View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Civic vti 99 philippines
- How much wear on the alternator belt is bad?
- 97 ek won't warm up
- 00 Civic EX coupe - Cannot lock drivers side door!
- 1.6 vtec using oil/skipping
- EG civic break line, fuel line tuck Jdm b18c R swapperuski
- How to wire VTEC when using an OBD2A to OBD1 harness
- HELP-Random AFR lean out
- 97 Type R Disk brake conversion
- 94 civic coupe b16a swap
- How do I time d15z1 block with possible d16 vtec head?
- Anyone done a seat pan swap for 4th gen prelude seats?
- Master Cylinder Question
- Dilemma: 93 hatchback build or 01 forester
- Speedometer/Tach issue
- mini me cold start high idle
- How fix big hole in front wheel well?
- Em1 overheating (solved)
- GSR into 94 Civic - plug and play?
- Hatchback Lid/Door
- d15b7 "lub" at idle
- 98 civic with cooling fan, A/C, and temp gauge issues
- hp gains
- 92 Civic VX (D15Z1) stumbles at 40-50mph and then throws code 9
- Del Sol door swapping
- Help Can't Figure out which brake pads these are ??
- Suspension for my car?
- Reputable company to purchase reman'd cylinder head from
- Crank pulley wobble
- 95 Civic - groaning/rubbing noise when braking at low speeds
- 1994 civic 4 door
- Rebuild engine ?
- EM1 Motor Mounts
- Burnin a lot of oil...
- 92 Si EG issues with starting D16Z6
- 93 civic turns on whenever it wants
- Type R wheels. Should I use hub centric rings?
- Frankenstein Sohc D-Series Build
- Headlights Intermittent
- hole in gas tank? easy to patch or replacement?
- Leaving lights on after shut off yields dead battery :(
- D16z6
- This is how my Honda drives
- won't go into gear while running - 93 SI 5spd
- d16y7 to y8 mini me help
- Fuel issue (solved)
- My ongoing oil leak saga
- 98 civic baffled on what to do next
- 2 piece front lower control arm interchangeability
- Timing belt install kicking my butt.....
- need o2 sensor best place?
- 97 civic h23a vtec iacv prob
- change mtf on del sol
- Dizzy problems B18c4 EG
- 1998 Acura 1.6 EL factory keyless entry issue
- has anyone ever seen a bent trailing arm
- UCA ball joint question
- o2 sensor wideband questions
- what would cause all this red rust in the distributor
- Do any of you suffer from a spongy brake pedal?
- 00 Civic - Brakes creak
- Prestigious DX badge fell off my 97 Civic
- Civic Si sound when turning (solved)
- D15B Vtec Rebuild for CA BAR??
- civic, hard start and flood
- Civic Suspension Components
- ECU compatibility??
- 52308-SR3-000 vs 52308-S04-000 rear sway d-bracket
- replaced tranny and now won't start! Help!!!
- 96-00 DX Cat Deletion
- Which path should I choose, and weird little noise
- tachometer problem 94 civic lx
- 94 Civic DX Stereo issue.
- Help with wiring
- Louder Engine After Valves Adjusted and Changing to Synthetic
- 96 del Sol si alarm question
- 96 Civic EX - cam gear sheared off. See anything wrong with head (pics)?
- 99 Civic LX overheating
- B16 Timing Belt loose? (Video)
- B16A2 loss of oil
- Engine stalls at IDLE and DRIVING
- B16a2 dies out once the motor is warm
- EK D16y7 swap
- '99 constant misfire
- eg spoiler removal help
- exhaust
- scan tool problems
- Oil leakage from shifter shaft.....
- 95 civic tie rods
- What color is that?
- 1993 Honda Civic Si - Theft Recovery
- 98 Civic miss-fire code
- It is surging REALLY hard at idle...
- 96 EX died while driving, starter wont engage?
- EJ - How do I remove the nrg short steering hub?
- b18b cranks but wont start. fresh rebuild. getting fuel
- Have any of you replaced these parts? Trailing assembly [PICS]
- d15b7 swap to d16y7 rough cool idle
- Radiator hose size
- Del Sol D15B Bucking
- P28 ecu questions!!
- Fenders
- head gasket, or cracked head?
- 99 civic d16y7 - sprayed carb cleaner into in TB, now won't start
- Auto to manual swap 93 EG. Help.
- del sol auto to manual conversion
- Low Idle, Stalls out when coming to a stop
- shifter linkage issues
- A Possible Solution For Swed_honda (closed thread)
- All of my lights pulsate on my EJ1 for 3 minutes
- Radio Help 93 Del sol
- need help wiring map sensor 92/95 civic
- Sprays of water being forcefully blown out of my EJ1 exhaust
- 94 EX horn not working, modified wiring issue
- 97' civic dx with a 93' d16z6 powerloss
- '98 Civic DX (Manual 5-spd)| GO TO START, but NO CRANK! Engine won't fire-up!
- EM1 Si vs SiR
- Damage to the forward hull!! (del sol)
- SRS light stuck on
- 00 civic dx/y8 head-y7 block mini me --> o2 sensor question
- First Build. Advice/Opinions
- 1997 Civic EX speedometer issues
- The keyhole , in the middle, behind the seats?
- HELP!!! I NEED HELP READING MY CEL CODES
- Front Camber kit hits Solved
- B16b em1 engine problems :(
- How can I tell if my subframe is bent? (Pictures inside)
- 1996 Civic DX Coupe Exhaust Piping
- 00 Civic Dx door lock
- Civic Motor Swap
- RPM gauge has gone crazy wth
- Rear UCA intall question (camber kit)
- Start problem - EK manual
- Radiator/overflow tube keeps coming off
- 99 DX - DD Rebuild Project
- Y7 Block swap Helppp!!!
- 99 honda civic ex coupe srs light on and off
- exhaust issue
- Burning oil bad
- Y7 Block in my Ex D16Y8
- Putting a y7 block in my d16y8 97 civic
- Slowly Losing Coolant, but Can't Figure Out Why
- b16a motor into my 97 civic ex - different engine post mounts?
- Defrost Activates AC -- 97 EX [2HG]
- 95 civic b18b crank start 3 sec and stall
- mini me swap
- cheapest way to lower 98 civic
- 99 civic lx d16y8 3000RPM idle, gas hog, just replaced head gasket, etc...
- 95 Civic DX Coolant Disappearing
- DIY video: Honda Civic distributor oil seal replacement
- A/C Problem on Civc 1.6 VTi EK4
- PGM-FI Main Relay
- Question with my vtec head
- check engine light works only intermittently
- New Tstat still overheating
- 99 civic lx is running hot
- d16y8 bottom d16y7 heads
- plz help me, dosent start.. checked almost everything :(
- 98 civic ex - battery dies every night
- Can I buy a 99-00 harness adapter to a 92-95 civic cluster?
- Does this Rollcage fit?
- 99 Civic with knocking motor
- 99-2000 civic si - no voltage at radiator fan relay
- You Can't Polish a Turd (98 Civic HX build thread)
- Sedan Taillight part #
- Help! 93 Civic - one fuel injector won't pulse
- Possible tdc problem.....
- y7/y8 mini me cel po132
- power window rhd civic 1992 siR without plug
- 97 gsr - Engine keeps dying help?
- Misfiring all 4 cylinders
- 1993 Civic PGM-FI Relay G101 Grounding Issue
- Semi-urgent: B16 TB gasket - same as B18C5 (ITR) besides diameter?
- d16z6 idle vibration
- Em1 b16 rebuild acceleration/hesitation problems! B
- Body or build?
- Where can I find a duckbill?!?!????????
- Best wire for big 3
- EK ABS on EG
- First Honda, Need advice/help
- A/C ISSUES ..MIGHT JUMP OFF BRIDGE.
- Cruise Control Fail(Auto Del sol 93)
- del Sol No Start
- 2000 Civic Dx: Opinions on SRI?
- Alarm Ignition wire help
- 94 civic hatchback cranks no start
- Catalytic Converter
- Difficulty on getting gear lever into 1st
- Trip odometer stuckthen tries to
- EG cluster lights question
- D15B JDM P2a_7 head distributor
- Em1 with ex harness dizzy help
- 92 civic - forgot to put spark plug wires back on and now it wont start
- Y8 swap help
- 92 hatchback dx -- Power door conversion help!
- b20vtec modded/milled what spark plugs?
- Wrong ECU?!
- NEED HELP - D16Y8 OIL LEAK
- 94 civic cx a/c overcharge
- 97 civic ex D16Y8 help please
- D16Y8 Timing Help / Getting it to run right
- 97 Civic Coupe D16Y8 - Header - Questions
- B16a block with b20 rods
- 98 LSV swap p0171
- Tein 88-91 springs on 93-97 del Sol EG
- 2000 civic dx wiring
- 97 civic dx. d16y7 aftermarket fan.
- D15B swap car misfires at 6k rpm?
- '93 Del Sol with 250k won't start. I don't hear the fuel pump.
- 2000 honda civic power adapter unplugged
- Clutch cancel delete
- 97 civic ex - thermostat fan switch
- 96 Civic Various Noises (Clacking and Squealing) + Bad MPG + Low Idle
- 97 del sol airbags replaceable?
- Del Sol Automatic Shifter Cable?
- Question about honda Civic EG Sedan 1992-1995 Mudflaps
- D16z6 timing
- 1993 Del D16Z6 Idle Problem w/ Smell
- 2000 Civic DX Hatch Alternator
- 2000 Honda Civic electrical nightmare!
- What exhaust is this?
- no power to starter 99 civic ex
- Pulling Shift Rod From Trans
- 97 civic lx all stock - coilovers?
- URGENT - Need help charging my A/C system
- Oil Burn/Leak/Overheating/Coolant loss - 93 Civic DX
- 98 Civic hatch with D16A block/P2A-10 head/P2E ECU - Need Help to Identify
- 2000 Civic Sport Exhaust problems
- 98 civic window trouble
- 92 Si/LS swap - questions about custom exhaust
- d16y8 vtec motor from 99 civic ex swap to d15b 3 stage vtec jdm motor
- Need help with a P1259 Engine Code
- 93 del sol si brake troubles
- 97 Civic - i want more performance
- 1998 Honda Civic Radiator fan coming on intermittently
- Need some help on my Civic 96 (ECU and Idling Problems)
- I want to put Headers on my 97 Civic
- Thoughts on the plastic fenderwell liners?
- Strange knock when shifting into gears
- 1995 del sol - modified d16z6 bogging, spitting, smoking, and stinking
- Engine Removal D16Y7
- Cylinder head question
- Rear ITR Seats in Civic coupe ?
- reverse light switch, gear sticking, dumbfounded
- Can't get timing right
- Really odd problem, Temp guage reads half way when I turn on car even when it's cold.
- 1992 Honda Civic overheating temp gage not working
- Thoughts on extended top hats.
- problems with the idle ??
- tire wear--suspension or alignment
