View Full Version : Honda Civic / Del Sol (1992 - 2000)
- How do you install this...?
- Anyone know of a cheap place i can buy a distributor for my 99 civic ex?
- H22 hasport motor mounts for EG
- Front windshield defroster is not working
- i've hit a wall
- Rev Limit problem!!
- EK Cruise Control Removal Q&A
- my first motor swap, what am i forgetting
- d15 smokes after head rebuild
- What axles for CTR 5 lug w/ D series
- knock sensor code help??????????????????????????????????????????
- where is the temp sensor
- Brake conversion need help!!
- Headlight switch? (01 Civic LX Coupe)
- Converting 5 wire o2 sensor into 4 wire?
- prop valve question
- Clutch went out again!!!!
- New civic owner<<
- will a coupe 92-95 exhaust piping fit a 97 hatch?
- del sol rear disc brake conversion on '99 civic hatch
- Upholstery help!
- idle problem
- oil pressure sensor for knock sensor?
- question about doors
- Questions about motor swap in a 95 Civic sedan...
- Clutch is slipping
- noob question about blinkers and guage cluster
- buying a legit gsr motor, but one problem, need help
- What did these rims come off of
- Can someone tell me what the hell this thing is?....(pic inside)
- z6 iacv problems
- Recommendations for my situation. Round 2
- Where to buy del Sol floor mats?
- need help ASAP cant get ignition rotor off
- Where to buy a cusco Roll Cage
- how to take off a flywheel?
- instrumental light / tail light problem
- Compressor!!! Help!!!
- quick swap question
- auto VSS for 96-00 please help crazy swap
- OBD0 B16 swap..please help
- 96-99 Civic EK in dash dvd in bottom din pic request
- aem pulley belts::::::help:::
- EK Wont Start Starter problem? HELP HELP HELP!!!!
- Del sol w/ B series What Mounts?
- Shaking at 20mph - 80mph ... What could it be ?
- Hard brakes
- mini me
- seat swap
- idling too high?
- itr catback on eg.
- gauge cluster not lighting up
- cel need help
- ek ex civic shifting?
- camshaft pulley and distributor don't line up ???
- Door indicator light wiring diagram?
- B16 Hesitation
- SRS light
- Re-wrapping door panel???
- p5m prelude vtec dohc ecu for sale paypal or money order accepted
- gauge question
- p72 obd1 ecu for sale paypal or money order
- WTB gsr motor parts,any hot seats, any eg6 or ek hatch jdm parts!!
- D15B7 Compression Test Specs
- Help: Power Windows sticking
- So... i went to the track..
- DOOR wont OPEN!?
- Whuts up everyone
- help! anyone with a turbo'd d-series!
- Wheel offset and drivablity.
- no vtec?
- cruise control help!
- b16 cam gears fit on my b20b cams?
- pedals that actually WORK?
- Tenzo R Rims FOR SALE!
- need help, eg cluster plugs!??
- Converting a 98 DX to all power doors
- fuse keeps blowing
- just a real quck swap question
- Is there a way to convert a obd1 95 dizzy to work with a obd2 harness..
- Quick Turbo/Overheating question...
- DAY 3: Still not running 85% done!
- fusebox for eg hatch??????????
- Rear Compensator Arm bolt?!
- d15b7 over rev help
- what can i get with $2000
- Difference between 4 door and 2 door mirrors for 6th gen
- quick air bag question
- skunk2 manifold, which intake??...
- H22 comp ratio and FI
- Quick quetion about wheel offset for a del sol
- d16a1 in 92 4 door??
- 95 civic lx squeaky bushings
- spun rod bearing
- Engine teardown/rebuild process
- engine hesitates
- ek part #
- IS IT SAFE TO RUN THE CAR WITH OPEN MANIFOLD?
- front swaybar...'92 civic hatch ?s
- **Official HOW TO** for B16a
- abs axle question
- Coolant leak coming froma around this area
- In need of honda part # !!!
- need a b16 d15/d16
- Heater issues? When engaged, it rattles through the vents..
- CTR and ITR Differences
- where does this vacuum line go???!!! b18c swapped ek
- Adjustable FPR locations
- h22a all motor building
- vtec pinout for p08?
- Quick help with manual trans fluid fill
- B16 on P28
- Can the RSX cable shifter be used for an H22 swap?
- Mechanical Steering Rack 92-95 to 96-00
- fuel pump
- How do you make the OEM foglights come on with parking lights?
- alternator bolts..expletive!!
- o2 wires
- rhd conversion cost for ek?
- b7 block y8 head...i need help fast
- Can i use the 95 civic ex dizzy on my 99 civic ex it fits perfect and the connectors click in??
- dc2 b pipe on ej1?
- where can i find jdm sticker for hondas
- throttle sticks
- My compression test results 00 EM1 71K
- CLutch is wearing down rapidly
- 5 Speed Conversion.
- help on drop question????
- HX swap wiring help?
- Supercharger or Turbo?
- can someone please run a carfax report on a hatch for me.....
- code 12 EGR Valve jdm D15B VTEC question?
- WHAT SHOULD I DO
- Need a bit of help on a Leak
- a problem with the rpm
- Steps to painting plastic j intake ?
- cometic head gasket/arp head bolts
- installing an intercooler in a non-turbo civic
- Valentine1
- primer no blndo!?
- Headlight Question
- Best cam setup for stock spring B16
- Ca state ref Q`s
- Integra Brake Conversion - Booster Question
- P28 or P13
- da rear low arm control bolt to eg?
- where is knock sensor
- when does my vx vtec hit?
- Need Advice On Repair of Roof
- problem after problem. electronics?
- fuel gauge always on E
- Hi, need help from the 92+ civic crew.
- Clutch/Rear main install
- what engine should I do?
- Jerkind Steering wheel
- Aftermarket headers?????????
- po6 ecu in b16a
- lsvtec set up.... help... opinions wellcome
- DAY 2: Swap is about 60%
- I WOULD LIKE TO KNOW WHAT DO I NEED TO INSTALL A LS ENGINE TO MY CIVIC COUPE 95?
- removing alternator
- Refilling trans fluid B16 HELP!!!!
- !!! Clutch problem: master/slave cylinder failure
- throttle body
- Help! Wheel fell off!!
- turn signal reflector
- popping noise
- Del sol Vaccum leak? problems take a look if u can help please also thnx ;]
- how to: jdm vti-rs climate control ?
- motegi FF6
- Oil pan gasket
- RSX SEATS IN DEL SOL FOR SALE
- Opinions On 5th Gen Del Sols
- where to buy keyed hood locks??
- Aftermarket ITR Catback on my 98 Coupe
- y8 manifold on b7
- OBX LSD GOOD OR BAD
- **stripted tension pulley bolt what tool to use to get bolt out***HELP PLZ**
- whats better for single cam boots
- 5th gear whining
- Turn signal
- Aluminum Radiators
- Civic EK fuse help
- starting problem, no spark? pic inside
- Can you UNDO a h22 swap in a ek.
- new motor from passwordjdm.com b20b broke upon arrival (pics inside)
- buddy club vtec controller please help!!!!!!
- Wiring harness
- ek4 cx muffler swap with integra 94-97 LS?
- Amtel 29C256 need Someone to burn
- P30 Ecu ?'s help speedlimiter
- bolt broke off in motor
- i need HELP!!! h22/eg axel problems
- ecu problems maybe? HELP!!!
- Rear motor mount bad? Exhausting hanging REALLy low
- Door vapor barrier adhesive
- 02 sensor question
- handbrake problem
- Oil Pressure Guage, ?? help
- aftermarket crank pullys bad for engine?
- HELP!!!!!! eg/h22 axel problems
- what would you guys do next?
- TPS code problems
- i need help
- Broken Motor Mount? Now my header hangs REALLY low to the ground...
- Energy suspension sway bar bushing
- 1995 Civic Coupe EJ1 Suspension
- what the difference between an eg 93 coupe and 93 eg 4d stuff wont fit
- yet another gsr strut bar question, yes i searched
- need timing URGENT need to go to moms for thanksgiving
- Need exhaust help really really bad!! I have a problem.
- anyone ever heard of useing a b16 ecu on a z6?
- Low trap speed with b20b hatchback
- Head gasket thickness?
- Keeps breaking axles
- how do i tell the difference?
- 99 rear bumper on 96-98 civic
- how much whp/wtq gain on p30 pistons and itr cams on '00 si stock b16??
- 99-00 D16 Y8 Head question...
- Power lock issue
- What causes a ecu to...
- CLUTCH PROBLEM HAVE SEARCHED!
- I think I broke my VTAK !!
- Exhaust rub is driving me insane.
- Will my itr dizzy work on a b18b??? and wiring harness question. (searched)
- Boost!
- where'd my vtec go?
- !help need sand and prime!?
- ITR Rear Swaybar fitment, with aftermarket exhaust...
- Autometer Air/Fuel problem
- diffrence between '96-'98 99-01 civic fornts
- EG to EK Front
- burnin alot of oil. need help
- don't know what to put in an eg
- anyone try to install rhd type r pedals into our lhd cars?
- Is the TPS voltage suppose to change with the motor running?
- 92-95 civic hatch w/rsx front end...
- Royal Gun Metal or Bronze Rota Slips? Red 95 EJ1
- my first post
- Help me name these wheels!!!!!!
- question on pricing
- Question about 96 to a 99 conversion
- Valve cover: brand name or no??? Any opinions???
- Wilwood rotors under 15 inch Mugens
- Have you changed the mileage on your gauge cluster?
- 92-95 Civic Underdash Fuse Box 'Pin Outs'
- D16Y8 D15B R headbolts the same?
- ABS fuse which to pull to disable
- shoot... think i broke something
- axle nut horror
