue
- D16z6 build. 97 civic.
- HATCHBACK!
- s8g trans in place of an s40
- Cat Confusion
- CEL, B18 swap form 99 Integra into 97 Civic EX
- Putting transmission back together - MYSTERY BOLT?
- Correct o2 sensors?
- difference in ohms between injector and pigtail
- EM1 windows...need help!
- b18b1 starts than immediately dies
- Mod suggestions on a 99 Civic LX
- Coilover suggestions
- overheating, white smoke, blown head gasket?
- Slid into a curb, unsure if I damaged my car or not..
- Smog Help.
- Dash removal vin question??eg civic(not wanting to do illegal vin swap)
- 00 dx hatch gsr swap no start
- 98 civic b20v coolant issues!! Plz help me out!!
- Del Sol VTEC Dual Core Radiator Info
- b16 locked up
- Eg is
- D13B2 fuel filter
- battery charging problems need help??
- OBD1 ECU, Motor and Harness into 2000 Civic
- First Honda, need help figuring out whats wrong
- obd1 electrical test plug question?
- 1998 Honda Civic and whining sound in driver side...
- subframe swap from 96 dx to 98 ex
- car tries to cut off when I brake
- 98 Civic - overheating
- GSR in EJ1 question
- 1998 Civic- LS Swap- P1457
- Bad slave cylinder or clutch master cylinder?
- replacing vlave stem seals ?
- Transmission Bolt Extraction - Bellhousing to Engine Bolt
- Excuse my ignorance. what is this d16y8 sensor?
- D16Y7 Crankshaft TDC NOT matching up to cam sprocket TDC
- Ordering Motor
- stuck on surging idle
- HOLY COW plume of smoke behind ek cluster after wot
- 97 civic LX pcv valve help
- How hard to swap my modified z6 in place of my y8?
- 96 Civic EX Rear Drum to Disk conversion
- Question about a cold air intake
- EG B16A good swap?
- ECT O ring
- Takes 30 minutes for CEL to turn off and fuel pump to prime
- No 12v at starter signal wire (I've tested almost everything)
- New to honda world!!!!????!!!!
- How important is the Crank Position Sensor?
- RPM's pick up slow when @ Operating Temp.
- Build Advice
- brake/tail lights won't turn off
- Del Sol won't start or crank
- ej8 overheating
- Lack of power after oil change
- Need insights on D15b swapped 97 civic ex
- jdm auto to manual swap question??
- 99 Si is backfiring and died - this is a tough one. someone please answer this.
- Issues with D15B7 motor mount bracket fitting D16Z6 block
- 1993 Civic EX shifting issues
- b18c5 swap issues ...... need help!
- d16y8 throttle body question
- What B series motor is the most powerful?
- LOUD POP/BANG/GRUNT, Now it won't start!!!
- AC Thermostat
- 97 civic ex automatic transmission rebuild
- cam install question.
- GSR into EJ1 issues
- Car Heater Question..
- HVAC Help
- Civic/Integra Subframe ?
- what size coupler for my intake to TB?
- D15B7 Idle issue - Need some suggestions
- stabilize rolling mass at high speeds
- EK wont start only clicks after stalled out
- Odd clicking when turning
- Odometer Question?
- Eg sedan corner light issue!
- Techsmart TPS?
- Air to fuel ratio guage not working properly
- Power window goes up but not down?
- burning smell in cold weather?
- crankshaft position sensor?
- What kind of PSI compression are you D15Z1 guys getting?
- Auto vs. Manual Trans. Clutches
- Strange Start & Stalls Honda Civic 94 DX Automatic
- jdm D16Y8 with US parts = idle problem?
- B18B1 civic HELP PLEASE
- D15B/d16 wiring harness probzz/P06 comp
- Bad Oil Leak
- need some help 97 civic build
- Car won't start unless I jump it.
- 205/50R16?!?!
- 98 Civic DX won't start
- Another real or fake Recaro thread.
- Need help with rim size!
- changing freeze plugs on b16b
- B18 wont rev past 3500 after tune up
- 98 Civic EX starting issue.
- Left over bolts
- Trouble code 6 on a '95 civic DX
- cooling fan problems?
- 92 Gsr Eg Opinions??
- Emissions help 92 civic 1.6 non vtech
- Cluster without tach to Cluster with tach
- Good Swap for an EG8?
- 93 Del Sol Windshield Wipers suddenly slow?
- Poor AC, Heater Control Valve
- Stripped Bolts on Valve Cover
- help installing head timing question
- No Vtec engagement when front wheels are off ground?
- So you want an Ipad mini Installed in 96 ex ...
- Cluster swap
- What are these wires for???
- B18c starting issue
- Timing Issue
- Iacv unplugged vs plugged
- Window motor fuse keeps blowing. No Ground. Damaged door harness wires.
- 1998 Honda Civic Cranks but won't start!!!
- P1305&1399 back again....
- 97 Civic Sputter/Jerking/ backfiring under load.
- steering wheel upgrade?
- e85?
- brake lights stay on/idle problems.
- TPS volts different in ECU plug
- EG Sedan Rear Seat Seatbelt Mounting Point Picture(s) Required!
- EG engine swap tips/help/ d motor?
- idle drop?
- High Idle?
- D16y8/d15b block idle prob/misfire
- Misfire or Distributor issue? Bad Vacuum leak. (2 Video)
- 94 del sol starts immed stalls
- EJ8 Rebuild and Customization Project
- Omex Rev Limiter Fitting/Coil Negative Wire
- 2000 Civic Aerodeck air vent selector
- throttle cable for b16
- 93 Del Sol S Where does this wire go?
- Start Up Issues with 98 Civic DX Coupe
- need help with fog light wiring 92 civic
- Start up Issues 2000 Civic DX
- Clicking noise from instrument cluster
- Car will drive fine then not restart, or stall and restart, or not, very strange...
- Leaking Coolant ! D16y7
- Gasket Compatibility D16z8-y8
- Car will not go over 40mph after replacing timing belt
- Symptoms of Hot Spots on Flywheel?
- y5 intake on d15b7/z6
- 93 civic si stumbling and bogging down when I accelerate after car is warm
- 2000 LX Y8 Charge System Issues
- LOSING OIL!! WHERE FROM??? HELP!
- Radiator Fan not working on Acura 1.6 EL?
- EM1 EJ6/7/8
- 00 civic si missfire and CEL
- Annoying Idle Troubles~
- b16a2 pcv valve
- To those who have done shave/tucks on EJ's, quick question.
- Radio wires and question about radio
- Smog Gurus ... Needing Your Help
- Huge compression problem
- B16 Mounting and exhaust
- mystery oil leak seems too be oil breather box
- What B16 head is this?
- transmission works fine until it gets hot
- Chasing a Vacuum leak
- 1998 Civic weird heater issues
- 93 civic b20vtec swap.. CEL problem
- Del Sol Trailer Hitch
- G.Sanchez's 93 civic aka Coco build thread
- 94 Civic LX cranks but will not start -- tried quite a few things
- HELP Cranks but No Start civic 96 ex
- 95 del sol vtec-e, ECU problems
