View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Help: B18Cr wont start, no spark and positive battery cable hot (solved)
- Radio works with key on/engine off but not with engine running
- 96 Civic - d16y7 to d16y5 swap issues
- HELP wont start & dont understand why!!!
- Ignition switch issues on 00' Civic Si
- Green MTF?
- rear main leaking still after replacement
- 00 Civic doesn't feel smooth to drive
- speed sensor issue with 00 civic ex b20 swap
- speedo not working
- Possible D16 Head Gasket Issues
- 92 Civic Hatch SI Starting issues
- timing help 98 civic hx
- Si '00 Stalling/Oil problems
- 92 Civic - brake fuse pops immediatly
- Maintenance help ?
- 95 del sol automatic Si/JDM D16Z6 swap - Idle too low under load
- Identify this connector/missing piece for $100 Virtual Dollars
- Eg sedan front on eg hatch
- Ordered a new rear wheel hub and got this
- Why are the valves so noisy?
- JDM B16A Evap purge nipple missing and potential IAT move
- Electrical questions - replacing headlight connector on 94 Civic EX
- EK D16y7 Misfiring? Runs fine.
- '99 EK hatch future build
- Auto to Manual..97 Civic
- 1994 civic CX mini-me questions
- del sol seats in a 94 EX?????
- distributor advise needed
- Floor Mats / Liners for 99 Hatch
- Reasons for lugs coming loose?
- Possible to use a 01+ civic seat belt on a 6th gen civic?
- crank no start need help. tried everything!!!!!!
- 00 Civic EX Another Head Gasket?
- questions on valve clearance adjustment - modified procedure
- 93 Del Sol Si wet floor
- 95 civic pulls to one side
- D16 Compatibility Question's..?
- roof rack 95
- 93 Del Sol SI - D16A - looseing oil
- metal on metal rubbing noise
- rocker shaft spring not pressing out
- 1994 honda civc heater issues
- street car build advice
- How easy is it to change the spark plugs?
- Replacing passenger door on 98 Civic DX Hatchback - What will fit?
- dirty drum brakes
- Transmission Difference on D16y8
- B16a hose connections.
- Odd clutch wear d series
- need some help troubleshooting this issue - bad axle teeth
- Recommend an exhaust system?
- How to Adjust Your Brake Pedal 1996-2000
- Help no power to starter!
- IPAD INSTALL HELP
- Brand of O2 sensor
- Did They Make a MOMO edition Del Sol?
- cut off 3500 rpm ? comp protection ??
- Low compression after rebuild?
- 1994 honda civic dx transmission problem
- P0105 MAP CEL
- del Sol brakes upgrade question
- No Ignition
- Redline after cruise control
- 93 civic dx help! mini me swap
- Transtop servicing help
- 1998 Civic EX - crank, no start condition..HELP!
- 98 dx hatch air conditioning help
- $750 Civic DX - Won't Start and frustrated
- brakes creak on passenger side of car
- Does an exhaust leak cause performance/power problems? Solve a debate!
- 97 honda civic ex #15 alternator fuse keeps blowing
- Axel Popped Out!!!! Why???
- EX power windows/locks into CX hatch
- Wipers stopped working
- Battery relocate problem
- B16A2 Factory Airbox
- D16Y8 knocking after main and piston bearing replaced. Can I drive short distances?
- 2000 Civic EX aftermarket head unit dimmer
- 97 ek idle problem
- IACV P-0505; HONDA HEADS PLZ HELP! (Electrical/Wiring)
- 94 EG hatch vs 96 EK hatch
- MAJOR PROBLEM, MASTER MECHANICS ONLY.
- Gabrial struts with coilover sleeves binding
- CV axle shake?
- NAPA steering rack dust boot doesn't fit
- 93 Civic ex NO SPARK?!
- Which REAR wheel bearing for 99 ex w/ Drum brakes & ABS
- Acura EL- 13" wheels
- Fuel injection air coltrol valve question/ swap out (not iacv)
- ZC Block + D15B Head
- Engine light
- Erratic Idle(96 civic)
- D16y8 random missfires, dead cylinder, strange compression, no 02 sensor NIGHTMARE!!!
- Weird cold idle issues-what is standard cold idle?
- Swap Wiring Question
- d16y8 transmission question
- 2000 civic fuel pressure spark lot of compression
- Radio Won't light up
- I want some backfire.
- 92 ex coupe d15b2/b7 hybrid swap does nothing?
- Sound deadening padding
- pulling obd1 cel code
- 99 civic wont start
- What is this plug?
- How to check an IAT sensor
- 1994 EG4 occasionally running rough, misfires, wont start
- 93 EG map sensor problem!
- 95 Civic - New axle, too short...?
- EG crank but no start
- help with tucking the engine bay wiring on 00 civic si
- 97 Civic EX Motor Swap
- Questions about JDM B16 swap into 00 Civic Si
- Metal rubbing sound from front right wheel.
- 96 Civic Ex 4dr Power Window Problem!!
- Swap D16z6 to D16y8
- rod bearing spun b16A
- EK B16A hesitation low rpm/feels weak high rpm/power loss
- 98 honda civic help with questions
- Loss of power while driving!!!!
- Total realistic number of miles on EX
- Will these fit my Sol
- 94 Civic almost dies when accelerating
- Need help with dash-lights and SI cluster
- Honda Civic 1999 DX door actuator fit a CX same year?
- Oil pressure sensor plug won't unclip.
- 1994 Honda civic no spark or fuel after rain or hard rain
- Car won't start; CEL/fuel pump do not turn on when key is turned to ON
- 1995 honda del sol si Crank no start has fuel and spark and compression
- how do i remove these clips ?
- HELP - Wierd B16A2 VTEC Problem
- Misfires at idle; Drives fine
- need I wiring help
- 1996 no start, mass air flow check engine light.
- wheel fitment question for del sol
- 1992 Sedan D16Z6 to D15Z1 conversion: Which exhaust piping to use?
- 97 civic ex b18c obd1 code 9 issue
- OEM Steering wheel
- What seats are Compatible?
- help for exhuast.... 00 civic si em1
- 1996 civic odd problem
- my car won't go past 3000 Rpms
- 97 civic ex b18c tps issues....
- 2000 civic ex front wheel bearing issue
- Big Brake Upgrade - Peer Review?
- Rack N pinion manny or power
- P1399 2000 Civic Ex
- d16y8 oil pan
- 1992 VX wheel shaking
- Seat Base swap, from driver to passenger
- Severe oil loss after head gasket replacement
- 1.6 head on d15b2
- white box near ground g751
- Compatibility of EK9 CTR Parking Brake Cables
- Del Sol JDM map light install
- Del Sol Roof Leakage
- Clicking noise on turns, some what on straigts, HELP
- 99 Civic - CEL codes P0153 and P0141 and inconsistent alternator voltage
- Will vtec still engage with no knock sensor on obd1 ecu?
- 1999 DX economy build
- S2000 Clutch master cylinder on Civic EG6
- honda acura AWD SWAP
- 98 civic ex lag start on crank
- 98 civic ex d16y8 strange lurching problem after idling
- RPM dropping very low
- 92 d16z6 Startup issues
- 94 civic mystery oil leak
- HELP!! 94 Civic DX-failed Smog- High NOx
- Sputtering issue 92 VX
- 2000 honda civic drags when accelerating.... help
- 2000 civic ex starting problem
- Location of New Topic button
- '95 Civic DX, new owner, lots of questions
- Engine harness: 94 Civic si ex different? (solved)
- Bad gas mileage and car bogs and back fires
- Wheel bearing issue
- wipers are tweaking out
- DEL SOL 1993 WINDOW & ROOF PROBLEM
- d16z6
- Fuel economy problems 96 HX
- plug wires
- 1993 civic ex ABS sensor light intermittent ?
- Need help installing short shifter
- 98 Civic EX-hesitation at 2500 rpm
- Honda brakes bleed in normal or reverse order?
- EG getting no electricity
- Lost oil pressure - engine destroyed - what happened?
- Nrg Frp fixed bucket seats?
- Odd electrical issues.
- p0113,116
- 1995 civic not getting spark
- 95 AT Ex Cluster into 92 Cx, no backlight
- HELP PLEASE, clutch won't build pressure
- 96 civic failed e-test 4 times and won't pass need help
- Straight Cut gear noise in first gear.
- Flickering Lights
- First generation B16A idle air control valve (iacv) issue
- 92 Eg 96-97 type r swap questions?
- speedometer/odometer not working
- My EJ project!
- EG Civics: Buddy CLub N+ Coilovers, how are they?
- b16a obd2b into eg swap questions?
- My EG Hatch project
- Replacing all the gaskets in B16A2, need help tough.
- Quarter Panel Question Help
- engine bay wiring chopped up
- Water Injection on NA
- Bought my girl a 97 EX - just found out it has a D15B under the hood ??? Auto to Man?
- injector flow rate stock ecu eg civic max
- Question about a 96 DX that I'm thinking about buying.
- EVAP Purge Control Solenoid Valve?
- Honda Del Sol Idle problem??
- Water sloshing behind seats
- help with conversion
- Trying to dispell myths about throw out bearing noises
- 1 of my aux lights not working. ..
- Head studs question...
- Popping coils 94 SI hatch??
- 95 civic idle issues help
- Dash Fuse Diagram
- Acura 2000 EL - the noise level shoots up in the belt area when accelerating
- Wheels
- 92 hatch d15z1 - idles oddly and won't respond to accelerator
- intermittent dying while driving
- Install new dizzy and now no injector pulse
- Need help swapping passenger rails
- Need help with rear interior eg hatch
- Crank pulley won't come off
- EG no electricity
- Sputter at idle
- Cluster Swap? (93 DX coupe)
- Trunk plastic holders
- High NOx for both 15mph and 25 mph
- eg8 axles fit a 93hatch?
- Front Bulkhead Install
- tranny swap problems
- Removal of Sound Deadning
- Del Sol lock on driver door
- 98 Civic Ex: Engine Motor No Start, Almost Starts Then Dies
- Broken valve cover bolt
- Various questions as I put sedan parts into my hatch...
- need a source for repair pigtails
- P1768 Help!!
- Dipstick tube pulls out easy after...
- Clutch Problems 95 dx hatchback
- eg gauge cluster lens compatibility
- Start then dies, then takes a few times to stay running
- D15B7 Head Gasket Replacement
- 1999 originally d15z4 with p2c ecu swapped to b16a v-tec with p30, problem.
- 94 b18b1 with 90-93 s80 transmission axle problem with drivers side fit...
