View Full Version : Honda Civic / Del Sol (1992 - 2000)
- swap,need help try search but found nothing!!!!!!!!!!!!!!!!!!!!!!
- Rear Disk
- eg rear upper wing??
- How HP does it take to get 2600lbs to do 1/4 mile in 12 seconds on street tires?
- Tire opinions/suggestions please
- Engine is missing @ low RPM & Light throttle
- whats the strongest japanese single cam motor....
- dash board reflection
- what kind of springs for 92 hatch
- Transmission woes...
- my car jerks hard when i floor it
- suspension problem
- Would the ITR suspension or...
- In search of my next car/project car/daily driver
- which side is left ?
- EK lip on Red 92 civic hatchback
- Cleaning and keeping clean windows
- Come get your CARFAX HERE!
- Distributor blues
- LS hatches??
- problem installing eg ctr console
- Brand new CTR pistons good till ?
- need a 99 civic fuse panel layout, radio fuse blew
- ITR headers work on B16a2?
- "Extended Shock Travel" upper perches installed and initial impressions (56k unfriendly)
- B16A tranny
- how do you remove the climate control in a 96-98 civic?
- ground control coilover spring rates for coupes
- PIC REQUEST! 92-95 civic coupes stripped rear interior!
- Well its about time a tech question
- B18C5 build up...BOOST!
- place racing motor mount question
- Uh oh....Help Please~ Dist. Problem0 Y0!
- need help!!!
- carbon fiber duckbill w/ LED
- Elegante 92-95 Civic 1 Piece Projectors
- where can i get this strut bar????
- TEIN EDFC Question
- the saga continue......new distributor no spark.
- Installing exhaust
- Stupid bolt
- Need hatch side molding
- differences between b16 tranny and itr tranny
- stock Si tower bar on CX
- RHD civic Si-R spotted in Dallas
- what one should i get ???
- everything is fixed... BEFORE and AFTER.
- Will Civic short shifter fit Teg shift linkage?
- stock tach 2500rpm's off???
- sway bar on 6 gen hatch question.
- gsr tranny
- what kind of exhaust please
- are crx's cursed or is it just mine?
- Post your B16 ek track times
- d15b: what parts do i use??
- people with y7's...
- What else is needed for H22A EG?
- Swap wiring question
- SRS light stays on.. HELP!!
- For those who have done a B swap and are using a SOHC fuel pump
- clutch change
- question?
- Where is the best place to buy a "Real" mugen twin loop
- How do i remove an air bag
- Clutch problem on my 99 Si, PLZ HELP!
- Swap From HONDA EX(2000) TO HONDA DEL SOL S (1994)
- Mugen axle-back exhaust with what middle piping?????
- How good of a price should I expect for a 99-00 Si???
- what car from this part #?
- GSR Cluster into EG
- Torque Specs from Civic...
- progressive alignment kit?
- HELP!! Install question. I have just bought a neuspeed rear upper strut tower brace...
- Got my motor today!
- Need help d16z6 motor
- Eibach Sportlines Need Opinions
- Hybrid Fuel Pump
- Question about 38 offset. Will it rub?
- B18C in 92 VX??? any problems??
- Excuse the amateur post (valve adjustment)
- D15z6
- 96-98 civic foglight part numbers, help me please!!!
- size of civic si factory catback exhaust?
- transmission fluid
- gsr full brake conversion or 5 lug conversion??
- I want to see all the Black Civics!!!!!!!!!!!!!!
- Surf/Snowboard Racks
- 215/45/16's on a EK Civic? Anyone using them?
- sound coming from front right wheel area
- Si or Integra GSR?
- ECM layout
- Anyone interested in some HX rims/tires??
- will a 92 VX engine fit a 94 SI?
- ITR Suspension Question
- do i need a tachometer adapter for 95 civic dx?
- sway bars on 93 civic CX??
- 99-00 ITR suspension on 93 civic cx
- Does this look real
- Does the Skunk2 Camber kit for EG/EH
- Rear Hatch Pins??/
- is z6 dizzy same as cx dizzy???
- capable tuning houses in the East
- Need Help w/ installing new clutch set...
- Canadian Civic owners....
- suspension question.
- 96 Civic (odb2) with b18a (odb1) questions ?
- What temp does your car run at durning the summer?
- lug pattern
- Selling Wings West 3pc Spoiler (5th Gen Coupe)
- Introduction
- Will stock internals on a d16 handle a 50 shot a nitrous?
- Good Camshaft for Nitrous?
- What is the general opinion on universal exhaust?
- Need Pics Of Del Sols With Eibach Sportlines Please
- Differences between D16 heads
- y8 intake manifold on z6 head
- Best Drop Springs / Struts
- need help locating these "fastners". thanks
- Strut bar confusion...
- name that rollbar/cage.....
- Question for those that put a OBD2 SOHC engine into a EG civic?
- 96-00 Civic / 94-01 Integra steering wheel hubs = vertical notch / horizontal notch??
- Small backfire in mid rpm range...
- Hmm, Tranny has no oil
- FAQ: Need ECU Pinouts? Then look inside.
- moonroof repair pricing?
- dynomax ultraflo size?
- Did someone sell me the wrong mount??
- good vtec kick in point?
- How Do I remove my Taillights?
- proportioning valve
- obd2 ecu in obd1
- VX diffuser...
- How do I know if my Distro Rotor needs to be replaced?
- Alternative to Hood Pins?
- Grinding Noise
- Help with Field SFC >>>> Fuel Computer
- No one can give me an answer
- procarparts.com
- Roll cage pics, starting one this week, just wanted to get some ideas.....EK's please
- ** HELP, code 14, IACV problems **
- picture of my car couldnt post up in Appearance forum
- photoshop eg
- Integra A-Arms on eg civics???
- Fiberglass
- !!HELP!! Engine Swap Problems
- 93 Civic and 94 Del Sol VTEC Front Suspension/brakes = compatible? Wheel bearing help
- 5G Civic sedan and coupe: Are exhausts interchangeable?
- vtec engagement on p28?
- JDM ITR rear tower bar in a 5th gen hatch
- hookin up power folding mirrors
- Info + pic request:) Del sol with 99-00 civic front end
- OK please...anyone...EK Si coupe hi wing on a ej1....
- need swaybar/bushing help
- what hatches came with anti-lock brakes, and is it possible to add anti-lock brakes
- any good shops in so cal for camber kit installs?
- 4 X 114 adaptor for our cars: eg6
- N2O progressive
- How much do Volk Gram Light 57C 16" rims weigh?
- Where to buy 5th gen hatch exhaust mid section???
- ITR hp numbers?
- first gen b16s
- Any suggestions on tuning my B18 EG
- Pics of cars racing....
- Almost lost the hatch tonite........
- Just Got A New Bumper Pics Inside
- NA set up
- will this fit a GSR throttle body??
- question on my hatch... please help!!!!
- 92 Hatch:Put stock motor back in, having alot of problems!! Help!!
- Recommendations on first mod?
- My Sputtering JDM d15B
- Stuttering gayness and other problems
- 99 civic si AEM cai fit on ex????
- dc2 srs wheel on eg... horn function?
- EG 3" thermal users, you have Sway Bars?
- Defi How Much
- Returning Civic Back To Stock
- Anyone know about brake swaps
- Mini Me OBD1 D15z6 vs. JDM D15 (Spade? Mistabone?)
- Whats the diff: ITR intake man. vs. skunk2
- how much would YOU pay for this????? 56k ok!
- What parts absolutely required to fix bad 2nd-3rd synchro (b16a)?
- Thieves tried to steal my stereo! (tech inside)
- Del Sol Stock Radio Code?
- 3 point strut tower brace???
- hx rims
- 2 buy an si or not to buy?
- gone in a puff of smoke
- knuckle swap
- Anyone know where to buy a muffler
- Which Teins.....
- Best Sohc Non-Vtec Cam . . .
- Clutch problem (can't change gears while car is on)
- Jack points...please help!
- Need wiring diagram for FIELD SFC HYPER!!!! HELP???
- no0b question
- Pics of my EG almost done...check link
- (EK) EX Gear Ratio?
- My new engine comes TOMMOROW!!
- crvtec Turbo Setups - PLEASE post your setup
- Edelbrock Turbo?
- Bored....Nice "Type R" on cardomain.com though
- which turbo kit would you get?
- ajustable FPR, on a turbo app? what PSI??
- 2150 lbs sound right for my hatch?
- Changing the VTEC point
- 93 ls automatic in a 1995 2 door coupe
- got code 4 and car doesnt rev past 3500 rpm
- Ecu
- Ricey i know! But about z3 fenders.............(PIC)
- for people with sportlines
- need your opinion: best 14" tire besides azenis...
- exhaust question on an eg hatch
- Short Shifter rubbing/rattling on exhaust?????
- SPOON Rims. Unheard of Price
- Long block help, Need experienced people.
- Running Lean
- Skunk2 Intake Manifold /Spoon TB install,.....now MPG is crap....*LONG*
- correct drop?
- Has anyone ever tried this...
- HOW TO: Tommy_Gunns Earthing Kit
- HOW TO:prep a car for paint
- rim pictures?
- Timing Question
- how much for Recaro type R seats?
- 1999 Si Headlight conversion on 92 Civic Hatch
- whats the 'best' supspension JIC makes?
- Pics of my Black2kcivic (56k needs to get some Astro Glide!!!!!!)
- has anybody needed extra parts from Honda when you dropped your car?
- ** URGENT! ECU code....please help! **
- Car won't crank over at all
- finally got my spoon lug nuts
- exhaust??
- how do i put teg mirrors on my ek
- 92-95 Civic Swaybar owners, take a look
- Project EK........RIP!!!
- ecu question
- Largest tire size on lowered hatch?
- Code 73 or 74
- 02' Si Front-end Noise
- D series nuts gotta problem 4 ya
- RS*R or SKUNK2 or Apexi N1
- Tranny problem?
- I need a test pipe in Orlando
- Need help opening the hood!!
- Tein problem Need help quick
- VSS wire question, can someone look it up in Helms for me.
- My engine size/code once and for all
- OBD 1 or 2???
