View Full Version : Honda Civic / Del Sol (1992 - 2000)
- turbo b20 no spark help!!!
- check engine code 22 at top of 3rd every time.
- iac valve. got wrong one need help
- 97 civic with ls swap will not stay running
- Fuse Keeps blowing
- Metal lining inside fender well
- 97 vs 00 tranny
- EG dual gauge Vent-Pod 92-95 Civic prototype with functional vent
- 97 civic with ls swap-trouble keeping it running
- d16z6 dizzy ??
- H23 Del Sol
- ►►94 Hatch with 270k.. hmmm. Need your help! Should I buy it?◄◄
- Heavy shuddering on engine braking, help?
- Gs swap in 98 civic: Ps and Ac questions
- b18 swap//wierd idle
- 92 Eg hatch Vtec harness question
- Dizzy problems...
- Craigslist for the WIN.
- New Ignition Control Module didn't fix...which fuse do I check?
- A little help can make my day much better!!
- Ek9 steering wheel in Ek3 airbag question
- cluster lights dim at high rpm
- Ebay underdrive pulley?
- 92-95 Civic mirrors
- Missing headlight reflector
- Del Sol Had a little Leak.
- SI fuse cover
- Alignment drastically off after suspension work
- corrosion in coolant jacket after cleaning with purple power
- foglight wiring for 98 civic with 99-00 front end
- Just picked up a 99 civic hatch with a h22 swap
- Gathers Error "DA"
- Considering purchasing 1998 Honda Civic Hatchback 1.6L
- s2k cluster in 99 cx help?!
- N/a catch Can Install help!
- 93 civic - making weird noise while in reverse
- 2000 Honda Civic LX Died Won't Restart - Need some advice
- aem dry flow ?
- front end "jerks" while driving. tie rods? ball joints?
- temperature gauge
- B16A2 B18C1 knock sensor question
- Looking for a snowboard rack
- 1995 Del Sol jdm b16a swap
- Secret Kill switch info?
- CEL CODE HELP.x5
- Eg Rear Diffuser
- Is it possible to bend a subframe back into place?
- Rear Disc Conversion for a EK
- head question
- where find R1 Racing exhaust/muffler?
- Stroking B16A2
- n00b exhaust question.
- EK coupe swap help!!!
- 68mm itr tb for my b16 w/ i/h/e/c -- professional products tb reviews?
- Ek with ITR rear bar & stock suspension = ride?
- Del Sol Trunk Latch ('93)
- Hiemsnox del sol Build Thread
- Water pump selection issues
- 00 Civic EX transmission issue, popping out of 2nd
- need good engine
- Bunch of problems with my EG, need some help plz =]
- aftermarket water temp gauge.......need some help
- Searched extensively...What are these plugs for?????
- Can 94-01 integra front lca fit in 92 hatchback?
- can i run an LS swap w/ stock exhaust system on my 98 hatchback?
- Grinding/clunking noises while making right turns - 96 hatch
- EG with B20 piping questions
- Driver side axle clicking
- CEL 22 now, help?
- missing my ej
- Building my first B18B1
- eg ek b pillar bars same?
- Front Suspension
- jdm b16a wires/distributer cap same as 99 si
- 93 Civic DX idle fluctuation problems
- EK Auto to Manual Question (Mounts)
- Hit curb, need suspension help, detailed description and pics
- HELP!!!! 93 Hatch Check engine light always on but no CEL
- CLUTCH ISSUES PLEASE HELP... SEARCHED
- help no power to fuel pump
- Does 92 Si power steering and A/C work on a B20vtec swap?
- 98 Civic Died while driving and getting no spark
- LEDs in ek cluster help?!
- dizzy wont read past 5k rpm
- 94 CIVIC wont crank
- D16Z6 help with hose locations
- Error code P0420 after install distributor cap assembly
- b16a idles up and down if i tap the gas
- d16 head build - what would be best parts for the money?
- Oil leak
- EG JDM yellow fog lights, drivers side brighter than other side???
- Anyone looking for repair/electrical manuals
- What is needed to swap a 91 Ls into a Del Sol?
- Will the ex tranny in my hatch harm the D16 non-vtec engine?
- Ek with hard throttle
- ebay/aftermarket harness on OEM fogs?
- Which way does the crank spin on a integra LS?
- Led's for interior dome light...
- eg coupe with rsx dash - How wire a/c?
- B16b vs B18c1/c5 vs Rebuild d16z6
- 94 civic dx starting problem PLEASE Help!
- Comptech Strut Bar Mounting Kit?
- EK brake upgrade
- a little short
- 98 GSR mufflers fit EG's...Help!!!
- Front end rattle
- OBD2 Harness to D15B (obd1) vtec JDM?
- Does integra brake booster work on EK?
- cel 21, vtec wont workkk or...
- I got a question? For del sol
- Best swap for my daily 98 Civic LX/D15b?
- No Power Going To Fuse Box
- Are 92-95 Hood Latches Matches to 96-00's?
- Boosted d16z6 catch can hook up.
- B18 Swap Radiator Question
- Smoking problem (radiator)
- LCA bushings worn bad
- Cel Question
- Whats that for a license plate holder
- 1999 civic radiator
- Engine Idle and Radiator Problems, please help!
- PLEASE HELP!! RPM's DROP with A/C ON only...
- JHPUSA JDM fog light help
- 99 civic d16y5 to y8 advice!
- D16Z6 jumped timing quick question
- ek radio/climate control bezel
- ECU compatibility
- Not enough fluid in tranny = VSS not working?
- Car losing power after swap, coolant issue?
- Excessive play in steering wheel/clunking noise
- 95 Civic EX SRS Light always on?
- Another stolen hatch - Aztec Green 94 Civic missing in Chicago
- 2500 D16Y8 Build
- rear seat pivot mount
- Head gasket issue
- GSR // B18C1 // PCV Valve Question
- is this catback any good?
- Rear Main Seal?
- carpet for my hatchback questions
- HyTech Website - How much are their b20 headers?
- crankshaft seal/check engine light
- B18b swap transmision. problems shifting
- D16z6 > engine stand bolt size and specs?!
- 2000 civic si door doesnt lock.
- makin my d16z6 more powerful need help
- Reading check engine light
- 00 CIVIC SI starts then eventually dies
- dreaded p1163
- Low Beam Not Working (Aftermarket Headlamp)
- Jdm cluster swap
- 97 y8 intake manifold on 00 y8 head...air injection questions.
- Knocking noise at 700-1kRPM
- Weight difference between 99 Civic hatchback versus coupe?
- Investment.
- 96 Civic EK with B20 swap - What ECU should be used?
- ek ctr wing issues
- gsr swap into eg hatch
- What is the 1995 ex civic stock exhaust pipe size?
- 2000 Honda Civic shuts off while driving
- Keep or sell?
- Opened up transmission have a quick bearing question
- Cushioning Material, But Wont Burn Up
- 92 Civic sedan - Questions about clear taillights, fog light switch, and drop springs
- D16Y8 to D15B Engine Swap Issue
- Reinforcement.
- front bracket screws
- 93 civic cx hatch will not start, got spark but no fuel
- sedan handles on a del sol
- NEED HELP!!!!!! Auto to manual conversion
- 2000 civic ex bolt up?
- Car bogs between on 1\4 tank of gas
- 98 Civic hatch - Help needed to identify missing interior part of trunk
- d15b 3 stage question
- Skunk2 Megapower vs. Greddy Racing Ti-C
- 93 civic tranny problems/fluid quantity
- TPS Replacement
- Overheated ONCE, now having trouble starting my HATCH
- What is need to swap B16a into 97 Civic Dx?
- Plan to swap 96 b18b1 into my 99 Si - Need help with wire harness and ECU questions
- piston slap / rod knock
- window off track - '95 EG hatch - PICS
- TPS testing question
- car runs terrible after i get off the interstate
- Buying B16 Longblock Vs Piecing Motor Together
- *GSR Swap//Wrong Oil Pan???*
- Estimated Value of this 97' Del Sol S 5spd?
- 94 Civic d16z6 Harmonic Balance Probs!
- auto to manuel swap on 95civic d16z6
- 2500 limit. 2000 civic ex
- 93 Civic 4DR LX Brake Upgrade Question
- difference between honda civic ek3 and ek5
- whistling door seals ej6
- 92 Hatch won't start, clicking from fuse area
- What is a good tranny to get? ? ?
- Head Gasket broken...need advice
- b18c1 white smoke not head gasket
- 97 acura el - coolant flow question
- got my head time to build it. advice.
- ECU Code P29
- Considering swapping an OBDI B18 into my 97 civic EX
- Would a sunroof from an eg hatch or eg sedan fit in my 93 civic coupe?
- strange noise from civic at random times. not sure how to diagnose
- 98 civic LX wont start
- 96 civic fuel pump doesn't prime, starter doesnt kick
- What del sol front bumper is this?
- B16a2 problem, possible blown motor??
- Ajustable camber upper control arms problems
- Water leaking into interior behind drivers seat
- JB weld on a cracked block?
- power window/locks on 98 civic cx
- Help! 1997 Civic speedometer freaking out & causing car not to shift right.
- 1994 Civic EX, driver's seat seems "soft"
- Rebuild D16Z6 or swap in a B16?
- LS motor into EG - What motor mounts work?
- Squeaky timing belt
- bad clutch? Hear scraping and squeaking noise when in 3rd gear
- 95 civic EX/ H22 swap
- No love for the Del Sol?
- 93 Civic DX - What spindle/knuckles are interchangeable?
- JDM B16B Swap Questions
- rpm/tachometer problem
- JDM CTR EK9 power folding mirrors question..
- EG8 not starting
- Will B18C Type R work with stock 2000 Si Tranny
- Various Rattle Annihilation Thread
- Random no crank problem - stock 93 civic 1.5L
- Porting and polishing y8 intake...any science behind yes or no?
- Need help with amp remote wire into original wire harness.
- Little Help: y7 into a 94 civic dx hatch-harness question
- Iacv trouble - P0505 & fluctuating idle
- EK Civic Sounds like its falling apart
- How do I swap a D16Y7 engine into my 99 civic ex?
- Got my head in today....
- 96 Civic EX - Part number for the rain rubber gutters?
- Ek shock towers
- HX Crankshaft vs. LX Crankshaft
- Bushings Civic Si 2k
- p1457 please helpppppp
- Car randomly dies, now wont start. Main relay/Fuel
- ek b16a3 power steering help
- **NEED HELP W/ LS-V SWAP INTO DEL SOL**
- 96 ek swap
- Whats the BEST jdm web site?
- 95 civic lx mini me swap
- h22 ek immobilizer problem
- valve check
- d16z6 odd engine noise from 3-3.6k rpm
- failed smog test, 2x
- Rear Main Seal question
- Maroon 92 civic ex sedan stolen near Flamingo in Las Vegas
