View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Noobie from Ireland
- lookng into buying an 99 civic si
- decent steering wheel?
- questions on bleeding brakes when car is started pressure seems lost
- A quick question on heads
- ek hatch dorr question
- POWER DOORS PARTS
- radiator brace
- DA integra steel brake lines fit EG civic?
- wire up a tach
- What should I know (DOHC ZC)
- information needed 92 civic
- headgasket help
- i dont get why people dont like to buy top of the line parts anymore?
- Rear Dics Conv Question
- singel cam help
- need help, pass side door wont open!
- Engine makin funny noises?!?!
- spoon wheels?
- ideas/help?
- can u remove the tranny alighnment plug to reinstall tranny
- Is anyone running a stock b20 in their car?
- Coolant Leak. cant find it. causing hardcore overheating
- Will 97 Civic Coupe Seats fit in a 94 Civic Coupe?
- new help cutting springs......
- O2 Sensor on the Cat Question...
- Check Engine Light Question???
- rear disc question
- Del Sol
- Header and Flywheel Question.
- 95 Civic coupe with GSR dash ?'s
- aftermarket wheel > OEM steering wheel
- DONT OVERLOOK fuel pump kill switch problem
- Steering wheel EP3 on EK4 ??
- Stolen Hatch...again
- Ek9 from Japan>wanted AEM CAI
- Spark Plug Wires information needed HELP!!
- d15b 0r b18a
- H&R Limited Edition Springs
- leak in rear
- Will EK Civic Auto Cluster work for a Manual EK?
- Shorty Header ?
- Out of Point Thread.
- Header Question
- How bright are the OEM EG foglights?
- cylinder head
- Gear ratios same for Ex and Si?
- Odd code eg hatch
- 93 Eg hatch
- cooling system
- Just cant figure it out Need HELP ASAP
- Header and no condenser
- o2 sensor
- Interior Swap Question
- Best Head for Integ Bottom
- HELP: Idle speed redlines?
- throwing a code 41?
- Trunk Leak
- sway bar.
- websites for front clips?????????
- dx and ex head difference question
- ignition switch
- Good springs??
- crx coilovers on eg coupe does it fit?
- Happy New Year
- FUEL PUMP NOT PRIMING
- injector problems
- Weird high pitch sound coming from my 93 civic LX
- yet another help needed for dc2 dash swap
- which motor mount inserts do i buy b16 motor??
- 94 DOHC VTEC- Please Help- Clutch Problem
- Help me find CF hatch.....
- (Time for an upgrade)
- motor help!
- tryin to fill my tranny thru vss... but not sure where it is.
- 4 wire o2 pin out for cx????
- jdm sidemarkers ?
- Is this what I need?
- kseries in ek help!!! help!!
- tell me what u think about this motor
- how many stock horsepower is the d16z6
- Where to buy...
- need an engine
- idle then stalling
- anyone removed block with tranny still in car?
- IS THE D16Z6 A V-TEC?
- Dumb question...Do 99-00 SI brakes fit a 95 EG?
- question bout rear disc on eg hatch
- 96 civic dx
- Vtec doesnt kick in
- cluster problem, blown fuse?
- obd2a obd2b dizzy wiring ???
- hyrdo to cable
- del sol front lca's same as 92-95 civic?
- primer question... encouraging rust?
- Torque specs on b16
- blinker trubble (Please Help)
- oppinion related(motor swap or boost, i know just look. lol)
- lost my radiator drain plug
- SRS wiring @ tranny
- auto-manual conversion on EG
- No spark on a 94 civic
- antenna replacement
- O2 sensor low voltage
- Voom?
- WTB: 99-00 Civic SI Engine bracket, intermediate shaft
- question about a hose on EG
- Dead engine, please help.
- are these lug nuts okay? blue gold red
- eg cigarette lighter wire diagram
- 1999 Civic Ex Stock Exhaust Swappable into 1999 Civic Ex???????
- engine died, need help ?!?!??!?!?!?
- new mounts question
- mini me swap.
- 1992 Civic Si - Oil leak in VTEC only?
- Stolen '95 Honda Civic Coupe DX (Ej2)@ Long Beach Towne Centre on 12/31/06
- Loss of power ..... occasionally
- i need alternater help
- where can i get a font bumper for my body kit?
- noob question - Intake + Exhaust + water leak
- Stolen Car Alert Woodbridge, VA 2000 Honda Civic Si EBP
- power folding mirror wiring help
- power question
- Need Help: anyone that has made a claim w/ AAA
- 94 civic ex, clutch pedal no pressure. HELP!!
- how do I replace the light bulbs for my fog lights on a 4 door civic >
- Rear disc break conversion for 94 dx coupe
- Urgent Question! What is this under dash plug for?
- Overheating Problem! Need Help!
- Lets solve this never ending problem for Honda Owners!
- Yeah...95 auto Civic sedan stolen.
- Need help..not sure what the problem is..
- Auto to Maunal Conversion Help Needed
- GOOD AIR COMPRESSOR BRAND? oil filled or oil free pump? and which brand?
- idle problems
- VTEC Engagement (D16Z6)
- 01 b18b in 92 civc
- quickest motor for a del sol
- car wont start
- engine ideas
- Integra Pedal Assem. in Del Sol
- Weird issue with back up lights.
- Full suspension overhaul and reviews. ASR, Ctr, Nrg, Password JDM Sway strut tie bar
- Affordable paint jobs in SoCal?
- OBD2a ECU Question
- lsvtec
- painting
- Very Strange, Blue flame in exhaust.
- d16z6..
- teins type flex
- EK Manual TO AUTO conversion - What parts are needed
- First Gear Grinding?
- EK door alignment (gap), please help.
- very very sad day........and very lucky...
- 4 door bumper fog lights
- NEED HELP!
- Replacing Main Relay help?
- i need help #2
- i neelp help
- Cluster swap Help
- Suspension for Ej8
- Eg wiring problems
- d15b smoking
- cant get my cel to work need help badly
- HELP: When i turn on the wipers, the 20 AMP Fuse keeps blowing!!
- civic 4 door fog lights
- No Spark
- overheating while its idling!
- Fuel Pump Problem... works sometimes
- Integra dash into Civic
- redlining
- Turbo ????
- replacement
- Car Wont Pass Emissions!! Please helpppppp
- installing walbro fuel pump how do I remove the back seats?????
- GPS Navigation System and Mobile Phones for sale
- Car Dies while driving!
- 99 civic problem! what the heck
- Where does this hose go????
- best power and ground sources for my lm1+rpm conv?
- MOTOR NO PAPERS
- Hard stop => no brakes. What's the problem - ABS, prop valve or other ?? (95 EX-T)
- Question swap or new car
- Pic REQUEST!!! All VSM EK's, Post em' up!!! VSM! VSM!
- LS/VTEC Swap
- bumper question
- Car Dies when it wants to and Starts when it wants to. Help?
- huge problem!
- DIY shift boot / eBrake boot
- EK starting up funny
- polyurethane bushings on a DD?
- Alternator belt change question
- 99 civic front end conversion on a 96 civic
- EJ Coupe Parts that will fit the EK Hatch
- Need help!!! B16 Automatic into 95 Civic Sedan Being told it cant be done
- b16 cam question
- car wont start (no sounds)
- replacing headlights
- defrost relay location? 93 civic
- civic K
- car randomly dieing
- motor mounts!????
- attempted stolen vehicle in jersey :(
- EG
- some help with my b16 swap
- Need some help here
- wtd: EK dashboard Wire diagrams
- EG Black Headlights..?..?...?...?
- ball joint or front upper control arm?? help, which do I replace?
- cel wont come on when I turn on the ignition and pump wont prime but car will start fine
- heater by pass.
- 4dr vs 2dr wheelbase.. dictates traction?
- 92-95 VTi/Si expensive services?
- 2 part lower tie bars for 99 civic
- Need help. 96 civic DX sedan with irratic idle.
- New dizzy... will not fit? why not?
- ek idle and starting problem
- tail light question.
- NEED HELP!!! MOTORS JACKED UP!
- how to take off 92-95 front bumper
- how to replace 94 civic headlights
- EK square fog install
- Need Help
- My 95 civic dx throwing code 12
- 2000 Si exhaust/header question
- new steering wheel. CROOKED??
- DelSol seats into an EG
- Noob question. Sorry
- dont know what else to do. help please
- power window
- are TOKICO HP STRUTS/SHOCKS a good shock for civic hatch?
- jdm type r center console, does it work on eg's?
- parts from japan
- Will these fit an EG hatch?????
- EG swap Question..
- access window visor?
- engine swap axles
- wiring prolem in eg hatch
- how to take out a headlight bulb in a 94 civic
- Fuel feed line >>> B18B into 99 Civic
- How to make the Integra cluster fit in ek
- I know I know Search but i wanna Double check!
- axle issues
- E-Brake cable hook up...
- tranny grind
- D16Z6 oil pan on D16Y8? will it fit?
- Very weird headlight problem
- I want to "de-badge" my civic...
- What Rear Leather Seat Did I Buy?
