View Full Version : Honda Civic / Del Sol (1992 - 2000)
- knocking sound while coasting?
- Integra shocks on EK?
- Car stuttering
- Which seats?
- Tire Treadlife question
- 03 civic headlights
- Location of factory horn...
- A/C and P/S on up coming swap
- SOHC ???'s
- Is my steering rack messed up?
- headers on ebay??
- smog legal guys... i got a question
- NEWB here with a couple of questions...
- engine code
- 03 Si 1/4 Mile time? Very sad I think, I beat one tonight in my S.
- KUMHO TIRES.. Help me find out what happend!
- D series header ques.
- civic price
- HELP, my car is sick!!!
- valve cover bolts how many ft lbs of torgue
- Some serious advice is needed from ecu/motor experts
- b16 throttlebody how many mm around , 64, or what
- 4 dr back bumper
- B18C Hatch 1/8 mile time...what do you guys think?
- jdm d15b vtec
- what do you guys do with your old motors????
- How to install horn for monte carlo steering wheel?
- does 00 b16 have a throttlebody gasket between intake manifold and tb
- d16 w/ ae86 pistons, b16 rods?
- wat kinda lambo door conversions do u recomend
- D16Y8 Edelbrock Open Track Turbo Kits
- 96-00 civic guys, show me your strut bar
- SRR : Sway bar, Tie Bar, Lower Controll Arm Installation Outcome!
- CEL for a second
- SPC or SRR Rear Camber Kit... Which One & Why?
- body kit, ground effects differances between coupe and sedan???
- Took some pics of my Si
- PROPS TO ANDRE @ Perpetual Concepts
- Headlight condensation.....
- weapon r fuel pump, what setting do you guys reccomend???
- someone please help with a possable head gasket problem
- ahh problems!! new noises
- Calling all honda mechanics!
- what tranny is ysk1?
- I'm getting a 93 VX tomorrow, want to swap a b16-2 in there!
- mugen mf10L mirror face
- HELP!!!!!!!!!!!!!!1
- anyone using the comp eng. chromoly front LCAs?
- p08 ecu ?'s
- 2000 DX Auto to OBD 1 5 Speed For a Hondata
- Honda engine codes website?
- rear sway bars and rear lca's
- please!!!need help deciding what wheels to get??? advan rg or racing hart cpf-tuners
- Complete ITR Change Over - The cost to date...
- who was the one selling the EkRomared with Si wheels like stock, Portland area
- B-pipes interchangeable?
- im really confuse where do i wire gsr secondaries...help wiring gurus
- O2 sensor check engine light + no exhaust?
- header installation question
- what tha...
- JDM B18C-R, unknown vacuum line?
- Soggy brakes
- Woot, got my Magnaflow exhaust on this morning. (pics)
- Dyno'd my car today..........Little Disappointed.
- The issue on: Resurface rotors and Brake other questions
- cheap alternative to replacing motor mounts
- Door Locking issue after replacing the "main" problem
- help on color.
- need to know asap 13s on 92-95 Si hatch??/?
- New 97 EX Owner Here!
- Exhaust Choice
- which wire on the O2 sensor for a gauge
- swaping B16 with tranny, can be done in a garage??
- What can I swap in my Honda civic 2000 HB (DX)
- HELP!!! car wont start, just installed built d16 turbo
- Windshield washer reservoir removal?
- OK did a search...99 EX doors on 97 CX....... how please????
- careful with rota centercaps !
- anyone have an ac diagram for an ek's A/C ?
- Starting problem
- machine shop in seattle area
- Bumper to fender connection is SHOT!
- Can someone do a carfax for me?
- 92 civic VX wiring help please
- unorthodox pulley?
- ef and egs?
- fpr,vafc,chip combined?
- how to adjust a fuel regulator?
- 00 Si Theft Recovery + JDM Front Clip
- Wrap around bumper mouldings for EGs?
- usdm vs jdm
- 92-95 3 door molding and coupe molding
- Is it Safe to drive on 3 Lugs??????
- SI STOLEN plymouth meeting PA
- high 12 sec b16a 95 civic hb cx??
- first post because i was booted by MIke M
- does anyone know who makes.....
- Searched, Where can you get a stock frnt. bumber & pass. door
- b18c5 or b18c1 or b16a??
- broken motor mount
- Can someone please do a carfax check for me! I'd really appreciate it.
- WILL 92-95 FRONT DOOR SKIN RH (PASSENGER SIDE) 2DR FIT WITH AN 93 HATCH
- skunk2 short shifter, should i get single or dual bend?
- where to buy 96-97 b16 delsol ecu
- GSR Turbo coupe times....
- Need a lil help (brake related)
- Help with finding an engine
- cranking problem?
- what do you think about this kit??
- should i get an adjustable fpr for my turbo b16 with vortec fmu?
- Time for some new brake pads.........suggestions?
- b series ignitor
- anyone have pics/list of all emissions equip. on usdm b16 del sol?
- need new exhaust help me
- thoughts on integra rs brake master cyl
- worth the trade?
- VIN CHECK PLEASE
- Hot Tanked a Head...How To Prevent it From Rusting?
- Can someone please help!
- 95 civic overheating
- This picture confirms: the JDM EG6 rear LCA is same as ITR
- boo.....swap went great, but it wont start
- tranny swap cost on a 97?
- AAAAAAAAAAAHHHHHHHHH!!! NOOOOOOO!!!!!!! MY CAAAARRRR!!!!
- tie rod end problem
- anyone from the middle tennessee area
- my timing tensioner won't stay tensioned so that means the belt comes loose!!!
- 1/8th times no 1/4 around where i live
- Members From VA Area...Need some info
- building a D a waste of time ?
- Soulracing's Carbon Fiber Hoods
- timing belt tensioner, can i tighten it up while the timing belt cover and stuff is still on there?
- valve lashing
- could i trouble anyone who knows me to vouch please :)
- Another 5 lug ? , need help fast
- Ran my car 1/4 Finaly!
- anybody ever put gsr muffler on their civic with aftermarket piping?
- B20 Turbo
- d-series oil pans swapable? HELP
- Q for ppl with KYB AGX's & pics of my car
- Some ITR stuff for sale.
- better braking force
- Help! Broke a bolt off doing suspension!!
- Anyone interested in small vinyl stickers that are in the shape of a EG hatch profile?
- Can a coupe exhaust be modded to fit a hatch?!
- What about this for theft protection
- JDM front bumper for EG
- Changing thermostat?
- SRR REAR Suspension Instructions.
- (92-95) CX speedo swap into EX cluster anyone have tips or tricks???
- Tranny that has been sitting a while.
- update on my problem with non-starting car
- b16a track time....
- wiring questions for a B18B in Ek
- Ran my itr hatchback at the 1/4 mile track.... ran a 23.4sec
- should i trade, or should i pass?
- Hey guys...could someone do me a carfax please....
- Upgrade Newbie (Engine Swap?)
- Tranny question and pics of my HX
- Are the rear disc rotors the same size as the front ones on Civics?
- y8 mani swap....
- civic header
- will 96 gsr engine harness plug into a 96 dx harness?
- GSR throttle body and GSR Skunk2 intanke mani ???
- Could I buy a J's racing intake for my future H22 swap and use it now?
- Smoking question
- ITR Intake Manifold Swap
- What no lips for 96-98 sedan no!!!!! Please tell me i'm wrong.
- when I step on the brakes, I hear a loud Click
- Car will not rev past 4k.
- stock radio relocation and din cluster (pretty small pics)
- HID Headlights in an EG Hatch
- what does a mandrel bending machine look like?
- P28 uses how many O2 wires?
- Octane rating question (how high in a b16a)
- Coolant mixing with oil?
- Brake pedel makes corners light up???
- SAFETY PROTOCOL IN VA. REPLACING STEERING WHEEL LEGAL? OR NOT
- rod bearing colors, d16z6
- Whats Your Car Weigh?
- IAC gone bad?
- Need Everyone's Help Please!!
- Does a b16 come with dual springs?
- what color rota group n?
- OT: How long will i be a trial user? sorry for the question.
- Does anybody know what website i can get EDM Del Sol aux lights?
- question: rear disc brake conversion on a del sol
- my coupe, my work in progress!
- Harvard Blue ?!?!?!
- Poor man's 5 lug brake upgrade....
- radiator blew after motor swap, what cause it?
- Anybody have some Eg pics? Trying to get some idea's.
- H22 Swap...Need help with things I need to complete the swap...
- 96-97 b16 delsol ecu
- benifits of going obd2 to obd1
- SRS light
- Need help from turbo civic owners!!!!
- gsr front clip
- Part number for 99-00 Si lip and rims.
- New shots of the POS!
- Code 1: Oxygen Sensor Problems
- what size tires for 16 inch rims??
- is this a good price?
- ut wire harness can i use
- Need EBrake Help!!
- rear or front shocks 'YOU PICK EM'
- and a cel is what?
- Price this
- where to pin to check cel on ek civic
- My first Honda
- windows glich...
- got spark, got fuel, got cranking power. but still no start!!
- soon to be sold (my blue egg).....goodbuy pics(pending)
- weight reduction
- mods, dont move he needs everyones prayers
- where do they sell bondo?
- cat problems
- Dumb headlights... wont aim worth a poop
- Black out destroys my friends AE86
- Stock del Sol Exaust size?
- Car is backfiring?
- Help with EK wiring problem?
- will a non attached TPS cause the car not to start?
- New wheels = photoshoot time! Phantom Grey 93 Hatch (56k maybe)
- removing rota centercaps
- Integra muffler on civic
- resistor box: reverting back to stock injectors
- HELP! new headlights, only high beam and parking lights work Type-r fakes H7 bulbs
- That's it, I can't stand another archived topic on GSR/ITR dash into EG...my question is...
- GE 9003sb = GREAT!!
- car ran for about 5 miles just fine (after new engine installed) then died, what to do?
- Car Wont Start!
- Removing door panels on 00 SI
- I need some detailed information on putting a stereo in a 96 civic ex
- ABS Spoon lip
- What is the part number for the ECU I need? (New Car) (Did a search)
- EG and del sol body kit fit....quick answer!!!
- 96-00 driver side motor mount replacment
- Rear view mirror fell off, what kind of glue?
- Will Low Oil Make My CEL 23 come one
- Header question. Eg/H22
- H22 in a 98 ex?
- 2000 EX wiring harness on 98 CX motor
- exhaust problems
- 1997 Honda Civic DX motor?
- Anyone know someone or has an F22 in an EG coupe or hatch
- I need a pic of tanabe hyper cat on a EG ? anyone?
- Brake line size
- help-obd2-obd2b conversion harness.
- 99/00 Civic coupe rear lip
