View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Crazy Odometer, just jumped 100K miles??? EM1
- Got it
- Civic turbo (just curious)
- 93 DX Idle Issue...CAI The Cause??? Bad Voltage to a Sensor?
- jdm rear seat install problem in 98 hatch
- Failed theft/break in attempt on my eg....
- another high idle prob
- wiring a mini me setup for vtech
- Wheel hop..
- Low idle and alarm doesnt work after battery swap.
- wiring question
- question
- Size difference between DC2R and EK9R rear sway bars
- is my ecu bad
- 96 ex coupe wiring obd1 motor. need 02 help
- need some input please
- Friend's car is messed up, not starting.
- swap help
- really bad shakeing need help quick
- questions reguarding skunk2 lowering springs (96 ex)
- Whole Car Harness
- 300 dollars running integra
- Question regarding Bumper Moldings!
- Tran problems!
- HELP !!! open valves question
- Car and harness is OBD2, engine is OBD1 will ecu work with engine?
- Help plz removing dash 97 civic
- rim/tire size for winter
- What should I ask for these?
- Baro Sensor? Barometric pressure
- New BBK throttle Body
- My EG build thread (56k warning)
- simple auto to manual question
- oil pressure sensor/switch. help wiring?
- going OBD1
- Dizzy Question
- shift linkage pin (bitch pin) removal made easy!!
- Lessons Learned: S2K seat pan swap
- Knocking problem
- no start
- fuel leak
- 2000 Honda Civic SI
- car wants to stall
- Any Ideas ?
- just smacked into ice with my Si
- does anyone know how to remove the panel that holds the heater controls and radio in?
- BOOST + retard timing ?
- 1 layer headgasket B16 TECHS only not a NOOB QUESTION
- signs of imminent fuel pump failure ?
- koni w/ gc question ??
- power steering?
- Switching to Full Synthetic question
- Cigarette lighter
- Civic CX D15B8 turbo HELP ? P28 ecu ?
- Only half of the rear window gets defrosted?
- VX motor in a non VX car??
- stage 1 Cams?
- my new cluster what do you think??
- SI Cluster Help!
- golden eagle block girdle
- In search of overfenders. Any help?
- S2000 steering wheel question
- B swap into a 97civic ex
- R Crew Racing Products
- Wiring Problem!
- swap help
- 00 si harness won't fit on 00 ek??
- Looking for a turbo kit in florida to buy !!!!!!!
- aftermarket clutch/oem t-o bearing
- N/A help
- Quick question..
- brake master cylinder
- swap to vtec-e head?
- Sleeved GSR overheating, need some help HT!!! complex problem
- Acura Legend Front and Rear caliper*Does it fit my civic?
- SOHC head
- Engine noise
- Quick 95 Civic B18b ECU question
- best material for spark plugs?
- About to get $4000 and want to get a motor
- Meanings, 0w30,10w30,20w40 ??
- how do you remove alternator belt?
- do egs have two O2 sensors?? thinking of getting one
- Need help.... GSR Surging Idle *Searched everywhere*
- HELP I Need A B16 Hydro Tranny ASAP!!
- Hot to add HP or rwad DYNO ??? D16a6/z6 all motor.
- 94 Civic EX PROBLEM
- Question about NRG EG rear spoiler
- map senser problem
- Twin engine civic
- tire sizes
- iacv
- 1996 civic starting issue
- Rebuilding the steering rack
- 96 civic heater not working
- B16 Swap
- oil pump ?
- buzzing sound
- b16a2 a/c
- one side is brighter than the other?
- dash help!!!!!
- skunk2 dual bend short shifter
- K24A4 worth swapping?
- Swap Question- Wiring Harness
- no clutch pedal pressure
- good sites for engines?
- i just bought 95 civic eg oem sir lip
- D16Z6 is done time for the D15B
- Swap questions?!
- Is it only the clutch?
- K24 swap. any ideas?
- 99 Si harness
- Auto and Manual Cluster Differences?
- Ball joint replacement
- what size for rear camber bolts?
- Burning Oil
- Piping Size?
- EX tranny faster than DX tranny?
- Is there a shortcut for wiring up knock sensor????
- problem with b16
- Rice Boys make me laugh at least once a day!!!
- oil filter??????????
- Battery Replacement
- will these beaks fit my car
- GSR fat fives
- << Master Cylinder - salvage >>
- Urgent Electrical Problem (Video Inside)
- Seatbelt help
- jsr spoon replica muffler
- Quick Dumb Q
- Cant get crank gear off help!!
- eg tub out with solid rear axle
- 93 DX...Air Flow Meter, Air Flow Sensor $395???
- Skunk2 MegaPower Headers
- Has anyone installed gauges in their air vents?
- "alpha werks"
- lookin into buying a civic turbo
- oil leak problem 96 civic
- 98 Civic IAC problems.. HELP!!!!
- SRS Light Issues
- ecu check engine probelm
- JDM EG6 with Traction control y21 trans LSD or NO LSD?
- hid foglight problem
- Car died, no start, ecu fuse blown
- mishimoto radiator cap
- quick headlight kit question
- b20b in a ek wont idle
- dash lights?? wtf
- Problem..Please Help
- eg CEL and cutting out
- b16b civic type r
- wtf just did a carfax on my 98 civic i just got 2 months ago wtf im pissed
- Lots of Ls/vtec ?'s Pics INSIDE!? 56k bye bye
- No brand quick release safe to drive with???????? Help please befor i instal
- high rev?
- A/C Removal ?
- JDM B16A Vs. USDM B16A2
- need some wiring help
- EG Hatch w/ $200
- Oil Pan + extreme cold weather
- Fixing rear defroster...
- Rocker arm adjustment.
- ECU Measurements Questions
- Spoon b16a swap temp problem
- 97 DX with B16a2 Help
- Ignition coil? Gas.. Help!
- help with Trans flush
- What to put in clutch ? FLUID ?? please look
- Valve Cover Fitment z6 on a y8
- What could cause wires not to get power after wire tuck
- want to build my 94 coupe
- Need quick on piston wrist pins, plz
- just got my motor need with with harness
- non vtec ecu with vtec engine?!?!?!
- need help!!!gsr motor whining...watch the video...
- ls vtec turbo
- where is the idle air control valve (b16a)?, and How do I clean or replace it?
- Got a new exhaust but ?
- acoord o2 sensor in civic
- What Tranny fluid for my del sol???
- Question for anyone who's tinted an EG Hatch
- Inoperable Dash Lights
- s2000 push start wiring.
- question about egr valve
- question about brakes
- half shaft
- B16 From Eh To Ej8
- alternator mount bracket bolt
- 96- 00 ctr side markers (where do they go?)
- 92 civic vx ecu
- look at this tell me what you think
- Remove IAB's or Unplug IABS?
- is this a good price to pay for the labor being done?
- vibration in civic after new axle install
- Solid Motor Mounts?
- check engine light doesnt come on what wrong?
- car lowering problem
- Rear brake disc not being wearing evenly
- Stock tach 500 rpm's off??
- How much to pay for '92 EG hatch shell?
- Wheel bearing quetions. 94 Civic CX
- Valve lash help!!
- 92 interga heat problem
- Is my car missing trunk trim panels?
- Will OBD2b GSR engine harness work on an EM1?
- problem at idel
- 98 civic HID's HELP!!!
- cold start problems. 92 si.
- 1.6 EL front end conversion on a 99 civic??
- MSD Soft touch rev control????
- s14 conv
- iacv help
- Just wnt to run a p08 for D15b vtec swap
- Won't Stay in 5th
- car choking
- valve cover bolts
- Engine please!
- Doors and Cold Weather/snow.
- d16y5 turbo? help yeah?
- Need info on hondata...
- 2008 Fit Steering Wheel in my EK
- problem starting del sol
- Post your damaged transmission after you had stiff mounts on.
- D16Z6 Turbo Problem, Help.
- Oil out exhaust...
- Gsr gsr gsr!!!!!! Head cam cap trouble.. Heeeelllppp
- Ebay Header, Yay or Nay?
- b16 swap help
- EK hatch leaking water, need help.
- Minor wiring problem giving me a big headache...pics (HELP!)
- 1994 EX, Possible bad alternator?
- Wheel Bearing? Or Tires?
- jdm 4dr ek front end on a ek hatch
- clutch is loose
- Ignition switch bad?
- block girdle question????
- new comer ej1
- Wheel rubbing on u-turn
- depo fog wiring question
- RE: transmission oil 2 choices pick 1
- smaller injector
- What is it and where does it Go?
- 98 civic ex RHD conversion CTR
- wheel well cut out/tub out
- shift changer thingy blah broken, can i fix the individual peice, or replace the who
- What to use for cleaning clock?
- What Transmission?
- B18C5 Distributor Question
