- i guess my fuel lines are frozen?? wont start
- 92-95 civic Autometer gauge cluster...?? F/S???
- lookin 2 buy 99 and up ek9 lights...
- need to know the colors of the coil cables....
- 96 civic hit =(
- tinting taillights
- Civic Mirror Question
- Interested In a Hyper Ground System.... Read This
- MD Area: ECU chip/rom
- b16 vs b18
- civic wont start
- Radiator........which of these?
- h22 eg with jdm headlights?
- B18c1 120k never modded is it worth 2000
- Rusty Bolts
- How much power can you get from an ITA motor?
- OT: HT
- FS 92-95 CIvic HB PA
- Rear Interior Removal (need help soon please)
- LS or B16 tranny w/ Turbo Setup??
- DX???? delsol
- gc and tokico blue combo any good?
- civic ex w/gsr engine
- wheel hop
- springs
- Please help me
- Replacing tranny with used one - should I replace input shaft bearing?
- timing belt bracket mount block attachment thing that i need <--what is the name and where can i
- timing belt replace on b16
- Top header flange (pics)
- Online Helms Manual?
- boosted D's
- O2 Simulator question
- cable vs hydraulic
- weird noise when driving???
- are my shocks blown?
- 00 Si Coupe
- Vtec (Not engaging)?
- gathers roof speakers
- Help Needed ASAP: 92-96 Prelude Seats into EG Hatch
- here's a noob of a question on an engine swap to d16z6
- Changing my brake pads
- spoon sports transmission drain plug measure?
- A few D16Y8/Z6 questions
- Transmission Noise
- crank pulley help
- CRX Springs on a Del Sol?
- crap headers?
- Can someone diagnose my engine problem? *VIDEO*
- newbie question
- AN-R header
- what is my engine doing,please help
- HIDS?
- Fitment of shifter -- b-series swap
- HELP:cant rev. pass 3.5k rpm!!
- what do do with NJ Salvage car
- Heater motor blows no air, fuse is bad, keeps popping when replaced..help it's cold in Chicago.
- Black canister next to oil filter?
- D16-H22 Swap question
- Stripped Rotor Screws...
- too low for an alignment
- What Does This Mean?????
- I Need Help
- BAd Ground Wire
- REAR BRAKES???
- just put on rear disk brakes
- F22 v-tec swap
- So my friend's radio got jacked....
- 91 civic sedan brake question?
- 90 sedan b16?
- Stolen...
- What motor came in a 97 Civic DX?
- So I went to target to pick up the new honda tuning...
- swap question
- what can i use to blend my body kit?
- blow off valve question
- speedo goes crazy
- Disc swap: possible to retain original hubs? (Yes I searched)
- head swap
- Help with what stuff to put on swop
- One quick alternator question
- Re-thinking hopping up my Del Sol.. Chassis experts opinion needed
- d15b18 on 94 Cx CiviC Wont start
- Cali Emission ECU?????? expert help
- EK Power Door Lock Conversion
- Clutch and Flywheel
- b16b---civic type R on Ek?
- 95 civic tachometer switch?
- REVIEW::: Buddy Club Racing Spec Condenser
- ITR Dash/Interior conversion into EG?
- idle bounces with new intake
- How do you replace motor mount inserts?
- del sol vtec
- Will stock gsr strut bar fit civic ex?
- Question on compression and air/fuel ratio.
- Dsport magazine says 11 whp with the direct hits spark plug setup...
- Can't get tranny filler bolt off
- what the better head
- CAR ACCIDENT
- help with O2 sensor
- eg coupe to jdm type r front end conversion
- Alright people I need your help... (CA especially)
- 97 civic hatch mis aligned need help
- City lights... got a question.
- civic igniter
- Did 99-00 Civic come with...
- B20 swap
- Clock dimmer
- Mini me swap
- HI
- 99 SI vtec q and gas mileage q
- front bumper ASAP
- Mr.E.G.
- Crunchy Reverse
- URGENT!! Del Sol seat into EG hatch swap.
- Anybody out there have the eibach anti-roll kit?
- Si's For LS Spiders...What chu think?
- what half shafts
- b16swapquestion
- Auto to Manual Conversion
- b20 mounts
- skunk2 IM rubbing the brake valve?
- rust removal
- b18 swap
- Looking for springs!!!!
- For those with K20 in an EG - what cluster are you using?
- Front rotor size 96-00...
- hollowed out cat question??????????????
- Del Sol dash in 92 Civic
- Tooo Freaking tall for my 01 coupe ex. Please help
- headlights
- Am I missing something?? Help Please
- Intake Manifold HELP!!
- Question on Honda short shifters
- Full Stainless Steel Hood Pins
- Del Sol Intercooler
- Help On TurboKit For 95 Swap
- WOW, I got apexi worldsport dampers... don't have the f***in tools to lower it
- Which 96 and up hatch brings a B16? or similiar
- When I turn my brights on, everything else seems to go out
- Steering
- fuel supply system code
- are the rear disc brake off a 1992 si the same size as the 99 si and 94+ integs?
- who's ek4 appear in the february 2005 edition of IR
- another dseries build up...PM3 pistons on VX rods in d15b2 block...good OR no no 8)
- What exactly makes the Si's so heavy? (92-95)
- obd2a-obd1 conv. questions
- anybody live in orchard park ny, or near it??
- CEL wont go away
- Does anyone or can you please post the part number for 1 wire O2 sensor???
- EG rear speaker panels
- cam specs
- are my rotors warped?
- d16a6 block - d16y8 head mini me
- Cam gear adjustment
- Can't close new hood
- I need A GOOD place to rebuild me engien in The Santa Rosa-Napa area????California please Help.....
- alternator problem
- another turbo question
- B18C1 into EH3 problems.. can't check code (good grammar!!)
- where can i get a reasonably priced B16A online?
- B-series TB with MAP sensoer on TB
- electric supercharger????
- tips on Civic HX
- rims
- Rear mount install of doom...
- Clutch push rod bolt
- Good Exhaust For my 94 EG *Besides Greddy*
- hx motors
- a bit confused?????
- Header Question
- 00 honda civic SI
- d6y7 turbo question
- del sol trans ?
- i know its off topic but i need help
- Gas spilling from my fuel rail..
- 99/00 B16 AEM CAI in a eg
- k swap header Q
- Suspension question?
- What year civics came pre-wired for vtec?
- D16Z6 Valve Springs in D16Y8
- 98 Civic DX Fuse Diagram
- can i run a vtec motor on a non vtec computer and wiring?
- what is this? and why is it leaking? clutch related
- Rough Shift possible tranny fluid
- how to install a rpm guage
- 92-95 passenger Side Skirt URGENT!!
- need advice to see if everything is normal
- Need some TE-37's ?
- REAR DIFFUSER ON EK's?
- need help vtec not working
- PLEASE HELP I HAVE TRIED EVERYTHING!!!
- Rear Brake Swap
- b16 going into my EG, what sensor?
- does anyone now about the difference between ignitor
- illegal lights
- illegal lights?
- what color to paint my hatch?
- obd 1 gsr in my del sol. having problems. no codes. timing maybe?
- Block Griddle removal HELP???
- b20 axle
- EK Interior Fuse Panel
- exhaust welding question (pic)
- DelSol rear license plate panel.. help taking it off pls..
- VAFC
- OBD2 Injector Wire Colors?
- 1994 honda civic ex 4dr d16y8
- Wrecked my car b/c of a jackass. 56k beware
- Knock sensor
- DIY amber front signals 96-00 civic.
- Where does this wire go?
- put a scunk2 intack manafoled on my b16 and ever sins its idaling like 1500RPM's and some time it lo
- Type R? interest?
- help window issue.. 00 civic si 50k
- need answer...
- 93 delsol wont start?
- how do you remove climate control
- tire advice on 15"
- b18b wit b16b pistons?
- 92-95 honda civic hb interior parts
- Ticking injectors...
- Recaros in my EG Hatch
- Wiring Harness
- help with cels
- Si interior...quick question
- Runnin lean what to do
- nitrous help plz!!!
- JET performance ecu question
- !!Need Help!! Ideas Anyone?
- low beams don't work but high beams do???
- new guy need advise............
- My melted P28 ECM
- Throttle sticking after D16Y8 Intake Mani swap...
- Installing GSR LCA's & RSB on my EG hatch...what hardware do I need?
- anyone know of a good running civic in southeast area for $3000?
- Need help with 2 things.. Please Help
- 2000 EK Hatch with B18c... Weird Problem.
- Ecu question about a 97 del sol (JET'd ecu)
- CTR door panel question
- 96' Civic body kit info
- H22 into a 99 civic EX
- need's a crank for a b16a
- Would turbo exhaust benifit me?
- Friend revved 400 past redline
- looking for a hatchback in chicago area
- del sol seats question???
- Fitment of 4x100 16x7 +42 offset on an EK hatch?
- What's the difference between the GSR and ITR Engine?
- Looking for the ep1 brakes into a ek thread (searched!)
- lsvtec...which intermediate shaft?
