View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Whats the best ek to buy for a B16a H22a swap?
- OBD2 code 45
- Who was the girl on the HWY? (Toronto)
- New Civic Si?
- Big brake upgrade...anyone done it (SRV rotors)
- where are all the JDM ek's at?
- spoon PK
- Wiring harness, VX adding d16z6 head.
- Check my SiR
- Stock Si Dyno
- dropping a/c misc from car..
- Need to get Tanked
- What is B18K
- 92-95 civic carbon fiber hood wanted. va area
- si guages on my 98 dx?
- Thermal Switch?
- D16Z6 OBD I -> D16Y8 OBD II???
- Please someone answer this really stupid question!!!!!!!!!!!!!!!!!
- cheap HKS dragger exhaust??
- auto down windows
- Si cluster in a civic hatchback
- Exhaust Cam Seal
- carbon fiber window trims
- EG Owners, lesse your clusters...
- should i buy this?????
- Finally getting my JDM B18c
- Hatch Exhaust
- Way OT: Carbon Fiber toilet seat...
- B16 Mini Cooper
- Question about dirty intake manifold
- How much does a stock hood weigh? The fiber images for a 95 ej shipping is 12lbs.
- crv engine
- bump
- will d15b7 flywheel go on d16y8?
- how do you check the outer cv boot on the driver side???
- People who have installed their own CV BOOTS !
- civic dx hatch 5gen 1/4 mile ?
- motor 4 sale!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- I got $550 from insurance/accident...where in tarnation can i get a FImages CF Hood for around this
- Driverside window washer arm not working right.........
- Tie Bar ?????
- 6th Gen. H22 Swap
- tinting my windows
- looking for a little advice...
- Lug Nuts?
- Does tthis seem possible?
- d-series gurus please help!!!!
- where to buy SI STOCK CAM???
- d16z6 question
- 6 PSI boost with 9.2:1 compression ratio
- quick question
- [FS] 99-00 Full Front End Nose Mask Si
- Need pic of 99-00 SI rear sway (stock)
- Which carsound cat with JDM header for 93 hatch??
- Anybody ever driven on an ACT clutch?
- Axle and Transmission change?
- How much is this worth?
- Chicagoland BBQ
- parts?
- Image Hosts
- insurance on a EG?
- Auto to stick :info needed:
- few ? on an eg
- Paint it gold!
- Vogue Silver Metallic paint code needed
- Short shifter or not??
- What do stock Si\SiR wheel weight?
- Taking out p/s & a/c questions
- need more speed.......swap or not
- 5zigen or apexi N1?
- How good is a '92+ Civic CX?
- The EG I told you guys about:
- anyone have a fields sfc instruction manual?
- need wire diagram for tach...
- Finally went Turbo!
- Stock 93 Ex ECU PSI limit?
- How to Change a timing belt, specific instructions please
- How to remove WHOLE ABS unit?!!
- I never realized how popular EBP Si's were.
- anyone vouch for www.jaydm.com???
- What's a good way to remove coilover sleeve from strut?
- front sway bar fits?
- Well it happened.....
- electrical problems...kinda stuck
- Would Type R springs fit onto a 99 Civic coupe?
- Integra Type R Rear Lower Control Arm
- engine shutter with a little bit of smoke....
- New Axles
- Idea
- spoon radiator hoses?
- eibach sportline springs?
- Stick with Honda or not? Mid-life crisis.
- carbon trunk lid??
- HELP ????Rear Disc Conversion???? HELP
- H22 EF shakedown
- my hatch
- 92 Civic CX hatchback upgrades?
- Ecu swap
- is street racing bad ??? why???
- lower compression ratio
- Distributor Questions
- ek civic hb exhust fit ek coupe?
- type R front on 6-gen civic ? ? ?
- the eg is gone :(
- Steering Column Help!!
- Smoke in exhaust at full throttle?
- 99 ex upgrade????????
- no flames needed: Anyone with air suspension?
- Size of 92-95' Civic EX Front Sway Bar?
- whats the deal w/ the spoon shiftknob?
- EG cx vs. EG dx? differences?
- Civic DriveAxle
- es n1 muffler
- ::seats from a 90 si/CRX fit in.....???
- mod options for a '96 4-door civic ex?
- si front end
- How to adjust b-series cam gears on your civic tutorial. *funny pic inside*
- looking for cf hood..please help
- how to convert my power steering rack into a manual?
- Help! About to drop the b18b in
- Pros and Cons of Greddy EVO?
- integra front on 92 hatch?
- best color for a EG hatch?
- is it hard to put in a tranny?
- anyone with a stock EK HB wing they dont need?
- Ok, helms manual says 4.2 quarts of oil, but
- Any one with A civic Si that has Volks TE37 Bronze.
- lookin to trade$+d-series hydro trans for a?(not LS)B-series cable trans... any takers
- Okay, some guy wants to buy my 1.5L stock CX engine/tranny!!!
- Integra Type R Rear Seats in 99 Hactchback
- Cold Idle
- check engine light on, how do i check the code?
- 550cc RC injectors on 99 civic SI ECU?
- Steering Pulls to one side
- whats this car worth
- d16y8 head on d16y7 make same amount of power as d16y8??
- Show me some hatch PIcs!
- Rear Suspension Sound
- Apexi GT Spec for 99-00 Civic Coupe DX?
- trouble with tranny
- WA people who can LOWER
- question on 89 civic lx???
- Spoon Wheels
- FYI: found this today at the library
- What B16 is best....in a 92-95 EX
- Adding an ACT clutch and lightened flywheel make car quicker
- 93 dx hatch auto to stick, difficult?
- got my d16z6 tranny...
- Lowering with Pro-kit, WA
- NEED HELP ecu probs
- Interchangeable VTEC wiring harnesses?
- people with STRIPPED hatches READ!!
- just bought a 96 coupe, got ?'s
- whats worth selling, from the rear end of an 99 Si/SiR?
- Spoon Exhaust
- This years club name for NOPI is......
- Magnaflow catback any good?
- eg cluster swap?
- Good deal on these koni?
- ITR Shortblock
- Stolen Car Poll
- Difficulty of A/C Install?
- price for 00 white hatchback
- EK people.. what brake lines to use for a 5 lug itr swap?
- engine swap and the ac doesnt work
- happy bday to me
- Fuel tank swap?
- are there any symptoms on your car if you have a bad o2 sensor?
- Tire Size q
- fitting 90'integ parts with 96civic LX
- Alright dumb question
- advice, how should i exact revenge on this thief? (semi-long)
- Hey Im a noob, well sorta......
- best cams
- B20B Question
- Del Sol Seats?
- Are the ECU "chips" from eBay worthwhile?
- Del Sol specs???
- on a scale from one to ten?
- Removing center console on 99-00 Civic?
- What's a good *** Computer Forum **(*
- do you feal better or worse?
- 4th gear, 120mph...
- Who is running 15" rotas?
- Dyno Sheets (problem)
- i need a B18b
- More Knock Sensor Questions...
- AutohausAZ.com
- exhaust questions for del sol im a newbie and dont know crap!
- whitelightnin in this thing?
- worth it to swap eg headlights to projector? 4 hid?
- Are 99-00 Civic SI Knuckles the same as 94-00 GSR Knuckles?
- Mni-Me Quesion
- EG shocks/springs? swappable with dc2 shocks/springs
- What exactly is ricey car?
- Check my Civic SiR....pic's inside
- Repair/Service Manuals
- 92-95 EX 5 speed tranny bolt up to a 99 LX?
- question on how to pull out a gauge cluster??
- which tires should i buy
- CF dash?
- Screwed Over
- Suspension Set-Up??
- clunking
- 1.CV shaft question/ 2.Clutch Question(Last steps in swap so help out)
- valve cover
- Spanky can be found!!
- Any SOHC specific sites?
- struts
- Eg people with upgraded radiators?
- H&R spring rate?
- New with Honda Cars
- How to tell what year a JDM B16 is from???????
- How to wire up a 92 Civic Hatchback cx Please Help everybody
- anyone interested in jdm mirrors? (96-98 sedans only)
- carbon lip for 96-98 civic
- B20 in 97 Civic, need some help
- civic with NOS
- 92 B16 VX Weight
- Are fuel pumps interchangable between different generation/motor civics??
- hey did u Hear....
- Car wont start!
- do axles from a cx d15 fit si?
- Need header to muffler exhaust
- An Alternative to Kyoguins (sp?) Lug Nuts - look
- torque spec on head bolts b16a
- my friend needs help pleaseee....
- Throtto body? senser
- changing shocks... breaking bolts...
- boost controller problems need help
- tranny question
- bent wheel need help
- i think it's time to change my name
- Is it legal to drive a right hand drive in the US????
- Tranny Mount
- Questions about Master cylinder,booster and proportioning valve?
- do i need to upgrade my fuel pump when swapping a b16a in my dx civic?
- is there a difference?
- New to hondas, need some help on brake choices thanks!
- Where to fill R12?
- Site
- B16A SiRII into a 2000 Hatch....ECU Question
- vtec does not work on B16?
- Can Someone run a VIN check on this car?
- so do the girl on this site have tight cars!!!!????
- Which AEM CAI works with a JDM B16A into 6th Gen Hatch?
- Oil Pan and Axle?
- Need help with friends '02 Civic EX
- need help with my SRS light!!!!!
- neuspeed spring alignment specs??
