- homemade big brake kit??
- brake booster and master cylinder Question?????
- 92 eg ls swap
- Window Wiring
- Innovative Hydro to Cable Conversion???
- 99 Civic CX A/C not working!
- y8 intake manifold on y7 head question
- DIY 96-98 CTR HEADLIGHTS!!
- I have birds on my brakes !!!!!
- how to disassemble tumbler?
- Spare Tank Full
- resealing winshield
- Cluster does not have Check Engine Light
- EG P/S Rack The Same as Integra P/S Rack?
- b16a2 in del sol swap problems
- Official suspicious car/license plate thread (North California)
- ef clutch in eg?
- little help on choosing a nice setup
- Will EG hatchback headlights fit EG sedan?
- erye
- questions about the d16b5 block
- b16 compression numbers?
- Need ec for d16
- dc2 to eg xhaust swap fitment
- got a stripped z6 engine....
- asap
- eg ignition switch wire Identification???
- Bad ISB I believe, just swap instead?
- best 96-98 CTR replica headlights?
- obd 2 d series dizzys
- Grinding/Rattling Noise
- E-Brake NOT working!! NEED HELP TROUBLESHOOT!
- how to install rear seats and seatbelts
- Good deal for 96 civic ex???
- interchangable door molding?
- Straight Edge Substitute ?
- rear main seal
- Does Auto P08 ecu work in D15b?
- 98 ex in safe mode
- '99 Civic issues
- Starter Relay 95 Honda Civic
- srs light is staying on how can i reset it ??
- fuel evap system
- Header paint doesnt work
- Carb # for 99 civic si headers?
- ground locations for a b18c in an eg
- more wire tuck problems.....
- Honda exhaust question
- My door..
- !! need HELP with the rack and pinion !!
- i need help with ek foglight wireing
- WTB 99-00 Civic Si ac bracket
- what rear leather seats can fit in 4dr ek?
- steering vibration? I cant figure it out please help me guys!!!!
- 1997 ek9 cluster
- vtec wire up help
- EG Cluster Problems
- 96 civic cooling fan problem
- 2000 DX Hatch NIGHTMARE!!! Need Help
- [removing] 95 coupe rear bumper?
- 97 CIVIC EX OBD2 & MOTOR SWAP QUESTIONS!!
- em1 rear trailing arm bushing removal?
- need some help on ek b series wiring
- S2K CLUSTER SWAP INTO EG HELP
- Manual Swap Question.
- p30 pistons
- How do you remove the OEM sideskirts?!?
- Civic EK4 Fog Light kit - OEM Part Number?
- obd1 to obd 2 swap
- 93 civic coupe wont start after messing with fuse panel any help?
- D16Y7 into EG8
- del sol audio wire harness diagram in need of
- feed back on mounts !!!
- What Front Lower Control Arm should I get!?
- ...D16z6 Q's about the egr...
- 95 radiator fan relay on del sol s ??
- CIVIC doors
- Air Conditioning Troubleshooting
- wiring fuel pump
- 95 acura ls idle gas problem
- Help Key On Deck wont even turn on????
- HOW TO CONNECT A EG SIR CLUSTER "NOT A NOOB QUESTION" PICS INSIDE
- ek to eg?? will it fit?
- B16A engine with used B20b crankshaft?
- ek coupe and sedan muffler
- Extremely low warm idle - Yes i've searched.
- oem piston rings and bearings
- USA or Canada
- obd2a to obd2b questions
- noise while driving from front driver side wheel
- Where is the cheapest place to get a CTR wing?
- fs apexi neo and vafc
- Fuel pressure bleeding off
- H22a4 questions?
- Help stock 95 Si eg D16z6 only revs to 6400rpms?
- ls vtec opinoins
- Need help please
- 96 hatch A/C pulley purr ?
- HELP! Will EF THULE Roof Rack Fit EG Hatch?
- rollcage question
- Clusterless
- Test Pipe: Megan Racing vs. eBay
- Need help deciding what size throttle body
- need help wiring fogs straight to headlights
- eBay Front Lip for 2000 EX Coupe
- What Causes Engine "flooding" and "knocking" noises in the block?
- New to the Honda scene.
- r12 A/C hoses with a R134a Compressor
- EX cluster into CX. Weird tach issue.
- Headlight Condensation!!
- Tokico Blues versus Illumina: Which shocks/coilovers would be better?
- Fluctuating Idle after turbo install
- No start until after messing with clutch pedal?
- d16 to h22a1 ahhhh??!!
- Carbon creations fender flares
- Rear wheel hub on my 95
- eg turn signals wont work/ and hazrads contol the fuel pump
- Wierd electrical problem 98 coupe
- Cooling Fan Help
- help with d15b7
- Help!: will 2dr integra sunroof ass. fit into a 2dr coupe?
- I honk my horn it kills my car
- k20/k24 into 96-00civic
- ls vtec questions.
- Rear Plastic Removal
- Question on Loose shifter
- noob in the ft worth area
- Coilover sleeves on Eibach damper shocks?
- SKUNK2 IM and a 68mm omni throttle body!!!!!!!
- 97 Civic strange wheel hop problem
- Ultimately Confused On TDC Markings.
- Oil pan thread or drain plug thread? you tell me.
- i need help on deciding on my GSR blades
- If its not one thing its another
- I'm about to buy a 99 LX 4dr, what do I need to look for?
- Getting compression back after flooding cylinders?
- heard of it?? cheap
- Speedo
- How to seperate Crank and Accessory Pulley. D16z6
- 97 GSR burning oil
- OBD2 ECU SIMULATOR/EMULATOR
- Running hot
- type r intake manifold on B16...worth it?
- General Tranny Question
- gut outa/c but keep heat?
- 96' EJ8 PW/PDL/PM not working!! Door Harness Problems!
- Can i change the head?
- Why is my clutch so heavy?
- Is it worth it? EM1 Civic Si EBP 43xxx miles
- why is my gsr motor burning oil?
- What is this!?!? Dripping Oil....**PIC INSIDE**
- Del Sol Aux light problem
- Just another harness question (newbie)
- Power steering going? Help!
- S2K Emblem on EJ8
- Transmission Problems!!
- Manual Conversion Wiring
- 92-95 civic HYDRO TO CABLE ? anyone?
- Where did you order your motor from?!
- EK with gsr heat hose need help.
- Turbo 99 Si
- need some help plz
- rear disc conversion question
- anyone else have this problem....
- gauge cluster question
- obd1 mani work with obd0 motor
- 95 civic b series mounts
- b20b IACV and TDCS codes
- fitment help
- Converting Automatic SOHC ECU to 5speed?
- Motor stutters then check engine light goes on! SOS
- Power windows not working SOS
- Let me know what you guys think of the new addition of my hatch..
- 95 / 96 quarter panels
- stripped screws in ds mirror
- Normal Amount of Soot in Exhaust?
- Lighting help
- ek coupe cv join questions need help..
- Del Sol Control Arm
- Overheating issue need help...
- Ecu or Distributor issue?? and How to Troubleshoot??
- overweight front end after B18C1 swap?
- K20 Dudes and Dudettes it's Poll Time
- 96 civic ex transmission leak
- Silly tie rod question eg
- 92 si - 95 vx motor swap
- check engine
- 3" Exhaust Suggestions
- 99 Civic SI cruise control/idle problem
- Front lip
- Another cel code question... chk engine light stays on when using jumper wire.
- D16z6 problem
- Figuring Out Compression Stroke Vs. Exhaust Stroke ?
- Wrecked my Civic :(
- 95 b16 put into a 99 civic si
- si cluster mph fluctuating!!
- Couple Questions
- Washed my engine bay... now no start.
- D16Y8 IM gasket Hondata
- B-Series Rocker Arms? all same??
- Upgrading cluster - keep old mileage
- Defi Air/Fuel Gauge--HELP NEEDED!
- Dashboard lights and Wipers Any ideas?
- Speed Holes
- d16z6 idle is low
- Fog light help
- d17a2??
- car wont charge.. tried everything
- Vac Leak? Need help
- EK Swap Question
- reliable mechanic or shop is SoCal? who to see or avoid?
- Looking for the local hawaiians....
- Quick Parts shipping
- Idling problem
- needs help finding sedan eg visors
- Deck install in pocket by cupholder in 99-00 EK
- boosted z6 need help
- B16A2 Plug Question
- b18c price?
- EGR Valve location?
- sunroof help
- Super RARE? EG SEATS! trip out
- brake problems
- Crower Cams/valvetrain? Any good.
- MY EK BUILD...CRASH...REBUILD
- wanna know what my d16z6 has
- HELP!!!!!
- Quick GC Coilovers Question
- diamond racing steelies
- Integra Rear disc into EK -- which ebrake cables?
- 92-95 axle-back fitment
- caliper replacement 98 Civic EX
- Thoughts
- How long dose a turbo civic last?
- wire tuck questtion OBD2b
- Eg hatch cluster questions...!!!
- Cluster Problem..Please HELP!!
- No EGR valve?
- EJ1 rear Disk Conversion Questions
- cam gear problem lil help??
- 2000 civic si starting issue
- symptoms of a blown fart head gasket??
- Recommendations for EG headlight bulbs?
- 99-00 Fog Light fitment on a 97
- EK front sub-frame/cross-member Help!!!
- 95 Civic DX Wont Move, Please Help
- Possibly buying this car for a DD, what problems might I run in to?
- i wanna get rid of my a/c need some help
