View Full Version : Honda Civic / Del Sol (1992 - 2000)
- my 93 ej2 build thread
- 99 Civic Headlight problem - Need correct wiring
- 1999 civic si oem Alarm wiring help
- 99 civic hatch power window conversion help
- 95 Civic sedan rear power window motor issues
- y8 oil pick up in d15b
- 97 civic - spark, CEL, ECU, and fuse questions
- Why engine no start?!
- clutch problems
- 99 civic rywire harness
- 94 del sol rear disk swap problem
- fuel pump doesn't always prime
- D16Y8 Tick or Knock topic again
- Compatible Motors for my 96 CX Hatch
- maxtrac coilover problem. HELP!?
- Power Folding mirrors keep blowing Heater fuse
- 94 civic coupe d16y5 crazy idle issues
- 00 Civic Si Smog failed !
- Advice for the Long Haul. 300k+
- Last words of advice - JDM 97' B18C-R Swap
- Buddy Club Exhaust Question
- 98 hx - exhaust separated in front of resonator
- d16z6 stuttering at 1400-2000 rpms, Need help!
- why wont my brakes work!
- B18 swap in EK with Skunk2, Integra cat or Civic cat?
- Question on complete Head replacement And what I need?
- no crank no start help
- Bad thermostat?
- Can too much negative camber indicate frame damage?
- 93 civic no spark or fuel power
- Car does not start/ no click sound
- AC Noise
- 95 EJ2 D15B7 - 11:1 block is good, i need brand advice for valves, guides, seats, etc
- Problem finding Pistons
- Does the 95 Civic have a power steering cap?
- Hose from valve cover missing. What parts do I need to buy?
- no books/fuse cover
- Which AEM short ram intake will fit EG with GSR?
- strange problem with my clutch.
- Hooks on trunk wall...for net?
- fuca specs/diagram
- CEL comes on while driving. What could be the problem?
- 98 civic
- 97 Civic - new to building
- How do you get the rubber gasket onto the D16Z6 valve cover bolt?
- EM1 Cluster Issues
- 2000 civic si noise
- Ek/Ej8/Em1 wing question.
- 2000 civic si wheel bearings
- strange noise after timing belt change
- 98 Civic EX keyless help
- valve cover bolt won't tighten
- 97 Civic LX D16y7 Head Gasket and exhaust replacement
- 1996 Honda del Sol VTEC - B16A2
- CYP Sensor Check Engine Light
- d15 using coolant
- cooling system questions
- d16y5 launch control
- Bumper replacement carparts.com
- gas leak 1998 civic hatch
- DelSol vti (uk) b16a2 not starting
- eg coupe, rhd converted using lhd harness, b16a swap - eld related problem?
- D16y7 block y8 head z6 IM what throttle body can I use? 97 civic mini mi
- Questions about cats (non-feline)...
- need help from the wiring gods!! 98 civic lx
- Are the EBAY exhausts any good?
- problem and decisions, 1.5 cyl#3 misfire.
- 96 EK: Can't get my climate control out!!!
- B16b Ctr with LS Tranny?
- gas guage 3/8 when disconnected (93-95 civic)
- Bunch of CEL codes after a car wash! WTF?!?!?!
- 94 civic coupe muffler choosing help!
- obd1-2 dizzy question
- Ek3 sunroof glass fit eg9 sedan?
- Two wires off power antenna harness?
- 95 Del Sol V-Tec Running problem
- Jdm Ek Mirrors Install Question
- Nrg quick release + horn install help
- what gen is my b16a?
- '05 civic SI cluster into '96 civic dx??
- New Bushings.
- cannot find a front bearing hub assembly
- benefits in polishing alloy wheels?
- Need ECU help, my GSR swap has a virgin P28?
- Begging for help! Obd2 b18c into 93civic hatch notorious code 9
- idle randomly drops when warm, getting ckp code
- Possible rack issue?
- password jdm flush valve cover bolts loosen?
- Can someone help me review, im still new. '96 Civic CX.
- Best way to clean a used oil pan and valve cover?
- b16a2 high idle, jerky shifts
- mini me ecu problem
- D16Y7 rough idle and O2 sensor problem
- D16a/y8 build backfire
- 96-00 EK power folding mirrors HELP
- 99' Civic EX - Oil Leak!
- 1995 Civic EX 1.6 VTEC having power issues
- Rough Idle problem - 98 civic ex
- 2000 civic obd1 LS code 14
- single cam 1.5 head problem
- Caliper keeps sticking!!
- valve stem seal questiona
- IACV inner seal bad?
- 98 civic b16 powersteering. p72 pump what bracket?
- b16a2 w/ ctr ecu?
- D16ZC Questions
- 95 Civic with O2 sensor Cel code
- D16Y8 Block rebuild need part info
- 2000 Civic WONT Accelerate!!!
- Remote Start and Keyless Entry Install, I NEED HELP!
- Majestic Honda - Confusion about "Discontinued"
- D16z6 block into 97 Civic with y8 motor - Won't start
- 2000 Civic front end wobble.... **UPDATE 3-28-14**
- Blown ECU fuse
- 96 EX D16Y8 oil leak
- Anyone run urethane side mounts with rubber rear mount?
- Y7 injectors in Y8?
- 92' civic 1.6 d16z6 "Starting Probs, And Loses Mass power when inclining"
- No power to left headlamp??
- 99 civic ex/b18c gsr swap - slow pick up
- y7 to z6 intake mani.
- d16y8 low rough idle at random times
- High Rpm? Just swapped b18b1.
- Manual to Power Panels
- what is this part?
- 2000 honda civic si with no spark?
- 2000 Civic dx 4dr chugging at idle horrible fuel milage
- Valve cover bolt replacements???
- 98 civic Ex Trunk Latch Issue
- Equal by Exedy/Daikin Clutch Slave and Master Cylinder
- 00' EM1 - RPMs drop at constant throttle
- [HELP] obd1 to obd2 ECU swap (GSR engine swap into EM1)
- Catalytic converter
- Advice! Transmission leak.
- 94 VTEC 1.6L engine problem - No Start
- Fuel Gauge Issues, maybe??
- cluster swap
- Beware thine intake pipe!
- 96 honda civic d16y8 Car stalls when I go to turn it on to warm up
- Will a b-series oil pan fit a d16y8 ??
- 97 civic crank angle sensor 3 pin out plss help!
- 92 si hatch electrical problems after unplugging battery and revving engine
- Car won't start after radio istall
- Distributor/Rotor Change?
- 94 Hatch running rich, low idle/stalls
- EJ6 mirrors same bolt line/pattern as DC tegs ?
- fuel pump / no voltage?
- Back Up Lights not working
- mutiple error codes (p0325, p0505, p0171, p0174, p0170)
- Finding what's right harness..
- Clutch opinions
- Issues with front wheels getting stuck. 00 SiR
- Electricial Grimlins! Multiple alternators at 13.4V
- 95 Civic EX - Lights don't fit well
- 93 SI (d15z1) check engine light 48 & 15 - emissions help
- Stock D16Y7 Misfire HELP!!
- No holes on 1996 civic hx for b series shift linkage.
- B18b1 swap in a 2000 honda civic dx
- Help with D15 3 stage econo light
- Soft brake pedal after rear disk swap. 99 ex
- Weigh-In on oil weight
- b series t bracket
- Where can I find a b16a2
- mini me d15b7 block y8 head timing???
- 1994 Civic EX--headlight/climate power issues
- 92-95 civic hatchback spoiler brake light doesn' work.
- 1993 Si (d15z1 block) Check engine 15 & 48
- 99 Civic HX - No spark after car warms up.
- 95 honda civic tail lights and corner lights not working
- Air Conditioning; Where to start on reviving the A/C?
- 1996 del Sol VTEC (B16A2) Swap
- 97 Civic LX auto won't engage in gear(D) in the morning
- starting problem with my 1998 honda civic lx
- 97 Civic/ Front door will not open
- Help Constant high idle 1,800- 2,000 - 94 Sedan w/ B20 swap
- 1995 EJ1 no electrical power problem
- 95 Civic A/C console light goes dim when cranked up with headlights on
- Ordered 1.5 timing belt kit, received the 1.6
- obd2 car with obd1 longblock questions
- obd0 b16 in EM1
- Yonaka B series half shaft
- GSR Power Steering Upper Bracket
- Once again, needs help with axle seals.
- 99 EM1 Wheel Bearing Question.
- plug c103 on passenger shock tower help??
- 98 civic lx front passenger window issue
- Sleeve and Tapping Help
- 97 Civic Bucking/Hesitating Acceleration
- Honda Noob help Overheating and intermittent no start
- 92 Civic hatch/jdm b16 - what 4-2-1 header has clearance for radiator/condenser
- b16a struggling in vtec.
- 95 Del Sol " NO START" II
- Can't pass deq because of 2nd o2 sensor Please help
- jdm b16a vtec - is the p28 the best ecu for this engine?
- 98 Civic Ex/D16Y8 timing/distributor issues
- Picking A Clutch Kit
- PCV Grommet Fell in
- An amateur's tips re: mini-me swap.
- Need advice on JDM engine replacement of D16Y7 in 98 Civic LX
- Rear door lock only pops up halfway
- Keyless Remote Question
- CRX roll bar in EG Civic?
- 95 civic lx cranks but won't start
- what do you use
- PCV Valve: Is this normal?
- 95 Civic EX - Electrical problems
- Identify chassis mount bracket plates
- Front Wheel Bearings
- 1998 Honda civic crank no start
- Speedo acting weird (96 civic coupe 1.6I)
- Engine mount bolt
- 94 Civic EX Q&A
- D16Y8 vtec solenoid oil leak
- BRINGING BACK TO LIFE AN EM1
- d16y7 head on d15b bottom does it fit ?
- Honda Civic Ek3
- 2000 civic dx overheating
- TW Sensor ???
- b18c1 swap into ek civic - tranny bracket problems.
- 97 del sol - intermittent cranking issue
- 98 Civic EX climate control back lighting?
- 99 Civic DX - need new muffler opinions
- Is there a difference between a y7 and y8 short block?
- Car sways while cruising
- 97 civic cranks and tries to start but wont??
- 95 del Sol Si no cruise/windshield washer spray/reverse lights
- Honda Ek 00 Dc header
- Tranny problems
- Spark plugs removed
- Collapsing Radiator Hoses
- b20b engine swap into 93 civic - info needed
- Built ls-vtec idle issue
- b20b swap into 00 civic - automatic to manual
- 94 Del Sol - Y8 mini me swap (OBD2b distributor harness)
- Honda Civic EM1 (Si, VTIR)
- 93 civic brake problems
- Vtec Solenoid Valve Gasket
- 00 civic si - what was the original motor?
- 95 Del Sol "NO START" and cruise control problems
- 94 Civic - brake pedal falls to floor
- Individual Throttle Body on a D16Y8?
- 93 Civic - rear disc brake conversion questions
- 99 ek4 sedan jdm - no vtec, no cel
- I want to lift the engine so that I can drop my car
- front end crash damage
- 92 Civic Si - speedometer & tachometer don't work, and exhaust leak
- B16a2 idle fluctuate problem
- Roof leaks - shave out roof molding?
- cold idle thermal valve question
- New key is stuck
