View Full Version : Honda Civic / Del Sol (1992 - 2000)
- hasport mounts for d16z6
- What do you think of this civic im lookin at?
- How many firewall delete plugs are there 92-95? Part #'s?
- Car stalls, CEL Code 20, Limp mode. . . SEARCHED
- 99 Honda Civic check engine light blinking!
- need help
- reinstalling cigarrette lighter at center console for 96ex
- What is the strongest?
- which conection rods
- need hellp id'ing stuff
- 96 ex coupe window visor installation
- Rewiring?
- honda badges
- black smoke, poopin' oil outta my exhaust! sloppy idle, what is it ????!!!
- VX ECM California vs. Federal Emissions
- AC with a LS swap in a EG HB
- Camming a d16z6
- JDM project-EJ coupe
- Idle Air Control Valve
- B18C1 ??????
- 96 Civix headlight condensation
- Integra Type R wing
- removing my AC
- 2000 si tranny pic.........
- jdm zc intake mani vs usdm mani
- radiator problem help
- Which is the Primary Oxygen Sensor plug 96+DX
- ctr rear seats in eg
- e-brake console wo armrest - that matches USDM interior (99 civic)
- 99-00 si header on 92-95 eg
- Del sol manual transmission question
- Thinking about throwing a JRSC on my 00 Si
- Dipstick?
- 75.5 mm bore what head gasket do i use
- throttle body
- Setting Ring End Gap.
- how do i install an eg sir climate control
- vaccum line?
- Have a 93eg, want to swap in b18c5, have questions
- GSR swapped ek wont turn off with headlights on..
- Hi guys, need help with idle!!!!
- CEL22 and storing my civic
- seat harness
- Car will NOT turn on. Advice needed
- Throwing Cel 61..
- Absolute quitest exhaust?
- d15b block - which head? y8/z6/ or d15b?
- Oil Catch Can
- shifter feelin really loose
- coilover question
- any info on writeups for swapping a k20 plus the 6 speed in del sol?
- what kind of cat back sounds good on hatchback
- should i just get a chipped ecu or straight up hondata i got 500 bucks
- Heater Problem Del Sol
- bogging issue after turbo, 92 civic coupe with d16y8
- 01 o2 sensor in 92 VX?
- Will EK or Integra Springs/Shocks work in an EG?
- well need help find out if obd0 or obd1
- d series with some power
- tranny fluid
- Motor Mounts
- Motor Swap Help??????
- Car wont start!!! 2000 Honda Civic Ex Sedan
- 98 EX header install Car wont run now
- Air Coditioning Help Please......
- Suspension wack?
- Slugish???? HELP ASAP!!!!
- Cant find 96-98 hatchback shell
- looking for these parts/similiar
- New sohc or sit on it
- B16A Revlimit questions
- Brake Hose question?
- Torque Damper 92-95 Civic?
- would JDM integra DC1 front seats fit 96 honda civic??
- big problem..need all the help i can get...
- EBAY lugnuts quick question with PICS^^^^^^^^
- bigger sway bar??
- B16/D16 axle interchangeability
- Hello Honda Tech
- single cam t/b on a h22
- RS*R springs
- 1997 Honda civic factory alarm problems
- B series VC
- EM1 front right tire shakes?
- ABS Light and Locking Up Wheel.
- Suspesion Damage. . . Estimated cost. . . ?
- EG stock carpet replacement ebay options?? question
- Ticking/Knocking with cold engine
- 99-00 EM1 Civic SiR
- Part number / where to buy input shaft bearing?
- b18b1 broken sensor HELP.
- RearView Mirror WEAKK!
- another CHECK ENGINE LIGHT!!!!
- Has anyone ever...
- Whats the best thing to do to my 92 civic cx for 2 bills ?
- cluster lights cut in and out
- Need a D/S door!!!!!!
- doing ls swap need to know what to get
- Pistons
- solution to my code 45/ P0171
- Oem Blank Rotor alternatives. Which ones are good?
- Ground Control Top Hats on EM1 clearance ?
- steering wheel tilt wont stay
- civic 97 dx cooling prob
- Swap
- satin silver EK9???
- swapping d16 to d15
- WTB: b-series hasport mounts
- b16a2 swap into 98 hb question
- d15b swap car stalls out when throttle slightly open
- Engine will not warm up
- power steering
- power mirror fuse for 00 SI
- Symptoms of a blown shock / strut. Shocks are off the car ..
- About my car warming up...
- obd2, obd1 engine
- Cluster
- rpm problem
- injector o-ring set -Who has'em besides honda
- 96 integra axleback fit 95 hb?
- EM1 headunit install. Help me out.
- ProStop brake pads
- quick apexi neo question
- Skunk2 Struts review
- newbie ? y8 head and z6 dizzy
- What kind of engine 1.5, 1.6?
- parts for sale!!!
- JDM Shift Boot - Question -
- door panel removal(searched)
- ANYONE has ANY idea hoW TO change The Timming BElt
- reason for idle problem?
- How to fix stiff auto shifter button?
- RADIATOR
- need help! need to pass smog!
- pic of skunk2 megapower exhaust?
- Vibrant Cat-Back System???
- SRS blinking?
- SOHC Turbo question need some advice. Need a lil help
- e-brake trouble
- grinding noise (when accelerating)
- how many grounding wires are you supposed to have and where are they?
- PLEASE PLEASE HELP ME!
- will a 92-95 head vtec head fit on a 96-2000 block ?
- injectors
- b16 swap - missing EVAP sensor plug??? what harness can i use?
- D15b Swap but is vtec running?
- Type R performance bars???
- Sohc Turbo Q's
- V-TEC selenoid swap???
- help!!!!!!!!!!! please with swap
- 96-00 civic window/lock wires fit into a eg hatch for power conversion
- Oil Breather
- Stabilizer/Sway bar upgrades
- intake manifold with no stamp?
- HELP =( My car just died while driving...
- chassis/body frame pics??
- Gear Shifting PROBLEM?
- OBD Question( DEL SOL )
- HID's possible in tyc black projectors?
- I think I pissed off the Honda gods.
- 92 cx w/ y8 obdI
- b16 starters
- please please help 96-98 civic engine
- What makes an LS/Vtec unreliable?
- GSR engine swap help
- F22b Sohc into a Eg
- Rolling odometer FORWARD
- Disable Daytime Running Lights (DRL)
- 99 hatch 5 speed swap
- Safe Redline
- need some advice on pulling tranny
- questions about d16y7/z6 head swap and crank pulley
- engine swap for 98 civic lx
- Windshield Washer Pump Replacement
- O2 Sensor Question
- damn thieves...car brokin into!!!! look out
- Rear hatch water leak
- will obd2 injectors fit obd1 harness?
- Can I use an OBD2b distributor in OBD2a civic
- 92 civic bad clutch?
- 99' DX Hood latch (any alternative ways to pop hood?)
- what ever
- help on a type-r swap.
- Remote Central Locking Playing Up
- Rear Chamber
- eg hatch...
- ASR brace and 24mm swaybar
- Wrong timing belt installed in my 1995 Del Sol VTEC?
- FENDER question!!!!
- what to do
- 92 Civic 02 sensor differences...wtf?
- dhelp a fellow eg owner, to turbo or paint? that is the question
- help a fellow eg owner
- sohc camshafts and gears
- My car... is wierd?
- Figuring out my Front Suspension Problem..HELp
- Hey guys im new
- Headlight Terminal...help
- Carbon deposits on pistons and valves!
- Carbon deposits on pistons and valves.
- B-series axle question
- JDM Type R style race seats question.
- Alternator
- Kteller Exhuast help
- a/c help???
- Idle Bouncing from 1000 RPM's - 2000 RPM's. Bad TPS sensor.
- electroluminescant gauges
- Help with Climate Control light not working?
- yes another damn cel 5 code thread -.-"
- what turb o should i use for my ls turbo
- Will the MIL indicate pending codes?
- Visteon Radiators ???
- timing belt??
- Stuttering, random check engine light.
- can you put 92-95 civic coupe exhaust on a 92-95 hatchback
- HELP!! does the 96-00 civic sohc L bracket fit 92-95??
- y8 head on a z6 block
- Dipstick location thru the years on D series?
- daily driving a N/A d16 with a stage 3 clutch ... dumb idea?
- i need help changin bulbs of my cluster make it amber eg
- new painted JDM D15B valve cover! pics inside!
- Confused on my tune
- did vtec swap with p28, have a question
- can 92-95 civic coupe catback exhaust work on the hatchback to
- need some help overheating
- Plug OBD2 sensor hole
- cel problems
- 1995 Honda Civic DX (D15B7)
- altenator problems
- lack of power
- usdm and jdm ecu?
- Wont start delsol after seting up, started then died after 10 mins
- 92-95 civic with integra type r suspension
- need help with my viper 1000 alarm
- should i buy EK or not?
- uv protectant for carbon fiber hood.
- engine light on saying Secondary oxygen sensor heater wire (black wires) need advice
- coolant temp sensor
- drivers side floorboard sopping wet?! need help
- Need Help!!! Car is acting up
- 90-93 integra rear seats fit in a EG
- symptoms of a bad thermostat
- My first car
- Coilover Advise
- over heating, HELP!
- Best D15 block?
- seibon carbon deck lid
- expletive HONDA's
- (pic request) 92 hatchback spoiler
- PW JDM FTL
