View Full Version : Honda Civic / Del Sol (1992 - 2000)
- NOt sure about D16 and D15
- EG with 98spec type-r exhaust question
- Civic quit in snow
- 99-00 si foglights
- Engine Swap Question.
- Acceleration Loss
- new clutch question
- What's the best web site so buy swap? (JDM B18C)
- Performing 100k maintenance - check out my parts list - what else should I add?
- a/c?????/
- ek hatch dx or eg hatch si??
- harness help
- Ol' skool Denji's
- LS/VTEC vs. SOHC Turbo
- jdm type-r steering wheel
- O2 Sensor problem with aftermarket headers
- Password Intake
- eg6 engine swap
- seat belts
- New PCM(Used) giving me code P0700 & P1768
- Overheating...
- y8 intake manifold onto z6
- 92 dx hachback whats this?
- help: p28 ecu rpm tach not working.
- Cam shaft
- Bubble car 93 Civic Ferio 32k miles!
- ek side skirts on a eg
- 95 vx exaust help
- RSR Lowering springs
- em1 shift linkage bushings
- em1 CEL code !?
- I do not get the right idle..
- exhaust help
- **high preasure in system**
- Launch control rpm point ? WHATS A GOOD RPM ?
- swapped engine now REALLY REALLY rough idle
- crankshaft position sensor
- flywheel question
- bogging or no power
- DIY installing turbo timer 4 92 civic help!
- Power door setup question
- Can I fix my cluster
- leaking anti freeze
- in need of some major help
- Do you have Crystal or Black headlights?
- Need Help Posting
- exhaust system question
- lost my car keys!!!!
- Bleeding coolant-bleeder bolt
- Ek hatch paint code needed
- civic tail lights
- "HOW TO: Fitting HX rims on big calipers."
- Car will not start..B16a built w B16b head..
- question on a y8 civic i just bought?
- 1997 Civic tail lights
- TURBO D15b7
- WTF is a P30...
- Am I getting ripped off?
- Shifter problem
- My EK sounds like an STi?! Plug wire?!
- EXHAUST question...
- Q about a members EK.
- 1992 civic vx
- EH3 D16Z6 harness = EG6 B16A harness?
- Super High Idle
- gsr swap help!!!
- Why does my car die?
- motor mounts
- Need help on decision
- EK dash woes.....
- Where to get torque specs?
- How to get the spring out
- brakes lose pressure while idling, 94 civic
- konig rewinds or rota rb's?
- NEED HELP wiring radio problem
- 97 Honda Civic EX Problems, PLEASE HELP!!!
- A/C Making Hissing Sounds?
- Boosting an engine over 130K miles
- tps cel 7 help
- Anyone here buy 99-00 Si EARLS brake lines?!
- No dash or gauge lights?
- Resparking this relationship....
- 96 civic bad mounts
- GSR sol tranny mount
- Block???
- Anyone have these part numbers??
- Shop to do body work damage
- What do i do? Rear EM1 seats...
- EG hatch lowering springs on a EG sedan
- Jdm eg6 civic intermittent problem,HELP!
- ? about oem alarm 00' si
- engine misfire code 71-74
- 92 dx need ls swap help
- 2 door vs. hatch question
- Brake upgrade
- do all jdm h22a motors have 220 hp??
- ls/vtec compression psi
- Battery light, CEL, speedometer problem
- 2000 Civic OBD2B using 1998 EL OBD2A ecu, engine and harness?
- *****del sol stolen in chicago******
- this a good deal on an Si?
- Tenzo R seats in del sol
- emmisions
- Question on springs and struts
- Which ek rear lip??
- haha **** yea, finally got a swap
- tranny problem
- is this a good ideal
- 96+ civic and 94+ integra inner tie rods the same? steeing rack?
- SRS Light Problem 95 civic
- press brake car shuts down?
- check engine light on
- 94 ls in civic hatch problems
- 1992 eg8 sedan windows dont work
- eg hatch exhaust question
- eg hatch exhaust quesion
- hmmm.....
- rear license plate conversion
- Which Header will fit a JDM Civic SiR with B16A
- jdm h22 hesitation
- Rev Match Performance EG Build
- noob question about axles
- 1997 Honda Civic Coupe Help! (Loose Bumper & Windows)
- Coilovers.........
- Will 96 DC integ turbo piping fit in my EK?
- Gauges where heater vents are
- ecu help?
- difference in between OBDI and OBDII cats
- Building my b16 and wondering about fuel management
- Will Si engine hanress fit d16y8?
- Junk Yard Turbo
- CGP em1
- Question about b16 engine, obd1?
- 92-95 suspension question...
- Ebay carbon fiber spoon replica mirrors
- Teach me the differences / ID these brake parts
- NEED HELP. B20 into 96-00
- EG help couple of questions....*****
- How to get the horn to work?????
- referee check
- vibration in steering wheel
- push start button
- what needs to be done before i put in a turbo...
- spring rate...help decide skunk2pro S
- P0700 & p0715 on y8
- Cant decide on engine
- looking for shocks.
- B18C1 swap in a 95 EG question
- Rim Question on 93 Del Sol SI
- mt shifter
- Neeeeeeed help with my eg!!!!!
- Skunk2 Short Shifter Question
- how do I change the bulb in the cruise control switch????
- Could this be my cat?
- which cluster will fit
- ex tranny swap prob
- 92-95 coupe to a sedan?
- radiator fan not turning on....what to check?
- Head job and Block job
- why do i have to press gas to start car???
- Nippon racing CTR pistons
- Crazy squeeking noises coming from drive train
- ok vtec help
- ebay header on a d16y7
- power windows dont work on my 4door ek
- Civic/Del Sol rear disk brake conversion help
- Which radiator should i get...?
- 92 Dx. Runs TERRIBLE cold then perfect warm
- 92-95 4 door front end
- 99 jdm type r in eg hatch..
- can I use integra ls/rs throttle cable?
- turm signal relay
- My interior lights dont work! Fuses are fine.
- Brakes Pads & Rotors Which to get?
- Center console controls arent working, what fuses to check?
- b17a1 vacuum lines
- Changed Timing Belt, Now Not getting any spark.
- Exhaust Problems. HELP!
- EK seat fitment help and...
- need HELP on trailing arms????
- Roll Cage with full interior
- Hello From alaska!
- anyone with an eg with +40 offset
- BackYard special replica??
- How To: Wiring secondary o2 sensor directly to ecu
- is it time for a motor rebuild?
- Thicker rear stabilizer to DS/Civic 92-95
- Cel light is flashing not good
- Step down/ wiring problems
- Pic Request: Civic eg/ek/ef with 4X100 to 4X114 adapters
- 95 Civic 4 Door - Idle problem
- installing headers
- Bad radiator?
- Which Corners For EG Ferio?
- Are there any LHD CTR headlight housings anywhere?
- Gauge cluster help!
- Hood latch won't unlock???
- Noob questions on b series motors
- Interior question for H-T gurus
- Eg door handle removal? And are they pre-wired for power
- d16z6 rebuild engine with p29 pistons
- 99 civic problems
- Yet another civic break-in story
- relocate cruise control box
- 01 dashboard to 96-98
- EK Plug Identification...
- i have a type r. its in a civic.
- 97' Honda Civic door lock issue
- need help befor i buy
- Ek Stolen quick help...
- LS meshes on GSR break conversion? (EJ1)
- fiberglass spoon lip for 96-98 civic??
- What wheels are these? (oem honda)
- ek suspension?!?!?
- camber kit
- civic type r
- 96 hatch
- Electric power delay on stereo/cig lighter '95 del sol ?????
- my new k20eg what is your opinion?
- jdm b16a
- car shoots blacksmoke!!!
- Engine has random, intermittent misfires; help needed
- b16's and nos
- Engine tranny
- Got a CEL, but can't check it.
- EX Header on D16Y7?
- 2000 civic ex?
- Brake lights dont work HELP ME
- b16 head help
- I hate ignition coils
- best tranny?
- Question on clutch, struts, and springs...
- is this a good deal? 1995 hb...h22 lsd...
- 00 civic si foglight wiring help
- d16 turbo or ls/vtec??
- Whine after cluster install
- pr3-2 head b16 or itr???
- steering wheel... removable hub
- crank sensor problem
- Explaining the difference between clutch and flywheel.
- Cusco Front Upper Tower bar question.
- im having some trouble with my axles
- gsr engine neeed help
- si cluster h-t help.
- paint??????!?!?!?!?
- d15b7 vacuum hoses
- eg civic 40 offset?
