View Full Version : Honda Civic / Del Sol (1992 - 2000)
- problem installed ac equipement into 92 eg dx
- b18 swap?
- Main relay buzzing, CEL Flickering....WTF?
- White smoke screen =P sooo gay!
- Stripped Fill plug hole on man. tranny,,,,suggestions?
- been a member since 04 and my first time posting pics of my car...take a look
- 92 civic with jdm d15b7..vtec not hitting?????
- gsr itr ?s
- Need engine bay wiring diagram for 93' si hatch! Searched!
- b16 in 92 hatch, weird idle
- 92-95 h swap, transmission questions
- mudgaurds!!!!!!!!!!!!!
- wut do i have????? ej1 ej2
- burned car...is my motor rebuildable?
- car heating up!!
- What low seat brackets??
- Master window and the all door lock...
- 93 civic si (EG) lights switch wiring problem
- horn button question...
- what exhausts will bolt up with my 93 civic with LS swap?
- tein h-tech springs on a ek coupe/sedan/hatch?
- only way to get 98 civic barred w/ acura 1.8L?
- memory fab seats
- I Need The Biggest Honda Guru On Here
- d16y7 into 94 cx Help Please
- bobbing idel
- power window conversion trouble: wrong harness?
- SPOON eg6 footage/pics wanted
- New to this world, few noob questions :)
- overheating problem!
- sunshade for moonroof 1996 civic ex sedan
- my mirrors arent cool enough
- rear swaybar end link fitting ?
- auto to manual Now no curse control
- Cleaned the engine bay, now car running poorly.
- MT and AT key key ignition casings the same or different?
- del sol aux lights dont work
- ek4 sir lip on del sol?
- Owners of Tein Suspension
- All the way from scotland
- Honda Jigglers
- Got a question about my BAR'D hatch
- '97 coupe rear quarter panel...
- BBS RIMS or NOT?????
- Best care tips for 150K engine? additives, maintenance, etc...
- i think i may have an electrical problem
- OBD2 Codes
- EK9 and EG6 B16 Engine Mounts the same or swappable?
- Steering Wheel Extension
- rear endlink difference's ?
- crx suspension on 99-00 civic si
- How does my car save more gas and runs better w/o the cat?
- 2 STOLEN CARS -- CENTRAL NJ
- New H-T Member =)
- EK CIVIC POD FILTER. DO I NEED PIPING??
- CAR CONSTANTLY DYING???
- need pic of dc2 and ek9 rear sway bar next to each other
- seats questions
- My car won't start after a car wash...Need help diagnosing it
- car will start up then stall.
- 100 octane to 91 octane
- need to find!
- hello lol
- My speedomiter and gas marker is stuck at full is not working, can i fi this??
- valve cover bolts broke
- Changing Instrument lighting in 2000 Civic Ex
- Sloppy Shifts.?
- No power steering??
- Smoke at Start Up?
- by-pass hose
- don't really know how to explain it... but i'll try my best
- s2000 cluster
- need help with suspension!!!!!
- Burning oil, running rich? Something's up
- crank sensor question
- Does anyone out there have
- Deck lid
- 92 si front rotors
- no spark....96 hatch
- new kid from PR
- looking for a website
- need advice on making my car faster
- Interior space in a hatchback
- 97 Hx - B18 Swap Heeeuuulllppp!
- axle install problem
- B-Series MOTOR MOUNTS in EG?? What's the deal?
- Relocating battery....searched.....just wondering if this will work
- Need help Fast
- Simple wiring question.
- brake conv. parts list request.
- low-fuel warning light not working
- New Here
- full tranny swap! auto/manual and manual/auto question.
- NEED HELP WITH VTEC
- Hard wiring reverse lights in EG.
- EG3 single carb, Rough idle solved!
- 1997 Honda Civic car pulls and releases when ac is on. Feel like I am driving a standard
- throttle body spacer ???'s
- lack of power 1.6
- A/C compressors interchangeability
- Please Help!!! No Spark
- HELP!!!! Hood Latch / Cable Problem
- NEW GUY LOLZ
- NEED ADVICE! AXLE, Differential, something problem~!!~()!(!(~!
- Exhaust for my 98 civic
- 1999 Honda Civic DX questions
- 99-00 civic si coupe doors fit on a 96-98 civic ex?
- s2k steering wheel...
- need some input!
- si/ex cluster (gas light) ???
- What is this part called?
- Not too light flywheel
- Modifying an Automatic?
- Integra arm rest into EG?Anyone fab'd it to look right?
- 96 Civic- Put stock intake back on, got CEL, when I jump it, keeps blinking long blinks
- 97 EX Coupe Power Loss
- 94 EG CX help
- putting in sun roof... ek hatch
- Wheel Hub & Bearing
- Need some advice on wheather to get a new car or an engine swap.
- spark plugs; tips are white?
- special color !
- clutch sticks? searched didnt find what i needed.
- Is it legit?
- Having trouble putting a em1 rear seats into my ek hatch....help!
- Motor in a 98 civic EX
- excessive noise from exhaust?
- Some probs wit swap
- CTR replica grill!
- Got some problems with my EG hatch
- Windshield wipers
- Flywheel question
- 2000 si how much is it worth?
- auto p28 g51 and g52 interchangeable?
- Intake Headlight for 00 civic.
- b20b half shaft
- MAP sensor voltage conversion
- 95 dx hatch with dc master Cylinder ??? what one to use..
- Civic Sideskirt question...
- Rear Swaybar for 96-00 DX Hatch
- KYB AGX w/ GC COILOVERS vs. Function&forum Type 1
- 98 civic sedan - BUMPER REMOVAL
- Rota Rims Gt3?
- Speedo and tach not working in del sol
- em1 catback?
- EK camber kit 12 mm bolts...HAVE A HUGE PROBLEM
- AC problems in a 95 Civic
- integra steering wheel
- Newbie from the UK
- OBD2 to OBD1 Swap D14A4->D16Y2 Please Help Me
- Mfactory sway bar
- mugen lip?
- 1993 civic lx swap d15b7 to b series
- Skunk2 sport shocks - anyone one running them?
- d16y7 clutch question. asap please!
- Koni yellows Question
- New to the site!
- 2000 Civic SI - RPM/Rev Limter Question
- are 94-95 civic r134a a/c interchangeable with 96 and up a/c?
- How to raise idle on d16
- I want someones opinion
- i have a little problem can someone help please
- Motor swap question
- Im new to this site
- SMOKE FROM THE DASH!@!!!!!@!!#!#
- Squealing coming from belts?
- what is the widest tire that will fit on a 13x5 wheel?
- leaky vtec solenoid
- oil pan QUESTION??
- rsx rears in an eg hatch
- ex tran on lx?
- push pins
- Burning a quart in two days....
- Ac problems 97 civic
- Which lip
- 94 civic charging problem
- quick ? about headers on ls/b18b and others
- Removd SRS now car won;t start
- Coolant Leak?
- Parts
- ls/vtec into 94 eg
- ******I HAVE A HUGE PROBLEM. SHIFTER WONT MOVE.**********
- vtec problem...
- passenger side axle help
- Reputable shops in new jersey?
- Problem with power to main relay
- P0420 CODE HELP....
- 5th Gen Civic Auto to Manual Starting Circuit, The Right Way
- $1500 sound right for new OEM cat and o2 sensor with tax and labor?
- B18b1 + 2000 EJ8. Which power steering pump?
- ls swap question
- WHAT MOTORS COME IN WHAT CARS
- What tool to remove and replace knock sensor?
- 92 civic with b16 couple issues
- What is the toughest allen wrench?
- Popping out of 3rd gear? LS swap short shif
- Radiator cap question
- 4000rpm Redline???
- dx intake manifold to a y8 will it work
- cant find CEL jumper plug on jap import
- help me answer this question plz?
- b16a2 into 94 civic dx
- TRANNY FLIUD
- Oil Catch Can Gas Mileage
- b16 swap throwing code 8
- Very laggy when reaching optimum Temp
- braking problem
- How much boost?
- B18C turbo starting to overheat
- 99-00 EM1 Si final drive?
- What dizzy for a B16A
- Need help installing Viper Alarm/Remote Start system!
- RECARO POLE POSITION + BUDDY CLUB RAILS/NAMS rails??
- ep3 seats in an ek
- Memory fab r98 seats. what rails?
- gas pedal position???
- IAT is confusing me??...
- Hi I'm new and I'm looking for ...
- WTF is wrong with my car?!
- Firewall Nuts and Bolts
- 98 civic a/c problem
- Auto to Auto swap... LS into EG Civic
- Need help/car wont start/I searched
- EJ6 B18C Swap Vtec Prob.
- cx tach light
- 96 Civic EX power window problem???
- Oem lip bolt size
- 2000 Civic - Snap-on scanner unable to read 02 voltage
- Metallic rattling noise when gears shift.
- CHEAP POWER GAINS
- 6 puck clutch disc/stock pressure plate??
- b16 needs new clutch? oem exedy?
- 13" rim clearance on a stock 2000 Civic CX?
- Which is better
- help with y8 swap in a 96hatch
- Does em2 seats fit in a EK?
- hey off topic but please look
- water leak
- Opinions on block guards...
- 97 Honda Civic Del Sol - Need Help!
- 92 Civic EX - clock reset / stereo reset - every time car starts
- EK Rear Lip in C. White......... Where can I buy one?
- h22 EK hatch PROBLEM
- new guy here
- Got a ?
- "Competition" Radiator caps Vs OEM Radiator Caps
- question about cleaning a gutted back??!! PLEASE HELP!!
- ACT Clutch Install
- 2000 Civic Cluster Bulb Size
