View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Intake manifold swap help
- Suprised with weight reduction
- Striped bolt, Any advice?
- Who running 14's on a bolt on 5th gen Si??
- d15b7 redline?
- The Honda OEM = Adler connection?
- Brake Job Help
- Volts droping after 4 grand
- Source for new OEM parts for JDMD15b swap.
- Help!!! Wiring for a D16Z6 into a 92 VX hatch!!!
- keep blowing a fuse
- Every H22 swap ive seen.....runs like sh*t
- Just woke up and my civic is gone
- My Rear Brake Swap In, Could You Check It Out?
- who makes a good eg hatch carbon fiber spoon replica lip? (wow that was long)
- Could a bigger tb make your car bog?
- what to do to my dseries ?? need help
- I need a p28!!!!!!!!!!!!!!!!1
- How do you calibrate a TPS?
- Draft:Check out TYPE R Fan Stalker stories in the TYPE R forum.
- Help!!! Working on a Civic Lx 1995, and the bottom alternator bolt will not slide free...
- any DIY's Specific For Fuel Filter Change 4 92 Si Sedan??
- Honda Beat
- Confused about my CX ecu. HELP!
- just got my new car
- cx motor
- will these bulbs melt jdm platic headlights?
- check this hatch out
- what is best turbo B18B or turbo D15B
- info on d-series trannys
- Compression Ratio basics please.
- What head gasket to raise compression?
- 3500 RPM's fells like I am hitting the rev. limiter...WTF?
- rear lower control arm question...
- EG swap
- A/C Compatibilty
- Universal muffler type.
- spark plug wires
- HELP!!!! I NEED A B16 TIMING BELT ASAP
- Will an o2 sensor from D15 work with a B18C1?
- Intake boot turning white
- OMG How can i tell what i have EK/EG/EF
- best front camber kit for em1?
- 96-00 Hatchback Exhaust and Header Questions.
- My Timing Doesn't Register
- MY FIRST HOW TO: making a flange for the Apexi Filter *PICS*
- canadian EG same as USDM EG ?
- wierd problem after injector install.
- Honda Civic Drive axel broke. Help
- CDM EG...different wiring harness colors ??
- 99-00 Si Spoiler Size
- 92 civic si w/jdm h22 should i go turbo or supercharged?
- engine swap!!
- What to buy...
- duckbill - less EG hatch??????
- P28 ecu
- any1 have dis setup?
- Sound clips of ES OVAL exhaust
- eg fron del sol HELP!
- Knock Sensor Identification?
- i think i've been screwed by ebay
- How much play is suppose to be on the clutch pedal..........
- Comparisin of Weight between H series and B series
- Tell me which SOHC Head I have....Y8 or Z6?
- comparing sycro's?
- anyone ever remove the middle of the dash (where the temp and ac plus radio)
- Would i need a resonator for my maganaflow oval?
- IDENTIFY this nipple please (no nudity in this thread ;)
- Aebs Or Skunks IM
- AEBS Im/ Skunk 2 on LsV witch is really better?
- ZC tq
- b16 Tranny/ Not good for Highway??
- how do you install the roof molding clips?
- Budget Suspension Shootout!
- READ ME!!!! PLEASE!!!! B16A and B18A1 Timing Belt question
- Is a Rear engine mount also known as a firewall side mount?
- are 92-95 4door and hatch mudguards the same??
- Been getting really bad gas mileage
- What to put in eg audio console? Want pics.
- 93 GSR seats in a 93 hatch
- JDM ecu
- are all d series clutch(PP)/flywheel the samething???
- Spark Plug Wires on B16
- I will the pistons fit?
- What Distributor Cap for a b16a jdm eg9????
- Whats to much for a stage 1 clutch
- o2 sim install
- d16y8 swap
- Hydraulic Lines
- obd 2 o2 1 sensor
- Throttle body help
- How bad will my Si run without a intake air temp sensor?
- Im looking for a 96-98 civic EX wiring harness
- JDM GSR...into 94 DEL SOL SI. Problems PLEASE HELP!!!!!!!
- 1500 mile deal
- what compressor to paint?
- Clutch and Flywheel
- put a EG jdm steering wheel but got problems
- Apollo Rear Sway Bar
- very quick question...too many search results for off the topic ish...what tranny do 98 civic EX hav
- Exhaust Pics...
- Hayame coilovers installed
- AEM alternator pulley problem
- How much does this cost . . . . .
- eg2 del Sol Vented hood fitment question???
- Integra steering rack swap into an EG
- foglight covers
- Custom bent piping, Discourse on JDM header, and future possibilities.
- HELP!!!! fuel rail bolts broke
- Skunk 2 cams in a 99 SI
- DIY/How to: Del Sol Seats into an EK
- ok i need an opinion here...
- Anyone in socal wanna put in a swap for some cash?
- D15B7 Oil Consumption
- cv joint replacement
- My new tranny redline's at 80 mph in seacond gear !
- Brakes
- sol or eg hb
- maintanance required warning???
- tach doesnt work after swap
- Does rim/tire sire affect camber/alignment?
- non-terminating turn signals. Help
- Cleaning engine bay and engine???
- d16 in to d15
- Dynomax super turbo muffler
- Quick Q about hatch trim
- 93 gsr rear disc setup, will it work on a 97cx hatch???
- 93 civic dx with gsr swap.....exhaust problems
- installing power windows in a cx
- what steering wheel is everyone sportin' ?
- 1992 civic si. overheating problem.
- What suspension are you running with your N1 on your hatch?
- About to just give up on my tranny troubles...
- DelSol weight reduction
- d16 header fitment
- civic type r dash color
- anyone tell me what this is on the throttle body?
- gsr not starting anymore.
- Type R
- Question about Motor mount inserts
- 94 Del Sol si. Fuel pump location?
- engine swap
- tune up stuff?
- All motor setups
- Using a ABS Master Cylinder without ABS?
- fuel pump?
- manual vs auto throttle bodies
- Will a B16 intake manifold work on a B18
- BIG ELECTRICAL PROBLEMS!!!!
- Will an obd2a ECU, work with my obd2b engine?
- Request! Ek with RSX-S muffler
- Exhaust Hanger
- anyone running 16x7's and no camber kit? on EG's?
- Civic Thread Pattern???
- CANT BELIEVE THIS SHIT
- stripped block mount bolt. HELP!
- I need to find this part.
- Mis-Shift from 3rd to 4th
- b20 1/4 times in a eg
- Getting good or bad gas mileage?
- Evo exhaust on a Civic
- obd2 = car ... ecu = obd1 .... emission?
- Where can i find a s2000 steering wheel????
- are leaking dampers unusable?
- B16A EK...Need info...please
- o2 sensor wire problem, using the p28 on a d15b?
- 15's or 16's on EG
- FS: SMSP 2.5" test pipe (NEW)
- ITR header on B16 SirII
- Apexi WS 2 exhaust rattle on an EG
- Just imported a Civic SiR EG6
- ITR header on a B16 SirII
- Will a F22A1 TB it on a D16Z6 IM??
- 96 Ex Build, What to do next
- What ECU you guys using?
- anyone re-cover their armrest with this?
- 4 Sale B18B, J4D LSD (Type R tranny), ACT clutch, axles, ecu, harness, starter
- Maintenance Indicator question
- Dave Hickman Anyone heard of HIM.
- Difference between 92-95 exhaust and 99-00
- Would you buy used shocks and coilovers?
- HKS Hipermax Damper II coilover
- H22 in an EK
- I NEED A B18 B
- Brake booster Q and A
- 4040 Prop valve question
- a lill info please on a mini me
- How do you remove the ps for a del sol?
- ITR cams with obd2?
- INJECTOR problems
- EVAP control system leakage?
- Carfax Please!!
- Tranny problems
- SI Part 2
- 99-00 Civic SI Axles?
- bigger brake rotors?
- using seafoam
- Valves tick after adjustment, LMA? Valve Guides?
- Intake Manifold and Throttle body swap
- help with neuspeed springs..
- Coilover Damper Question
- does anyone have the link to es mufflers?
- how to remove cruise control
- ek side skirts on eg
- Honda Plug wires what model can use them?
- Need help on future swap maybe....
- Seatbelts locking?
- Will these brake pads fit? (Do not post unless you truly know the answer)
- Need header help ASAP, regarding JDM GSR, Please!
- Are Ground Controls supposed to come with an adjuster tool?
- Spoon Muffler
- 95 d16z6 distributor on a 94 B18b1 fit ?
- VSS differences [99-00si]
- Just put in my VAFC and now i have a weird idle o.0
- doing an install and i have a few questions
- C pillar bar ej1
- Navagation system for the ek
- tein type flex pillow ball mounts
- noise when driving...
- Jerky car
- progress sway bar
- Please help with one more thing before my car runs right...please just look here....
- Service Check Connector
- Ignition Rotor Screw
- Need some freakin help once again:(
- my eg got me in trouble with the home owner association.................
- Performance Chips, which is best?
- USDM Engines
- Civic ECU Swap
- Seat Rail Q
- Civic ECU Swap
- rim question
- EK hatch with 5 lug/brakes -> suspension dilemna
- where can i find a fiber image hood?
- Swap questions on new motor
- 96-00 Exhausts 4dr vs 2dr
- cable trans coversion?
- advancing your timing
- best for ek9 hatch?
- Average guess on value.
- Fitment question
- Best place to buy b16a swap?
- CONSOLE BACK TO LIFE
- Integra dash in a eg6 HELP wiring
- jdm d15 vtec Q's?
- Need help finding o2 extensions
- need help asap car wont start !!
- price for tires
- ?How to intall EK9 power folding mirrors?
- Dremel and intake manifold
