View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 94 CX Electrical Problems.
- i want my exhaust quiet.
- 99 civic Si cel
- D15B VTEC into 92 VX---Searched
- Charcoal container on rear firewall..
- d16y8 throttle body w/ no sensors
- Caliper bolts
- List of all Engines, and Styles for Del Sol and Civic
- AEM Cold Air
- 92 civic DX hatch electrical
- Shocker sign on gas cap rice or not ?
- whats the diff... d16z6 or d16y7? which is better
- 96-00 Any one using obd2 computer and have a turbo??
- Civic hatch, coupe, sedan Show Off!!!!!!!
- milling my head
- Cam Holder Plate Torque - same for B18C and B16A?
- Rear Brake Disk Replacement
- Taking off the hatch glass?
- Make money with paypal!! PLEASE READ!
- Bulletproofing motor to OEM specs.... Any thoughts??
- Spark Plug Wire Diagram
- Not sure what the problem is here. Axle? Brakes? wheel bearing?
- act clutch kit making noise
- is this it?
- Itr intake on b16a2?
- Where do I buy Paint??
- Where does everyone get their Squash refills?
- help me with wiring!!! please
- b16a timing mark
- Starter fried and now no power to car at all
- 99-00 civic si & 96-98 engine harness ecu plug question ?
- Tire size question... ***************************
- A/C in a EK Cx?
- B16b swap in a 95 EX
- what obd is my car?
- AC
- vafc Air Fuel controller Settings help tune?!?!!?!
- fast linker on my 94 civic hatch cx
- proportioning valve question......
- NEWB & my new to me car
- HELP PLEASE !!!
- shift linkage to tranny leak
- EXHAUST QUESTIONS???
- wich is the best turbo for me??
- help with H22 swap into 95 civic SI
- P28
- axle woes, someone help
- knocking noise when braking
- b18c5 Turbo or B18c Turbo?
- b18a1 into a 94 civic hatchback
- b18 swap and power steering
- help car wont start
- Synchromesh....will it help kill the grind in 3rd?
- Del Sol Rear
- COrner Light Problem!!
- 98 Civic Dx Hatchback UGR Coil Overs any good?
- Is this way to much
- attention 11secEk
- Looking to trade CRX for EG........
- a/c experts please!!
- valve cover painting... few more questions.. searched
- any one know whatb fuse is related to the VSS
- question?
- fuel filter
- What is the best Hid kit on the market on honda-tech???
- clutch reservoir cap interchangleable between years & makes?
- GC Spring Rate Question
- should i be mad..tooo bad i am!!!!
- ej2 roof assembly
- d16y8 intake on d15b7 head
- Axle replacement question
- Need B16A knowledge.
- supercharger vs. turbo charger
- Where to buy AC block off plate for 96-00 Civic?
- del slo engine swap question
- rear disc swap question....please respond ASAP... GSR brakes in civic coupe
- Ek Carpets
- Which wire harness is this?
- noise under shifter boot (auto tranny)
- where to place a MSD 6AL ignition in the engin bay?
- 99 civic coupe N1 axle back to a EG
- jdm fog light relay for EK
- Can a Shift Lock Solenoid that "shorted out" blow an ECU?
- mini-me comp. ratio question
- Should the p/s and a/c stay or go???
- Which pistons for d15B? SEARCHED
- Hyundai's new car better than civic
- bled brakes but not a strong hold.
- NEED Help Quick....How to identify Skunk2 Stage 1 Cams For B-Series VTEC
- a/c compressor
- wtt::::my del sol for a 92-95 hatch
- car idles messed up
- Do I dare?
- I'm thinkin of buyin my friend's complete swap [Searched]
- my hatch is running rich (D15B7)
- Tranny Rattle
- Compression: #1: [180], #2: [20], #3: [172], #4: [180]....?????
- couple mods estimates
- 5 lug conversion
- del sol wont start
- Weight?
- steering noise
- Electrical wiring?
- which shock/springs should i get???
- SELLIN MY 99 CIVIC SI!!!!
- clutch peddle adjustment question
- B-SERIES TURBO MANIFOLD
- Puck clutches
- Car shakes HELP!
- ran over a fire hydrant cover... what do you think
- Skunk2 Camber Arms Squeeking??
- OBD2A to OBD2B HELP !
- D16y7.....secondary o2 sensor question
- timing belt problem
- fog light wiring help, fusebox
- Wheel question....
- chipped ecuu 95 honda civic dx
- Help electronic gurus, turn signal problem
- Remote keyless entry in '98 Civic is kaput
- will a 92-95 aem cold air intake fit my 96 civic w/ bseries swap?
- Cracked head on a 97 Civic DX Hatcback.. Questions
- 95 civic Engine Problems help!!
- tokico illuminas with GC? or Koni yellow with GC?
- Civic model differences..... HELP!!
- usdm vs jdm b16
- dx or ex coupe roof
- Revealed! - Lock to Lock - ITR rack swap to EH3
- del Sol susension
- running gsr ecu
- OBD 1 Pinouts
- difference between 96+ civic ex intake and 99-00 Si airbox??
- rear disc brake help
- B16a2 question...
- Skunk 2 Intake Manifold
- are there differences between german and us d16z6 ?
- AEM Hybrid HELP
- ebrake cables question....QUICK!!!!
- Anyone have the MagnaFlow Muffler 4" x 9" 11" Body?
- Rear Disc Conversion Removal
- guage wire size for fuse box wiring?
- help Broward County, Florida
- What could be wrong?
- So... what 92-00 civic should I get?
- calling out people with exedy and ACT clutches!
- Tein Ras on eh2???HELP????
- autometer prolite
- Replacing electric door lock motor
- Noob question! What is the uk version of the GSR?
- removing pinstriping from 98 DX this week - potential problem(s)?
- Code 67?
- Tranny Hookup in custom car
- Will d16y7 injectors work in a b18b motor?
- whats best?
- power steering d15b
- what type of lip is this?
- 2000ex with b16a Hard to start only after Re-Fuel
- loud Wine noise under passanger side dash with A/C on
- I have a P28 for my GSR....
- b18b
- cheapest place to get some koni yellows
- HELP me get this nut off!!!
- what do i need?
- b20b turbo??
- LOOKING FOR A DECENT EK PLEASE MESSAGE
- Floor Press specs?
- ANYONE HAVE A 96-98 POWER STEERING SYSTEM?
- Installing Ep3 seats into my del sol
- what is my compression?
- a question regarding to upshifitng at low rpm..
- O2 sensor question, switching headers
- buddyclub spec ll exhaust
- y8 to z6 edelbrock intake manifold sensor problem
- 92-95 civic hatchback headlight wiring
- si cluster help
- XSi Cable Tranny Problems
- Skunk stage 1 or Type R for daily driving?
- Which Wire Guage do i use?
- front end vibration?
- engine sawp
- which o2 sensor do i use??
- Tuning ECU w/ minimal bolt-ons
- Check out this front bumper beam
- 92-95 keyless entry
- New clutch!
- Check Strap; simple question.
- A/c question
- what shocks do i use?
- Anybody have this type of radio antenna?
- Stock ECU tuning limits?
- hey my speedo went out.
- JEG'S Fuel Pressure Gauge
- OEM front hood??
- 99'-00' Civic parts
- Help with '94 Civic Headlight Problem
- emanage y not use it?
- 3 questions
- Momo Tuner V. Momo Montecarlo
- HX wheels HELP!!
- Integra shifter in an EJ1
- depot fog lights.
- Anybody know where to buy wiring harness for power window/mirror/lock for door?
- clutch quest? HELP!!!!!!!
- exhaust suggestion
- My custom button start ignition video
- Oil ?
- Del Sol Front Bumper
- tranny
- Neuspeed Sport springs on stock struts.
- Pull CEL code while car is running.
- speedometer help
- honda nation is da real generation!!!
- 95 del sol compressor stays on?
- idle gets funny with a/c on? whats the matter with it?
- just did a compression and leakdown
- Put in new motor, turns over, but not fast enough.
- is there a rebuild kit for a proportioning valve?
- hx wheels, anybody, anyone!!
- turbo d-series
- I think somethings seriously wrong....a question for the wise
- 1992 civic si w/ rebuilt 97 jdm type r lsd tranny
- s2000 swap for a civic
- Need help determining if this will fit..
- WHat camber kit for my needs?
- What does Si stand for?
- Can't remove rear tires on '96 Civic DX
- Compression test on 95 Civic. NEED HELP!
- anyone selling eg or ek
- thinkin about buyin a 1997 CX with 220,000miles... crazy?
- 1993 Civic starting problems
- '00 d16y7 into '93 w/blown motor HELP
- can anyone id this del sol spoiler
- Z6 tranny rebuild cost *pic*
- * 2009 Civic Turbo Diesel
- Just swapped in 2000 GSR, car wont start
- b16 fpr?
- Ignition Control Module
- 5zigen catback
- how to install 02 si seats in 94
- 94 ex hard to start after its warm( already searches but my problem seems different)
- throwout bearing..
- CRX turbo kit..
- i searched but .... to no avail. How do you change the headlight bulb on a 2000 civic?
- LS VTEC: help please!
- Stay the F*CK away from harbor freight compession testers..
- Air condtion problem!!! help
- Ignition help
- HELP!!! Are these compression readings correct?
- d15z1 build up question????
- would this clutch be a good buy, anyone have experience w/ F1 racing.
- What does an A/c shop charge for vacuum and recharge?
