View Full Version : Honda Civic / Del Sol (1992 - 2000)
- very rough and low idle, dies after gas is applied
- alternator question
- just a quick question
- What are these rims called?
- Got a REF Ticket, anyone know how to avoid the hassle?
- jdm gsr wont rev pass 3000 pls HELP NEED HELP ASAP!!!!!
- damn, tie rod ends
- Jdm motor supply numbers?
- Some help plz no start issue.
- identify this dizzy
- 94 coupe suspension
- need rear emblem size help plz??
- Pic request
- 1998 ex swap question please help
- canadian ek ecu pin diagram
- Removing 2000 coupe sideskirts question
- can CEL's cause additional CEL's?
- ECU questions....
- Slow Oil Seep Help from D16y7 people? (pics)
- 96-99 dx manifold/cat..I NEED ONE!!!
- My ek was just stolen
- 93 hatch ls swap
- no spark, no power to white/blu wire
- Eg hatch exhaust on sol
- Opinions on this setup.
- Aztec green pearl or Tahitian Green Pearl
- question on ek
- Idle Problem
- question on ek
- Leaking intake manifold gasket
- Steel Metal Noise???
- am I going to need to replace the clutch?
- SOME THING IS WRONG WITH THIS CAR..
- changing locks
- Question about my EK's cluster
- needing advice
- Which site is most reputable to purchase honda motors??
- Looking for 2 Clean EG's for photoshoot
- 1994 eg tranmission help
- d16z6 cylinder should I bu?
- Si grill with si emblem?
- d16 y8 problems
- 1996 - 2000 Civic changes by year?
- are dual valve springs on b16 the same as itr dual valve springs???
- B18C 94-97 (GSR) >> 99 Civic EX ?'s
- AEM EMS Compatibility.
- lowering my car...need help!!!
- OBD2b->OBD2a D16Y7 swap
- p2p or p28???
- Cluster swap question!!! Quick
- Honda civic 93' engines swap
- 97 civic fan speed blower switch only works on 3,4
- Coilover Suggestion?
- cutting itr muffler (canister part) to fit eg6. will it ruin the muffler?
- civic mugen mf10
- What year Transmissions will work for my car
- Longest lasting brake pads?
- How to remove lug locks without key
- SI rear disc fit 97 civic hatchback? please help!!
- cel 9
- my vtec dont work
- b18a1 into eg
- Part # for 96-00 door lock/unlock plastic
- b20 vtec into eg
- B series headers problem
- 2000 Si A/C compressor issue
- Shifter loose
- hw to remove rear garnish? (del sol)
- d15b setup questions
- Quick Lug Nut qestion
- WHAT SIZE
- vss question
- ej1 no power..
- HELP
- where do you keep your gauges??
- High Mileage Oil Filter?
- Seafoam Question..
- 94 Del Sol... new to the Forums
- vtec help
- LS or turbo a mini me?
- ECU UPGRADE???
- have a plan, but need a lil revision
- AUTO-ZONE/ADVANCED/O'RIELYS
- Deer just took out both Pass side doors on '99 Civic EX sedan
- MINI_ME swap..Help please
- Mugen knob thread
- Where to buy JDM ITR Pistons
- oem b16a3 del sol rear calipers issues
- Paddle shifter 94 ej2
- 96-98 vs. 99-00
- arp and belt questions
- Arc induction box with power chamber in a 95 coupe.
- 92 coupe wont start
- Cylinder Sleeves question
- P06 Ecu for b18b1
- Brake system em1
- HELP WITH A 99 CIVIC WITH LS SWAP
- supernoob
- cam selection
- d15 mini me swap
- feel like a noob
- Need Help: D16Y8- Water leak between head & intake manifold
- b18b1 not making power like it did
- anyone got pics of itr muffler in a 1992-95 civic hatchback???
- Where do you buy side mirror visors?
- CTR Clock Install Writeup??
- HID lights
- do I need a 4040 prop valve?
- basemap
- Installing antenna on 92 CX (searched)
- code 41 on eg with b18b1
- boosted 92 sedan crankcase problem
- 2000 Civic Spoiler Brake Light Replacement??
- Is Maaco Good?????
- Which head do I have (I have searched)
- D16Z6 Swapped
- 96 CX B16 Swap
- front end body swap
- Msd Ignition With A chip?
- fuel pump the same? eg's and ek's?
- does ek 4 dr skirts fit eg hatch? Help..
- Creaking/Popping coming from passenger door
- EG (1992 to 1995 hatchback) civic brake conversion?
- being a good daily car.
- Power window help on EG. Can anyone snap a pic of the back side of there switches
- power problem=[
- IAT sensor problem?
- D15B swap question
- Tell me what kind of ecu I have
- VSS installation...
- Removing a/c
- A/c Help!!
- eg hatch horn doesnt work...HELP!!!
- Sway bar question!
- transmission and clutch swap problems
- What Headers Do I Buy??
- Tourque specs gsr
- what axels do i use??
- Draining and refilling Transmission fluid question
- tuning in real time
- B Series in EG
- LHD Civic EK Dash w/ vent???
- wierd groaning from the clutch hydro line
- Leagalize It
- What is this EM1 trunk??
- 2000 Si died - need help troubleshooting
- Are all the ej1 the same?
- My Ek build
- honda civic will not rev past 5500rpm help!
- Right axle?
- Password JDM 96-98 Fenders YAY or NAY
- Grinding noise coming from hub...
- how is Fram?
- EK9 CTR OEM Intake into EK with B18-C Spec R
- 00 fog lights on eg
- 98 Civic A/C Removal
- OBDII Sohc ZC California Smog
- E-break
- zc-vtec
- Wierd 95 civic d15b7 idle
- '92 - '95 Civics, which ones had manual steering?
- Em1 block code, not original ?
- MAIN RELY FUSE
- Sunroof grease? What grease does honda use?
- Ls oil pump question
- swap overheating
- Relay Location?
- how to check vtec solenoid?
- need help
- 95 Civic EX, No VTEC
- 44300-s5a-008 wheel bearings fit ABS hubs?
- vtec problems?
- Help!! Car wont start
- has any one supercharged and turbo there car at the same time
- ARC induction box and chamber in a 95 gsr swap?
- chrome
- Accident - car is probably totalled - need help with insurance claims
- D series automatic transmissions all same?
- Need help on turbo d16
- Need help deciding..
- Whats up from cali!
- drop zone springs
- clutch problem...
- Need help choosing OEM or JDM
- tach gone crazy
- 96 Hatch Build
- receiver hitch?
- how do i install a tachometer?
- EK hatch Build
- gas smell???? help
- Part out or Sell whole?
- Does your 02 sensor effect your gas mileage?
- i want to get gauges..
- Turbo on a D series automatic
- TPS, IAT and ECT CEL's on
- help when I push in the break to start...
- Speedo Jumping all over the place
- 93 civic IAT and O2 sensor problem
- Can I replace the plastic parts under my car?
- Ek guys: No start with no coolant question
- 97 EX swap?
- 93 del sol si cluster on a 97 del sol s... gas gauge issue.
- brake lights will not turn off
- Field's SFC-VTEC
- P06 ecu mods
- I just got a 99 Honda Civic Ex[EJ8]
- HELP ON LS-VTEC
- p1259 VTEC system malfunction
- Help. 95 civic w/ gsr swap dead suddenly dont know why
- b16a swap in 95 honda civic
- Help Deciding what motor to build for Turbo build. Single Cam VS DOHC?
- EM1 leaking grease near axle boot clamp HELP
- why does my car sag to the left
- clutch qustion
- EJ8 header, test pipe, muffler quick ?
- windshield molding question...
- how to wire up eg power replica spoon mirrors
- Wanting to tune car..
- I cant find my coolant drain plug?
- engine light question. help
- problem with exhaust manifold
- Will a Del Sol Tranny Work with a D16Y8
- buying separately need some advice.
- csf sensor code help!
- b18c1 intermittent oil leak
- can i pass smog with b16a2 with ctr piston and itr cams???
- Help!!!
- GSR CD Player in EJ1
- 99 ek wit b16 idle problems
- turbo d15
- im looking forr..... and need help
- Exhaust opinions needed
- Strut and Wheel Problems
- Short Shifters bad or good????
- motor mount problem
- motor swap bar
- what Type of Coolant should I use?
- Extra honda logo emblem (attach or too ricey?)
- omi power front camber kit question
- Gear Fluid and Silicone?
- vtec question
- 99-00 civic egr roof shade
- '95 del Sol JDM Headlights - HIDs?
- process of BAR in california
- not so quick question
- EG with b18 ls vtec
- 98 ek front seat replacement
- deleting cruise control
