View Full Version : Honda Civic / Del Sol (1992 - 2000)
- LS tranny problem
- Question on these wheels for del sol (please don't move), quick question
- 94 Del Sol - need input on headlight casings and other upgrades
- Radiator fan not coming on (Again!!)
- Best D-Series Combo???
- b20 vtec turbo S300 Help!
- d16y7 block z6 swap
- b series wiring question
- ECU Question!
- 93 1.5 Bad sputter, need your thoughts
- Ek9 window tint
- D16Y7 ECU
- Suspension the same del sol and 96-00 civic?
- won't start when very cold in the morning
- 97 Civic HX Climate control illumination lights NOT WORKING!!!
- advice d16z6 head
- AutoZone GSR Distributor Warranty !?!
- my eg halo light rings arent lighting
- easiest engine swap for a d16y8
- Please help with my navigation install! VSS location?!
- CTR EK9 Sunvisor question?
- BRAKE ROTORS EK9 VS USDM ITR
- Emissions test - failed at idle
- Question: Y7 trans on a D16z6 block? Please Help
- Camber Kit?! Look at my TIRES your advice is appreciated!
- Aftermarket sunroof leaky...
- Throwing codes need insight!!
- eg dash clock
- Checklist for buying a civic?
- HELPPPPPPPPPPPPP MAJOR BRAKE PROBLEM
- EM1 window went off-track, AGAIN
- Blue EG Hatch on this forum? Video inside
- Having some serious electrical problems with my EK..
- 96 civic sedan lx window problems
- 96-00 Hatch rear disk conversion
- Timing Problem NEEDS HELP ASAP
- Installed 4-2-1 header on 93 del sol!!!
- Rod Knock???
- VTEC Solenoid
- fans
- New Exhaust??
- PO141 Sensor heater malfunction(no plug)
- EH1 1993 Civic - rear cross member missing
- link to knock sensor bypass plz!??
- Tranny final Gears
- lining up front bumper and grill
- 2000 dx auto to b18b manual?
- d16z6 swap into 99 ex. P/S issue
- B16a Missing PCV System?!? Cause smoke?
- Stumped!!Sunroof on a 99 hatchback
- b16a 1st gen and b16a 2nd gen
- b20v head gasket dowel pin problem
- C5B tranny suitable replacement for E5F?
- DTC code 4! tried everything please look....
- skunk2 intake manifold worth it????
- Bizarre electrical problems
- how to remove back license plate holder??
- stock side skirt painting help
- fuel pressure regulator install ???
- Need help identifying these plugs and what they do. (labeled pics)
- 99 civic ls swap?
- Failed CA Test only Smog- need H-T diagnosis
- Both PO117 and PO118 codes - HELP!
- Sounds like vtec is constantly engaging
- B16 Swap guides
- b16 or d16y5?
- vtec solenoid issue?
- How to fix my broken speedometer?
- 98 honda civic ex new cap ,rotor no start
- Best cams for ITR springs and retainers
- y8 on eg hatch
- B-series engine mounts in EG
- ****SERIOUS ISSUE, TAIL LIGHTS, INSTRUMENT PANEL DONT LIGHT UP, 93 CIVIC****
- 98 Civic EX brake rotor hitting caliper bracket
- Hi Folks 94 del sol
- oil filter question
- 96 spec type r 4x114 conversion
- fixing a spun bearing without removing the engine ??
- (please don't move) What strut mounts for kyb agx 99 civic dx
- changed intake gasket now car wont start d15z1
- 98 civic brake upgrade help plz
- B16 map sensor question
- will a 96-98 civic carbon fiber spoon style front lip fit a 2000 civic????
- whats vtec controller do? (mini me)
- UCA fitment problems
- Pounded out Hub, No C-Clip there?
- civic window trim FADING! help!
- Intake swap need some help Thanks
- 98 y8 to y7 mini-me spark plug gap????
- eg6 rhd fault code
- How long have you driven your swapped/built car? (poll)
- what is this part?
- 94 heat issue
- D16y8 engine + P2N ECU
- 97 Civic LX Trans Problem
- Shifter Problems
- D series Manifolds questions! Help please
- Gears at high RPM - tried everything!
- Anyone know ecu pinouts for reverse lights on a 96-98 civic?
- Power window problem :/
- Intermittent Wiper Question
- Engine Bay question
- OneSikEJ8's Build Thread
- body style question
- EG Foglights + bumper frustration
- tail light help
- 95 Civic won't start
- Automatic l/s
- How to tow a car?
- hard to get started, but only when warm
- motor mount broken
- motor work?
- Back up lights stay on
- H2B swap wiring question concerning 1996 engine and 1992-1995 Civic
- j series trannys???
- Erratic Fuel Level Reading on Dash Gauge
- altenator or battery????
- Rear disc conv. On 4 door 99 lx
- b16a Parts???
- Wheel bearing - scratched my hub
- thermostat ground has power on a 93 honda civic and tach problem on b16 swapped crx
- inconsistant REV limiter
- A/C Question (00 civic hx)
- F20B? is it possible for a 98 HB civic?
- newb tach question
- D16Y8 engine build questions
- h2b swap question in eg
- Painting rims - Do it yourself???
- d16y8 engine harness fit on b16a2?
- re wiring tail lights?
- 93 civic ex a/c problems
- engine swap now clutch wont work?
- Drivers side rear control arm question
- 3000 rpm idle after installing a gsr TB new gasket too
- 1999 Integra GSR Rear Sway Bar on EK Civic
- How to tight should a timing belt be? 98 civic.
- what are the best jdm websites?
- 94 Honda Del Sol wont turn over..
- 97 Civic LX MTX, shifter feels like its in mud
- 1997 civic stock spoiler help
- 2012 2.4L Civic Si Motor for past generation civics
- Lots of coolant in Cyl. 1, good compression!?
- lug pattern/ abs problem???
- 00 Civic Si - misfiring
- d16z6 Cel 6 replaced sensor twice still on
- CAR DONT MOVE!!!
- 98 Hatch with GSR Swap-No tachometer reading
- bad starter signal?
- Trouble with starting my Eg6
- B16B VS B18B?
- Radio Problems
- 99 ex into 00 lx
- D15Y7 97 civic lx
- so i converted my power rack to manual by looping it...question.
- car wont crank
- My eg won`t start
- Broken Coolant temp sensor
- Turboing a d15b7 non-vtec - piston question
- b16a into 96 dx hatch dx to ex engine harness mod
- Mini-Me. What octane to use?
- Questions about clutches, short shifters and turbos on LS swapped EG
- Why is speedometer off by 5 mph according to GPS...
- 98 civic cx, what next?
- Mil on b16b in 99 si
- 92-95 Civic Temp. for Radiator Fan
- white smoke only when I shift into a different gear....
- clutch went out...kinda?
- Idle and a Miss?
- JDM D15B AC HELP
- MPG questions
- 92 civic having radiator problems
- 00 - 94 P/S Question
- gauge help...?
- My 95 Civic cranks but will not start!!! Help
- AC Wiring Diagram?
- P0505 Revisited. List of symptoms for 99 EX
- blown fuse 15 (you already know)
- Compensator arms squeak, can it be fix?
- Replace window regulator or motor?
- DC2 Cusco Cage in EK9. Will it Fit?
- 97 Civic has strange(?) compression readings
- interchangable clutch lines?
- Clicking noise through intake when ignition in on position
- 4door or hatch
- 92-95 Struts on 96-98 Civic??
- 15 or 16's on 1997 CIVIC?
- Car won't start....
- aftermarket fuel filter, stock fuel pump
- i need help
- Del sol with gsr swap, bar questions
- Car starts then dies immediatley
- Full Odometer & Trip Odometer went out.
- 96 ek coupe w/ 99-00 Dash swap, HOW TO INSTALL AND GET AC TO WORK???
- Need help with chugging idle
- 1997 Civic LX Driving Problem...
- b16a3 reliable past 208 k?
- 1998 Civic EX Shifter won't move
- PWJDM Whale penis fitment
- rpms needle jumping around, running rough
- 1997 CIVIC DX. window/motor problems. HELP!
- car wont start
- b20 swap!!!!
- How to fix my coolant temp sensor light Code 6
- 94 si/b20block+gsrhead -- What transmission should I use?
- i have a 92 civic Sİ HB - What other performance mods should I do?
- Need help removing plug
- fog lights
- y7 into a 99 ex... ftw!!!!!
- 99 civic si turn signal and hazard dont work help asap!!!!!
- rhaspy exhaust fix?
- Door Window/Glass molding
- 00 Civic EX - new honda owner needs help with idle
- b16a3 iddle?
- mini me swap help
- Suspension issue?
- Auto ecu on manual ls swap
- Ridiculous Surging Idle- '92 civic 1.6 V-tec
- EK3 D15B rev.problem
- brakes seem to lock up very easy these past few months. 92 civic
- P0505?
- mini me swap quick question...!!!!
- vtec-e question
- Replace dash cluster bulbs
- ign relay bypass?
- 3 brake light annoyance
- How to remove automatic shift plate? (2000 Honda Civic)
- 96 Civic with VSS CEL code -- under dash fuse 24?
- speedometer issue
- 98 HB/B16 swap with OBD2A to -2B JUMPER HARNESS - Any problems expected for swap?
- The Best 92-00 Civic/Del Sol?
- D15B7 IDLE ISSUE
- d16z6 Possible rod bearing.
- OBD2a motor to OBD2b harness questions
- main relay fix
- 98 Civic hatchback mpg
- 1992 Honda Civic - Thrown Rod
- S2000 vs GSR EK???? need opinions
- manual steering rack impossible to find
- Car Broken into - Stolen Alpine IVA-D105 HU in Las Vegas - Acura 1.6EL
- Why does my civic VERY hard to start cold but starts and runs fine after warm up ??
- choppy throttle, idle stalls - fuel pump?
- UGH!!!....another d15b/y8 question
- help with installing chasebays brake line relocation kit???!!!
- Mysterious wet carpet in driver side after it rains
- help friends car overheated
- Warming up engine?
- Putting A/C back into 92 civic. Is a lightweight underdrive crank pulley helpful?
- 97 civic LX dimmer shorted out my dash lights?
- vtec solenoid gasket
- A/C wiring Diagrams and Pictures?
