View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Flex seal rubberized stop leak in a can!
- Secondary 02 CEL - fixed
- Where can i find a metal key for the D16Z6 cam pulley/gear?
- Brake Pedal Travel
- water outlet gasket question-do i need it?
- JDM B18C SiR vs. B16B swap
- No power to door?
- intake hose hook up
- ARP Head Stud Kit?
- Need torque specs for timing belt install
- 96 Civic with some issues
- del sol SIR trunk convertible opening problems
- 92-95 Si hatchback interior options
- pressure plate
- Vtec-E swap
- NEED HELP...car won't start
- How to install blox intake manifold on my b18b1
- 94 Del Sol. Do you know how to reset a Airbag sensor so I can put airbags in my car?
- What exactly do I have??? 2000 Civic Ex Y7/Y8 mini me
- 97 EX: Want to swap crappy electric windows for manual windows.
- Parts needed to mount radio by cupholder, 99 civic
- Grounding Troubles? Check me out
- fuel injectors
- D16Y7 EK not starting (fuel?)
- My ek not popping vtec need help
- Vtec wont work
- Clutch problem?
- Need advise on gaskets for a b16a
- Starts then shuts right off
- d16y8 problem running three cylinder
- Thinking about refreshing the old stock suspension...
- gsr vs si rear disc conversion
- 96 civic steering problem
- No spark after new distributor?
- Battery Light flickering with NEW Alternator
- Idle problem
- Differences in 92-95 body to Door connectors
- help identifiying plugs and sensor.
- Would a dc2 steering column be a direct swap into my EM1?
- obd2a harness to obd1 dizzy please help
- new sol project
- D15B7 Starter removal help
- 97'-00' EJ hatch. Do they have A/C?
- Engine getting old, New motor, Rebuild, need advice.
- replacing eg civic doors
- Ej1 Weird Clutch Issue HELP
- Ebay CTR Wing
- seat leans Help!
- fog light cap
- why rpm s too high on 4.5 in 5 speen manuel -75mph
- need help can roll start but cant start with key
- STICKING TB, SOMETIMES
- Header does not match up to exhaust?
- burning oil after oil change?
- Very interesting 99 sedan problem - intermittent starting problem
- Stripped valve cover bolts -- any easy fix?
- Running ok, then restart warm runs rough
- Need help.. D15b8 d16z6 head
- 00 Civic Ex Coupe/Usdm b16 swap -- Wont Start, No Cranking or Clicking
- Does this relay look fried?
- 00 Civic EX/B16 swap - wont Start
- Purchasing Catalytic Converter
- P0420 coming on after cat replacement
- Seat installation issues?
- 1999 civic ex coupe-manual transmission-popping out of second gear??
- Installing obx intake manifold just need to know where to mount the iac valve
- 99 Dx: Is there a fuse for the coolant temperature gauge?
- Miss fire problem Need help
- Crappy Aftermarket Distributor?
- Engine Swap Question
- 4th gen ZC in 2000 Civic EX
- dc5 conversion
- question for maintenance
- Changing oil pan/gasket on Y8 soon. Couple questions.
- 2step/speedo
- Does my 97 Civic EX have a swapped D16Y7 engine?
- Car wont start PLEASE help!!!
- B18c GSR - want to install aftermarket parts before putting in the car
- Car shows, sorry it's off topic
- Smell of Motor Oil when Air Conditioner is on? (1996 Civic EX)
- 99 Ek swap wire issues iacv?
- 94 B18B1 swap into 97 Del Sol D16y8 HELP
- 00 civic si em1 cluster problems
- how do i replace the ignition switch in a del sol?
- b16 running rich
- What oil do you guys use in your D16y7?
- 99 Civic/B18b1 swap - doesn't run great and throws TPS code
- eg tach
- Solid CEL/Code 0
- b18b flywheel need help!
- Orange Spark Issue
- IACV problem
- Pulling head soon
- 94 civic ex d16 engine
- Can i swap a d16zc into a 98 hatch ?
- 99 Civic Ex (d16y8) Starting up a bit slow. Any of this sound familiar to anyone?
- s2000 seats in del sol???
- need help and ideas!!!
- 92 Honda Civic won't crank
- Should i go for this?
- Burning gas with engine off? WTF
- putting on headers for my d16y7
- Car keeps bogging. NEED HELP
- help stop our socal dragstrips from being shut down!!!
- Gold_pwr_r4ng3r’s 1994 del sol
- 92-95 civic Hb cluster conversion
- 95 eg DRL relay?
- WTF. GSR hitting rev limiter at 7k
- Bad news :(
- B series OBD1 vs OBD2 motor differences?
- 1999 Civc LX Sedan Pillar Strut Help!!!
- Skunk2 516-05-5685 Pro Plus Camber Review
- Help With CEL 45
- LSV Build
- 1999 Civic Ex feels like it has no power- engine codes too
- B16a dimension's
- ...detonation?
- Is myhondaparts store a legit place to buy parts?
- B16 cam seal
- electrical issue in climate control of my 94 del sol
- 98 civic y8 head
- Timing Issue????
- 93 del sol b18b1 wont start
- good rims ? wat kind
- How do you remove my door handle.
- How do I identify D16 cranks
- Noise front driver side
- Throttle cable firewall problems eeekkk
- Need Feedback; Reputable Engine Depots
- ZR Headers fitment ??
- Coolant overflowing from reservoir
- 99 Honda Civic DX dies while driving/stop
- Unstead Idle on 99 Honda Civic SI-G
- Rear JDM H emblem not fitting flush.
- Questions about Cam Gears & Cam Shafts
- rear passenger upper control arm
- All motor B16a2 build!!!
- 94 civic ex idle problem(d16y5)
- EM1 bogging below 2000rpm - problem was temporary
- 92 Honda Civic LX 1.5 D15B7: Loose harmonic balancer
- d16y8 low clutch fluid
- Buzzing Noise behind the seats, Del Sol far from home.
- Em1 Radiator
- SRDFTITAN'S 97 EJ8 TURBO BUILD THREAD!! LOTS OF PICS **CUSTOM GAUGE HOLDER**
- d16 timing guestion
- Civic Injector #2 issues
- 99 civic lx d16y7 lack of power going up hill
- 96 4dr door to cabin harness clip
- 97 coupe ex swap to b18c1
- Random loom plug
- Sensor help!
- b16a Em1
- 1997 EK Hatch DX, Muffler Question
- New to honda-tech- would like to know more about v-tech's
- Del sol si shiftlinkage.. No reverse?
- antifreeze loss help
- Will a civic trunk release lever fit in 94 del sol?
- has your civic ever failed a smog check?
- Opinion needed: 2000 Honda Civic randomly cutting off at idle and misfiring
- D16y7 to b18b1 swap in 1999 civic se
- Break-in oil vs non break-in oil
- Replaced brake pads and front disks - soft pedal?!?!?
- Broke hood latch handle - how to replace
- 1997 Civic DX dash lights/exterior light question.
- Cost to restore EG body?
- EK le bra Question?
- 94 DX coupe and 94 Integra LS transplant project
- 96 civic?
- best motor swap?
- HELP! ecu problems
- VSS Unplug no CEL??
- 92 eg hatchback rwd ;)
- d16a6 into a 98 dx?
- Easiest way to correct timing WITHOUT replacing belt
- B-series swap last check list
- New hardware for header install
- 94 Civic LX won't start when ever it rains - no spark
- Airbags
- Question regarding cruise control
- o2 sensor
- Trade 2 civics for my accord
- Engine swaps???
- b16 head on d16 block?
- Need OEM Part Numbers for 92-95 Civic OEM Floor Mats
- Y8 Oil Pump
- LHD/RHD STEERING ISSUES AND QUESTIONS
- 93 del sol si acting funny
- Can the speedometer be adjusted?
- B16 oil leak -- Head gasket?
- Cylinder Misfiring Need Help
- 95 civic, LS injectors not having a pulse
- B series waterpump replacement.
- A little smoke...
- 1993 Honda Civic DX With Intermittent Start Problem
- 98 CIVIC EX RADIO WIRE COLORS
- Someone tried to steal my car last night...lessons learned
- Extended Top Hat Clearance
- how do i make my 95 honda civic all wheel drive
- Completely new to the car/honda scene
- Voltage Stabilizer?
- 96 ek (DX) + b16a2....would a 99 civic ex engine harness work?
- HELP!!! del sol to EG6
- b16a2 good rebuild kit
- 99-00 Spoiler Fitment on an EJ1?
- 97 Del Sol Build or Not.
- vtec question
- Steering wheel shake after Exedy Clutch install
- Convert Engine from OBD1 to OBD2 possible?
- 98 Civic LX broken speedo & odometer
- 95 Civic Ex disappearing coolant
- 98 Civic Ex Radio Installation Question
- eg wire tuck and fuse box relocation
- Sketchy steering
- oil is SUPER thin..
- B18C EG1 swap parts list check
- 93 civic hatchback/y8 swap/P28 ECU - 2 separate issues [Interm wiper & Cel 22]
- Trailing arm bushing replacement, tips?
- D16Z6 auto vs 5 speed engine harness
- main relay doesnt have power
- is the obd1 o2 sensor the same for the obd2?
- Cleaning JDM SiR gauge faces?
- can someone tell me what type of bumper this is
- 94 b18b obd1 with no crank sensor going into ek
- Disappearing Oil.....
- Axle Nuts won't come off - Ive broken 4 1/2 breaker bars and torched them
- d16y8 97 del sol decelerating, weird smell
- lsvtec arp stud question
- quiet exhaust
- Integra seats in ek hatch?
- 94 Del Sol S: starts and idles if throttle held half open
- b20 civic coupe running problem. plz help
- 1999 honda civic help - oil in the overflow tank
- Question about installing new aftermarket intake, Picture inside
- Need Tuning Guidance
- JDM B18c/USDM B18c1
- Best Primary O2 Sensor Location
- Need quiet muffler suggestion since I can't have stock muffler in good cond. for eg
- Del Sol and Civic harness
- 2000 ex with b18a1
- SRP piston pitting
- Burning smell from radiator/front area of 2000 Civic
- what oil should i use for the break in
- Weird Brake Problem
- FG2 rear seats in ek sedan?
- d16 engine is powerless
- cluster swap problem
- What Seats are these!!??
- B18B1 Swap Question, Please Help.
- my civic wont start
- Weird performance issue after SWAP to a D15b HELP!
