View Full Version : Honda Civic / Del Sol (1992 - 2000)
- cel code 65 on 96 ek gsr hatch
- how difficult is it to install an intake manifold?
- cel code 65
- Swappers, Take a look! 92 Civic SI/ 94 GSR brake question!!!
- LOOKING TO BUY AN AVID PRODUCT? READ HERE FIRST!
- What brand sells perfect fitment cleared tail lights
- help me!!! please
- Couple Quick Questions
- Radio Code
- Tempature and gas tach is not working right, Whats wrong?
- Blinker Trouble
- Valve Cover Screw Broke in Half and Drive shaft HELP!
- 93 civic hatchback stereo panel
- ek with gsr swap intake questions
- How do you hook up speedometer on 95 civic?!
- Car smells rich, poor gas milage.
- alternator for 98 civic
- clicking clutch
- swaped motor
- D15 to D16z6 help
- Looking for k20 engine
- Since the suspension forum is slow: Its time to play recommend me a spring
- What is...Manufacture Control Ignition system
- Brake problems...
- Help! Installed Short Ram Intake, screeching noise o_o?!
- Brake Pads?
- Benen Tow hook question...
- Remove Power steering
- Idle problems...yes another idle thread.
- 96-00 civic 2/4 door lip *its not fitting...
- 97 EX e-brake handle on 96 CX?
- HELP WANTED: How to Change my Manual Door Locks/Windows to Power?
- CVT for Manual Tranny Oil?
- Ls/vtec ecu?
- I have a 2000 Civic CX and want to run nitrous reliably. Is CAT on exaust manifold bad?
- Question on city light socket...
- Differences in 92-up Civics? Coupe VS sedan?
- need civic exhaust suggestion
- How to remove the actuator on an EK civic?
- t1 motorsports dallas
- Wheres the rev limiter located
- N E 1 KNOW FELI GODOY?
- Mini me not starting
- replacing wiper switch
- please help me im stupid...
- san angelo texas
- NEED HELP ASAP
- UKDM CTR Headlights 96-98
- HELP PLEASE!!!
- Just bought a 97 CX Hatch.. Need help
- A "what's this leak" question
- radiator question
- d16y8 manifold on y7 head
- Considering buying an 00 SI
- Need Help Installing An VIS Spoon style Lip!!
- 3 door to 2dr conversion?
- ctr crank pulley, specific question
- dizzy clocked all the way forward is this ok?
- skunk2 throttle body???
- Civic Fog lights question !?!?
- obd2a harness???manual harness can it be used on a auto civic???
- d16y7 converted to OBD1 idle problem fix
- J30A1 in a 93 civic?
- smog
- HID Lights for 97 CX Hatch
- Quick Question..
- HELP: Replacing Door Shell on 92 Hatch.
- strange sounds ?
- clutch??
- Need Help with DX hatch on CX car.
- 92-95 civic question
- quick tie rod alignment question
- 00-03 tl hids in ek?
- Removing valve springs - quick help
- 93 hatch w/ 98 ls swap, exhaust and cat question.
- needheLpasapO2 Simulater
- Spoon mirror base, are the 2 holes same as other mirrors?
- 93 hatch stolen!!!
- D16Y8 SWAP into EG HELP!
- Lambo doors for sale !
- 95 hatch with b20
- code 43 and 22 ???
- Rear-end Noise when turning...
- swap question
- High HP and TQ applications 4 or 5 lug?
- B16 Swap question (its a quick one)
- D16A6 Stage 1 Crane Cam fit D15B7?
- Timing Belt Help
- 2000 Civic 02 Heater
- 93 Honda Civic HB Mini Me CYP + Rotten Egg smell
- Ek avid mounts question
- Help Camber Question
- E-brake handle
- d16y8 head build
- Electrical issues
- BLOWING FUSES LEFT TO RIGHT
- 92-95 civic SRS Control Unit
- pingin??
- Magnaflow offset XL muffler...anyone got one on a civic ???
- Top Speed 2nd try
- Rear Brake Lines
- Where can I buy...?
- horn problem
- high idle
- tranny making a ticking sound
- solid CEL 96 dx auto to 01 ITR swap tried diff ecu's
- Need a quick review... FIDANZA short throw shifter. ANYONE ever tried one?? Know someone who has??
- Vtec Light
- speedo freakin out
- z6 intake manifold on a obdii car
- HELP:starting probs
- type r internals in a b18 ls block
- what ecu do i need?
- VSS or Speedometer Cap...
- No IAB? a Loss?
- Idle Problem
- d16y7 IDEL problem
- horrible creaking iwhile in reverse
- All motor D16Z6 Build.... take a guess
- TPS or Timing problem? (d16y7)
- HELP:Oil Pump+Oil Light+Whine+No Vtec =????
- 99-00 SI Comptech icebox/arm in a 96-00 Hatch with B18C5/AEBS Intake? (I searched)
- DC Hood Dampers on EK?
- I need to get a new speedo cluster for my 94 si does it have to be from a 94 or can it be something
- s2000 steering wheel?
- Introduction; had my 'Sol for a year, my thoughts, some questions; slight idling problem.
- looking for a shop in 323
- Would have posted in General forums, but im restricted.. help please.
- CELS when Warm???
- ITR Sway bar hitting RSR exhaust on ek!
- Parts that come with an engine swap? Brake Q?
- hey can some one help me with this code.
- LS swap into ej help...
- foglights installation question??? Need help
- good place for oem parts?
- b series tranny compatible with d series motor? yes or no?
- Swaped 99ex cam into 93ex motor.
- license plate bulb. where can i order hyper white ones
- y7 y8?
- Question about grounding cable on the Valve Cover
- Did 91 ex master cyl swap and brakes now feel worse
- Stock EG radio
- will 96-00 civic lower control arm fit?
- Just double checking....(searched just want to make sure)
- CF Hood Install
- Integra dash in EG
- where can i find oem style clear ek square fogs?
- stolen ek
- Chipping p28 quick question
- Does this price sound right for a head-gasket?
- Speakers
- ek skirt in eg pics plz
- CIVIC EXPERT NEED IDEAS !
- thinkin about buying this wondering if it needs anything
- are aem power steering and alternator pulleys are the same for B&D?
- help, what is my tranny
- where can I go to get jdm oem parts?
- 99 DX, cable or electronic speedo?
- NEED DISTRIBUTOR CONVERSION DIAGRAM
- HOW FAST IS YOUR EG / EK HATCH WITH B18C1 SWAP IN 1/4
- fuel system?
- EG Stolen From Cal Poly Pomona Fully Done JDM Show Car 10/30/06 plz read.
- B-d adapter anyone make em yet.
- o2 for b and d the same???
- noobie here. just postin up to introduce myself
- d16y8 swapped in del sol need HELP!!!!
- NEED HELP with Rust On My EG Hatch!!!
- HID question. Where to tap into for high beam
- cant get retainer off!!!
- Vaccum leak! Noooooo...
- 99-00 si rims - tuner lugs work?
- Water Leak. Water Behind Driver Seat On Floor 92 Civic Hatch
- Coupe Bumper Onto Sedan
- Problem avoidance
- Seat belt bolt Q
- Please help ID my clutch
- 00 sparco seat base
- type-r pressure plate question???
- Honda EXPERT!!! tranny question?
- PowerSteering help!
- Car wont start when wet.. WTF?!
- my EH3 wants to be EG6* pics
- Noob Question T_T how the heck do i install an SRI on my 97 civic
- EM1 for $1900...
- readiness monitors.. how long does it take for them to be ready?
- Does anyone know the part Number For The Main relay for a 93 EG hatch?
- what factory cd players fit in eg?
- NEED HELP installing a OEM Speedometer into an EG Hatch
- ebay cat backs?
- 2000 civic Si clutch problems.. please help a newb..
- Oil windage tray?
- can em1 use civic 5 lug?
- got a dayco timing belt for my b16a2. just wanna confirm that this is what i need?
- compression test #'s / good-bad ?
- PIstons???????
- Civic EX HELP
- Changing Injector Wires?!?!
- 7400rmp fuel cut on D16y8?
- Gasket Maker
- Car Starts then Immediatly Cuts off
- installing an alpine deck. two harnesses?
- What type of engine? VXi
- HELP!!!!!! check clutch fluid!!!
- 92-95 civic & 93-95 del sol have same Upper Control Arm??
- somthing..pops when letting off the throttle
- is it bad to not have a cat converter on my obd2 car?
- Question: ITR Axles. Conversion.
- ecu fuse
- d series turbo or b series n/a
- 96-98 ex. hx wiring harness
- AWD EG !!Help the Noob
- plz help! broke down beast.
- What NOT to do with your lower control arm.
- Projectors
- 15amp ecu fuse keeps blowing
- how to get stuck lca bolts out?
- idle probelm when in park or neutal
- dose the 99-00 sihave abs?
- Paint Question
- top speed
- Weird noise...
- put ex coupe doors with power windows want to make them work in my dx do i need harness from the doo
- leather seats
- when i step on the accelator the steering on my car goes NUTS!
- my first car d16y7 shift times?
- B-16 SIR-ll JDM swapped....
- Got done with motor swap but idles crazy
- MIAMI BEACH PEOPLE!!!!! looking to be shown the miami car scene
- Hot Start Issues...
- help with d16z6
- 225-50-15 bfg drag radials on a EG...drivability issues??
- Civic Type R cluster help????
- AEM Short Ram on a d16y7? Is it worth it?
- Tach Problem
- itb's???
- EG OEM Foglight
- Fairly new clutch slips- Can glazing be worn off?
- lsd for a b16 tranny
- NEED A SHOP!!!!!!!!!!!!!
- NEed a clutch! suggestions?
- b16a2 nitrous pistons????!!!!!
- How to change radio time?
- car idles high what to do
- snapped bolts for distributor
- AC friendly performance headers
- Thread size pitch etc etc various engine bay bolts, fenders , headlights , 12pt
- Which pstons would be beter for my ls blockt
- y8 with crower setup
- D15B8 8 valve or 16 valve relief check!
