View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Most enjoyable honda to drive?
- Weird Idle Problem
- Wiring harness
- Civic Ek Fuse Question ....
- DIFFERENCE ABOUT B16s.
- b16 questionz
- When to change timing belt?(age, not miles!)
- D2 Coilovers
- need help
- Little D16z6 help *Searched*
- N00b swap problems.
- WTH code 3,7,8
- My Honda Center Caps just got stolen
- 1993 del sol si electrical issue
- H22 & EG Axle Hop Problems
- Skunk2 Intake Manifold H22
- 93 civic code 21. but vtec works
- D16z6 Zex stage 2 cam
- fuel pressure HELP? b16 stock bottom end fully built type r head.....
- Question about the quaulity of these Si wheel replicas..
- Exaust Question
- how to fix cel code 10 and 19
- 95 DX suggestions......
- Car shakes when releasing clutch in first gear
- obd1 B18c1 into obd2 Civic DX-HELP
- Swap Wiring Issue! Please Help!
- G401 and A/C problem
- bent valves
- Is This Civic Worth It?
- Why Doesn't AC Blow Cold?
- 99 Civic Si - lots of slop in my shifter..
- 88-00 civic t/a bushing in teg 95 t/a?
- Muffler for 2000 Honda Civic EX 4dr?
- Little Problem, Crank Pulley Question
- B16a Auto swap
- bad idle problem getting worse. please help.
- Post D15B swap problems, really need help!
- need help asap 02 sensor
- integra AC condsener in 93 4dr..??
- bad outter or innner tie rod?
- H23 swap CEL problems
- CTR / 93 Octane
- 98 Civic EX Oil Still dirty after oilchange
- Brake light fuse keeps blowing.
- Spacers for HX's
- Need some wiring help =\
- Help me!! fuel problem! d16 turbo.. wont start!
- Are OEM del Sol steel wheels 13 x 4.5?
- my Baby wont start??
- Ref Ticket VC 27156B HELP!
- eg cup holder for bigger cups
- 96 EX Sunroof Problems PLEASE HELP!
- Axle Seal leak on stock 97 Civic DX
- 95 del sol brake master
- Auto to Manual Pedal Assembly Problems......Please Help
- Heat getting inside through shifter, ebrake, bottom of feet?????
- Rear headrests in EK HB?
- buying parts for the b16
- Help with my power mirrors! It doesnt work anymore!
- planning to buy a EG with LS swap had some question
- No speedo
- throttle body question
- hks ground wire
- Skunk2 Camber Kit
- magnaflow catback resonates inside?
- 94 Civic 4DR - Driver door pillar?
- weird loud transmission noise
- Good ideas on body glue removal?
- h22/ek mount question
- having a tough time finding a grill for my EK
- exhaust question
- throw out bearing help
- Not Running h23
- MAP sensor mystery
- B18C1 650+ WHP Goal!
- brakes locked up
- What just happened to my crank pulley?
- GSR Cloths
- Swapping Y8 to Z6
- Fixed brake line, bled the system, brakes still spongy
- EP3 Seat into EK?
- honda profiling
- Impossible idle problem
- Obd1 harness to obd2 injectors wiring?
- Del Sol service manual online?
- Vtec harness plug
- Ek rear disk Brake Question???
- B16B does not clear hood in EG
- Hi im new and i need your advice.
- h23 problems... thanks
- civic swap h22a not running!!
- Shifting problem in my 92 civic automatic
- will a y8 motor bolt on to a y6
- Installing rear sway bar on non factory sway bar'd eg
- Will Coil Overs and Shocks from the EK fit the EX
- 96-00 exhaust in 92-95 civic?
- Del Sol Swap
- socal: can I borrow a ignition timing gun?
- have new aem ecu car wont start
- idle problem
- hood wire help
- if car was stolen what kind of title is it? didnt report to insurance..
- removed rear windshield wiper
- big dent, any ideas?
- Need Help - Contact info for Kenji ECU Chipping
- Using P28 instead of P08 for D15B JDM VTEC
- Is it worth the time / $ ?
- gas tank leaking???
- b20
- Parts Problem with B16
- S80 trans help!
- Rear Sway Bar question
- Need info about Ksport suspension?
- 95' Honda Civic my first car
- people with gutted rears (balancing weight)
- Where can I buy OE honda paint?
- Maaco
- F1 Racing clutch kit
- jade green ej1
- moldings....anyone...please...
- b18c1 into 93 civic problems
- power steering help
- P75 A51 Ecu
- turbo piston question
- Best quality carbonf fiber hood/trunk lid for del Sol???
- Ball joint removal / repair tips?
- Electrical problem
- help name window molding
- sohc
- ECU question
- Are 96-98 4dr side skirts the same length as 99-00 2 dr?
- no start
- B16 Compression? Leakdown Test?
- need to find out which axels toget
- CHECK OUT MY EG6
- ITR front lower tie bar on an EG
- Some CEL codes..
- Headgasket or Seals?
- Are EG and DC2 suspension arms 100% the same?
- 98 civic ex smokes when cold till it warms up? then no smoke? help!!!
- Catch Can smoking
- suspension swapping
- question
- 95 civic no start
- fuel pressher ragulator vaccuum??
- VEIP help!!!
- Where can I get this?
- 92 Civic EG8 Sedan, Power Window Issues..
- EK LCA fit into DC trailing arm?
- looking for a civc
- 95 SI Weird Electrical Problem
- CLEAN pics
- TO ALL EK9 CTR CONVERTER!
- Rims
- Swapped my engine now no spark.
- engine problem
- Oil leak now bad timing.
- 1998 black ek coupe 4/s
- Transmission case swap, what do i need to change?
- 93 EX wont turnover Battery is good
- H22 Sub Frame Pictures
- quick power gain...?
- COILOVERS
- Duffed out the civic
- AC cycles on/off upon acceleration
- Best Online seller to buy from?
- SOHC VTEC
- "TURNING" the distributor???
- sohc D16Y8 ??? type r???
- Resonator and Intake
- 93 civic trunk swap
- turbo cam
- Wire Harness Question
- 96 Hatch Climate control button functions reversed...
- EK SQUAD !!!!
- 97 help
- turbo is next.
- Broke an axle racing, now i need better ones... where from?
- bump steer? how do I fix?
- 95 civic ex dies not sure what the problem is please help
- Problem
- rust issues.... help finding metal patch panels
- b16a overheating headgasket?
- b18b eg bogging when under battery load
- new short shifter
- 98 Civic EX window issue
- want to buy a civc
- ac in a ek
- D15B question....
- 98 ek o2 censor issues, please help
- tell me a good build for 400hp.
- How much would you pay for stock Si springs and struts ???
- Rear window bubbling?
- Bad motor mounts caused exhaust leak?
- cant find cams for my ls?????
- Innovative Engine mounts
- Possible to make a D series faster than a GSR?
- Small dents in fender, what do I do?
- cops hate tint on civics???????
- AC compressor oil question
- Doin an LS swap..
- 99-00 power lock conversion
- having idle trouble. TPS MAP IACV gone bad???
- Exhaust leak is it bad?
- Acura = Honda?
- AEM EMS question
- What Do You Think?
- clutch question
- 94 Si Over heating Issue need assistance please
- HELP!!! please. Delsol head/aux-lights stop working
- h23 wiring problem
- EK's
- Radiator Problem
- need idle help. steady @~1500, pull iacv, surges 1k-1500 ????
- new car was auto hx mess!!
- 95 Civic - Radio/climate control surround trim removal
- Idle & Tranny problem, pls help.
- Crank Pulley or Accesory Pulley?
- need help with brakes drum to disk??
- p61 ecu
- timing help!!!
- what is needed for power window and lock?
- hooking up shift light
- 93 CX idle and Ac Problems...
- What to do with my 98 Civic CX
- How much is my 99 civic vp worth realisitically?
- how much is a full color change for a ek hatch?
- My 2000 Honda Civic EX 4dr
- D16Z6 Problem.
- NEED HELP! Type R tranny rebuild....tight input shaft?
- Help clean
- Ek ex disc brake?
- READY TO GET SUNROOF ASSYMBSLY
- '62 Mini Cooper?
- my lsvtec smokes when vtec engages
- Which high flow cat should I go with? under 200
- Sway bar install
- PROBLEM putting in new clutch...HELP PLEASE!
- 95 civic headlights + corners
- slow as hell b4 3k
- EG SKUNK SPRINGS ON EF???
- b18c clutch help please
- 2000 Civic SI runs rough
- www.jormoo.com nike air max shoes,Supra Shoes,gucci shoes,air jordans,air force 1s,jo
- Turbo choices. looking for 300 HP
- How do I wire m3 style mirrors?
- o2 sensor
- Del Sol Wheels
- help! removing radio/climate control bezel
- broke manifold stud, need advise please..
